Official Panasonic DMP-BDT300/350 Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 937 Old 08-08-2010, 07:16 AM
Super Moderator
teachsac's Avatar
Quoted: 839 Post(s)
Liked: 1360
Originally Posted by vader100 View Post
The salesman was wrong. Only the TV's do a conversion. The Panasonic VT20 doesn't convert at all, the Samsungs do a good job with some material and reports say the Sonys are poor.
I have one burning problem with this player now. I cannot get it to play back from where it left off. It always starts the disc off from scratch. Gets incredibly annoying, a very big backwards step unless I have missed a setting somewhere.
As with all BD players, it is not a problem with the player. All BD players operate this way. Discs must be authored to resume playback. Some are, most are not, especially movies that have heavy BD-J authoring. A few studios have been doing a better job with resume playback function. Some you need to use the bookmark feature, if available.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #272 of 937 Old 08-09-2010, 12:42 AM
Nimo's Avatar
Originally Posted by akadennis View Post
Default settings for Chroma, Detail Carity and Super Resolution
Anyone know the default values for this on the Panasonic DMP-BDT350? Doing factory reset default from the setup does not reset these settings. I was messing with them while watching a movie and now don't know what the default was. Thanks to anyone who responds
To reset the player to factory defaults (ALL SETTINGS)
1) With the player off press OK on the remote at the same time press "B" & "Y"
2) "00 RET" should be displayed on the front panel.
3) Use the right arrow key on the remote until you see "08 FIN" on the display panel.
Press and hold [OK] for 3 secs.
This will return your player to out of the box settings.
pg 34 ITM.
Nimo is offline
post #273 of 937 Old 08-09-2010, 03:51 AM
vader100's Avatar
S~
Thing is it is doing it with DVDs as well. Not a single disc I have stopped has ever started back at the point it was stopped. My PS3 is faultless at it.
vader100 is offline
post #274 of 937 Old 08-09-2010, 12:17 PM
Nimo's Avatar
Playing back DVD's on my BDT300 starts and stops at the point you last watched. I'm playing Mr & Mrs Smith SD DVD the 4:3 version @ 24Hz going through an SC-07 to the 50VT25 with no last scene issues. As mentioned a lot BD titles don't do this depends on the encoding on weather or not they implemented it or not.
I also want to mention how good this player upconverts SD material by far the best player I've owned in a while and with the DVD playing right now I have the TV set on "just" to fill the screen and it looks super good. I mean it really looks good!
Nimo is offline
post #275 of 937 Old 08-09-2010, 07:35 PM
nolan1123's Avatar
Hello I just got my DMP-BDT300 today and I have a few questions..\\
1. I did not get a DEMO disk, should I have got one? If so should I contact Panny?
2. Why does the model # on the box say DMP-BDT300PP? why is there a "PP" at the end?
Bruce
nolan1123 is offline
post #276 of 937 Old 08-10-2010, 08:01 AM
KenJr's Avatar
S~
Aggravatingly, when fine tuning the BDT300 and its associated system you must use 'setup'. To use 'setup' you must press 'stop'. That's not unusual - same with my Oppo Blu-ray player. But on my OPPO (other good players too), part of the feature set is: If you press 'stop' once you can restart where you left off .. Press stop twice to restart from the beginning.
KenJr is offline
post #277 of 937 Old 08-10-2010, 09:54 AM
vader100's Avatar
The restart from where you left works fine as long as you leave the disc in the machine. Take it out and it loses all memory and just starts from the disc start.
vader100 is offline
post #278 of 937 Old 08-10-2010, 10:10 AM - Thread Starter
lujan's Avatar
Quoted: 2668 Post(s)
Liked: 1231
Bruce
I got one with my 300 but I got it when they first came out so I don't know if they ran out?
lujan
229 Ultra HD
782 HD
18 HD DVD
4 SD
lujan is offline
post #279 of 937 Old 08-12-2010, 12:56 AM
John de Highden's Avatar
Originally Posted by Nimo View Post
I think Onkyo may need a fw update for this issue. The Pioneers don't seem to be affected by this, along with the Denon and Yamaha's.
The Yamaha RXV-765 receiver, Panasonic THP-54VT20 and Panasonic DMP-BDT300 combination definately have the problem of "V.off" reset, despite saving the setting on the player. I have read the work arounds but I want a software fix for the issue. The whole point of the Panasonic DMP-BDT300 was to enable a legacy receiver to be compatiable with Panasonic 3D through the sub hdmi. Even though I may remember the work around sequence, the rest of the family may not. What is Panasonic doing to fix the issue? So far, the response from Panasonic Australia is: "Should have bought a Panasonic receiver". Follow up by Panasonic Australia: "the issue will be probably fixed on the replacement model for the DMP-BDT300". Panasonic Australia state they do not care what a few people say on this forum, facebook or tweeter. They are not going to spend money on fixing this issue. Not good enough!
John de Highden is offline
post #280 of 937 Old 08-12-2010, 06:04 AM
mikethomasson's Avatar
what is the difference between the BDT300 vs the BDT350. Thanks for your input
mikethomasson is offline
post #281 of 937 Old 08-12-2010, 06:28 AM
NashvilleMark's Avatar
Quoted: 14 Post(s)
The 350 has DLNA. The 300 does not. The 300 is a bit less expensive.
NashvilleMark is offline
post #282 of 937 Old 08-12-2010, 02:56 PM
sonter's Avatar
Also depends where you are located. in Europe there is no 350 version. but the 300 has the same features(DLNA) as the 350
sonter is offline
post #283 of 937 Old 08-12-2010, 09:46 PM
JediFonger's Avatar
Quoted: 59 Post(s)
i have the HD66 and want to get the 300 to play 3-D. can the posters from the last few pages who just got it w/the ZD101 glasses confirm 3-D playback from this player?
to the edge of eternity and depth of infinity, stupidity knows no bound.
JediFonger is offline
post #284 of 937 Old 08-15-2010, 03:57 AM
QuadESL63's Avatar
Noob 3D question: can I use this player on a 3D Samsung plasma (e.g. PN50C8000) for 3D movies?
QuadESL63 is offline
post #285 of 937 Old 08-15-2010, 05:24 AM
Dominus's Avatar
Send a message via AIM to Dominus
Yes
Cheers!
Dominus is offline
post #286 of 937 Old 08-20-2010, 08:46 AM
jtmcalpin's Avatar
Bruce
I have the same question. I just bought the BDT-300 and did not receive the DEMO disk. I bought the player last week.
Has anyone else recently bought this player and received this disk? I really want the disk. Should i go back to where I bought the player or contact panasonic?
Thanks in advance
jtmcalpin is offline
post #287 of 937 Old 08-20-2010, 03:14 PM
pizzaaman's Avatar
pg 34 ITM.
tried everything to reset my player and still same
(i cannot output any sound or video via the hdmi main port)
help please
pizzaaman is offline
post #288 of 937 Old 08-20-2010, 09:09 PM
mick16a's Avatar
Can anyone please tell me if the DMP-BDT350 can playback files from a usb powered hard drive?
mick16a is offline
post #289 of 937 Old 08-21-2010, 06:48 AM
007james's Avatar
Quoted: 22 Post(s)
I just purchased the 300 last week and I did not receive the Demo, I called Panasonic and the rep said it was not part of the package. I may try calling again........
Thanks in advance
007james is offline
post #290 of 937 Old 08-21-2010, 08:00 AM - Thread Starter
lujan's Avatar
Liked: 1231
Could it be that the demo disk was provided by the retailer? I bought mine very soon after it came out from BB and it had the demo disk. Could it be that only those purchased by BB got the 3D demo disk?
lujan
229 Ultra HD
782 HD
18 HD DVD
4 SD
lujan is offline
post #291 of 937 Old 08-21-2010, 02:48 PM
pizzaaman's Avatar
any 1 else help me reset my 300 blu ray
as no matter what i try it wont reset
and i getting no signal from hdmi main port
post #292 of 937 Old 08-22-2010, 11:39 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
No. Mine is a 350 purchased through Amazon and it came with the demo disk.
Buzz
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #293 of 937 Old 08-23-2010, 07:11 AM
Elladan's Avatar
Originally Posted by John de Highden View Post
(snip)
I have a Panasonic SA-BX500 receiver and the problem exists on this combination as well. I disabled VieraLink on all devices to see if that would fix it (that receiver, BDT300 and P50VT25) but the problem persists. A case has been opened with Panasonic tech support.
Elladan is offline
post #294 of 937 Old 08-24-2010, 12:30 PM
sonter's Avatar
Anyone know what the latest firmware update fixes ?
*edit
Well I updated and surprisingly It retained v.off setting when I restarted. I Might just have been lucky, but It has never done that before, regardless if I had my tv or onkyo reciever on or off
sonter is offline
post #295 of 937 Old 08-25-2010, 05:49 AM
Elladan's Avatar
I can confirm that yesterday's firmware update fixed the V.Off setting. I played a BR disc, changed the setting, played it some more, turned everything off, watched some TV, put in a different BR disc, started playing that, and the setting was still enabled.
Good stuff. Now if I can only get my BA-SX500 to show that I'm getting TruHD sound (even though I know I am).
Elladan is offline
post #296 of 937 Old 08-25-2010, 06:43 AM
sonter's Avatar
and I even got it to be DVD region free by buying a small remote for 5 $ off ebay..Things are really looking up for this player
sonter is offline
post #297 of 937 Old 08-25-2010, 01:17 PM
Razvanel's Avatar
Oh, DVD region free? PM sent
Razvanel is offline
post #298 of 937 Old 08-26-2010, 12:15 AM
stelch's Avatar
That's not true with my BDT300 (Europe version).Even when I take the disc out, it still restarts from where you left!
stelch is offline
post #299 of 937 Old 08-27-2010, 09:15 AM
mick16a's Avatar
Stelch have you been able to playback files from a usb hard drive on your BDT300? I tried a couple of drives that don't require a seperate power but had no luck.
Has anyone used any type of usb hard drive with success?
mick16a is offline
post #300 of 937 Old 08-27-2010, 09:18 AM
jtmcalpin's Avatar
Stelch have you been able to playback files from a usb hard drive on your BDT300? I tried a couple of drives that don't require a seperate power but had no luck. Has anyone used any type of usb hard drive with success?
I have been able to play back files fine from my USB flash drive. I know it is not a hardrive but it works great for movies (.avi) and pictures (.jpg)
Reply Blu-ray Players
Panasonic Dmp Bdt310 Integrated Wi Fi 3d Blu Ray Dvd Player , Panasonic Dmp Bdt350 Full Hd 3d Blu Ray Disc Player , Panasonic Dmp Bdt300 Full Hd 3d Blu Ray Disc Player
