Questions about the frames into DVD and Blu-Ray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2010, 07:10 PM - Thread Starter
sinner1966's Avatar
Hi. I've got a couple of questions concerning motion conpensation of both Blu-Ray and DVD movie files:
- First, why on both DVDs and Blu-Rays I can't pause and forward frame by frame the movie (saying each frame out of 24 per second, like you can do on any LaserDisc or even VHS players)?
- Is it true both DVDs and Blu-Rays use motion compensation to compress the movie files in order to fit onto their specific discs? Wikipedia mentions about motion compensation and its p-frames (type motion compensation on wikipedia)
Hoping someone will answer. Thank you. Sam.
sinner1966 is offline
post #2 of 3 Old 02-21-2010, 07:33 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3175 Post(s)
Liked: 2456
It would depend on the player. The OPPO models do this.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3 of 3 Old 02-22-2010, 04:01 PM - Thread Starter
sinner1966's Avatar
Thank you for the OPPO link. Why is it only that brand making the frame by frame feature? Why not Sony or Panasonic? And does an OPPO BD player actually decompress the movie file codec like a computer or something, in order to get the 24 frames?
Also, is it true the motion compensation thing on Blu-rays and DVDs (which means there are mainly predicted frames instead of the orignal frames)?
Reply Blu-ray Players
