Panasonic DMP-BD65 - Page 63 - AVS Forum
Old 07-11-2013, 09:00 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
Has anyone's BD65 stopped streaming Netflix? All of a sudden 2 days ago, mine won't stream Netflix. Netflix had me run a bunch of troubleshooting, but nothing worked. They said my speed is fluctuating between 1-8 Mbps. Then I called my ISP and they found no such thing. A speed test showed 13 Mbps. I hooked up my 220 to the same TV, and it works fine. Tonight I will hook up the BD65 to another set and see if it works. Just wondering if other people's BD65 has gone bad(with Netflix). Thanks.
Jim McC is offline
Old 08-08-2013, 04:25 PM
rjhseven's Avatar
I have not updated firmware in over a year. Have to set suntitles each time i switch discs or turn on Blu ray player (watching 24 series). Think update would help?
Memphis Home Builder
rjhseven is offline
Old 08-09-2013, 09:20 AM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
The latest firmware was April of 2012 (v. 1.76), so you probably already have it. None of the firmwares have changed the subtitle functionality. I don't know of any players that will keep subtitles on after switching discs. So you'll just have to live with that.
rjhseven likes this.
mdavej is offline
Old 08-09-2013, 12:07 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
Originally Posted by Jim McC View Post
Has anyone's BD65 stopped streaming Netflix? All of a sudden 2 days ago, mine won't stream Netflix. Netflix had me run a bunch of troubleshooting, but nothing worked. Just wondering if other people's BD65 has gone bad(with Netflix). Thanks.
It will stream You Tube, but not Netflix. Anyone have any ideas? Thanks.
Jim McC is offline
Old 08-09-2013, 12:22 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
My guess is when Netflix rolled out its new profiles feature it broke Panny's old app. The new feature also broke other older Netflix apps, like the one in Windows Media Center, which was subsequently fixed by Netflix. Someone's going to have to report it to Netflix and Panasonic to have any hope of getting it fixed. Most likely Netflix will fix it on their end. I doubt Panny will ever update that old app of theirs again.
mdavej is offline
Old 08-09-2013, 12:51 PM
gregoryperkins's Avatar
Quoted: 33 Post(s)
Poor performance with Netflix on my 65 drove me to the Roku. It's a much more stable experience.
gregoryperkins is offline
Old 08-09-2013, 02:31 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
And I don't think the 65 even does Netflix in 1080p either, nor does it do DD+ or subtitles. If you're still watching Netflix on a 65, you're really missing out.
mdavej is offline
Old 08-10-2013, 02:30 PM
Jim McC's Avatar
Quoted: 21 Post(s)
Liked: 33
I know it doesn't do 1080p. I replaced it with a 230, and gave it to my daughter. I was hoping to get Netflix streaming again on it, so she can stream.
Jim McC is offline
Old 08-10-2013, 04:09 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
If profiles is really what broke it, then deleting them all might work. That was a work-around that worked for WMC users. If you have only one profile already, then I'm out of ideas. Time to get Netflix and/or Panny on the phone.
mdavej is offline
Old 09-07-2013, 08:31 AM
cluster_flux's Avatar
Netflix rep blew smoke and played with mirrors for an hour. First he said my ISP was jamming up then stated my player was bad. During prime time hours netflix chokes @ 500-756kbs. I ran a speakeasy benchmark through same network while netflix was fumbling their service that showed 11Mbps. Running netflix off prime time hours and I get 4-10 Mbps. Netflix will not admit it's on their side. It was fun while it lasted, but screw them if they can not meet their commitment and pin the blame on everybody else with FUD BS.
cluster_flux is offline
Old 10-25-2013, 07:38 PM
SkOrPn's Avatar
Quoted: 51 Post(s)
Liked: 43
Is it possible to change profiles on this DMP-BD65? I have the latest FW, and I deactivated my account to re-add my account in order for it to give me the Profile page to select the correct profile but it just instantly goes to the owners profile. How do I select the proper user profile?
Rod
EDIT: Did I really just say all that? LOL, completely failed to look at the last few pages of complaints. However, it is streaming 1080p for me just fine, but it only shows the owners profile and not the profile I created for it. Amazing how they find ways to get us to buy more hardware.
EDIT2: Ok, well we have given up on this player and going to get a Samsung now with the new 2013 SmartHUB. Seems to have the very latest version of Netflix and Plex app.
SkOrPn is offline
Old 11-07-2013, 07:27 PM
Tokapeba's Avatar
I updated the firmwate and now my BD65 just goes into a boot loop. It will eventually boot, but it can take up to 10 minutes. I tried reupdating, but it won't let me. Is there any way to force it to reupdate?
Andy
Tokapeba is offline
Old 11-15-2013, 09:03 PM
Jpepper's Avatar
We've had our DVD player for a couple of years now with no issues. The other night, we had a power failure while watching tv, not a dvd. The next day, I went to play a dvd for my son and could not get any sound. I have checked all the settings and everything seems okay. Just wondering if anyone else has experienced this or is someone knows what the issue could be?
Jpepper is offline
Old 08-31-2014, 05:20 PM
treefrog1's Avatar
Home Video Burned DVD won't play in Panasonic Blu-ray DMP-BD655
Hi all,
I have home movies of my family taken from a Canon camcorder that records in .mts files (AVCHD). My intention is to burn blu-ray discs, but I have blank Memorex DVD-R dvds at the moment so I thought I would test out my new Pavtube imedia converter (for mac) and Pavtube DVD Creator Software.
I converted the .mts files to vob files (NTSC 16:9 format) using the imedia converter and then burned a dvd using the DVD Creator software. I did one trial at medium quality and another at low quality.
Both dvd could be played on my macbook and pc, but could not be played in the Panasonic Blu-ray/DVD player (DMP BD655). This blu-ray player has not had a problem playing home video dvd's that were created using a VHS to DVD Recorder (large component, table-top equipment).
Clearly there is "something" amiss in the software, the process I am following or the burner from the macbook.
Any ideas? I'd really like to view a dvd on the Panasonic Blu-ray/DVD player.
treefrog1 is offline
Old 09-01-2014, 07:16 AM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
My authoring software had the option to burn the AVCHD structure directly to DVD which played fine on my Panny. No conversion required.
mdavej is offline
Old 09-15-2014, 08:59 PM
Dave T's Avatar
dmp-bd655 remote issues
When watching streaming from amazon on my dmp-bd655, the pause/ff/rewind buttons on my remote don't work. I've searched the web and can't find any reference to this issue.
Any thoughts?
Dave T is offline
Old 09-15-2014, 10:03 PM
DocCasualty's Avatar
Quoted: 124 Post(s)
Liked: 1162
Any thoughts?
It's the way the app is designed. Use the "ok" button to pause/play. Use > and < buttons to ff and rewind. It's clunky but functional.
"Dave, this conversation can serve no purpose anymore. Goodbye." - HAL 9000
DocCasualty is offline
Old 09-15-2014, 11:44 PM
Dave T's Avatar
Thanks! That's it. Definitely clunky though - I agree. Strange that they couldn't design it so that the regular buttons on the remote would work, but at least I know now how to pause, etc.
Dave T is offline
Old 09-16-2014, 12:23 PM
pixelation's Avatar
My BD65 is having a lot of issue playing back less than perfect disc. Mostly Blu-rays from library. Yes, I see some scratches and fingerprints on the disc and I always try to clean it off before playing. But the BD65 simply chokes when playing some of the discs. It is increasingly frustrating.
I have another player, Panasonic BDT210, which plays the same disc without problem.
The BD65 is reasonably fast. Has analog output that BDT210 does not have. And it form factor fits nicely in my setup. So I wish I could fix it. Any owners can share some thoughts? I already tried cleaning following the instruction below:
Panasonic DMP-BD65
It didn't seem to help much. Did it reached end of life? Or is it a known issue that BD65 had trouble with less-than-perfect disc?
pixelation is offline
Old 09-16-2014, 07:24 PM
Quoted: 124 Post(s)
Liked: 1162
Have you tried running one of those lens cleaning discs through it? I don't know if it will solve your problem but they're inexpensive and probably worth a shot. Something like this: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I bought it because I thought I could use it on my HDDVD player, which unfortunately didn't work for that. It worked in my BD65, though I wasn't having any problems with it thus far.
Old 09-17-2014, 05:47 PM
pixelation's Avatar
I haven't and most likely won't invest on a cleaning disc. I figure if I have to go that route, I might as well open the drive again and rub the laser head with a lens cloth.
Old 11-15-2014, 10:44 AM
dasher123's Avatar
I still have this player, and hope someone can help me with some questions:
I just bought a new 2014 Panny AS680U 240Hz LCD TV to replace the old Samsung LN-550A series TV (60 hz) from 2008 or so.
BD65 is set to 1080p and 24 fps, and new Panny TV is set to "True HD 4:4:4" ON. (which the BD65 also supports)
Since then I have noticed following issues when playing BR discs with the BD65:
- "just scan" aspect ratio on Samsung TV was the aspect ratio I had it on, and it was perfect. When selecting "just scan" setting on the new Panny, faces seem to get more oval shaped (skinny); when I select 16:9 it's perfect. How could this be?
- I notice some motion judder/jitter on BR discs, more than it did with the Samsung. (I have the "motion picture" setting to OFF on TV, as I don't want Soap Opera effect. But even with it off, shouldn't this be not a problem? ) - also, IDK i am imagining stuff or what, but as the BR disc plays for while, this problem seems to get less and less...i know that sounds weird.
-is my old BD65 having trouble handling a 240Hz tv ??
PQ is great though, no issue with that. But motion is less smooth than with the old TV. (ALL other sources work great with new TV, laptop and Roku; NO motion artifacts; this is ONLY with the BD-65)
- The HDMI cable (monoprice premium) IS about 5 yrs old but i don't think that should be a problem... or can it?
To help, here are full specs for the BD65:
http://shop.panasonic.com/shop/model...s&support#tabs
I am reluctant to upgrade due to newer BR players not having any analog 2-ch audio outs, which I prefer to use with my home amp, which is a 2-ch amp.
Anyone has any idea what these issues mean? or how I can correct them?
dasher123 is offline
Old 11-15-2014, 11:00 AM
dasher123's Avatar
Exclamation Old-ish BR player with New LCD... a few concerns...
I just bought a new 55" 2014 Panny AS680U 240Hz LCD TV to replace the old 40" Samsung LN-550A series TV (60 hz) from 2008 or so.
FYI:
BD65 is set to 1080p and 24 fps ON, and new Panny TV is set to "True/Pure HD 4:4:4" ON. (which the BD65 also supports)
- "Just scan" aspect ratio on Samsung TV was the Aspect Ratio I had it on, and it was perfect with the BD65. When selecting "just scan" AR setting on the new Panny, faces seem to get more "oval shaped" (skinny); when I select 16:9 it's perfect. How could this be?
- I notice some motion blur on BR discs, more than it did with the Samsung. (I have the "motion picture" setting to OFF on TV, as I don't want Soap Opera effect. But even with it off, shouldn't this be not a problem? ) - also, IDK i am imagining stuff or what, but as the BR disc plays for while, this problem seems to get less and less...i know that sounds weird.
(ALL other sources work great with new TV, laptop and Roku; NO motion blur; this is ONLY with the BD-65
Old 11-15-2014, 11:26 AM
Super Moderator
teachsac's Avatar
Quoted: 133 Post(s)
Liked: 178
It would be the opposite. You might try the thread for your TV to see what settings people are using. For BD, try changing the settings for HDMI output between Auto and 4:2:2.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is offline
Old 11-15-2014, 11:32 AM
dasher123's Avatar
Thanks! Will try that, and I already posted on the TV thread too, but it's hard to find that exact TV/BDP combo, so that's why I posted here.
What did you mean by "it would be the opposite"?
Old 11-15-2014, 11:41 AM
Super Moderator
teachsac's Avatar
Quoted: 133 Post(s)
Liked: 178
The only thing that will change the ratio in the BD player is the Zoom. That works mostly with DVD scaling. It sounds like the Panasonic has different overscan settings between the two modes. My Sony does, also.
S~
teachsac is offline
Old 12-13-2014, 09:58 PM
C*Tedesco's Avatar
Liked: 32
Originally Posted by teachsac View Post
Quote:Originally Posted by kezug
I am able to get to Amazon instant video from my BD65 player, however, is there a way to get 5.1 sound from the HD content? I only tried one HD movie and it was MI:3 and the audio was only in Stereo. Is this possible through some sort of Firmware upgrade?
No. Older model players do not support 5.1 audio with Amazon. The current Sonys do as does the Roku.
S~
Well not sure if this has been updated on this thread, but Amazon updated their App for the BD 65 so it does now indeed stream 5.1! Not sure, but the video quality appears to be better as, well. The GUI on an over haul too. Nice surprise on an ol' Blu model.
DocCasualty likes this.
C*Tedesco is offline
Old 12-21-2014, 04:20 PM
Liked: 2
All of a sudden my bd65 has eaten my blu ray of The Descendents and won't give it back. After pushng all the buttons as recommended in the manual I took it apart down to the disc holder but decided to wait and do some research before I do irrepairable damage. I want the cd because I was an extra on the movie! But now I need a new blu ray since I have discovered my laptop does not play blu ray. An suggestions on a good $100 blu ray player? Premium streaming would be nice. Oppo? stick with panny?. I have a 3 year old 42" Panny Plasma TV and a denon avrx2000 and 5.1 speakers HT. Any help or suggestions. Do not think I want to run down to anywhere before xmas. Might be better deals ??
Are there major differences in blu ray brands for a modest system as mine?
kolopuadoug is offline
Old 12-21-2014, 11:33 PM
Rich86's Avatar
Quoted: 37 Post(s)
Liked: 32
My comment below has to do with cleaning/lubricating a BD55, but may assist in retrieving your disc, assuming the basic construction of the BD65 is not all that different from the BD55 . . .
Panasonic DMP-BD35/55 Cleaning/Lubricating
Take the player cover off and open the sealed internal drive assembly (4 screws on top and gently release the tab in the rear and lift top cover off).
Remove any dusty/crud from inside the drive unit.
Be careful not to disturb or contaminate the lubricating grease on the laser assembly rails.
If it needs fresh grease, suggest using a white silicone based lubricant.
Clean the small round platter the center of the disc rides on.
Gently clean the laser lens assembly (both lasers) with a q-tip using denatured alcohol
Put it back together.
A long-time audio/video addict!
Rich86 is online now
Blu Ray Players , Panasonic , Panasonic Dmp Bd60 Blu Ray Disc Player Black , Panasonic Dmp Bd65 Blu Ray Disc Player , Panasonic Dmp Bd85k Wifi Enabled Blu Ray Disc Player Black
