Yamaha BD-S667 Blu Ray Player - AVS Forum
post #1 of 9 Old 10-04-2010, 03:48 PM - Thread Starter
Skakruk's Avatar
This BDP appears to be priced similarly to the Sony S570 and Panasonic BD85, and while those playersboth have extensive threads here, the Yamaha unit is conspicuously absent. In fact, there has been barely any discussion on it anywhere on the web.
Why is everyone ignoring this unit?
Skakruk is offline
post #2 of 9 Old 10-04-2010, 04:37 PM
TuenMuner's Avatar
In before the lock!
There is a thread about this model, use the search button.
BD-A1010/CD-S1000/PF60
HTR-6290/A-S1000/KDL46V5100
NS-555/SOAVO-900C/NS-125F
BD - 242
HD - 7
TuenMuner is offline
post #3 of 9 Old 10-05-2010, 03:35 PM - Thread Starter
Skakruk's Avatar
Originally Posted by TuenMuner View Post
In before the lock!
Skakruk is offline
post #4 of 9 Old 10-05-2010, 04:19 PM
TuenMuner's Avatar
Originally Posted by Skakruk View Post
http://www.avsforum.com/avs-vb/showt...ghlight=yamaha
I won.
BD - 242
HD - 7
post #5 of 9 Old 10-05-2010, 05:25 PM - Thread Starter
Skakruk's Avatar
Oh, it was written wrong.
Not much of a thread though. So my question still remains, why is everyone ignoring this unit?
Skakruk is offline
post #6 of 9 Old 10-05-2010, 06:37 PM
rokki's Avatar
I have a Yamaha BD-S1065 which apart from being a bit slow to load gives an awesome picture and sound. But also seems ignored as well. I have tried searching through the iPhone app for the official thread but it doesn't seem to find one.
rokki is offline
post #7 of 9 Old 02-02-2011, 04:17 AM
ziggy02's Avatar
Hello,
can anyone help to make working external HDD connection through USB with this player? I'd like to play.mkv archives from it.
thanks.
ziggy02 is offline
post #8 of 9 Old 03-15-2012, 01:59 PM
Sennaista's Avatar
Originally Posted by ziggy02 View Post
Hello,
thanks.
I'm having a go at this too so any further information would help.
Although it is possible to connect an external HDD to this player, the HDD has to be formatted to FAT32 standard, otherwise the player will not be able to access it. That leads to a major problem; the maximum file size supported by FAT32 is equal to 4Gb. That might be plenty for lower resolutions but a BD rip or other HD content is likely to be larger than that. One way to get around that is to break the file into separate splits using, for example, mkvtoolnix. This is as far as I've got to. I copy the splits on a USB memory stick and play them using the player. The only problem is I can't get the full HD stuff to display correctly. The quality is degraded and the footage pixelate quite badly. I have a hunch that is caused by my slow memory stick.
Any further help would be appreciated.
Sennaista is offline
post #9 of 9 Old 06-02-2012, 05:00 AM
Bryceo's Avatar
Love myn :-) just Gourgues crisp picture and sound
Bryceo is offline
Reply Blu-ray Players
Yamaha Blu Ray Player Bd S667 , Sony Bdp S570 3d Blu Ray Disc Player , Panasonic Dmp Bd85k Wifi Enabled Blu Ray Disc Player Black
Gear in this thread - S570 by PriceGrabber.com
