Official Samsung BD-C6900 3-D Blu-Ray Player Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 1266 Old 10-11-2010, 01:26 AM
xxmastermushxx's Avatar
Originally Posted by VisionOn View Post
How so? You have a player without wifi and you want to know if the 6900 is better? In almost every area it is, and even if you can't get wifi to play with your router what have you lost by upgrading?
Nothing. You have a unit which performs better in every aspect of your current player.
You asked if the PQ and performance was just as good not if the unit had flawless wifi. If that's your main concern then stick with the 2500, otherwise where's your downside?
Like I've said before, a wireless device is only as good as all the components in use.
I take that back, what I said was stupid. You make a very good point and I really don't care if it has Wi-fi, I just think that a product should function as intended whether the feature is used or not. My concern as of now is my AVR, I wrote this in the Denon AVR-590 thread as well, maybe you can shed some light on it:
"OK, so from what I've read the AVR-590 won't pass HDMI 1.4 through.
I'm getting a new Samsung PN58C8000 and it's bundled with the Samsung BD- C6900 which has only one HDMI 1.4. Can I just connect the BD-C6900 via HDMI 1.4 for video straight to the TV and then connect an optical cable from the BD-C6900 to AVR-590 for the audio?
  • Will I still get lossless audio, such as DTS Master Audio and Dolby trueHD?
  • Will the AVR still act the same as it would with HDMI if the audio is going through optical?"
xxmastermushxx is offline
post #542 of 1266 Old 10-11-2010, 11:04 AM
4mula1's Avatar
Liked: 26
You will not get lossless HD audio while connected with optical.
4mula1 is offline
post #543 of 1266 Old 10-11-2010, 01:07 PM
mike-tee's Avatar
As 4mula1 said, you will not be able to get lossless with optical connected to your Denon 590.
But just a suggestion here, possibly the vendor that you're purchasing your Samsung bundle from will allow you to substitute the BD C7900 for the BD C6900 as an equal swap, or maybe adding a few bucks???
The 7900 is the successor to the 6900 and I believe it is equal in features but adds dual HDMI outs, which will allow you to connect to your Denon 590 for lossless. One other thing, the C6900 does have an HDMI audio issue with some of last year's Denon AVRs. Your Denon 590 may require a firmware update which can only be done at a factory authorized service center. Perhaps, the C7900 does not have this issue.
Just, a thought.......
Mike T
My BDP-05FD, still going strong and still my favorite player!
mike-tee is offline
post #544 of 1266 Old 10-11-2010, 02:09 PM
Soldier_Kris's Avatar
Well it's good that they are adding dual HDMI output..I am having an issue though with my 58c7000. When i connect directly between the tv and blu-ray i can of course get 1080/24 playback but when i loop through my HK AVR-3600 i can't. The BD wise option is greyed out unless i turn on HDMI bypass mode and then i can turn BD WISE on and it turns on 1080/24 playback automatically. If i turn BDWISE off though i can't enable 1080/24. And my AVR does have 1.4 functionality now through a recent FW upgrade,not that it would make a difference in this instance. Does anyone have any insight to this?
Soldier_Kris is offline
post #545 of 1266 Old 10-11-2010, 04:26 PM
I just want to make sure, could the BD-C6900 support HDMI 1.3 and just play DVD and BD. I don't care about the 3D part of it, I won't be using it. If not, it just seems like too much work. My current BD-P2500 is serving me fine as of now, I'm just worried that I'll be giving up picture quality because of this. Is there any significant differences in PQ that the eye can tell?
post #546 of 1266 Old 10-11-2010, 06:45 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Yes, it works perfectly fine with HDMI 1.3 cables, and regular DVD and Blu-ray disk playback is fine. You don't need a 3D TV or HDMI 1.4 to use it. I don't have HDMI 1.4, and I don't use the 3D feature. You just use Setup to set it to 2D and you're good to go. I mainly bought mine for the 7.1 analog outs.
PQ seems great to me, but I did find that I had to turn Sharpness up to 10 in the setup. The default at 0 was pretty soft.
Kilgore is offline
post #547 of 1266 Old 10-11-2010, 07:14 PM
chs4000's Avatar
I find the highest setting I can tolerate on the 6900 is '2'. '10' introduces all kinds of ringing artifacts, aliasing, etc. Just horrid. I'd recommend that most people set it to '0' or '1' and forget about it for the most part.
chs4000 is offline
post #548 of 1266 Old 10-11-2010, 08:04 PM
So would I still have to get a firmware update for my AVR-590?
post #549 of 1266 Old 10-11-2010, 08:29 PM
pelmen84's Avatar
Hi all,
First post here
Anyways i have a problem with bd-c6900 and hw-c770bs. Blurays are no problem no issues what so ever. But when i stream mkv's from my computer wireless or if i stream netflix movies my sound disappears for 3 seconds or so then comes back. This happens maybe up to 10 times during a regular movie (Bandwidth is not a problem at least from video point its not, the video and audio are synced together )
The screen goes blank on hw-c770bs during that time... Might be the AV receiver problem but i am not sure or some improper audio conversion on bd-6900...
Thanks in advance
Sorry if i posted this in the worng section
pelmen84 is offline
post #550 of 1266 Old 10-11-2010, 09:42 PM
mike-tee's Avatar
You may need the firmware update. If your 590 was built in 2009, it is highly likely you may need the update. The symptom is no HD audio with the C6900 connected to the AVR. Since you won't hear any HD audio if your AVR is affected, it will be obvious as to whether you need it or not when you connect them via HDMI. There may also be slight possibility that a current release of Samsung firmware for the C6900 could have remedied the problem.
If you haven't already done so, read the firmware info for your model from this link: http://www.avsforum.com/avs-vb/showt...6#post17512496 The info here will give you a better understanding of any possible issue but again, you won't really know until you hook up the equipment.
Mike T
mike-tee is offline
post #551 of 1266 Old 10-11-2010, 11:24 PM
Mike T
Yeah, I've read it. I'll be getting the BD-C6900 this Thursday, guess I'll find out then.
post #552 of 1266 Old 10-12-2010, 12:54 AM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
What your saying may be true for you and the majority of others, but not for me.
Checking against sharpness patterns on both the AVSHD and GetGray test disks, I get no ringing or artifacts with sharpness at 10, and at 0, my image is very soft indeed. I also know my Epson 6100's sharpness controls are set correctly because these test disks sharpness patterns look fine on two other blu-ray players with their sharpness settings at zero, including a Samsung BD-UP5000 combo player with sharpness turned off.
Perhaps it is an issue with my 6900. Either way, setting its sharpness to 10 works perfectly for me...no EE, no halos, no artifacting at all.
Kilgore is offline
post #553 of 1266 Old 10-15-2010, 07:56 AM
IslandHT's Avatar
Is there a way to have the unit show the current bitrate being output by the player? I'm using the 6 channel analog audio out to a HK AVR745 (non HDMI 1.4a) receiver and need to use this way to get the lossless audio. I'd like to double check the bitrate to see if that is actually happening!
Thanks.....
IslandHT is offline
post #554 of 1266 Old 10-15-2010, 02:03 PM
theperkman's Avatar
Just took delivery of my new C6900 bluray and U55C8000 LED. Man have I been praying for my Toshiba RP 50H81 to die! The red crt finally went permanently out of alignment and it didn't take long to order some new goodies. Paired with my HK 2600 (new 1.4a firmware) and Miller & Kreisel 5.1 speakers I should be pooping in tall cotton.
This forum is invaluable and I look forward to getting the help I'll inevitably need here this weekend!
theperkman is offline
post #555 of 1266 Old 10-16-2010, 07:10 AM
theperkman's Avatar
I hooked my new BD-C6900 up last night. Wifey wanted to watch Hot Tub Time Machine so installed it in our bedroom on our LG 37LH40 LCD instead of the new UN55C8000 Samsung. Upgraded the firmware on the BD and fired up the disc.
To my horror, the screen would flash white with an audible crackle from the speakers every few seconds and the playback would seem to skip at that moment too. Tried another disc, Kick Ass, and it did the same thing. Swapped HDMI cables, same thing. Moved it out to the new Samsung 8000 to test and it didn't do it there which was a relief. Finally went through all the options in the menu and once I turned off the 'Deep Color' option, the disc worked fine on the LG using a 6' Monoprice 24g HDMI (high speed).
After disabling the Deep Color, this player is absolutely flawless. The picture is fantastic even on the cheap LG 37LH40.
post #556 of 1266 Old 10-16-2010, 01:48 PM
sigmaace01's Avatar
I asked in the 7900 topic, but figured I'd ask here since the 6900 is the 7900 with 1 HDMI. How well does Samsung's BR handle streaming mkv, avi, etc, from the home PC? I currently have the LG BD-570 & it streams like a champ. I often stream 720p & 1080p mkv files from the net and really need it to be able to do so, too.
sigmaace01 is offline
post #557 of 1266 Old 10-18-2010, 02:33 AM
Gooseboy's Avatar
My player just deleted the YouTube app after a recent Internet@TV update and it doesn't look like it's available anymore for download in the Samsung Apps channel. Has this happened to anyone else? WTF
Gooseboy is offline
post #558 of 1266 Old 10-18-2010, 08:22 AM
theperkman's Avatar
After further troubleshooting this weekend, I found the culprit to be the Monoprice cables. They simply will not pass through Deep Color without flashing and crackling. I temporarily used a 1 meter Pure AV that's 2 years old and it works fine. Anyone else seen these problems with Monoprice before?
post #559 of 1266 Old 10-20-2010, 05:06 PM
bluestockings's Avatar
I'm buying my first blu-ray player. Does anyone know if the Samsung BD-c6900 will resume playback at the same position after shut-off for DVDs? I'm not concerned about BDs. Thanks.
bluestockings is offline
post #560 of 1266 Old 10-21-2010, 09:09 AM
4mula1's Avatar
Liked: 26
That is not determined by the player, it is determined by the disc. And I believe all DVD's will resume play.
4mula1 is offline
post #561 of 1266 Old 10-21-2010, 10:43 AM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
I currently have the C6900 and Onkyo SR608 hooked up to my 63C8000. Will I notice a difference in picture quality by going with a C7900 or higher model? Dual hdmi imput will allow for me to run straight to tv and receiver. So better picture quality for bds and dvds or is digital digital and won't make a difference?
Also, I'm just getting around to using the 3d feature with my monsters vs aliens starter pack. I put the tv in 3d mode and hit the little button on the glasses but nothing. I can see the doubling of images on screen but the glasses aren't working. I threw out the manual a while back because I figure I didn't need it. I regret doing that now because I can't get it to work. So what am I missing here?
PathofNeo is offline
post #562 of 1266 Old 10-21-2010, 09:26 PM
Jackdaw's Avatar
PathofNeo,
Does a red light on the top right of the glasses blink when you turn them on? (Is the battery installed correctly?)
Is the bottom edge of the TV blocked by anything? (the IR transceiver)
Jackdaw is offline
post #563 of 1266 Old 10-22-2010, 12:25 AM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
Uhh.. that did it. I feel like an idiot for not checking the battery. I assumed the 2 that came with it were extras. I assumed wrong lol. Thank Jackdaw!
post #564 of 1266 Old 10-22-2010, 12:30 AM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
Now how about the other question? I have an Onkyo 608 with the C6900 feeding my 63C8000. I probably won't get it because I still have other things going through the receiver (PS3, 360, DVD, etc) but just thought I'd ask.
Will the picture be any sharper by having the hdmi go straight to the tv or not?
Thanks bud.
post #565 of 1266 Old 10-22-2010, 08:16 AM
thegoldenhand's Avatar
hello... a friend has this bluray player... when playing Ironman 2 BR, he keeps having playback issues. the playback would stop randomly throughout the movie. we already upgraded the firmware but keeps having problems. is there a known issue with this player with ironman 2 bluray discs? tia
thegoldenhand is offline
post #566 of 1266 Old 10-22-2010, 08:24 AM
4mula1's Avatar
Liked: 26
Thanks bud.
No, not any sharper. Going through a receiver is just a straight pass through.
4mula1 is offline
post #567 of 1266 Old 10-22-2010, 09:07 AM
meriquillo's Avatar
I watched iron man 2 in my 6900 las night and had no playback issues. Sorry but i think something is wrong with yours. The only time that i had playback issues was with a disc with some fingerprints on it. I notice that blu Ray discs are more difficult to read with fingerprints than DVDs Don't know why.
meriquillo is offline
post #568 of 1266 Old 10-22-2010, 09:25 AM
JPPhil's Avatar
Sorry if this is the wrong thread. I was hoping to buy the 6900 mainly so I could stream Netflix and Hulu Plus. Having a decent blu ray player is just a bonus, as I don't watch dvd's all that much. Will this machine fill the bill?
JPPhil is offline
post #569 of 1266 Old 10-23-2010, 04:33 AM
den110's Avatar
Only if you use a hardwire cat-5 connection. the wireless card in this player is worthless....
"It's time to nut up or shut up."
den110 is offline
post #570 of 1266 Old 10-23-2010, 04:33 AM
lattimershotgun's Avatar
here is a questoin... I have this player hooked up to a portable hard drive and stream bluray rips off of it. MKV's and Mp4s. Mkvs support ac3 up to 640 and mp4s do aac up to 320. These movies are ripped in either or and are done in 5.1 audio encoding. My questoin is, is when I play a bluray movie that is 5.1 the player upscales it to 7.1 and kicks it out the analog out to my 7.1 reciever. Problem is when I watch a movie using dlna it wont upscale it to 7.1, it only plays it at its default encoded 5.1. Now is that a known issue of dlna and this model or if I were to use a different audio format like dts or something would it scale that? Sorry I know it's a long winded post but wanted to make everything clear and laid out for ya.
lattimershotgun is offline
Reply Blu-ray Players
Blu Ray Players , Samsung , Samsung Bd C6500 1080p Blu Ray Disc Player , Samsung Bd C6900 3d Blu Ray Player Refurbished , Samsung Refurbished Blu Ray Disc Player Bd C5500 B
