Official LG BD550/BD560/BD570/BD590 Owners Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #121 of 6426 Old 02-28-2010, 11:44 AM - Thread Starter
GizmoDVD's Avatar
Great.... DTS MA discs don't play properly. The dialog is very distorted to the point where the dialog is very low (sounds like what you would hear if you were talking into closed hands). WTF. The settings are identical to that of my BD390.
GizmoDVD is offline
post #122 of 6426 Old 02-28-2010, 11:49 AM - Thread Starter
GizmoDVD's Avatar
Did the firmware update and it looks like it fixed it....on both an MKV that had the same problem and the BD (Gentleman Bronco's). So we'll see... This happened every once and a while randomly with my BD390, but it was maybe 1 out of 30 DTS MA BDs.
GizmoDVD is offline
post #123 of 6426 Old 02-28-2010, 12:03 PM
drew64's Avatar
Quoted: 13 Post(s)
I think a lot of us forget that these are blu ray players first and everything else that you get with them is a great extra. I have the 390 and want to get the 590. I have streamed netflix and vudu with only minor issues both those were from my Internet connection end. Other than that it plays all my discs. I think people are looking for one machine that does everything well and you are not going to find that yet.
drew64 is offline
post #124 of 6426 Old 02-28-2010, 12:15 PM
irod87's Avatar
Having owned the 390 and now the 590. The 590 did seem to load the bluray I tried on it last night faster...I did have some hiccups with my wireless but after downgrading my security from wpa2 to wpa. It seems to have alot better of a connection. Pandora worked smoothly for me, Netflix seemed better than that on the 390 performance wise. Havent tried vudu or cinemanow. Picasa loaded right up and accuweather seemed to be having some issues loading.....All growing pains that I assume will be tweaked with future firmware updates.
irod87 is offline
post #125 of 6426 Old 02-28-2010, 01:05 PM
Toleedo's Avatar
Quoted: 49 Post(s)
Gizmo after doing the update you can still play .mkv?
Toleedo is offline
post #126 of 6426 Old 02-28-2010, 01:10 PM - Thread Starter
GizmoDVD's Avatar
Yep. Ill try more later.
GizmoDVD is offline
post #127 of 6426 Old 02-28-2010, 01:47 PM
Toleedo's Avatar
Quoted: 49 Post(s)
Thanks for the info, wonder why mine stopped working. Going to see if theres a way to go back to the old firmware and then re-download, or just exchange the unit
Toleedo is offline
post #128 of 6426 Old 02-28-2010, 02:00 PM
wildwillie6's Avatar
Quoted: 22 Post(s)
As online streaming becomes more common, will that be reversed? That streaming comes first and the disk functions are just for playing old libraries?
wildwillie6 is offline
post #129 of 6426 Old 02-28-2010, 02:46 PM
msp203's Avatar
I've tried only a few BD discs so far but they all work fine. Load times seem fast. Netflix works great. I couldn't get Vudu to stream HDX previews - might be a problem my wireless network strength though. The 590 froze up on me while attempting to access files on my desktop computer requiring me to unplug the player to reset it. Hopefully future updates will solve the minor hiccups.
msp203 is offline
post #130 of 6426 Old 02-28-2010, 03:13 PM
HTPC4Ever's Avatar
After the firmware update, I stated having major issues... another reboot solved them so far...
Only thing that seemed different after the firmware, I can't jump ahead using the timer when streaming video... can still use it while watching video on the usb hard drive (good way to cheat not having a rwd and fwd).
Can play mkv files... although, I've erased all of them to start converting using vobmpeg converter (change of name, into one file for easier playback on 570). I'll leave the original ts folder on the server / htpc.
Weather worked fine... clicked on the other stuff, not loaded any of them yet.
All disks seem to work fine... no issues so far after the upgrade, but only watched maybe 5 movies / partial movies.
After working with this over the weekend, I doubt if I'll do streaming from a computer to the 570... more than likely only from a usb hard drive... as said before, I'll keep my media center... still like the streaming there and like media center's free tv options... was watching Twilight Zone while making some networking cables a while ago. Made some new cables to feed my new setup... and to clean it up... messy back there.
edit:
spoke too soon... now my surrogate movie that I wanted to finish watching looks washed out. Odd, I've made no changes, not moved anything... only the firmware update. Even tried rebooting and starting from the beginning. hmm...
HTPC4Ever is offline
post #131 of 6426 Old 02-28-2010, 04:51 PM
drew64's Avatar
Quoted: 13 Post(s)
Had my eyes set on the BD 590. Will move my 390 to bedroom. Then [i] came across the VBR200W from vizio. Appears to have a lot of apps on it. Good price too. May have to see the reviews compred to 590 or 570.
drew64 is offline
post #132 of 6426 Old 02-28-2010, 09:51 PM
drkimble's Avatar
Just got the 570. Easy setup with my Netflix and Pandora accounts. Both working well with a wireless network connection.
I have a Mac laptop and am having trouble with my DLNA however. I downloaded Nullriver MediaLink on my Mac and the LG sees it and allows me to select it but when I try to connect "a network error occurs". Am I missing something? Does anyone know a workaround?
The software that comes with the LG, Nero MediaHome 4 ,is PC only.
drkimble is offline
post #133 of 6426 Old 03-01-2010, 06:15 AM
spyfy's Avatar
You don't need to install any software to stream from a Mac with the 570. Turn on file sharing and enable SMB under sharing settings. Your 570 should now see the folders you setup to share. Just put the files you want to play in those folders and you are all set.
spyfy is offline
post #134 of 6426 Old 03-01-2010, 09:58 AM
citrus's Avatar
Quoted: 69 Post(s)
Liked: 38
Picked up a BD570 yesterday from Frys. Haven't done much yet but find a problem with it regarding the audio sortof.
Can't find a way to turn off the HDMI audio as there isn't any "off" in the selection. My audio from the player is connected to the AVR; had to "mute" the TV audio using the TV remote else I get audio from both the AVR & TV.
Perhaps there is a hidden setting for no HDMI sound?
Did have 1 problem when setting up the BD570; the setup went fine until I got to the "update" section & had the bd570 do the looking for updates; lockup; hardwire connection to the router. Had to pull the power cord to shutdown the player.
On power up, everything went fine & got the new update available which I did. Just don't get too anxious to update the firmware before using the bd570!
Oh, opinions please. My Panasonic 37 incher can accept 1080p @ 60hz. is it preferable to have the TV downscale from 1080p or 1080i as I remembered that the Panasonic doesn't display video at 1080p.
citrus is offline
post #135 of 6426 Old 03-01-2010, 11:47 AM
stepmback's Avatar
Quoted: 17 Post(s)
I have a BD370 which does not have the networking functionality. Would love to play videos on my server downstairs. I dont care about wireless but DNLA is critical. Does the BD550 have DLNA or will I need to get the 570?
stepmback is offline
post #136 of 6426 Old 03-01-2010, 12:23 PM
joerod's Avatar
Quoted: 704 Post(s)
Liked: 633
I have a 590 on the way.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #137 of 6426 Old 03-01-2010, 01:00 PM
drkimble's Avatar
To Spyfy
That brought up my files! - thank you for replying!!!
Now I need to figure out if I can play my itunes music in succession. Seems like I have to click every mp3 individually at the moment
drkimble is offline
post #138 of 6426 Old 03-01-2010, 01:00 PM
Alcoholic247's Avatar
GizmoDVD, I saw a review on BB's site and apparently, the 570 has problems playing mkv files, the user claims that it stutters but not on the 390. I would keep the 390 for now if i were you until a firmware update happens to fix the stuttering issue on the 570.
Just throwing my 2 cents in..
Alcoholic247 is offline
post #139 of 6426 Old 03-01-2010, 01:07 PM - Thread Starter
GizmoDVD's Avatar
Yeah, MKV stuttered on me last night about 45 minutes into it. A reboot fixed it. I have a 45 day return policy at BB, so I'm sure it'll be fixed by then.
GizmoDVD is offline
post #140 of 6426 Old 03-01-2010, 01:37 PM
So I just finished reading every post and I have a few concerns regarding the 570. And I apologize in advance for the noob questions...
1) Can you stream mkv, avi, m2ts files wirelessly from your computer to the 570? If so, how?
2) Can you use playon? (for hulu)
3) Is there a USB connection in the back of the 570 so I can avoid using the front to plug in an external HD.
4) What's the difference in PQ compared to a Samsung 1600 in terms of DVD upconversion?
I appreciate your help! Once I purchase this player, I'll be happy to post my setup.
post #141 of 6426 Old 03-01-2010, 04:09 PM
ruinertt's Avatar
Aside from the "extra" streaming site-capabilities on the BD570, what would be the real argument for buying this if you already have a BD390?
ruinertt is offline
post #142 of 6426 Old 03-01-2010, 04:19 PM
lance_60031's Avatar
If you can play items from your network/pc thru the 570 why do you need a HD on the 590? Would there be a benefit to move a large file from the network -- place it on the 590 HD so the play image quality is better?
lance_60031 is offline
post #143 of 6426 Old 03-01-2010, 04:25 PM
Aguapolo17's Avatar
I am trying to transfer an MKV file from my iMac to an 8 GB thumbdrive. The file won't transfer onto the thumbdrive though because the MKV file is over 4GB. Does anyone know a way to copy the MKV file onto the BD 590? Are you able to copy through the network?
Aguapolo17 is offline
post #144 of 6426 Old 03-01-2010, 06:13 PM
teague's Avatar
The 550 does not have DLNA, so you will need the 570 (or 590).
teague is offline
post #145 of 6426 Old 03-01-2010, 06:58 PM
doodabides's Avatar
Originally Posted by captaindave View Post
Just bought the 550 today from BB along with UP Blu Ray. Tried to play up but it keeps skipping forward... sometimes 3 or 4 chapters at a time. Tried 3 other Blu Rays with no issue. Took up back to BB and exchanged it. Same problem with the new disc. I did the firmware update when I hooked it up. Anyone care to try UP and report back if you have a problem?
I had the same problem with Up and IIRC the exact same places. So it looks like this is definitely a problem with the player. I was able to go back to the spots and ff over the skips, but it needs to be fixed.
doodabides is offline
post #146 of 6426 Old 03-01-2010, 06:58 PM
doodabides's Avatar
I just got the 570 to replace the Samsung BD3600, which is going back due to continuously dropping the wireless and getting locked up just about every other time playing discs.
First impressions are that both video and audio are very good - wireless seems to be stable and SD up-conversion looks as good as it did on the Samsung. I plan on comparing it to my Oppo DVD player and will post any major observations.
As one other person noted, there is a problem with the movie Up - chapters are skipped at the beginning and end of the movie and in the same places as previously reported - so it was player issue, not a smudged disc.
No lip sync problems (unless Cinemasmooth on the Samsung plasma is activated, which is another matter entirely).
Interested in others' impressions of upscaling.
post #147 of 6426 Old 03-01-2010, 07:04 PM
doodabides's Avatar
Now that you mention it, I had the same problem and "solution."
post #148 of 6426 Old 03-01-2010, 07:30 PM - Thread Starter
GizmoDVD's Avatar
Yes. Setup a share folder on your computer.
You could on the older models...so I assume yes.
Nope. Only in the front.
Not sure, but probably about the same.
GizmoDVD is offline
post #149 of 6426 Old 03-02-2010, 08:42 AM
Mr. M's Avatar
Just picked up a 5700 last night but had several problems both pre and post update.
1. The wireless seems very weak. Not a big deal as I intend on using a hardwired connection but I thought some people might be curious.
2. Unit froze up several times on BluRay discs. Transformers, I am Legend.
3. Unit began stuttering between TrueHD and then dropping out to just ProLogicII on my receiver (Pioneer Elite VSX 21). It then began to stutter even when the menu was coming up for the BluRay disc...
I will give it another try tonight, but if I have any of the above problems its going back.
Mr. M is offline
post #150 of 6426 Old 03-02-2010, 10:06 AM
DasRaven's Avatar
First off, I really appreciate you early adopters for reporting in your findings.
Secondly, are we really 4 generations into blu-ray and still having disk compatibility problems?
I was all set to pick up a 570 (or maybe even a 590) this weekend. But now I'm back to considering another PS3.
Built a new home, now filling it with sights and sounds!
DasRaven is offline
Reply Blu-ray Players
Lg Bd550 Network Blu Ray Player , Blu Ray Players , Lg Bd570 Network Blu Ray Disc Player , Lg Bd590 250gb Hd Network Blu Ray Disc Player
