Official Samsung BD-C6900 3-D Blu-Ray Player Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 1266 Old 08-10-2010, 09:10 AM
BigPlasmaFan's Avatar
Originally Posted by BigPlasmaFan View Post
Sorry for asking a dump question. Can anyone confirm the amount of the built-in memory? I can onle see 598MB. Thanks.
Can anyone give me a quick answer on this? Thanks.
BigPlasmaFan is offline
post #362 of 1266 Old 08-10-2010, 09:39 AM
BSoares's Avatar
It has 1GB but I bet not all of it are available for usage. I'm sure the Samsung Apps and stuff all use that same 1GB so you'll likely see a lot less. And 500 and some MB sounds right.
BSoares is offline
post #363 of 1266 Old 08-10-2010, 09:58 AM
Thanks for the clarification. That's what I thought too. I just want to make sure I am not "cheated" by Samsung. Just joking.
Yea, I also see Samsung apps takes up some 200MB too. I just hope that I am wrong since Samsung claims that it has 1GB internal memory for BD-Live download. I guess it is just another false advertisement from Samsung.
post #364 of 1266 Old 08-10-2010, 12:13 PM
Simba08's Avatar
Originally Posted by talbain View Post
nope, lossless audio issue is still there
Can you explain what the problem with lossless audio is please.
Simba08 is offline
post #365 of 1266 Old 08-10-2010, 12:23 PM
Vipper IV's Avatar
Ditto.
I've looked through this thread and haven't found anything that really describes what the supposed problem is.
Vipper IV is offline
post #366 of 1266 Old 08-10-2010, 12:28 PM
dkegel's Avatar
Originally Posted by Vipper IV View Post
Ditto.
Check out post #213
Dave
dkegel is offline
post #367 of 1266 Old 08-10-2010, 12:44 PM
4mula1's Avatar
Liked: 26
4mula1 is offline
post #368 of 1266 Old 08-10-2010, 02:08 PM
mchasal's Avatar
Apologies if this has been covered, but I couldn't find it through any searches.
Can someone clarify for me whether the Netflix app on this player has the search and browse categories features like the Roku does? I'm considering getting this for Netflix and Hulu Plus so I can ditch most of my cable service, but if the Netflix app only gives access to your queue, I'll have to consider that.
mchasal is offline
post #369 of 1266 Old 08-10-2010, 03:45 PM
thulsa-doom's Avatar
Originally Posted by sleeping martyr View Post
Not streaming over the net.. but works fine on external HDD as described above.
Anyone know why when trying to stream video files, that some files don't show up even if they are .avi? is it a codec issue? they aren't even listed sometimes.
I can stream mkv files wirelessly (N) from my PC to the C6900, but have intermittant stuttering issues with 1080p (720p and less works fine with no stutter). I think it's an issue with the wireless (maybe dropping to G when something else touches it), though in theory it should be fine (I have excellent connection as everything's in the same room). I've actually just purchased an external HD to connect via usb to hopefully alleviate this issue, but perhaps one of the recent firmware versions has improved it (I haven't tried since the first few attempts). Anyone have any suggestions? It's irritating because 11n should be plenty fast enough for 1080p streaming (assuming a good connection).
I'm sure you've probably thought of this, but when I noticed some files (AVI or not) not being listed, it was because I forgot to refresh the Share DB in Samsung's Share Manager program after adding files. Otherwise I'd guess it's a codec issue.
thulsa-doom is offline
post #370 of 1266 Old 08-11-2010, 04:51 AM
FGEvans's Avatar
This usb drive problem i am having is a real nuisance.
I have had no luck in connecting a USB powered drive to my player. It works for around 10 seconds then disconnects.
I even tried buying a y cable (ie a usb cable which can draw power from a seconds source) - however the drive can not be seen by the player when i use that lead.
USB flash memory sticks work brilliantly but this samsung s2 drive just wont work. -its very small and would expect it to be very low powered etc
FGEvans is offline
post #371 of 1266 Old 08-11-2010, 07:10 AM
Simba08's Avatar
Hi !
Try another USB Cable, i have 2 Samsung S2 portable drives and it works just fine, you do not need a powered disc.
Simba08 is offline
post #372 of 1266 Old 08-11-2010, 09:20 AM
Simba08's Avatar
I have a problem watching 3-D i have a rental Blu-ray "Coraline" that have a 3-D version on it but i cannot get the 3-D to work,
when i start up my Monsters vs Aliens 3-D movie i get info on my tv like this: Blu-ray - HDMI 1 - 3-D
but when i start the Coraline i do not get the 3-D
You have to choose in the start 2-D or 3-D i choose 3-D of course.
Simba08 is offline
post #373 of 1266 Old 08-11-2010, 09:35 AM
Simba08's Avatar
Originally Posted by dkegel View Post
Check out post #213
Dave
Hmm Explanation ,It says the parity bits in the audio stream are not set correctly as an explanation, but how does this problem shows ?
How do i know if i have this issue ?
Sorry but i am not a expert on this issues :-)
Simba08 is offline
post #374 of 1266 Old 08-12-2010, 09:24 AM
bfocussvt's Avatar
Originally Posted by meriquillo View Post
I'm not happy with the wireless performance since this blu ray player only uses N band on 2.4ghz. Can I use the samsung wireless adapter to make it work on 5ghz like when I use the adapter in the tv ?
You could do like I did and buy a D-Link DAP-1522 bridge. It runs on either the 2.4 or the 5ghz band and includes 4 gigabit ports.
It works great for me, I currently have one feeding my bedroom TV and BD player. Another one feeds my TV, PS3 and Onkyo receiver in the living room downstairs and I am purchasing another for the kids bedroom. They are all running in the 5ghz band and my signal doesn't go lower than 90% running at 243mbps, often times reaching a full 300mbps.
Hope this helps.
- Barry
bfocussvt is offline
post #375 of 1266 Old 08-12-2010, 10:08 AM
phreaky_d's Avatar
Hey, guys...this is most likely a retarded question, but I have my BD-C6900 hooked up through my receiver to my Samsung UN55C8000, and I know the Blu-ray player has that HDMI Deep Color support. Is there any way to verify whether the TV is in fact utilizing the Deep Color playback from the player? I know my player's Deep Color support is set to Auto (which I verified under the player setup menu), but I'm not sure whether what I'm seeing is in fact Deep Color...
Samsung KN55S9C OLED TV, Onkyo HT-S770 home theater system, and Samsung BD-F5900 3D Blu-ray player
LG 55EC9300 OLED TV and LG NB5541 Sound Bar
LG EL9500 OLED TV
Sony XEL-1 OLED TV (x2)
Samsung UN55C8000 3D LED TV and Samsung BD-C6900 3D Blu-ray player
phreaky_d is offline
post #376 of 1266 Old 08-12-2010, 10:52 AM
dkegel's Avatar
OK, I'll keep doing the searching for you. Check out posts 92 and #130.
"the sound doesn't work when set to bit-stream (audiophile) on the BD player."
Dave
dkegel is offline
post #377 of 1266 Old 08-12-2010, 11:57 AM
Simba08's Avatar
Dave
Ok thanks Dave i have a Onkyo SR-607 so i will test if have this issue
(Englis is not my 1st lanuage and sometime i do not know what words to search for)
//Bengt
Simba08 is offline
post #378 of 1266 Old 08-12-2010, 09:20 PM
phreaky_d's Avatar
Bump...
LG EL9500 OLED TV
post #379 of 1266 Old 08-12-2010, 09:36 PM
VisionOn's Avatar
Liked: 2375
Bump...
Why are you bumping a post that's only three posts earlier? If you haven't got an answer on the same page just repeating it on the same page isn't going to get you a response any faster.
Google Deep Color support and you'll get your answer.
VisionOn is online now
post #380 of 1266 Old 08-13-2010, 04:07 AM
FGEvans's Avatar
Hi !
have you used the samsung s2 drive then on this samsung blueray player.
its very odd as it works fine for around a few minutes then just disconnects itself - the drive works happilly on my pc etc but not on the blueray player.
i also dont think its a fault of the player as usb flash keys work ok on it
FGEvans is offline
post #381 of 1266 Old 08-13-2010, 07:31 AM
I have a silly question to ask. I am wondering why can't I pick BD-Wise and 1080p at the same time in the setting menu.
To my understand, BD-Wise will give optimal setting for Blu-ray movie play back. However, the player will not upconvert any SD DVD. So in order to view SD DVD in 1080p output, you need to switch to 1080p manually.
Am I missing something? Is there a work around that could have a "fix" set up that could use BD-Wise for Blu-ray and 1080p to upconvert SD DVD without any manual switching?
Thanks for your time.
post #382 of 1266 Old 08-13-2010, 07:43 AM
talbain's Avatar
//Bengt
if you bitstream lossless audio from the 6900 to some receivers, the audio does not play and at least on my pio elite reciever the DTSHDMA or TRUEHD lights flicker like crazy. the only way to fix the problem other than to turn off bitstreaming is to FF/REW a few times. the lossless audio will then play fine, but if you pause or rewind the movie at all the problem returns. it sucks
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #383 of 1266 Old 08-13-2010, 08:20 AM
dkegel's Avatar
I don't think there's a workaround. I also manually turn BD Wise off whenever I watch a standard DVD. The only thing I think you could do is to write down all the BD Wise picture settings and then manually plug them in, and then leave BD Wise off.
Dave
dkegel is offline
post #384 of 1266 Old 08-13-2010, 08:45 AM
Simba08's Avatar
I have 2 S2 discs and i had to format them with Samsungs own format software because i had some troubles when i connected them to my pc. Try re-format the disc with samsungs format software.
Simba08 is offline
post #385 of 1266 Old 08-13-2010, 09:42 AM
phreaky_d's Avatar
Hey man, I was just hoping to get an answer before the weekend, which will be the only time for a while that I'll have to play with settings for the TV and Blu-ray player. In any case, I did a Google search and didn't come up with any answers, so if anyone has any input, I'd appreciate it.
LG EL9500 OLED TV
post #386 of 1266 Old 08-13-2010, 04:14 PM
FGEvans's Avatar
hi can you confirm that the s2 drives work with the samsung blueray player - they work with my pc without any problems.
what software did you use to format the disk with
FGEvans is offline
post #387 of 1266 Old 08-13-2010, 04:58 PM
Simba08's Avatar
Yes the S2 drive works with 6900, look at Samsung support side for the format software.
Simba08 is offline
post #388 of 1266 Old 08-13-2010, 10:25 PM
bcab17's Avatar
Quoted: 40 Post(s)
Does anyone know if there are discrete "power on" and "power off" IR codes for this player?
bcab17 is offline
post #389 of 1266 Old 08-14-2010, 01:40 AM
SectorZero's Avatar
I don't think it does. On my Harmony remote, there is only PowerToggle for the BD-C6900. Most of my other devices also have PowerOn and PowerOff. Of course, it could just be that the Harmony database is incomplete.
SectorZero is offline
post #390 of 1266 Old 08-14-2010, 06:12 AM
Badboyztn's Avatar
Has anyone ever gotten the message "Cannot load this disc, please check disc"? I tried 3D Blu, Blu, and DVD. I have fw 1014.0 installed and have done the factory reset.
Anyone???
Badboyztn is offline
Reply Blu-ray Players
Blu Ray Players , Samsung , Samsung Bd C6500 1080p Blu Ray Disc Player , Samsung Bd C6900 3d Blu Ray Player Refurbished , Samsung Refurbished Blu Ray Disc Player Bd C5500 B
