Samsung BD-C6500 Bluray Player------ - Page 52 - AVS Forum | Home Theater Discussions And Reviews
post #1531 of 1625 Old 12-28-2011, 07:19 PM
amesdp's Avatar
Originally Posted by Fred27 View Post
Anyone using PlayON with this device?
It works erratically. The Samsung DLNA client usually times out and says "Incompatible format" while the PlayOn server is still starting the video stream with most streaming TV sources. You can sometimes get it started with a retry if your timing is exactly right, but it's a pain. I gave up on it. PlayOn is aware of the problem, but says that it's Samsung's problem and they can't fix it.
amesdp is offline
post #1532 of 1625 Old 12-28-2011, 09:46 PM
mrvideo's Avatar
Quoted: 587 Post(s)
Liked: 328
Originally Posted by Kuc View Post
I can't agree with you. The speaker system is connected through subwoofer via 6 RCA cables to the analog outputs of the player (2 fronts, 2 rear, center, woofer).
So, why didn't you say that in the first place? By default, when one says they are using the analog output, they are talking about the stereo analog output. You needed to say that you were using the discrete 6-channel analog output connectors (which are not common).
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is online now
post #1533 of 1625 Old 12-29-2011, 02:14 AM
Kuc
Kuc's Avatar
I'm sorry, that's my bad. I did not mention this, because I thought the 7.1 analog output is sort of a distinctive feature to this particular player.
Kuc is offline
post #1534 of 1625 Old 12-29-2011, 04:05 AM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
The OP said he had 5.1 speakers connected via analog output and you assumed he knew YOUR default was to assume that meant a 2-channel analog connection?? I thought he was quite clear. Where is it stated what "one means" by "analog output"?
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #1535 of 1625 Old 12-29-2011, 04:42 AM
Ghpr13's Avatar
Originally Posted by bguzman View Post
Have you tried pressing menu first then play as I suggested before?
Originally Posted by Ghpr13 View Post
bguzman,
I will try that next time it happens. I don't know why, but for some reason I didn't catch that in your previous post (senior moment???). Thank you for stating it again.
Ghpr13
Bguzman,
Followed your advice and that seem to end the problem. Thank you.
Ghpr13
Info=Knowledge=Understanding=Better TV!
I see dead pixels!
Ghpr13 is offline
post #1536 of 1625 Old 12-29-2011, 11:46 AM
mrvideo's Avatar
Quoted: 587 Post(s)
Liked: 328
Just because one says that a system with 5.1 is connected to a player doesn't mean that the discreet 6 channels of analog connectors was used. The most common analog output is the 2 channel stereo out. So, it should be stated that the discreet outputs were used, to avoid confusion. If it would have been perfectly clear I wouldn't have posted about it.
We aren't mind readers and can't look at a user's equipment. Full disclosure is appreciated
Mr. Video
My Geek Images
post #1537 of 1625 Old 12-29-2011, 04:19 PM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
I can see that maybe the OP wasn't perfectly clear, but your assumption that he must magically know that "analog output" means 2-channel was more than a little snippy. In the interest of civility, why not just ask the guy which analog outputs he meant?
post #1538 of 1625 Old 12-29-2011, 07:15 PM
BEACHIN' CHRIS's Avatar
My 18 month old unit's a pain of late. Started a month agao but i'll just note the latest problem.
Seventeen minutes into Blu-Ray Hangover II, there are clicks, picture flashes on and off and then some colors (pink or lime green) appear and nothing. Ditto with DVD too.
Latest FW 1024.0 installed in November. Did the reboot with no new FM changes and same old results. HDMI into receiver then to my Samsung 8000 series TV.
All comments are welcomed. Thanks.
BEACHIN' CHRIS is offline
post #1539 of 1625 Old 12-29-2011, 07:45 PM
mrvideo's Avatar
Quoted: 587 Post(s)
Liked: 328
Wasn't meant to be snippy.
Frankly I forgot about the discrete set of outputs, as I use HDMI for the video and optical for the audio. Another reason to mention which set was used, for those like me that can sometime be forgetful
We are all good now.
Mr. Video
My Geek Images
post #1540 of 1625 Old 12-30-2011, 04:32 AM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
This sounds like an HDMI handshake issue. Do you have HDMI-CEC (or HDMI Control) turned on in the player or the TV? If so, turn it off everywhere and see if that stops the problem. If it doesn't, connect the player directly to your TV and see if the problem occurs.
post #1541 of 1625 Old 12-30-2011, 08:27 PM
Thank you pbarach; I'll try your recommendations this weekend.
post #1542 of 1625 Old 12-31-2011, 10:20 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
oopps wrong thread
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #1543 of 1625 Old 01-01-2012, 10:59 AM
Damonb10's Avatar
The player flagged me last night that a new update is available. I think it was to go from .1023 to .1024. Has anybody installed this yet?
Damonb10 is offline
post #1544 of 1625 Old 01-01-2012, 11:52 AM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
1024 has been around for a while. I haven't noticed anything negative since installing it.
post #1545 of 1625 Old 01-09-2012, 01:12 PM
andrewdale's Avatar
This may have been asked previously, but there's a lot of posts in this thread and Google is proving to be somewhat useless to find information for the issue.
I've had my BD-C6500 for a couple years now and it has worked great in the past.
However, it will no longer play ANY blu-ray discs. DVD's work properly and look great, but when you insert a BD into the player, it will stick at the "Loading..." screen for 5-10 minutes before a message comes up that says the disc cannot be played.
I've tried rebooting, unplugging for 5 minutes, even cleaning the laser lens with a soft Q-tip. I haven't tried a can of air yet, but that's next on the list.
Any ideas?
andrewdale is offline
post #1546 of 1625 Old 01-09-2012, 01:18 PM
andersa's Avatar
Quoted: 31 Post(s)
Liked: 31
Any ideas?
I have the same problem with ours... and haven't found a solution.
andersa is offline
post #1547 of 1625 Old 01-09-2012, 01:31 PM
mrvideo's Avatar
Quoted: 587 Post(s)
Liked: 328
My money is on the blue laser failed. Needs to be sent in and repaired.
Mr. Video
My Geek Images
post #1548 of 1625 Old 01-09-2012, 02:29 PM
andersa's Avatar
Quoted: 31 Post(s)
Liked: 31
sigh, makes sense I guess. I doubt ours have played more than 10 or so BDs since we got it almost two years ago as we tend to watch movies in other rooms equipped with Oppo and PS3 respectively.
/Anders
andersa is offline
post #1549 of 1625 Old 01-09-2012, 02:54 PM
andrewdale's Avatar
Yeah... I'm gonna see if I can repair or replace. The way I see it, it's broke anyway, so I might as well see what I can do. I'll post any results I can find.
post #1550 of 1625 Old 01-11-2012, 09:19 AM
amesdp's Avatar
The first unit I got had the same problem - it played the first few Blu-Ray discs I tried, then on the second day I had it the blue laser failed and it could only play DVDs. The second one has been ok, but it's clearly a weak point of this model.
amesdp is offline
post #1551 of 1625 Old 01-17-2012, 08:17 PM
rmf
rmf's Avatar
Upgraded to 1025.1 tonight and then lost connection with streaming from Netflix ~1/2 hour into movie and couldn't reconnect. Maybe a coincidence, but anyone else have a problem with streaming after upgrade?
Also, getting brief black screen shortly after the beginning of streaming, brief HDMI connection lost message, then all is well. Checked both connections for the cable and they appear OK.
rmf is offline
post #1552 of 1625 Old 01-17-2012, 08:36 PM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
I just did the 1025.1 upgrade. All was well afterwards.
post #1553 of 1625 Old 01-17-2012, 08:37 PM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
I upgraded, all is still well.
post #1554 of 1625 Old 02-05-2012, 08:18 AM
link2metroid's Avatar
I have the latest firmware 1025.1. I've tried entering the region hack. It's not working. Can somebody please tell me what to do exactly and whether it works with the latest firmware? Thanks.
link2metroid is offline
post #1555 of 1625 Old 02-14-2012, 09:45 PM
asg49's Avatar
I've tried to install the newest FW for my 3 1/2-yrs-old BD-P1500 by inserting a USB drive with an unzipped 111125_01_BDP1500_XAA.RUF file, but the player does not react at all. Tried to turn it on and off, open the door etc, but nothing works. Is there a special initialization procedure to start the install? The drive is fine, there's nothing else on it but the RUF file.
If I succeed, will the 1500 stream Netflix movies? Could not find this info...
asg49 is offline
post #1556 of 1625 Old 02-15-2012, 03:01 PM
vmaxed's Avatar
Can the Samsung 6500 get Vodo App ?
Thanks..Ed
vmaxed is offline
post #1557 of 1625 Old 02-15-2012, 03:31 PM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
Thanks..Ed
The C6500 does get Vudu (I think that's what you have in mind)
post #1558 of 1625 Old 02-15-2012, 05:31 PM
vmaxed's Avatar
Yea.... Vudu BB has it on sale for 119.
Thanks... Ed
vmaxed is offline
post #1559 of 1625 Old 02-15-2012, 08:37 PM
pbarach's Avatar
Quoted: 320 Post(s)
Liked: 193
Thanks... Ed
What it does not have and probably won't get is 1080p and 5.1 audio from Netflix. It's an excellent video player ( and it plays DVD-A discs, too), though.
post #1560 of 1625 Old 02-16-2012, 06:23 AM
I'm looking to Region 1 DVDs on a Region 2 player. The hack involving pressing REPEAT and entering 57538 +9 isn't working. I hear it's difficult to get it to work. Has the latest firmware blocked this code? Will someone please give me some advice?
Reply Blu-ray Players
Samsung Bd C6500 1080p Blu Ray Disc Player
