Official LG BD550/BD560/BD570/BD590 Owners Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1081 of 6422 Old 05-30-2010, 08:38 PM
dfreeman1971's Avatar
Here is my system info with Build Date.
LG BD590
Build Date: February 2010
B.D. 8.31.254C
Servo Ver: H80588 (H08SAN)
Netflix IS NOT Working!!!
So I guess this does not help narrow down the issue.
I have checked for updates throughout the day but there is nothing new out there. Hopefully soon.
dfreeman1971 is offline
post #1082 of 6422 Old 05-30-2010, 09:20 PM
tandi's Avatar
LG BD-550
Build Date: January 2010
Main Ver: BD.8.31.254.C
Servo ver: H80588 (H08SAN)
My Netflix works perfectly fine (though it seems the movie occasionally changes from HD to standard midstream-- I think it's an internet connection issue not a player issue though because I've seen it happen on my sister's xbox as well).
I haven't been able to test VUDU yet. When I try to log in I receive a connection error stating that the current account needs to be unprovisioned. I spoke to VUDU about this and they promised me it would be fixed within 24 hours. Apparently my player was either a returned unit or a test unit. I'm almost tempted to return it to Amazon because they sold it to me as "New", however I don't want to risk getting one of the later players that has issues.
I should also note I haven't had any problems with Blu-rays or DVDs.
tandi is offline
post #1083 of 6422 Old 05-30-2010, 11:35 PM
den110's Avatar
Hi
I have a general question concerning the use of ir flashers on the 570. Since my remote does not have line of sight with my equipment rack, I use ir flashers that are stuck to the window where the ir eye is on a piece of equipment. Since the front panel flips down when the eject button is pushed, am I going to have an issue as to where i can stick the flasher? I would think that if I stick it on the flip down panel, once the panel is in the down position, it no longer has contact with the remote eye.
"It's time to nut up or shut up."
den110 is offline
post #1084 of 6422 Old 05-30-2010, 11:52 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
LG BD590
Build Date: Jan 2010
Latest Firmware: BD.8.31.254.C
Netflix Streaming Working: Yes
bori is offline
post #1085 of 6422 Old 05-31-2010, 07:36 AM
golfermike22's Avatar
Bought my BD-570 last Thursday. Installed Friday and updated firmware. Netflix streaming not working but can see instant queue. Everything else appears to be working ok.
Build date: April, 2010
Netflix Streaming: Failing
PS: Anyone know the code to be used on thisLG remote for a Panasonic Plasma S1?
golfermike22 is offline
post #1086 of 6422 Old 05-31-2010, 07:41 AM
macbillybob's Avatar
Originally Posted by den110 View Post
Hi
You will either have to leave the panel down and stick the emitter to the face of the player. Or stick it to the flip down panel and leave it closed. Going to have to experiment I guess. I am going to be doing the same setup.
What ir flasher system do you use?
macbillybob is offline
post #1087 of 6422 Old 05-31-2010, 11:20 AM
Mamasboy's Avatar
Originally Posted by Mamasboy View Post
Best price on the 590 I have seen so far is around $320 with free 2 day prime shipping at amazon. Ohhh the temptation. Must...hold...off (at least in to summer rerun season starts and I start watching more movies).
$303 at Amazon now. Very tempting.
I feel infinite
Mamasboy is offline
post #1088 of 6422 Old 05-31-2010, 01:56 PM
andgarden's Avatar
My January built 550 w/ updated firmware streams Netflix fine.
It's looking like more recent hardware has the problem.
BTW, it's really obnoxious that the 550 won't play movie files off of a data DVD.
andgarden is offline
post #1089 of 6422 Old 05-31-2010, 03:10 PM
blue k7's Avatar
Is this blu ray player better or the Panasonic DMP-BD65?
blue k7 is offline
post #1090 of 6422 Old 05-31-2010, 07:28 PM
olivechicago's Avatar
BD590
March 2010
BD.8.31.254.C
Netflix Streaming is failing
olivechicago is offline
post #1091 of 6422 Old 05-31-2010, 08:25 PM
den110's Avatar
I have the Universal Remote MX3000 and the rf extender mrf 200.
den110 is offline
post #1092 of 6422 Old 05-31-2010, 08:48 PM
bslade's Avatar
With the configuration described above, with the 802.11n access point (base station) pretty close to the BD390 (30 ft), I saw regular breakups when watching Netflix instant videos. When I ran Internet speed tests on my PC, it always showed 15mbits/sec. When I switched to a hard wired ethernet cable, everything works fine.
I'm surprised that Netflix can't handle hiccups from the wireless network. I wonder if it's some sort of bug with the wireless software. Anyway, I just thought I share this in case other people have similar problems.
Ben in Chevy Chase, MD
bslade is offline
post #1093 of 6422 Old 05-31-2010, 08:58 PM
My WII works fine on wireless g network.
The BD550 won't work on wired network.
post #1094 of 6422 Old 05-31-2010, 11:09 PM
lalittle's Avatar
With all these reports of the newer players having problems with Netflix, has anyone gotten any official statements from LG tech support on the issue? It seems to be common enough that they would know about it by now.
On a related note, has anyone been able to actually get to the lg website (www.lge.com)? When I try, I just get a security pop-up asking if I want to download a file.
Larry
lalittle is offline
post #1095 of 6422 Old 06-01-2010, 09:19 AM
dbara54's Avatar
Hi
I had the same problem. I ended up running it to the inside. There is a tiny slot on the bottom right corner of the flip down front panel where the wire can go thru. I did have to find an IR emitter that was not quite as thick as some because the panel would not close all the way. Works perfectly.
dbara54 is offline
post #1096 of 6422 Old 06-01-2010, 09:23 AM
dbara54's Avatar
Originally Posted by olivechicago View Post
BD590
March 2010
BD.8.31.254.C
My 570 just updated to BD.8.31.259.C. Maybe this new release will help if it is also for the 590.
dbara54 is offline
post #1097 of 6422 Old 06-01-2010, 09:44 AM
Interesting, this is a newer update. I will try.
Edit:
BD550 here. I think the update is for all the 500 series. The number you give is the same for my 550.
Did the update and now the little red retrieve bar goes to about 90%, hangs and gives the same error message.
Is this progress or what?
post #1098 of 6422 Old 06-01-2010, 10:08 AM
Upgraded my BD570 to the new .259 firmware. Netflix streaming still failing, with a different symptom. When trying to stream the progress bar is now showing progress in red and gets almost to the end, then delays, then fails with same error message as before.
post #1099 of 6422 Old 06-01-2010, 02:16 PM
Greenvillian's Avatar
Exact same thing with my BD570 . . .
Greenvillian is offline
post #1100 of 6422 Old 06-01-2010, 02:30 PM
blufkin's Avatar
I bought a 550 last weekend and can't get an internet connection. Installed latest update and hard wired straight to my modem bypassing my router. The unit says it is connected but when I try to go to any of the Netcast services I always get a not connected to the internet message. Any ideas ?
Unfortunately I bought it 350 miles away and left my proof of purchase receipt in the motel trash!! Great big OOPS.
blufkin is offline
post #1101 of 6422 Old 06-01-2010, 03:42 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
BD590
Jan 2010
BD.8.31.259.C
Netflix Streaming is working
bori is offline
post #1102 of 6422 Old 06-01-2010, 05:06 PM - Thread Starter
GizmoDVD's Avatar
Anyone have any good IP/DNS settings for VuDu (for when setting up a fresh WiFi setting)? I can't get HDX from VuDu on WiFi, but when directly connected it runs fine.
GizmoDVD is offline
post #1103 of 6422 Old 06-01-2010, 05:17 PM
I went to setup and did the INITIALIZE. (after doing the .259 upgrade) Netflix works now.
You will have to reinitialize Netflix etc but my now works great.
I guess it is great. Does Netflix not stream Dolby Digital? I went to audio setup and set it to pass-through.
Edit: Just answered my own question. I see where they hope to stream 5.1 in the near future.
post #1104 of 6422 Old 06-01-2010, 08:10 PM
troyd75826's Avatar
I have had the same netflix streaming problem that has been listed here, and I was able to fix it tonight.
Here's the solution:
1. Update to latest firmware.
2. Initialize player
You will lose all your setting for netflix and vudu; therefore, you will have to reactivate all your accounts. But this worked!
troyd75826 is offline
post #1105 of 6422 Old 06-02-2010, 04:40 AM
orbitalpunk's Avatar
Can any other 590 users who had the netflix problem before confirm this solution worked with the new .259 firmware?
orbitalpunk is offline
post #1106 of 6422 Old 06-02-2010, 05:12 PM
i had the same "new symptoms" until i reinitialized.
all works now!
post #1107 of 6422 Old 06-02-2010, 06:22 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
My 590 worked with all the firmware updates.
So I decided to initalize for the heck of it. Now I have gotten 2 bd to hang on me. Coraline hung right on the one second mark. War of the worlds hung in the begining loading screen. I had to stop play start again to get it to work. Can someone verify this with there 590 to see if that is an issue. Is I possible to reinstall an older firmware? I am on 259 and would like to go back to 254 or 211.
bori is offline
post #1108 of 6422 Old 06-02-2010, 07:58 PM
My unit updated today and after reactivating my Netflix it is now working.
Thank you , thank you, thank you.
post #1109 of 6422 Old 06-02-2010, 08:29 PM
blufkin's Avatar
I posted a few days ago about not being able to connect to Netflix with our new 550. I have the unit in our living room and it is hardwired through the wall to my router in the next room (20 feet). Today I took it to the room with the router and hooked it up to our extra TV and it works perfectly. All online features work like they should. Then I took it back and hooked it up again in our main room. No go . It says it can connect to my local network but not the Internet. I can unplug the ethernet cable from the 550 and then plug it into my Roku Netflix box or DTV receiver and have it work but not with the 550. Any ideas would help.
blufkin is offline
post #1110 of 6422 Old 06-02-2010, 08:48 PM
eddie_b's Avatar
Originally Posted by ckouba View Post
I recently purchased an LG 55LE5400 LED HDTV as well as the BD570 Blu-Ray player. I have them connected to each other with a high-quality $140 HDMI cable. I have two prevalent problems with this hardware: (i) When playing a disc, the video and audio frequently drops out (the screen goes black and audio stops) for about a second, then it comes back; and (ii) the second problem is that the audio is always a half-second behind the video, creating a very bad lip sync issue. I've tried ALL the settings on both menus, have tried different cable, different HDMI ports. I even took both units back to the store and swaped them out for another serial number. So this appears to be a design problem with this setup. Both problems are extremely annoying, and if I can't resolve this issue I'm taking both back to the store and return them for something else.
I've called LG and haven't gotten very good response (they keep reading their script to me, and say that no one else has had this issue).
Has anyone else experienced this problem? Any ideas on how to fix?
I too have this issue, I have the BD570 and 42LE5400. Exchanged mine also and get same problems. I had called LG and first time they said I need to have it set to 1080p/24. Next time I called and they said it should be set to 1080p/60.
eddie_b is offline
Reply Blu-ray Players
Lg Bd550 Network Blu Ray Player , Blu Ray Players , Lg Bd570 Network Blu Ray Disc Player , Lg Bd590 250gb Hd Network Blu Ray Disc Player
