The Official Sharp BD-HP24U Owner's Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 05-02-2011, 07:55 PM - Thread Starter
SinistrV6's Avatar
I don't have an answer for you other than to call Sharp Customer Service. They were very helpful both times I called.
I'm sure you've already thought of this, but your connection is to a "known good" internet connection, yes?
Richard Gautier
"If you always do what you've always done, you'll always get what you always got."
SinistrV6 is offline
post #32 of 38 Old 07-13-2011, 07:29 PM
Keiser62's Avatar
I originally posted this separately but thought it might get more attention as part of this thread.
Wife bought me the BD-HP24U(A) from Best Buy for fathers day. Just hooked it up tonight to a small Insignia NS-LTDVD19. The picture quality is great with an HDMI cable but the volume is poor.
At first I hooked it up with the included composite cables and was greeted with sub-par video and even worse volume. Both DVD and Blu-Ray had to be cranked to full volume on the TV to hear it at normal levels.
I think to myself maybe the HDMI cable will help out. It did help to a degree but did not completely fix the problem. Here is a comparison just using our ears for audio comparison. Each figure represents what it takes to hear it at the same volume.
Motorola DVR HDMI - 20%
BD-HP24U(A) Composite - 100%
BD-HP24U(A) HDMI - 75%
So my question would be is the signal from the BD-HP24U(A) not as good as the DVR or is there something that needs to be altered in the BD-HP24U(A) to boost the volume.
Note: The reason I unplugged the HDMI from the DVR is that the TV only has one input. I will be purchasing a HDMI switch and 2 more cables to get by this problem. Also the only thing attached to the TV while testing was the BD-HP24U(A) itself.
Any help will be greatly appreciated.
Keiser62 is offline
post #33 of 38 Old 07-30-2011, 11:57 AM
wlchase's Avatar
That is, does the BD-HP24U do Vudu. Vudu's website says the BD-HP24 does, but doesn't list the 24U.
TIA!
Bill
wlchase is offline
post #34 of 38 Old 09-14-2011, 11:22 AM
av addiction's Avatar
This Thread is more than 46 days old, just wondering anyone still follows?
There is firmware update for BD-HP24U model is online ready for download.
Version HA10092201 Date: 11/18/2010
Hopefully with this update will fix all the problems.
I don't any problem with this model, but I updated anyway, the updated goes smooth and easy to do, just follow instruction
Good luck
av addiction is offline
post #35 of 38 Old 01-23-2013, 04:20 PM
sunpacy's Avatar
For some reason the DVD menu player no the disc menu the actual player menu run vertical images down to up in Black and White. Like if is set on PAL or something
How I fix this? is a code to press in the remote that will switch to NTSC? the disc play okay but once I take the disc out I can't see the NETFLIX menu or any set up menus on the machine
sunpacy is offline
post #36 of 38 Old 06-03-2013, 05:35 PM
DonTBarnes's Avatar
Deleted
DonTBarnes is offline
post #37 of 38 Old 10-03-2013, 01:09 PM
Linz 7's Avatar
Yep, happens to me about every 4 movies from Redbox. I always just go back and get a different disc and usually it works.
But right this moment Iron Man 3 is giving me fits....I'm on the 3rd disc.  Still holding on mandarin shield pattern.
Linz 7 is offline
post #38 of 38 Old 12-03-2013, 10:04 PM
rpaesani's Avatar
Hello, I have a BD-HP24U(A) sharp model and my remote control only works to control the TV, the controls for the blu ray does not work. I can not watch the movies and I'm really desperate. Anyone know how to make the remote control work?
rpaesani is offline
Reply Blu-ray Players
Iron Man 2 Single Disc Edition Blu Ray , Sharp Bd Hp24u Blu Ray Disc Player
