Official OPPO BDP-80 Owner's Thread - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
Old 04-05-2016, 09:42 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Howdy guys,
I've opened the player and cleaned up both laser lens with alcohol/q-tips, as suggested and the BD is running fine now, but no way at all to play DVD's though... it shows the very same message all the time... no disc, which leads me to believe that it's a hardware issue, as Bill said before, but you know, I'll take Dave's advice now and will re-open the player, in order to make a second cleaning on the red laser lens though... who knows??
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is online now
Old 04-05-2016, 11:09 PM
JimProuty's Avatar
Lightbulb Pictures of the Oppo BDP-80's lasers
Getting access to the transport's lasers is trivially simple: just unscrew the lid, lift the tape off the drive and remove 2 screws from the drive. Lift the cover off the drive, and there are the lasers!
ID:	1361298   Click image for larger version
ID:	1361306   Click image for larger version
JimProuty is offline
Old 04-05-2016, 11:13 PM
JimProuty's Avatar
The reason *I* opened my BDP-80 is the same as yours: my blurays play fine, but often my DVDs from Netflix just stop playing back. Several movie nights have been thus ruined.
I'm considering selling my BDP-80 and using a cheapo Sony BDP-S570 (which plays SACDs and has component outputs at 1080i) I'll try to buy on eBay.
[Edit: I'd bought a Sony BDP-S580, and found to my disappointment that component output was restricted to 480i even for Blurays. Argh!]
Old 04-18-2016, 10:01 PM
JimProuty's Avatar
Question Repair or sell?
I've had my BDP-80 in for service once to Oppo for skipping of Bluray playback, and apparently cleaning the loader + lens(es) "fixed" the player.
Since then, the player has skipped at random places during both Bluray and DVD playback to the point where I can't trust the player to not ruin the movie experience. I've opened it up to see if the loader was dirty again; it wasn't as far as I could tell (pictures in a slightly earlier post).
I've thoroughly enjoyed the Oppo over the years I've owned it, but I need to either get this fixed or move on.
The difficulty with "moving on" is that my little theater uses mostly Component Video (because the DVI connection on my elderly RPTV has always been flaky), and any Bluray player newer than 2011 doesn't have full-resolution component output.
Q: Should I try to repair the Oppo myself by replacing the Bluray drive? Or just settle for the cheapo Sony BDP-S570 I bought off of eBay?
(Yes, someday I'll replace the RPTV with a fancy new OLED 70" display, but that day is not today.)
I'm interested in what you might suggest.
--Jim
Old 04-19-2016, 04:54 AM
rdgrimes's Avatar
Quoted: 1314 Post(s)
Liked: 632
If it needs repair, send it to Oppo.
Mike_WI likes this.
rdgrimes is online now
Old 04-27-2016, 06:30 AM
jkscherk's Avatar
Quoted: 43 Post(s)
--Jim
Sent you a PM. I have a BDP-80 to sell.
jkscherk is offline
Old 05-13-2016, 01:53 PM
audiodane's Avatar
Quoted: 91 Post(s)
Liked: 69
Originally Posted by Avliner View Post
Howdy guys,
Hey avliner, any updates on this?
My BDP-80 magically has started doing the same thing.. BD's play fine, DVD's don't even register ("no disc"). When I close the tray, the bluray laser blinks a few times, the DVD laser never seems to come on.. Opened it up and tried the q-tip cleaning, no luck. Oppo says I need to send it in...
Not sure if I want to spend $100 ($65 repair, plus shipping), or try to find another Oppo BDP-xxx for around the same price.. ???
cheers,
..dane
audiodane is online now
Old 05-13-2016, 03:01 PM
rdgrimes's Avatar
Liked: 632
cheers,
..dane
If you can find a working Oppo BDP for $100, buy 10 of them.
Old 05-16-2016, 09:19 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Hey Audiodane,
well, a re-opened the player and q-tipped once again the red laser with alcohol, to no avail and that means it's clearly a hardware issue though.
IOH, I still believe that's worth paying $100 for an ovehauling and basically get a new player back from Oppo
Regards, Chuck
Old 05-20-2016, 02:26 PM
audiodane's Avatar
Quoted: 91 Post(s)
Liked: 69
Hey Audiodane,
Yup, me too -- swabbing did no good.. I just mailed mine off for service today. Looking around ebay even the 80's are still going for twice the repair cost (at least)..
..dane
Old 07-14-2016, 09:41 AM
JimProuty's Avatar
Lightbulb Not an Oppo problem, ONKYO HDMI problem.
At Oppo's instructions, I disconnected the HDMI output from the BDP-80 from the Onkyo TX NR-905 receiver, and the playback pauses ceased. I now connect the BDP-80 to the receiver using the multi-channel audio outputs and playback is perfectly fine.
That receiver is known to have "issues" with the HDMI input board. I was surprised that the audio connection would affect video playback, but HDCP is a mysterious thing.
--Jim
Old Today, 01:45 PM
audiodane's Avatar
Quoted: 91 Post(s)
Liked: 69
Thought I would update, player was received quickly, repaired quickly, returned quickly, and has been working great ever since! ... laser was replaced, if I recall correctly from the paperwork.. I guess that just happens sometimes..
Oppo Bdp 80 Blu Ray Player
