Samsung BD-C6500 Bluray Player------ - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 1625 Old 04-09-2010, 06:17 PM
WulfmanX's Avatar
Howdy All,
Lot of good info here.
My C6500 (connection to a PN50B560) and wirelessly to my PC.
The C6500 NIC seems to drop out, but only when I stream .mkv files?
Anyone else had this issue? If so, what did you do to fix it?
Wulfman
WulfmanX is offline
post #302 of 1625 Old 04-10-2010, 10:58 AM
Madman Jay's Avatar
Hi,
I just bought a Samsung BD-C6500 yesturday and I am finding that the audio from the 5.1 Analog output is very week compared to the optical connection.
I have an older Sony 333ES receiver that does not have HDMI inputs, so I would like to utuilize the 5.1 Analog inputs in order to get the better uncompresses audio from Bluray disks. However, I find that the audio quality does not appear to sound as good when I used the analog outputs from this player. I have to turn the volume WAY up compared to the optical cable, and I find that the overall audio seems "confined" and "lacks bass" with the analog inputs. When I flip it back to the Optical output and let me receiver do the decoding, the sound field opens right up.
I have the player set to pass PCM audio as recommended in the manual.
Just as a test I hooked up my original 10 year old Sony DVD player using its 5.1 analog outputs and it seems to sound fine so I know it is not my cables or anything.
In addition... when I first got the player all audio sounded bad and actually distorted. However, I did a manual update to the firmware to the latest version and that seemed to fix that part. For whatever reason the Automatic update over the Internet was not seeing that there was a newer firmware. I was just about the rip the player out and take it back to the store (after spending well over an hour hooking it up in my enclosed cabinet... a bit of swearing was occuring last night let me tell you).
Any suggestions? Is anyone having this problem?
Lucky for me I purchased the player for a price cheaper than the BD-5500 model due to a print mistake in the Bestbuy flier this week (they reversed the prices) so if I had to use the optical and have the player convert it to DTS audio it wouldn't be the end of the world. This method sounds WAY better than the analog for some reason.
1. My theory is that the decoders in the Samsung player suck and don't decode as well as my receiver (it was a $1400 receiver 10 years ago).
2. I got a defective unit.
Comments?
Madman Jay is offline
post #303 of 1625 Old 04-10-2010, 12:51 PM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
This player has worked great for me. But there is one minor thing that kind of bugs me. When you put a disc in, you can usually hit a button and go straight to the menu bypassing all of the previews. (my other BD players do this) But you can't do that with the 6500. It gives you a "feature unavailable" message. You can't even skip forward to the next preview. The only thing you can do is fast forward through each individual trailer. Not a dealbreaker, but annoying nonetheless.
Scoob is offline
post #304 of 1625 Old 04-10-2010, 01:29 PM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
Originally Posted by Madman Jay View Post
Hi,
Comments?
Man Jay I wish I could help you. I do know that all the players I have hooked up to analog outs the common thread has been that you have to turn up the volume a bit especially when listening to Dolby TrueHD. But after you get the volume level up its sounds great, not confined or lacking bass at all. I wish I knew what to tell you. I have a hard time believing that the decoders in the Samsung player suck, that just doesn't seem likely as they have released several players with analog outs that sound stellar. I wonder if you do have a faulty unit............
Scoob is offline
post #305 of 1625 Old 04-10-2010, 04:04 PM
GizmoDVD's Avatar
How does this handle MKVs? Can it access an external harddrive plugged in via the USB input?
GizmoDVD is offline
post #306 of 1625 Old 04-10-2010, 08:49 PM
Samsunging's Avatar
Does this player have the Reon chip for upconverting sd dvd's. I just watched a video of the 6900 taken apart and it appears to have one, I was wondering if this 6500 also has it.
Samsunging is offline
post #307 of 1625 Old 04-10-2010, 08:58 PM
GizmoDVD's Avatar
The 6900 has a Reon? You sure about that? I thought those were long gone.
GizmoDVD is offline
post #308 of 1625 Old 04-10-2010, 09:14 PM
Samsunging's Avatar
Maybe i'm wrong but what is that processor with the big 'R' on it, I assumed that was a Reon processor.
http://www.youtube.com/watch?v=oWxjz...layer_embedded
post #309 of 1625 Old 04-10-2010, 09:34 PM
Samsunging's Avatar
I got a question, I have my router in the same cabinet as my components hence do not need wifi, so what is the advantage to me buying the c6500 over the 5500.
All I can seem to see is hard drive capacity (1gb).
So are they identical besides wifi ready/ wifi installed and hard drive capacity/ no installed storage?
post #310 of 1625 Old 04-10-2010, 10:02 PM
druber's Avatar
The manual for the 6500 says to use the analog outputs that are all in a group on the right-hand side of the back of the unit. It suggests that you don't use the standard LR outputs located on the left-hand side. I had this suggested setup direct-connected to a surround sound amp, and it sounded like my main two channels were connected to surround sound outputs--low volume, very little dialogue, etc. I connect the LR to the main LR outputs on the 6500 and got full volume sound like you'd expect. Check your setup. If you've followed the manual's advice, you may be only half-way there.
druber is offline
post #311 of 1625 Old 04-11-2010, 06:26 AM
Madman Jay's Avatar
Thanks for the reply. I tried your suggestion and I don't hear any differences.
However, my wife and kids step out for awhile and I had a a chance to listen to the audio at "reference levels". :-) I put in a few different bluray, some DVD's and audio CD's. And now that I have listened to it for a bit I think it sounds pretty good now. I do have to turn it up more than I used to, but the sound quality seems warmer to me using the analog versus letting my receiver decode the signal. I think I just had to get used to the volume level differences, and I fell into the trap that louder sounded better, but in reality, I think it sounds better now using the analog.
So, I guess its a keeper now.
Thanks for you suggestion though.
post #312 of 1625 Old 04-11-2010, 08:17 AM
imaginereality's Avatar
I have an external WD My Book (formatted with NTFS) hooked to the player and it works great. MKVs play fine, but if you have a MKV with multiple audio tracks, the playback is jerky to the point where it's unwatchable. Hoping Samsung fixes this soon with a firmware update.
imaginereality is offline
post #313 of 1625 Old 04-11-2010, 09:18 AM
GizmoDVD's Avatar
So the 6500 can power the External HD through the USB port? No AC adapter needed (my BD390 can do this, but not my Insignia)
GizmoDVD is offline
post #314 of 1625 Old 04-11-2010, 09:41 AM
rdn
rdn's Avatar
I think that the 1 GB is flash, not a hard drive. With the C5500 you need to add some memory for BD-Live. I suspect that a 1 GB USB thumb drive would give the same functionality and the rear USB port (intended for a wifi adapter) can be used for this. The C6500 has 7.1 analog audio, which the 5500 does not. I didn't need wifi either, so decided to save some money and get the C5500.
There is some additional installed memory for apps on both models.
Bob
rdn is offline
post #315 of 1625 Old 04-11-2010, 04:58 PM
It can if the hard drive doesn't already require the use of an AC adapter (Western Digital My Books require AC power).
post #316 of 1625 Old 04-12-2010, 08:24 AM
GizmoDVD's Avatar
Ok good. I know my Insignia can't so I wanted to make sure (interested in the HTIB version)
GizmoDVD is offline
post #317 of 1625 Old 04-12-2010, 10:49 AM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
Has anyone streamed a Vudu movie through this player yet? I have seen a mention or two of the Vudu app in this thread, but no one has actually commented on the experience and if it worked adaquetely. Anyone care to chime in?
Scoob is offline
post #318 of 1625 Old 04-12-2010, 07:33 PM
rdn
rdn's Avatar
I signed up with Vudu and they gave me a $5.99 credit (nice!) My internet speed isn't too great (Clear 4G Wi-max, typically 3-4 Mbps) so I used the credit to view a SD movie. The picture quality was pretty good, but I did get a few dropouts. Otherwise it was fine.
Bob
rdn is offline
post #319 of 1625 Old 04-12-2010, 10:20 PM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
Thanks for the reply. How much did the SD movie cost?
Scoob is offline
post #320 of 1625 Old 04-13-2010, 07:51 AM
Stanton's Avatar
Quoted: 1550 Post(s)
Liked: 798
Definitely not. First of all, that "R" is hand-written with some sort of pen. A Reon chip would have had "Silicon Optix" stamped on it somewhere. Unfortunately, both the company and their HQV chips are long gone (as I hang on to my BD-P2500).
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #321 of 1625 Old 04-13-2010, 08:05 AM
rdn
rdn's Avatar
$2.99 (Sherlock Holmes). The prices vary a bit. Once you start watching, you have 24 hours to complete it.
Bob
rdn is offline
post #322 of 1625 Old 04-13-2010, 08:52 AM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
FWIW, I have been able to play my HD videos that I made with my Canon HD camcorder that were burned to disks. No issues at all. Not a surprise by any means, but good to know it works correctly.
Scoob is offline
post #323 of 1625 Old 04-13-2010, 07:46 PM
druber's Avatar
The FCC iPhone app pegs my actual download speed at around 6 megabits. The C6500 reports about 1.5. We tried streaming a movie from Vudu in HDX and got pauses for rebuffering (or an outright stop with a "try again later" message) about every 10 minutes. I switched quality down to their HD stream and watched the rest of the movie without incident. On my 720p set, I really couldn't tell a difference between HD and HDX. It was a drama with very little action, no high speed chases or anything, but I thought the quality was great. I'll definitely use Vudu again.
druber is offline
post #324 of 1625 Old 04-14-2010, 06:26 AM
ziimen's Avatar
Seems like Samsung has posted another firmware update 1010.4. Gonna try it tonight.
http://www.samsung.com/us/consumer/t...il&tab=support
ziimen is offline
post #325 of 1625 Old 04-14-2010, 08:22 AM
I can confirm that the 1010.4 update fixes the jerky MKV playback on files that have more than one audio track.
It still cannot play certain MKVs however (thankfully, it's less than a handful that I've personally found so far).
post #326 of 1625 Old 04-16-2010, 07:45 AM
Scoob's Avatar
Quoted: 30 Post(s)
Liked: 25
Anyone else updated to the new firmware? I haven't had time, but am going to this weekend.
Scoob is offline
post #327 of 1625 Old 04-16-2010, 08:23 AM
rdn
rdn's Avatar
I updated the firmware this morning. I haven't noticed anything different yet.
Bob
rdn is offline
post #328 of 1625 Old 04-16-2010, 10:17 AM
ziimen's Avatar
What I noticed was:
- Getty Images gallery was added to internet section
- It plays an mpg file created out of vob-s that it couldn't before but still choppy
It still doesn't do dvd foders / video-ts file. I still need to test the mkv created out of vob-s, but am not holding me breath. Mkv contained subtitles are still a no go.
One thing that bothers me also is inability to set the default device... you can select the device by A and D buttons. Well that screws up using my receiver remote. Cannot do it via menu nor can you set a default one.
ziimen is offline
post #329 of 1625 Old 04-16-2010, 08:44 PM
HankTheTurtle's Avatar
Having an issue with the PC share function. Does anyone know if there's a way to add a file to your shared files without having to refresh everything you share? When I refresh through the share manager, it takes just as long as the first time I scanned the files to share. it's really annoying. If I download something new, I have to wait hours before I can even access it.
HankTheTurtle is offline
post #330 of 1625 Old 04-17-2010, 06:12 AM
BritInVA's Avatar
Currently PCSM can't - Serviio does.
See link in my sig where there is further discussion
BritInVA is offline
Reply Blu-ray Players
Samsung Bd C6500 1080p Blu Ray Disc Player
