Samsung BD-C6500 Bluray Player------ - Page 55 - AVS Forum | Home Theater Discussions And Reviews
post #1621 of 1625 Old 10-01-2013, 05:24 PM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
Yep, I figured that the laser went. It shouldn't have though. It isn't that old and doesn't have that many hours on it.
Component out I do not use. The lack of Cinavia is a plus though.
That said, I am looking at a Panasonic player that supposedly has NAS support, something that is better than DLNA. I'm trying to get that verified.
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is offline
post #1622 of 1625 Old 01-26-2014, 04:39 PM
pbarach's Avatar
Quoted: 318 Post(s)
Liked: 193
I just listed my Samsung BD-C6500 on eBay (same username as I have on AVS).
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #1623 of 1625 Old 05-06-2014, 10:57 AM
truthy's Avatar
I just tried to play my 1st bluray 25gb data disc in the BD-C6500 but it won't play any files - I get the 'not supported file format' error. I know that the BD-C6500 can play these files as they work flawlessly when played via my usb-stick so I must have messed up some burn/filesystem settings.
I used ImgBurn Mode1, ISO9660+Joliet+UDF Revision 1.02 and set allow files exceeding the ISO size limit (4 gb) for multiple extends as there are several large files above 4gb.
Do I have to loose iso and joliet and use udf only with revision set to 2.50? does anyone know the correct settings for a DATA (not a Movie) BluRay filesystem so that the BD-C6500 can play it properly - I don't wanna waste another one.
EDIT: Solved
UDF had to be set to 2.50, as the blu rays are intended only for media playback on the br-player and fairly new pcs I definitely don't need iso or joliet and use udf only. maybe denying imgburn to change the mode from data to divx when adding avi-files also had something to do with it ... idk.
truthy is offline
post #1624 of 1625 Old 05-16-2014, 05:04 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Originally Posted by SanchoPanza View Post
ever since the last firmware update, mine will not load or play anything, but continues to OPEN the tray, even when there is no disc in the tray & even when off, with no disc in tray; had to un-plug to get to stop? have reset to factory defaults, with no joy, any ideas? cool.gif
Any more ideas? It will stay closed when OFF now.
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #1625 of 1625 Old 08-04-2014, 10:15 AM
Quoted: 197 Post(s)
Liked: 511
IF the tray would just stay CLOSED, we could use it for Pandora/YouTube.
Any ideas???
Reply Blu-ray Players
Samsung Bd C6500 1080p Blu Ray Disc Player
