DBP2011 & DBP-1611 owner's thread. All questions and comments go here. - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1051 of 1075 Old 03-24-2014, 01:48 AM
azahid's Avatar
Can anyone direct me to a link where I can directly download and update my software for my BDP-1611UD Denon player. I prefer to download the file on a USB and then upload it. Will this option work best.? Thanks.
azahid is offline
post #1052 of 1075 Old 04-16-2014, 10:35 PM
Deano79's Avatar
I have had the DBP-1611UD for a little over two years and have not used it to its full potential. However last week the ON/STANDBY button started blinking when I turned it on from the remote with nothing showing on the display panel of the unit nor on the menu while viewing it via the TV. I switched the power off and removed the plug  and left it overnight but the same thing happened the next morning. Would appreciate it if anyone on this forum has had a similar issue and how they resolved it. As I am unable to get into the menu given there is no display how else can I reset it to the factory settings.
Deano79 is offline
post #1053 of 1075 Old 04-16-2014, 10:51 PM
nismo604's Avatar
Make sure the pure direct is off. Keep pressing the pure direct button until it says pure direct off.
nismo604 is offline
post #1054 of 1075 Old 04-16-2014, 10:58 PM
Deano79's Avatar
Thanks for your response - As there is no display on the front panel I cannot see if Pure Direct is off and there is no menu display on the TV. I just tried turning it on again kept pressing the Pure direct and nothing happens.
Deano79 is offline
post #1055 of 1075 Old 04-16-2014, 11:13 PM
nismo604's Avatar
Oh too bad it looks like you'll need to have player serviced. I was hoping that because the display was off that the pure direct was engaged.
nismo604 is offline
post #1056 of 1075 Old 01-22-2015, 07:49 PM
Quoted: 51 Post(s)
Denon DBP-1611UD Skipping/Freezing
Hello all,
My 1611UD just started freezing/skipping randomly. Is this a known issue? I tried checking the owners thread and I couldn't find much about it.
I understand the player is around 4-5 years old at this point, but is there a firmware update that fixes this?
Any help would be great. Thank you.
MasterAudio is offline
post #1057 of 1075 Old 11-09-2015, 12:22 PM
Quoted: 62 Post(s)
Liked: 8
Repost
Cndctrdj is online now
post #1058 of 1075 Old 11-09-2015, 12:43 PM
Quoted: 62 Post(s)
Liked: 8
Hi. New to the forum. Still searching the vast amount of info to find all my products.
Anyway I've had my 1611 for a little while now and have had a few questions about it.
It's loud. It doesn't connect to the internet.
Also what settings should be used to get the most out of it. Like, to let my reciever do the sound processing, or is it better letting the player do it?
Any advice with it or tips and tricks. I scanned the forum but didn't see much
post #1059 of 1075 Old 11-09-2015, 01:36 PM
Transmaniacon's Avatar
Quoted: 1495 Post(s)
Liked: 1294
I would probably let your receiver handle it, that's how I have mine set up and it works well. Download the firmware update for it, it's a little slow to load initially but the firmware helps things speed up.
Cndctrdj likes this.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is online now
post #1060 of 1075 Old 11-09-2015, 04:10 PM
Quoted: 62 Post(s)
Liked: 8
Any way to update it other than being online? It can never seem to connect
post #1061 of 1075 Old 11-09-2015, 04:24 PM
Liked: 1294
Hm not sure about that, it has a USB, maybe there is a way to download it to a flash drive and install that way?
Sent from my SAMSUNG-SM-G900A using Tapatalk
post #1062 of 1075 Old 11-11-2015, 07:56 AM
Quoted: 62 Post(s)
Liked: 8
I tried to update but got nothing. This thing doesn't like the internet. Won't connect. Any tips?
It's hooked up to an Asus WiFi router
post #1063 of 1075 Old 11-11-2015, 08:13 AM
Liked: 1294
Maybe try plugging it directly into the modem and seeing if it will connect that way?
If not, give Denon a call and they might be able to help you out.
post #1064 of 1075 Old 11-16-2015, 06:14 AM
pwlucido's Avatar
Denon DBP-1611UD no disc
My Denon DBP-1611UD will no longer read any disc. This blu-ray player has been a bit annoying from the start. It is slow to start/shutdown. Slow to load. Earlier this year it stopped playing homemade discs. And now it won't play any disc (DVD, blu-ray, CD).
Does anyone have experience with this model and this issue?
What would it cost to fix this? Not that I am certain it is worth it.
Paul
pwlucido is offline
post #1065 of 1075 Old 11-16-2015, 06:58 AM
Liked: 1294
Paul
Have you updated the firmware? If that doesn't fix the issue then I don't know that it will be worth fixing as it is likely out of warranty.
post #1066 of 1075 Old 11-16-2015, 07:07 AM
pwlucido's Avatar
Thank you for the reply. In the past couple years I have not seen a new update. I believe I last checked earlier this year.
Paul
pwlucido is offline
post #1067 of 1075 Old 04-26-2016, 10:37 AM
Quoted: 62 Post(s)
Liked: 8
Anyone have a link to the site I can download the firmware update to usb
Reciever - Denon avr x7200wa / dvd Samsung ubd k8500
Front - Klipsch rf7 / Klipsch rc3 II
Sides - klipsch ref iv rs52
Rear - klipsch rb 61 II
Sub - deftech supercube 1
Atmos - klipsch rp 140sa
post #1068 of 1075 Old 04-26-2016, 03:58 PM
Quoted: 62 Post(s)
Liked: 8
i red up on it and you can download the firmware and update it but i cant find a download. i find a txt file from denon that has the update list but no actual update file
post #1069 of 1075 Old 04-30-2016, 09:29 PM
Quoted: 62 Post(s)
Liked: 8
Tonight my player wouldn't turn on. I'm kind of sad. Anything to check? Or things to do
Tried remote control and physical button
post #1070 of 1075 Old 05-01-2016, 07:56 AM
Quoted: 62 Post(s)
Liked: 8
If I can't get it to turn on, is it worth sending in to be fixed or should I just movemailed on? I know technology has moved on
post #1071 of 1075 Old 05-01-2016, 10:48 AM
mogorf's Avatar
Quoted: 1019 Post(s)
Liked: 560
The troubleshooting section of the Manual says:
"Power does not turn on: The safety protection decive may be activated. Unplug the power cord once, and wait for 5-10 seconds and then plug it in again".
Try this and report back please.
mogorf is offline
post #1072 of 1075 Old 05-01-2016, 02:55 PM
Quoted: 62 Post(s)
Liked: 8
It turned on. But every couple of seconds the screen would go fuzzy and blank. Then it would come back on
post #1073 of 1075 Old 05-01-2016, 03:15 PM
mogorf's Avatar
Liked: 560
Glad to hear the unit finally turned on. The screen problem could be some HDMI handshake issue, dunno. Just make sure the HDMI cable is fit tightly at the BD player side and at the AVR side as well. Also you may press the "Resolution" button on the front panel and press it again until the display shows "Source Direct". Leave it like that.
You may also disconnect the power cable and leave it like that overnight and re-connect tomorrow. Let's see.
mogorf is offline
post #1074 of 1075 Old 05-01-2016, 06:30 PM
Quoted: 62 Post(s)
Liked: 8
Thank you. I'm happy as well. I'll check the cables tomorrow and the source direct.
post #1075 of 1075 Old 05-02-2016, 04:22 PM
Quoted: 62 Post(s)
Liked: 8
So... each day when I get home I have to unplug the player for a few minutes before it will work. Any new suggestions
Reply Blu-ray Players
Blu Ray Players , Denon Dbp 1611ud Universal Blu Ray Dvd Cd Player Black
