New Oppo BDP93 Blu-ray Player - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1323 Old 10-01-2010, 01:01 PM
progprog's Avatar
Originally Posted by Perpendicular View Post
It has already been determined in a previous Post that it is the depth, not the height of the player.
And this is why I mentioned it to the guy who thought is was the height....
progprog is offline
post #452 of 1323 Old 10-01-2010, 01:12 PM
drbonbi's Avatar
Hell, at first I thought it was 1/2 the depth of the 83! I thought that was amazing!
Then it was pointed out that somewhere along the way, the abbreviation for inch was dropped.
Oh.
Dana
"If you think you can, or think you can't, you're probably right." Mark Twain
drbonbi is offline
post #453 of 1323 Old 10-01-2010, 01:15 PM
gonk's Avatar
Units of measure are important...
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
post #454 of 1323 Old 10-01-2010, 01:27 PM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
It looks nicer than I thought it would.
RobertR is offline
post #455 of 1323 Old 10-01-2010, 01:34 PM
slipstream8's Avatar
True, just ask the JPL guys that worked on that satellite.
slipstream8 is offline
post #456 of 1323 Old 10-01-2010, 02:48 PM
Jim Hef's Avatar
You were expecting an ugly stepsister???
Jim Hef is offline
post #457 of 1323 Old 10-01-2010, 02:54 PM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
It looks nicer than the Audioholics pictures led me to believe.
RobertR is offline
post #458 of 1323 Old 10-01-2010, 02:55 PM
Bryan Beckman's Avatar
The first pictures from Audioholics were somewhat less than flattering.
Bryan Beckman is offline
post #459 of 1323 Old 10-01-2010, 02:59 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
I'm not sure I understand the reference to the "eSATA" availability Is this for an internal or external HD ? If so , where is the connection ?
Quote"The SATA standard defines a data cable with seven conductors (3 grounds and 4 active data lines in two pairs) and 8 mm wide wafer connectors on each end."Unquote
Scott...................
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
post #460 of 1323 Old 10-01-2010, 03:03 PM
gonk's Avatar
"eSATA" is the external version of the SATA interface, so it would suggest support for an external SATA drive (not going through the USB).
gonk
gonk is offline
post #461 of 1323 Old 10-01-2010, 03:05 PM
drbonbi's Avatar
Check this out. Right in the middle.
Dana
drbonbi is offline
post #462 of 1323 Old 10-01-2010, 03:06 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
I wonder if it is one of the ports to the left of the first HDMI connection in the photo...
http://api.ning.com/files/ze9W2MlljF....JPG?width=721
Scott...........
EDIT: oops! that was faster than me . Thanks for the better photo .
post #463 of 1323 Old 10-01-2010, 05:33 PM
rdodolak's Avatar
Originally Posted by drbonbi View Post
I would expect Wireless N to be built in.
Also from page 1. "increased performance and improved build quality."
Dana
I was kind of wondering why the pictures of the prototypes weren't displaying a wifi symbol ... guess we know now. Here's what Oppo had to say on Twitter today:
Originally Posted by OPPODigital View Post
@tristantom WiFi will be a separate included USB dongle. Built-in WiFi would require lower build standards (plastic) and lower performance.
8 minutes ago via web in reply to tristantom
rdodolak is offline
post #464 of 1323 Old 10-01-2010, 05:33 PM
ti-triodes's Avatar
Quoted: 236 Post(s)
Liked: 264
It still looks like it will be a fingerprint nightmare.
ti-triodes is offline
post #465 of 1323 Old 10-01-2010, 05:38 PM
progprog's Avatar
Especially that eject button surrounded by shiny black plastic.
progprog is offline
post #466 of 1323 Old 10-01-2010, 05:39 PM
drbonbi's Avatar
Well, guess I was wrong - again!
Dana
drbonbi is offline
post #467 of 1323 Old 10-01-2010, 05:54 PM
Stew4msu's Avatar
Don't know if I've ever touched a bd player after set up
Stew4msu is offline
post #468 of 1323 Old 10-01-2010, 06:10 PM
slimoli's Avatar
Quoted: 492 Post(s)
Liked: 231
From OPPODIGITAL Twitter:
"Many of the specs. can't be officially discussed as the player is still going trhough certification. Netflix included. "
Reply to a question about specs and Netflix.
I was so happy without HDR...
slimoli is offline
post #469 of 1323 Old 10-01-2010, 06:13 PM
slimoli's Avatar
Quoted: 492 Post(s)
Liked: 231
Also, a little bit of humor in another reply:
"Try not to drool on the player. Water damage is not covered under Warranty. "
Chinese sense of humor ?
slimoli is offline
post #470 of 1323 Old 10-01-2010, 06:39 PM
drbonbi's Avatar
American sense of humor.
Dana
drbonbi is offline
post #471 of 1323 Old 10-01-2010, 07:15 PM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
I could never NOT touch a player after setup. Have to press the open/close button to insert/remove a disc. To do otherwise would involve 75 feet of walking just to avoid touching it. Would make no sense.
RobertR is offline
post #472 of 1323 Old 10-01-2010, 07:26 PM
Stew4msu's Avatar
Oppo's dont' have an eject (open/close) button on the remote? That's what I always use so that it's open when I get there and just have to remove/insert the disc.
Stew4msu is offline
post #473 of 1323 Old 10-01-2010, 07:31 PM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
My remote is at my listening chair, which is 25 feet from the player (player is at the entrance to the room). As I said, I'd have to walk 75 feet to do what you suggest. Hardly worth it.
RobertR is offline
post #474 of 1323 Old 10-01-2010, 07:41 PM
gonk's Avatar
They do have an eject button on the remote, but my equipment cabinet has a door on it - I have to open that door before I can eject the tray, so I may as well use the button on the front panel. Others probably have similar reasons for using at least that front panel button.
gonk
gonk is offline
post #475 of 1323 Old 10-01-2010, 07:57 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Dana
Will an external eSATA HD be a requirement of its streaming potential ? Is this a Netflix requirement ? I'll have to research a bit to see the advantages of eSATA over USB .
post #476 of 1323 Old 10-01-2010, 07:59 PM
kiko1's Avatar
Will there be pre orders for the new player, because judging by the excitement it will sell out.
kiko1 is offline
post #477 of 1323 Old 10-01-2010, 08:06 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Some info on eSATA for those that are curious...
External Serial Advanced Technology Attachment or eSATA is an external interface for SATA technologies. It competes with FireWire 400 and universal serial bus (USB) 2.0 to provide fast data transfer speeds for external storage devices.
SATA replaced ATA legacy technology as the next generation internal bus interface for hard drives. The SATA interface is more streamlined than ATA and provides serial architecture for greater speed than the older parallel technology. eSATA cables are narrow and can be up to 6.56 feet (2 meters) in length, whereas parallel cables are much wider and limited to a length of 18 inches (45.7 cm). With eSATA, the speed of SATA expands to encompass exterior storage solutions.
While eSATA reaches transfer rates of at least triple those of USB 2.0 and FireWire 400, it does have one drawback. eSATA requires its own power connector,
Original SATA, or SATA 150, has a data transfer speed of 150 megabytes per second (MB/s). SATA 3G doubled the speed to 300 MB/s or about .3 GB/s. This is also sometimes referred to as SATA 300.
Scott......................
post #478 of 1323 Old 10-01-2010, 08:13 PM
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 314
The player carries the standard 1GB of built in memory required to be BD 2.0 compliant. This is more than enough storage required for streaming Netflix and other internet services.
eSATA is used for external media support for audio, video, and picture files. Think USB, but a crap top faster and more reliable.
Neuromancer is offline
post #479 of 1323 Old 10-01-2010, 08:26 PM
drbonbi's Avatar
You can register here to be notified by OPPO when the player is available for purchase.
Dana
drbonbi is offline
post #480 of 1323 Old 10-01-2010, 08:38 PM
kiko1's Avatar
thanks,
kiko1 is offline
Closed Thread Blu-ray Players
Oppo Bdp 93 Blu Ray Player
