Official LG BD550/BD560/BD570/BD590 Owners Thread - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #6421 of 6427 Old 05-28-2016, 09:17 PM
dr.zapp's Avatar
After upgrading to Windows 10, my BD570 no longer lets me connect to my network computers like I was able to with Windows 7, it keeps asking for the CIFS ID and password. I CAN connect through the DLNA server, but I want to be able to navigate to all my different folders directly, and many media types don't show up in DLNA for some reason. I have removed all Windows Live ID stuff I can find, The sharing settings are identical to what was working in Windows 7. This particular computer does not even have a password?
dr.zapp is offline
post #6422 of 6427 Old 06-18-2016, 12:27 PM
zardozZ's Avatar
Liked: 0
Need to go back to version B5.242.00
Hi DukeNukem1967 I was wondering if you still have that b5.242.00c firmware for the BD555C. I just upgraded to 279 and had the exact same problem and now I need to go back down to 242. The site you provided is no longer active.
Is there some way you can post up the firmware? Thanks
zardozZ is offline
post #6423 of 6427 Old 03-12-2017, 06:24 PM
ashishm02's Avatar
Liked: 0
Did you find the solution for this? Or anybody else find out to view shared folder on BD570/BD590 when the pc has Windows 10? I have been trying so long, but can't figure out a solution
ashishm02 is offline
post #6424 of 6427 Old 03-13-2017, 09:20 PM
dr.zapp's Avatar
I tried for months, but it never worked... So my solution was to get an Amazon Fire TV and run kodi to access SMB shares
dr.zapp is offline
post #6425 of 6427 Old 03-16-2017, 08:36 AM
ashishm02's Avatar
Liked: 0
Thanks for responding. Just curious, did you buy the Fire Stick or the Fire TV?
post #6426 of 6427 Old 03-16-2017, 02:54 PM
dr.zapp's Avatar
Fire TV 4k, so I can hard wire it with Ethernet. Any Android-based multimedia device that can run Kodi will work.
I think Kodi also works with Windows built in DLNA media server, or you can set up a Plex server.
dr.zapp is offline
post #6427 of 6427 Old 10-01-2017, 04:44 PM
Gadget_girl's Avatar
Anyone else having issues getting newer USB portable hard drives to work with their players? I've got an LG BD551C - just figured out how to update the firmware to the 5.277.000C (I think, unless I copied it down wrong) Hoping that would fix my issue. It worked fine with the Segate 1TB usb 3.0 drive I had, but not with the new Western Digital 2TB drive. I'm assuming at this point, that the 2TB is a deal breaker for this unit.
Gadget_girl is offline
Reply Blu-ray Players
Lg Bd550 Network Blu Ray Player , Blu Ray Players , Lg Bd570 Network Blu Ray Disc Player , Lg Bd590 250gb Hd Network Blu Ray Disc Player
