Problem playing "AVATAR" - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 239 Old 04-23-2010, 10:03 AM
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
Originally Posted by ser182 View Post
Panny BD-60 took about a minute to get started. Other than that no problems. Transfer was really nice. The audio seemed a bit low. I had to crank it up alittle more.
What firmware are you using?
MidnightWatcher is offline
post #92 of 239 Old 04-23-2010, 10:56 AM
Quoted: 3256 Post(s)
Liked: 2743
Just back from Best Buy, there are now large warning signs posted on the shelves and at the check out counters that The Avatar Bluray may not run in your player without a firmware update. Gotta put a dent in the sales for someone with an older player who doesn't have a clue what firmware is nor how to update it. As for companies that don't support their legacy products with firmware updates we all have special words of advice.
Thank God for Oppo.
Just previewed it, WOW
post #93 of 239 Old 04-23-2010, 11:17 AM
smjbh5's Avatar
Quoted: 47 Post(s)
Worked just fine on my 470 and my old 350 (have not upgraded the fw in over a year)
smjbh5 is offline
post #94 of 239 Old 04-23-2010, 11:35 AM
JJHXBR's Avatar
Avatar played without issues on my Denon BD3800 but was completely unwatchable on my HTPC using ArcSoft TMT3.
The Avatar blu-ray loaded and played, but then the picture started to breakup and completely pixelate.
Now waiting for ArcSoft to issue a patch fix.
JJHXBR is offline
post #95 of 239 Old 04-23-2010, 12:29 PM
audiomixer's Avatar
Panny BD30, lastest firmware update, plays it fine...just looooooong load time.
Santa Claus has the right idea...visit people only once a year...Victor Borge
audiomixer is offline
post #96 of 239 Old 04-23-2010, 12:56 PM
Spanbauer's Avatar
Originally Posted by bigcoupe2003 View Post
I attempted downloading the firmware several times for the BDP-09FD euro version it never seems to work every time I put it in the player it says DATA DISC is there anyone who can help me solve this problem so I too can watch AVATAR I have attempted on my mac osx and also on a windows based computer.
You're not burning it correctly. On Mac OS X, do this:
1. Download the firmware and locate the file, which after it automatically unzips should be a .iso file.
2. Open Disk Utility from your Applications/Utilities folder.
3. If it hasn't already appeared in the lower left of the well (the white column on left of the Disk Utility window), drag the .iso file there.
4. Select the .iso file in the well and click the "burn" button.
Click here for my home theater setup
Spanbauer is offline
post #97 of 239 Old 04-23-2010, 01:21 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Let's keep on topic to discussing issues relative to Avatar. The wider range topic should be taken to it's own thread. I don't want those having issues to have to search through the debate to find the answers they are looking for.
Ron
PS: We've had several threads in this forum, the HDM software and Blu Ray software forums that discuss the larger issue of firmware updates etc. Here's just one of the threads that would be appropriate to redirect the discussion to..
http://www.avsforum.com/avs-vb/showt...light=firmware
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #98 of 239 Old 04-23-2010, 01:29 PM
huyqp's Avatar
Originally Posted by alonne View Post
Thanks for the information. My player is Eu zone. I called Pioneer and they said they have made a query to Belgium to see when and how the model will be updated, because the Japanese firmware can not be used in our player.
NEWS: pioneer call me now. The next week the bdp 120 will have an update (29-30 or 3-4 May.)
I installed the japanese FW BP9200300 for the Pioneer BDP-120. Unfortunately, it played Avatar but still have random pop up of the timeline. Guess will have to wait for the FW Pioneer promising for next week
huyqp is offline
post #99 of 239 Old 04-23-2010, 01:51 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Understood- could the deleted posts be moved there?
Rgb is offline
post #100 of 239 Old 04-23-2010, 02:13 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Undeleted and moved to this thread
http://www.avsforum.com/avs-vb/showt...3#post18529433
To all
If you don't see your posts, it was moved to the thread linked above
Retired Moderator
post #101 of 239 Old 04-23-2010, 02:17 PM
Rgb
Rgb's Avatar
Quoted: 32 Post(s)
Rgb is offline
post #102 of 239 Old 04-23-2010, 02:39 PM
Tyro's Avatar
I just updated to the lastest firmware and still had to insert the disc 3 times before it began the excrutiating load time
Tyro is offline
post #103 of 239 Old 04-23-2010, 03:14 PM
thekeiser's Avatar
hey guys dsok found out for the Samsung BD-P1400 that downgrading firmware one version (from v2.2 to v2.1) solved the timeline popup problem for us. I downgraded and just tested, confirmed. You Pioneer guys may want to try that, no guarantees though. Good luck!
thekeiser is offline
post #104 of 239 Old 04-23-2010, 04:16 PM
rickcfer's Avatar
Quoted: 46 Post(s)
Liked: 24
Thank God for Oppo.
And thank God for Pioneer which released firmware for their players the day of release. I know the US site was hammered yesterday , I downloaded the firmware for the BDP-320 this morning off the US site with NO problems
rickcfer is offline
post #105 of 239 Old 04-23-2010, 05:18 PM
ser182's Avatar
Tyro I have only had a long load time with mine. Played it today after my calibration and it loaded with no problems. I have the panny 60.
Xbox live- SER 182
Mix Cloud
http://www.mixcloud.com/Ser182/
ser182 is offline
post #106 of 239 Old 04-23-2010, 06:47 PM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Originally Posted by clarkeven View Post
Avatar runs fantastic on my old Panasonic BD30...
That's good to hear!
_________________________
Franin is offline
post #107 of 239 Old 04-23-2010, 06:49 PM
audiomixer's Avatar
Mine, too...it just takes a looooooooong time to load.
post #108 of 239 Old 04-23-2010, 06:49 PM
CIH USER
Franin's Avatar
Liked: 1311
So which players require the firmware update to play this film?
Franin is offline
post #109 of 239 Old 04-23-2010, 06:50 PM
CIH USER
Franin's Avatar
Liked: 1311
How long?
Franin is offline
post #110 of 239 Old 04-23-2010, 06:51 PM
CIH USER
Franin's Avatar
Liked: 1311
Has anyone tried the Denon 2500,Denon 2010 or the Sony 550?
Franin is offline
post #111 of 239 Old 04-23-2010, 08:03 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Plays fine in a Panasonic BD55. A little slow to load. But, not outrageously slow.
BIslander is offline
post #112 of 239 Old 04-23-2010, 09:29 PM
stretch's Avatar
man...What the bleep! Pio:320 aint playing it! Downloading the new firmware now. Not sure why Pio didn't allow firmware to go straight to the player.
stretch is offline
post #113 of 239 Old 04-23-2010, 10:02 PM
faux123's Avatar
So far I know from my own experience of the following:
Samsung BD-P1000 and
Philips BD-P9000
neither of these will play Avatar at all.
My High Definition Media Collection Formerly: My Blu-ray/HD DVD collection
faux123 is offline
post #114 of 239 Old 04-24-2010, 01:41 AM
Waboman's Avatar
Quoted: 4581 Post(s)
Liked: 10685
Avatar played fine on my older Panasonic BD30 and my Oppo BDP83. For the record, I have not updated either one recently. Why would an older player like the BD30 be able to journey to Pandora, whilst newer players cannot? What changed?
Waboman is online now
post #115 of 239 Old 04-24-2010, 04:00 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
BD-Live capability.
JazzGuyy is offline
post #116 of 239 Old 04-24-2010, 04:21 AM
CIH USER
Franin's Avatar
Liked: 1311
Good to know waboman. Cheers for that bud!!
Franin is offline
post #117 of 239 Old 04-24-2010, 07:00 AM
Selden Ball's Avatar
Quoted: 3052 Post(s)
Liked: 1494
Avatar plays fine on my Sherwood BDP-5004. That player was released around October, 2009, and no firmware updates have been published.
Selden
Selden Ball is online now
post #118 of 239 Old 04-24-2010, 08:16 AM
Wolfepack's Avatar
Downloaded the Euro firmware and installed and was able to play the movie flawlessly last night for a group of people. I was the only one to have seen the movie previously and it was cool to see peoples reaction to it. Pioneer USA site produced a corrupted file when it was downloaded. Thanks to Ruined for the link to get one that works!! BTW movie looked solid on my Pioneer Elite Pro-150FD.
Wolfepack is offline
post #119 of 239 Old 04-24-2010, 09:21 AM
redd2ca's Avatar
It will not play on my Samsung 3600. Says it needs an update but there is no newer one available from Samsung.
redd2ca is offline
post #120 of 239 Old 04-24-2010, 09:27 AM
laddieluv's Avatar
>>Does doing the above also solve the AUDIO HICCUP issue that goes with the TIMELINE POP UP issue?
Samsung UNB7100 55" LED HDTV
Onkyo SR 600 SS
Samsung BD-P 1400 BD Player
170 BD titles and counting
Recent Buys: "Iron Man" "Crazy Heart" "Avatar"
laddieluv is offline
Reply Blu-ray Players
