Official Sony BDP-S570 Owners Thread - Page 132 - AVS Forum
post #3931 of 3958 Old 01-04-2014, 12:03 PM
BIslander's Avatar
Quoted: 123 Post(s)
Liked: 138
hmunster2 - When using HDMI, the proper settings to get lossless bitstreams are HDMI to Auto and BD Mix to Off. The player then uses the HDMI handshake with the receiver to negotiate the best connection. If the processor has the needed lossless decoder, the player will bitstream the soundtrack and the AVR will show DTS Master or TrueHD as the audio format. If you set HDMI to PCM, the player will do the decoding. If you set Mix to On, which is the default, the player will decode the track and mix in secondary audio. You may get a PCM output or a lossy bitstream, not lossless, depending on your receiver's capabilities.
The other settings do not matter. The Dolby and DTS settings only apply to the coax and optical outputs and settings such as DRC only come into play when the player is doing the decoding. They apply to PCM, not to an encoded track that is being sent to the AVR for decoding. When bitstreaming, DRC and other such processing is applied in the receiver, not the player.
AVfile likes this.
BIslander is online now
post #3932 of 3958 Old 01-04-2014, 02:46 PM
hmunster2's Avatar
Quoted: 75 Post(s)
Liked: 29
hmunster2 is offline
post #3933 of 3958 Old 01-06-2014, 06:58 AM
regs4's Avatar
Originally Posted by mudfrog View Post
This bluray player is capable with 24fps and so is my tv, it works great with my HTPC. In the settings for 24fps you have a choice of auto or off. On auto it never uses 24fps. Evey bluray I have tried is shown at 60fps according to the details display on the bluray player. I don't have a clue as to what to look for.
The Sony BDP-BX57 goes through my Onkyo TX-NR509. My tv is a Vizio SV470XVT (1080p / 120hz).
Suggestions?
I've tried to playback the latest Wolverine and Steve Jobs blu ray and had to turn off 24fps. The auto setting won't let me play the movies.
regs4 is offline
post #3934 of 3958 Old 01-25-2014, 07:10 PM
bob_m10's Avatar
Hi, I have been having trouble streaming from Netflix. The program starts but frequently pauses during playback. During a longer pause I have jumped on my computer and streaming of the same program is fine so I believe my Internet connection is ok? I am using the Ethernet connection. Are there any options I can change on the player or other troubleshooting steps I can take? Do the newer Sony machines handle streaming better?
Thanks Bob
Dah Finstah likes this.
bob_m10 is offline
post #3935 of 3958 Old 01-26-2014, 08:36 AM
JohninLA's Avatar
Thanks Bob
I have this same problem with my s570 recently. I thought it was my wireless internet, except I have TWC's fastest service, up to 50 mbs. I then thought it was Netflix, except it plays fine on my other devices. I then figured it had to be my s570. I try to pause whatever I'm watching something to let it buffer, but it won't, it just sits there. Playback with pauses every few minutes is normal. I sometimes stop the streaming and then resume playback, which sometimes can get it back on track. It's getting to the point where it's unwatchable. Hulu streams fine though, and media serving works good also, it's only Netflix that the player has a problem with. .
JohninLA is offline
post #3936 of 3958 Old 01-26-2014, 07:33 PM
phantoms's Avatar
I believe the problem is Sony themselves. As I understand it, the Netflix stream doesn't come straight from Netflix. Instead, it's served through Sony servers.
The problem seems much worse in the evenings. It got to the point that I used the Xbox to watch Netflix instead of trying to watch through the Sony. Not wanting to have to use the Xbox to watch Netflix, I finally just broke down and bought a Roku.
I don't know if Sony does it intentionally, because the 570 is an older model, or if there servers are just overloaded. But it's aggravating just the same.
phantoms is offline
post #3937 of 3958 Old 01-27-2014, 12:24 PM
JohninLA's Avatar
Well, I'm getting pretty tired of it. Why would they use their own servers to further deteriorate the signal? I may just decide on replacing it with another brand. Something else that really bugs me is watching a disc on this player, and having to sit through all the previews at the beginning. I try to go directly to the menu, but I get a message that that feature has been disabled. I don't know if that's the way the disc is made or Sony forcing me to sit through endless repeats of pushing the Blu Ray Experience. I'm watching on their Blu Ray player, why am I forced to watch this stuff instead of going right to the movie menu?
I used to be a firm believer in all things Sony, but I have lost it. Samsung is my current brand of choice.
JohninLA is offline
post #3938 of 3958 Old 01-27-2014, 08:03 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
Why? So Sony can keep track of its consumers' preference. LG got caught doing something similar (except worse) not too long ago. It's the old cliche about information/knowledge being power.
I hear Samsung and LG devices make you go through their network like Sony too. I think pretty much all first-tier brands do it.
Apostate is offline
post #3939 of 3958 Old 01-27-2014, 11:23 PM
AVfile's Avatar
Quoted: 65 Post(s)
Liked: 65
Welcome to Blu-ray (pun intended).
If you think the Sony has a bad interface, you will be horrified by most of the other offerings.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #3940 of 3958 Old 02-25-2014, 12:40 PM
WaltN46's Avatar
I'm having an issue with my Sony BDP-S570 that I THINK started after the last update. I use this box to stream MP4 videos from my computer. No matter what I do, it seems, the video appears "squashed" from the Sony. These videos are 1280 x 720 and are therefore 16:9. I'm pretty sure this problem did not exist prior to the recent firmware update. The same videos play fine on my PC using either VLC or the Windows player. They also play fine on my Samsung DVD player. Only the Sony displays this annoying problem.
Any ideas would be appreciated.
WaltN46 is offline
post #3941 of 3958 Old 02-25-2014, 01:22 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
Are you sure about that? I think the last firmware update on the 570 was nearly 3 years ago. Setting Screen Format to Fixed Aspect Ratio should do the trick.
mdavej is offline
post #3942 of 3958 Old 02-25-2014, 02:49 PM
WaltN46's Avatar
Yeah, I'm sure. It was a long time between, but there was a recent update.
That doesn't help; already tried it. BTW, it plays 1080 just fine. It looks like the 720 covers about 2/3 of the screen which incidentally is 720/1080. I've also observed that (according to my TV) the HDMI output is always 1080P, so the player is not sending the original 720 video to the TV.
WaltN46 is offline
post #3943 of 3958 Old 02-25-2014, 03:14 PM
JoeKustra's Avatar
Quoted: 148 Post(s)
Liked: 139
The current firmware is M04.R.788. You can download it: http://esupport.sony.com/US/p/model-home.pl?mdl=BDPS570&template_id=1&region_id=1&tab=download#/downloadTab and it shows a release date of 10/22/13. I think that is wrong.
If you have the output at 1080p, as I do, all it will send is 1080p. There is a native/fixed option also.
JoeKustra is online now
post #3944 of 3958 Old 02-25-2014, 06:11 PM
WaltN46's Avatar
That date sounds about like when I installed it, so I don't think it's far off.
I use 720 for my "temporary" files that I record and then delete (tv shows) only to save space. I have the output set to "original" or whatever, but it makes no diff it seems. I transcode all these files, so I guess I'm going to have to use 1080 if I expect to play them on the Sony.
WaltN46 is offline
post #3945 of 3958 Old 04-20-2014, 05:36 PM
DMJ
DMJ's Avatar
Our 570 won't turn on. Anyone have any idea why? No power surge, no previous problems, and the last time we used it was about two weeks ago.
In the meantime I guess we'll start looking for a new player.
Dan
DMJ is offline
post #3946 of 3958 Old 04-21-2014, 08:02 AM
Colonel Badger's Avatar
Quoted: 16 Post(s)
I've owned the S570 for quite some time and only recently obtained a 3D capable TV (Samsung 8500). Saturday for the first time I watched a 3D Blu ray Movie, Avatar, and have to say I was a little disappointed. I'd previously watched some 3D content from the 3net channel on DirecTV and was VERY impressed with the overall quality of 3D as well as some of the scenes with "pop out" etc. However with Avatar there just wasn't the same effect. I definitely got the depth factor, and while I know Avatar didn't go for the gimmicky "pop out" effects I know there are certain scenes where things appear to "float" out of the screen. However in my case when these scenes happened I didn't really get that effect. Additionally it really seemed like when objects were supposed to float out of the screen, they appeared quite blurry. What I mean is that objects at the very front of the screen were blurry, whereas objects further back in perspective (z level), were sharp ! 3D is definitely working, I notice the difference between glasses on off (without glasses there's the double image), and the TV tells me that glasses are connected, so 3D is definitely "on".
Am I expecting too much from Avatar, did I misread those scenes and they just don't pop out?
One thing I noticed in reading the manual later, was a "Screen size" option on the player. I wasn't aware of that and so haven't set the correct screen size yet (no idea what it defaults to). I wonder if this would help?
Mark.
Colonel Badger is online now
post #3947 of 3958 Old 04-21-2014, 08:11 AM
HGN2001's Avatar
Yes, I'm sure the screen size setting would likely help.
I did sort of the same as you, in getting the 570 a couple of years ago, and then happened to get a 3D TV without intending to (Sony KDL-60R550a). So with the two hooked up together, it seemed a no-brainer to find some 3D blu-rays to watch. So far, we've done THE POLAR EXPRESS, and I was very impressed with that; and then later we got GRAVITY which I also thought was exceptional.
Harry
HGN2001 is offline
post #3948 of 3958 Old 07-14-2014, 09:02 AM
red71rum's Avatar
I have had an S570 since it came out and had not used it for some weeks. I recently was demoing my new speaker system and was playing a pivotal fight scene in Avatar(not a great movie, but it was what I had on hand) and the movie had slight pauses during the action sequences. I then put in another blu-ray that I had and it did the same thing. Both discs are very clean. So I was wondering is it possible that the laser is going out or something? Has anyone else run into this issue before?
Xbox LIVE gamertag: red71rum
red71rum is offline
post #3949 of 3958 Old 07-14-2014, 09:38 AM
JoeKustra's Avatar
Quoted: 148 Post(s)
Liked: 139
I never saw it on my S570, and I have Avatar. I would replace the cable first. The S6200 is very good, and you can keep the S570 remote.
post #3950 of 3958 Old 07-14-2014, 09:52 AM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
Sounds like the hub just needs to be cleaned. Happens to all players after a few years, unless you live in a dust free environment.
mdavej is offline
post #3951 of 3958 Old 07-14-2014, 10:11 AM
red71rum's Avatar
So would I open the tray and blow compressed air? Is the hub where the disc resides or is the part that spins the disc?
red71rum is offline
post #3952 of 3958 Old 11-13-2014, 06:49 PM
Albert Noel's Avatar
I just picked one of these up second hand about 2 weeks ago. Has anyone else found issues with it showing the menu on some blu-ray discs? Namely, The Beaver and the original Crank? The Beaver won't play beyond a portion of the animated menu and Crank just hangs unless you hot the play button and then it plays the film (however there is no menu nor do the controls on the remote actually work to select audio/options)
Is this normal for this player? It's on firmware M04.R.788
Edit: Figured it out on my own. Tuns out, turning off the 24p output completely fixed the problem. I wonder why this is an issue?
Albert Noel is offline
post #3953 of 3958 Old 11-13-2014, 09:10 PM
AVfile's Avatar
Quoted: 65 Post(s)
Liked: 65
It could still be an issue. The 24p thing could just be a coincidence.
Any USB Memory stick installed? Crank wouldn't load properly in one of my players unless extra memory was installed. Also try to Clear persistent storage.
Albert Noel likes this.
- AVStefan
AVfile is offline
post #3954 of 3958 Old 11-16-2014, 07:56 AM
No memory stick installed however I had also cleared persistent memory so that probably fixed it and NOT turning off the 24p output. (I ended up turning it back on and both loaded fine)
post #3955 of 3958 Old 12-25-2014, 01:43 PM
Jim Shaffer's Avatar
I just got a used S570, and it came with firmware M.04.788, which is the latest listed on Sony's website. When I set up the network, it told me that M.04.789 was available. Does anyone know what it does? (I'm not going to jump right into it because I'm hoping that the version I have doesn't include Cinavia -- but I haven't had time to test that yet.)
Jim Shaffer is offline
post #3956 of 3958 Old 12-25-2014, 01:56 PM
JoeKustra's Avatar
Quoted: 148 Post(s)
Liked: 139
Just did the update. Nothing seems to have changed. No Cinavia that I can see. Probably just the usual "improves internet/Blu-Ray ...." stuff as last time. Other models were given an update today also.
post #3957 of 3958 Old 01-07-2015, 12:39 PM
Viper32's Avatar
Quoted: 76 Post(s)
Liked: 37
Well I have used my unit for several years with no issues, but it took the new update the other day and now it freezes and the screen turns pink during a movie. I have to power it off then back on to get it back going.
Any ideas? Or anyone have a older firmware I can go back to?
Current Sets:
PN64F8500 Plasma (4K-LCD's are not in the same ballpark)
Sony XBR65X900B with BDP-S6200 Blu-Ray Player
Previously Owned:
UN65HU7250 (4k Curved) UN55HU6840 (4K Flat) UN65HU8550 (4K Flat) All Returned due to Poor Quality
Viper32 is online now
post #3958 of 3958 Old 01-07-2015, 09:32 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
It's impossible to load an older firmware on a Sony player. Sorry.
My guess is they beefed up the copy protection, which is causing issues. I'd try to report it to Sony so they know that they've broken something. As a test, have you tried connecting the player directly to your tv, which no AVRs or HDMI switches in between?
mdavej is offline
Reply Blu-ray Players
Sony Bdp S570 3d Blu Ray Disc Player , Blu Ray Players , Sony Bdp S370 Blu Ray Disc Player , Sony Bdp N460 Blu Ray Disc Player
Gear in this thread - S570 by PriceGrabber.com
