Sony NSZ-GT1 with GOOGLE TV - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #721 of 732 Old 08-21-2012, 12:02 PM
drhill's Avatar
Quoted: 28 Post(s)
Liked: 24
The one I received last week just said "general system stability". I haven't noticed any difference.
drhill is offline
post #722 of 732 Old 09-12-2012, 12:00 PM
Phineas's Avatar
Anyone know if it is possible to have the Google Music app playing music while I am watching TV (ie. running the "TV app") on this device? For example, if I want to watch, say, a football game but have tunes playing from Google music. It works fine in the background for other functions but for obvious reasons, the music shuts off when I switch to TV viewing. I was hoping there was some way to do this.
Phineas is offline
post #723 of 732 Old 09-25-2012, 12:09 PM
dt325's Avatar
I have been searching for an answer for this for awhile and havent had any luck so I decided to make this post.
Can I control a Denon receiver from the remote itself... without using IR blasters. All I want to do is be able to adjust the volume, which I can do just fine on my Samsung TV, but everything I see/read states I need to use the IR blaster for an AVR. I think I am stuck here but wanted to make sure no one knew of a workaround (denon volume control is the same code as sansui TVs for example) or if there was something I was missing. Thanks in advance
dt325 is offline
post #724 of 732 Old 08-10-2013, 09:51 PM
Dawn Marie's Avatar
I'm having the same problem with reboots. Did you ever get it to stop?
Dawn Marie is offline
post #725 of 732 Old 11-19-2013, 09:52 AM
byrontho's Avatar
Hello All,
  I recently switched from DirectTV to basic cable and now my Sony nsz-gt1 Blue Ray Google device will NOT be recognized as an input to the TV.   I would just like to use the Blue Ray player to watch movies for now until we get ATT U-verse in a few months. The TV inputs allows for 5 inputs of all kinds (DVD1, DVD2, Camcorder3, AVR, etc..).   The Sony unit has 1 HDMI output and 1 HDMI input.  The TV only has 1 HDMI interface that works fine with other devices such PS3.   The Sony is NOT recognized by the TV.  I tried switching the HDMI cables to no avail. I reboot the device as well STILL not recognized by TV.  Please help.
Byron
byrontho is offline
post #726 of 732 Old 11-21-2013, 05:08 PM
Bill C.'s Avatar
Apart from making sure the HDMI cable isn't plugged into the HDMI input port on the back of the thing (it happens), if you've swapped out the cable and other devices are working just fine with both cables on the same set, then that's pretty much everything. You can probably try unplugging the GT1 from power entirely for about a minute or so, but if you're still not getting a picture at that point that probably wraps it up for that thing...
...and I need your sweet love, Latina T-Mobile girl!
Bill C. is offline
post #727 of 732 Old 11-22-2013, 05:54 AM
izzy900's Avatar
Quoted: 28 Post(s)
Originally Posted by byrontho View Post
Hello All,
Byron
Some TV's are proprietary and are finicky about what HDMI cable they will accept...eek.gif Also while you had Direct TV did you connect to the NSZ-GT1? If so you may want to call ATT U-Verse for support as their cable box needs to connect to the INPUT on the back of the NSZ and the output HDMI on the NSZ to your TV. You can usually hit home key on remote even if you do not have cable box on and you will be able to see the home shortcut screen...wink.gif Make sure that on back of NSZ output HDMI is connected to TV and input HDMI to cable box....wink.gif
http://esupport.sony.com/US/p/model-home.pl?mdl=NSZGT1&template_id=1&region_id=1&tab=tutorials#/tutorialsTab
izzy900 is offline
post #728 of 732 Old 05-31-2014, 07:44 AM
cmkunisch's Avatar
My unit is down. No power. The power brick has power. The unit does not. Any suggestions? Sony offered a replacement --- for $500!!!!!!
cmkunisch is offline
post #729 of 732 Old 05-31-2014, 09:34 AM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
Wow, you called Sony about that?
Their Playstation 3 (a better piece of tech) can be purchased for $200.
I'd give some suggestions, including troubleshooting where the power failure is and how bad the problem is, but that's a chicken-n-egg issue. If you knew how to do the troubleshooting I recommend, you'd already know what troubleshooting to do.
Sell the remote on ebay and save up for another BD player.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #730 of 732 Old 11-15-2014, 10:41 AM
phidelt40's Avatar
I must say although it has MANY continual issues, I am still very satisfied with what this product is. I scooped it for under $125 over 2 years ago before I had a tv that was anywhere near modern. However, I feel it is time for something a little more practical for browsing the internet and using some of the apps (thuuz sports is frickin sweet btw esp if you're a sports fanatic). I groomed the thread casually to no avail, but is it possible to pair the backlit mouse pad remote from the gs8 to the gt1?
phidelt40 is offline
post #731 of 732 Old 11-15-2014, 06:39 PM
izzy900's Avatar
Quoted: 28 Post(s)
Wink
I got my GT1 on Ebay without the remote for a good price. Instead of getting the original remote for mine, I got a Logitech Mini Controller that connects to my system wirelessly through a mini usb connector. I would imagine a GT8 controller is compatible, and if it is a bluetooth device you just need to pair it with the GT1.
phidelt40 likes this.
izzy900 is offline
post #732 of 732 Old 11-17-2014, 11:48 AM
phidelt40's Avatar
Thanks for the tip. I will certainly look at the Logitech option. I may just buy the Bravia Stick and use my ps3 for blu ray playback in the living room. I could then move the GT1 into my bedroom because god only knows every upgrade to the living room is an upgrade to the bedroom!
Reply Blu-ray Players
Sony Nsz Gt1 Wi Fi Enabled Blu Ray Disc Player , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi , Sony Bdp S570 3d Blu Ray Disc Player , Sony Bdp S470 3d Blu Ray Disc Player , Sony Bdp S370 Blu Ray Disc Player
