Official OPPO BDP-83SE Analog Audio Discussion Only Thread - Page 194 - AVS Forum | Home Theater Discussions And Reviews
post #5791 of 5811 Old 08-07-2013, 10:39 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1278 Post(s)
Liked: 1310
Originally Posted by beekermartin View Post
I took the cover off, removed the analog board, reinstalled it and made sure all the connections were good. Hooked it back up and now DSD over analog, both the stereo and multi channel layer, are working properly!?!? Everything appeared to be fine before I removed the board but I guess something must have been off a smidge. Now I need to find some time to give the SE some serious listening to!
Good for you! The most likely "repair" needed here was simply to correct a connection that got jarred loose in shipment. Depending on whether the previous owner used DSD or not, it might have been that way for a while.
If you spot any additional problems, try re-installing the current firmware first, as it may not have fully "taken" if some connection really was loose.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #5792 of 5811 Old 08-08-2013, 07:41 AM
beekermartin's Avatar
Quoted: 27 Post(s)
How would I go about re-installing the firmware? I assume I would have to download it to a usb stick or something. I tried to update the firmware via the network and it says the firmware is up to date.
beekermartin is offline
post #5793 of 5811 Old 08-08-2013, 08:02 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1716 Post(s)
Liked: 736
Correct. If you are already current you need to install from USB or a CD. OPPO's pages have instructions.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #5794 of 5811 Old 08-08-2013, 08:39 AM
Quoted: 27 Post(s)
Thanks for the help guys. I appreciate it.
As of now it appears to be working 100%. I decided to run the stereo outputs of all my sources through the 886 so it can handle the switching and volume using the zone 2 ouput to my headphone amp. I only had a few minutes to listen last night but it sounds great! I will try running directly from the SE to the headphone amp to compare just to see how much, if any, sound quality I am losing running through the 886. If the loss is minor I will keep it running through the 886. The ability to switch sources and control volume without having to change cables or turning the knob on the headphone amp are worth a minor loss of sound quality. If the loss is more than minor then I am going to have to rethink it.
post #5795 of 5811 Old 08-09-2013, 01:08 AM
Quoted: 27 Post(s)
I posted in the 886 thread as well but I still have no responses.
Anyway, with the volume set to variable it is bluntly obvious of the degrade in sound quality. I am actually shocked of the difference, After matching levels the best I could it was still plainly obvious of the difference in sound quality. With the sound set to variable in the 886 it almost sounded like there was a "veil" over the sound. With it set to fixed the sound quality opened up and sounded just incredible. The difference is night and day.
I have to assume the 886 is doing more than performing volume control when variable is selected. I posted in the 886 thread as well hoping someone will confirm my suspension. Regardless, for now I will allow the 886 to switch sources but I will control the volume using the tube amp.
post #5796 of 5811 Old 08-10-2013, 11:52 AM
Quoted: 27 Post(s)
I did get a great answer in the 886 thread. Someone posted a photo of the analog signal path from the 906 service manual. The 886 and 906 are almost identical but the 886 has no amps of course. The zone 2 output has a tone control box that the analog signal goes through before outputting. The Zone 3 output does not have any tone control. I am now using the zone 3 output. I haven't had time to a/b the sound quality using the volume control yet. For now I am leaving it as fixed and controlling the volume using the headphone amp.
Anyway, I updated the firmware using a usb stick. I then tested the regular stereo outputs as well as the multi-channel outputs set to downmix stereo with no sub. Both outputs are working perfectly with PCM as well as DSD. I think it is safe to say whatever the problem was is now corrected.
BTW, boy does this player sound good!!!
post #5797 of 5811 Old 08-10-2013, 03:21 PM
Quoted: 27 Post(s)
Quick question. I've been trying to read this entire thread. I am now up to page 66. I came across a post that stated the volume control does not work when you are outputting DSD. I just checked on my player and volume does work when outputting DSD. The on screen display says it is outputting DSD, my 886 preamp is receiving a DSD signal via HDMI, and I can still control the volume using the Oppo's volume control.
I assume Oppo added that ability in a firmware update. If that is true is there a listing anywhere of what firmware updates changed what? I looked on Oppo's site but I couldn't find anything.
post #5798 of 5811 Old 08-10-2013, 03:33 PM
JazzGuyy's Avatar
Quoted: 181 Post(s)
Liked: 149
There are summaries of all firmware releases plus a lot of other info in the first few posts on the BDP-83 thread. You can find it here: http://www.avsforum.com/t/1124287/official-oppo-bdp-83-owners-thread-technical-talk-only#post_15914837
Everything about the BDP-83 also applies to the 83SE as far as video, HDMI and other features. Only the analog audio features are unique to the SE.
JazzGuyy is offline
post #5799 of 5811 Old 08-10-2013, 05:49 PM
Quoted: 27 Post(s)
Thanks! That was exactly what I was looking for. Sure enough about half way through the firmware updates I found my answer. They did add volume control for DSD.
post #5800 of 5811 Old 08-11-2013, 08:42 PM
Quoted: 27 Post(s)
Btw
Everything about the BDP-83 also applies to the 83SE as far as video, HDMI and other featur ,es. Only the analog audio features are unique to the SE.
Btw, according to the firmware updates the 83 and 83se volume controls are not the same. I assume it is because of the different dacs. The regular 83 can't control the volume of the multichannel outputs while using dsd. The SE can. I tried it on my SE and I can control both the multichannel and stereo volume using the Oppo's volume control.
post #5801 of 5811 Old 12-26-2013, 03:54 PM
marc1006's Avatar
How does the DAC in the BDP-95 or 103 compare to the 83SE.  I own the 83SE and I play a lot of SACD material through the analog outs on my player.
marc1006 is offline
post #5802 of 5811 Old 12-26-2013, 04:03 PM
Quoted: 27 Post(s)
The 95 uses the dacs the 83se uses for the stereo outputs for the multi channel outputs as well as stereo. I've read many threads comparing the two and most said they sound similar. I haven't compared them so I can't comment on that.
post #5803 of 5811 Old 12-26-2013, 06:00 PM
marc1006's Avatar
Thank you. BTW, native Rhode Islander myself.
marc1006 is offline
post #5804 of 5811 Old 02-12-2014, 09:07 PM
William Moore's Avatar
Hello. New to this thread, but not a new Oppo owner. I have owned the BDP83SE for about 3 years and now I am moving it to my dedicated 2-channel system for CD and SACD playback, replacing an NAD M5. For CD playback, I will use the coax out going into a PS Audio NuWave DAC and for SACD playback I'll be using the player's dedicated 2-channel outs. I was just wishing to "pick your brains" a little as to how I might want to set up the player for optimum audio playback for both CD and SACD, and yes, I have read the manual on this, but I just wanted to hear your suggestions as to which menu options will work the best. Thanks!
William Moore is offline
post #5805 of 5811 Old 02-12-2014, 09:14 PM
Whoops! I almost forgot! Will the 83SE, thru the USB port play back any of the newer HiRez music files such as FLAC and some of the others. And then the manual says that a thumb drive containing such files must be formatted using the "FAT 32" file system. Is this common and compatible with Windows 7? I'm really in the dark when it comes to downloading or playing back files stored on a thumb drive. Can you "clue me in?" thanks again!
post #5806 of 5811 Old 02-13-2014, 03:59 AM
wmcclain's Avatar
Liked: 736
The -83 is limited in the types of files it will play from USB. It does not support FLAC or other hidef audio formats. Later players added more.
For more info, see the FAQ sections:
FAT is very common on USB sticks and is one of the original Windows filesystems.
-Bill
wmcclain is offline
post #5807 of 5811 Unread 12-03-2015, 12:20 PM
celticpride's Avatar
Is it true that the oppo bdp-83 does NOT PLAY dolby atmos or DTS:X soune codecs?
celticpride is offline
post #5808 of 5811 Unread 12-03-2015, 01:45 PM
Bill Mac's Avatar
Quoted: 983 Post(s)
Liked: 996
The 83SE and 95 use SABRE32 Reference DACs but different versions. The 83SE uses the ES9016 and the 95 uses the ES9018 DACs. Not sure what the differences are but I owned both players and the they sound excellent .
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk 1801-TLs, Salk 1801b center, ADS 300C (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #5809 of 5811 Unread 12-03-2015, 02:44 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 763 Post(s)
Liked: 579
Not exactly. The problem that BDP-83 has is with bitstreaming Dolby True HD 7.1 tracks that also use complex seamless branching. If those tracks are converted to LPCM in the player, they play fine (obviously Atmos tracks need to be bitstreamed in order to make use of the Atmos info). So if you have a movie with an Atmos track that also uses complex seamless branching, you might run into problems, but otherwise it should play just fine.
There aren't any issues I know of with DTS HD Master Audio tracks, so I suspect DTS:X won't be a problem. Of course there aren't any AVR's or pre-pros that actually have DTS:X support yet (unless Datasat has it?) and only (I think) 1 Bluray so far, so it's not exactly a high demand feature yet.
gsr is offline
post #5810 of 5811 Unread 12-03-2015, 02:59 PM
Quoted: 27 Post(s)
Bill
Sorry about that. You are correct Bill. The 83SE uses the Sabre 9016 dac for the stereo ouputs and the 9006 for the multi channel outputs. The 95 uses the Sabre 9018 dac for both the stereo and multi channel outputs.
I agree that they both sound great. I honestly couldn't tell a difference between the two using the stereo outputs feeding a headphone amp. They are both great sounding players. I've never used the multi channel outputs on either player so I can't comment on those.
post #5811 of 5811 Unread 12-03-2015, 03:19 PM
Bill Mac's Avatar
Quoted: 983 Post(s)
Liked: 996
Not a problem as you did not say they use the same "exact" DACs just that they both use the SABRE32 Reference DACs. It's all good !
Bill
Bill Mac is offline
Reply Blu-ray Players
taboola here
