Sony NSZ-GT1 with GOOGLE TV - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #631 of 732 Old 01-31-2012, 09:00 PM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
Originally Posted by j_lm08 View Post
So last night I was watching a Qriocity movie (Real Steal) and then I got this pop up telling me that that I had a network error and if I wanted to retry or cancel, I hit retry and nothing was happening. At the same time the movie was still playing in the background. It happened like three- four times. Then it was buffering alot as well, the only thing that I had changed was disconnecting my pc from my router and using the ethernet cable for my NSZ-GT1. Which I thought would give me a BETTER conection considering it would not be running wireless anymore. Does anyone have any ideas. Please it would be great.
You have a lot of un-mentioned factors here.
Is your ethernet terminated correctly?
Is the ethernet by a crazy amount of interference (power lines, plasma, etc)
Did you try another ethernet port on router?
Was your ISP having the problme? Busy time of day?
Is the GT1 old, new, does it run everything else fine?
Maybe Qriocity was whack. I didn't know anybody actually uses those services (maybe I'm cheap)
You've got some fiddling to do.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #632 of 732 Old 01-31-2012, 10:18 PM
Shink's Avatar
3D BluRay playback should be rolling out this week.
https://twitter.com/#!/GoogleTV/stat...06499572432896
Shink is offline
post #633 of 732 Old 02-01-2012, 12:27 PM
Bill C.'s Avatar
...and my GT1 just downloaded an 260MB update for 3D BD playback a few minutes ago. (It also referred to "performance enhancements," including a Chrome browser startup boost, but that was it.)
...and I need your sweet love, Latina T-Mobile girl!
Bill C. is offline
post #634 of 732 Old 02-01-2012, 01:13 PM
j_lm08's Avatar
I think qriocity is down , I get this message that it is getting a updated on the 2nd. So im just going to watch my movies via Amazon, I dont think its my connection because in running my laptop and its working smooth, that same day I was having that issue I tried watching netflix for a while and is working fine as well, the next day I tried purchasing on the Qriocity site via my pc and it was acting weird and was not letting me make any purchases. I checked my PS3 and it had an updated and was working fine. I think its just not working on the other devices, such as the NSZ-GT1 and the PCs . I'll do a follow up tomorrow if its still not working right then I'm just going to have to give them a call.
Thanks for your input though
j_lm08 is offline
post #635 of 732 Old 02-01-2012, 05:57 PM
ammomeister's Avatar
I just did mine also - 3D blu-ray playback update, awesome....thanks for the info!!!
ammomeister is offline
post #636 of 732 Old 02-01-2012, 07:31 PM
drhil's Avatar
Still waiting on my update. :|
Anyone who downloaded it yet try to see if lossless audio formats work while using 3d playback?
drhil is offline
post #637 of 732 Old 02-02-2012, 01:51 AM
psych2l's Avatar
I got the update (says firmware 3.2) but I still can't play harry potter 3D, it says it can't detect a 3D display. I called sony and they said that the update is supposed to come out incrementally in parts from google and sony respectively. Can anybody confirm that the 250 mg update brings 3D support? Thanks!
psych2l is offline
post #638 of 732 Old 02-02-2012, 07:49 AM
Cravit8's Avatar
Liked: 610
This is definitely the REAL question about the update.
During 3D playback, the PS3 now does DTS-HD, DTS-HD MA, DTS-HD HR decoding/bit stream output (or lossless audio) but PS3 cannot do Dolby TrueHD.
http://us.playstation.com/support/sy...tory/index.htm
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #639 of 732 Old 02-02-2012, 10:59 AM
ywallet's Avatar
I see this too - I am able to play a 3D video on youtube app (search yt3d) on my LG 3D TV (55LW6500) but when I play the same video via Youtube app on NSZ-GT1 it shows the 2 split images instead of rendering it in 3D like the LG app - is there a setting I am missing ?
ywallet is offline
post #640 of 732 Old 02-02-2012, 11:28 AM
Shink's Avatar
It sounds like your tv is not properly interpreting his as a 3D image.
Shink is offline
post #641 of 732 Old 02-02-2012, 12:01 PM
psych2l's Avatar
Well I was just wondering if anyone can confirm that they can play any 3D Blu-ray disc after they received the update to 3.2
psych2l is offline
post #642 of 732 Old 02-02-2012, 12:39 PM
ywallet's Avatar
Yes, but I am not sure if this is a issue with TV settings or NSZ-GT1 settings, the latter seems more likely to me since TV is playing 3D correctly with native Youtube app on TV.
I wasn't able to play 1 - I got the "Jonas Brothers : the 3D concert experience" blu-ray from local library but do not see it rendering the 3D. I will try with another 3D rental from family video and update here.
ywallet is offline
post #643 of 732 Old 02-02-2012, 01:49 PM
Shink's Avatar
I have two 3D Blu-Rays I'll test with as soon as I get the update and report back.
Shink is offline
post #644 of 732 Old 02-02-2012, 04:55 PM
drhil's Avatar
Didn't work for me either. Tried with 6 movies.
drhil is offline
post #645 of 732 Old 02-02-2012, 06:02 PM
ywallet's Avatar
I can now see youtube 3D videos correctly (search yt3d on youtube to play some) - this confirms that the player now DOES support 3D video playback.
Running to Family Video to rent a good 3D movie to test the disc player.
ywallet is offline
post #646 of 732 Old 02-02-2012, 07:02 PM
psych2l's Avatar
Do you mean playing stereoscopic youtube videos? (side by side) I was able to view 3d from the youtube app previously like that, I just had to turn the side by side 3d option on my LG 47lw6500 to make it work. Now if only the damn blu ray would work grrr
Edit: I may have been thinking of the native youtube app on the tv itself because doing yt3d on that app gives a better 3D image without having to manually set it to display 3D. Can you elaborate on how you got the youtube app on googleTV to work properly with 3D?
psych2l is offline
post #647 of 732 Old 02-02-2012, 09:27 PM
ywallet's Avatar
For youtube app I intially was seeing the side by side version. Today I realized I need to update picture setting for each input so I set the input to Google TV and then updated the picture settings under expert 1 to match the recommended settings for LW6500 (look here -> http://www.avsforum.com/avs-vb/showt...4#post21054884 ) .. viola, youtube was now showing 3D. Just note the TV did not automatically detect the 3D signal so I had to press the 3D button on remote and select the 2nd option after 2D -> 3D.
I also got the Yogi Bear 3D movie from family video (not great reviews but they have very few available & I just need it for the test) and its showing beautiful 3D !
ywallet is offline
post #648 of 732 Old 02-02-2012, 10:02 PM
psych2l's Avatar
Intriguing, I'm using standard but I'll try those settings as well on expert. Can I ask if you used any special input labels for your HMDI to google tv? I'm using Game to minimize input lag but maybe that's affecting the 3D?
psych2l is offline
post #649 of 732 Old 02-02-2012, 10:14 PM
ywallet's Avatar
I have connected GTV to HDMI 1 on my LW6500.
ywallet is offline
post #650 of 732 Old 02-02-2012, 10:23 PM
psych2l's Avatar
Blarg I must be missing a setting somewhere because I still get spit screen even on expert lol
EDIT: I changed the setting from expert to cinema and now it works, hope this helps others with an LG LW6500 model
EDIT 2: You can use any video profile you want, but you have to use cinema in the audio profile under the quick menu settings, gotta love DRM lol
psych2l is offline
post #651 of 732 Old 02-03-2012, 11:42 AM
mr_jbloggs's Avatar
Excellent! I've had the NSZ-GT1 sitting unopened after purchasing it for $75, but was going to sell it as it did not support 3D. I will now keep it and set it up with my 82" Mitsubishi 3D tv.
mr_jbloggs is offline
post #652 of 732 Old 02-03-2012, 12:20 PM
Had the same intent to sell this unit since I got it free as part of the promo last year to buy the NX720 TV. But now its more useful than my other regular BD player and with the added 3D playback functionality....hell yeah its a keeper!
post #653 of 732 Old 02-03-2012, 02:15 PM
Shink's Avatar
Just bought a Pioneer VSX-1021-K receiver from Newegg for $300 to replace my HDMI 1.3 receiver that doesn't support 3D. I held off as I wasn't sold on 3D since ESPN3D isn't super great or anything, but now that this player has it I tried out Cars 2 and was convinced. If 3D is an option for a movie going forward, it's a no brainer.
Any good place to rent 3D blu rays?
Shink is offline
post #654 of 732 Old 02-03-2012, 10:44 PM
Greg T's Avatar
I just purchased one of these units a few weeks ago and so far I love it. For some reason I can't get the unit to decode DTS-MA and TruHD and pass PCM audio to my Denon 3806 PCM only receiver. I've had a PS3, Dune and Panasonic Bluray player hooked to this unit and they all seemed to decode DTS-MA and TruHD as PCM just fine. When I hit info on the NSZ-GT1, it displays the audio as DD 5.1 or DTS 5.1. My plan was for this to be my bluray player, but if I can't get it to decode next gen audio, it's a no go. I do get PCM when I play a movie that has a PCM track like 300, but when I switch to the TrueHD track it quickly switches it to DD from TrueHD. I see the TrueHD for about a second.
I have updated to the newest version and it didn't resolve my issue. Has anyone else experienced this issue?
the unit is set to mix audio under setting.
Greg T is offline
post #655 of 732 Old 02-04-2012, 12:45 PM
drhil's Avatar
There are setting in the "main" settings sections for disc audio. You have to turn off re-encoding/mixing of other sounds. Can't remember the exact setting but I noticed this when I brought my unit downstairs to test 3d. After some setting tweaks it passed dts-ma HD.
drhil is offline
post #656 of 732 Old 02-04-2012, 10:33 PM
ywallet's Avatar
Thanks for the tip pysch2l !
ywallet is offline
post #657 of 732 Old 02-05-2012, 11:45 AM
Cravit8's Avatar
Liked: 610
Does anyone have an idea if Amazon Instant Video will ever have a standalone app?
Watching it through the browser is...not so enticing.
Also, anybody have a link to instructions on how to move apps to more preferable positions around the main screen and the app page?
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #658 of 732 Old 02-08-2012, 11:28 PM
Shink's Avatar
I'm having the same problem - mine won't play back 3D when connected via my new Pioneer VSX-1021, but is fine when going direct to the TV. Anyone have any suggestions? I've already tried swapping HDMI cables.
Shink is offline
post #659 of 732 Old 02-09-2012, 07:08 AM
drhill's Avatar
Quoted: 28 Post(s)
Liked: 24
Shink, you should complain to Sony. I'd suggest email and posting in their forums (https://forum.sel.sony.com/viewforum.php?f=79). I posted on their about my unit not working with 3d. I assumed it was a receiver thing but didn't bother to try without a receiver in the chain. I plugged my sony gtv player into the same hdmi plug my Samsung 3d blu ray player uses (successfully) so if that didn't work it is on their end.
drhill is offline
post #660 of 732 Old 02-12-2012, 10:27 AM
RawisTheGameHhH's Avatar
I am really considering picking one of these up; however I do have DirecTV and I keep seeing it only integrates with Dish Network. Is the only issue that this will not display the dvr recordings via a search? If that is all; that certainly is not a deal breaker for me. Anything else that doesn't work the DTV??? I see its about $200 on Amazon; is there somewhere else you would recommend to purchase this?
RawisTheGameHhH is offline
Reply Blu-ray Players
Sony Nsz Gt1 Wi Fi Enabled Blu Ray Disc Player , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi , Sony Bdp S570 3d Blu Ray Disc Player , Sony Bdp S470 3d Blu Ray Disc Player , Sony Bdp S370 Blu Ray Disc Player
