Vizio VBR120 Owner's thread. All questions and comments go here. - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-2010, 08:00 PM - Thread Starter
captain12pk's Avatar
THe main menu will load normally, but whenI select any other feature other than a watching a disk movie, the screen goes black. Netflix,Vudu, Pandora, Flickr,..doesn't matter. They all have black screen. I have only had it a month, but this has just started. Is there an issue with the player? Has anyone else had this problem as well? The Panora will play the music I can hear it. When I return to main menu screen it comes back on.
captain12pk is offline
Old 05-13-2011, 10:05 PM
gramps2one's Avatar
Is it possible to connect my Vizio blu-ray (vbr120) to the internet by connecting it to my laptop and use the laptop's wireless connection? The vbr120 doesn't have wireless and it's kinda far from my router.
gramps2one is offline
Old 05-13-2011, 11:27 PM
amb7247's Avatar
not usre how performance will be but you could by holding control key and click on both your local area connection and wireless connection where you see your network adapters and bridge your connection. Then plug a crossover cable from your laptop ethernet to the player and try it.
Xbox Live: ShadyFusion23
PSN: Nukleard1sa5t0r
amb7247 is offline
Old 05-26-2011, 07:20 PM
MPNASCAR24's Avatar
Quoted: 38 Post(s)
Liked: 30
I recently purchased the Vizio VBR120 blu-ray player & a couple of times when i try turning it on none of the buttons on the actual player & the remote respond so i unplug it for one minute & it works like normal. Has this happened to anyone else because i looked at the troubleshooting guide in the quick start guide & it says a safety device may have activated. Is that what's happening with my player or is something wrong with it.
MPNASCAR24 is offline
Old 05-26-2011, 09:29 PM
dbldare's Avatar
Mine did the same thing when I first got it and I had to use the remote to turn it on. Come to think of it I haven't used the power button on the unit in a while due to my Harmony remote. I do remember having to hold the power button down for a few seconds to turn it on, though.
There is an update for the player available. So if you haven't already downloaded it you should do so. Maybe that will help you out?.?.?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
Old 05-27-2011, 03:35 PM
MPNASCAR24's Avatar
Quoted: 38 Post(s)
Liked: 30
dbl
I installed the updates for my player this morning & i haven't had any problems with my player since. I think the updates helped.
Old 08-29-2011, 09:51 AM
MPNASCAR24's Avatar
Quoted: 38 Post(s)
Liked: 30
Last Week I installed software updates for my Vizio VBR120 Blu-ray player & ever since the tv won't accept 1080P on HDMI 1 & 2 (Rear Input) but HDMI 3 (Side Input) will. I tested the player with my DVR's HDMI cable & all the HDMI inputs accepted 1080P. Do i need a new HDMI cable or is the problem something else?
Old 12-21-2011, 06:32 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
I started a thread, not knowing this one existed. Wts, anyone want to explain the video settings, like all of them LOL...
Explain away
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
Old 12-21-2011, 06:58 PM
MPNASCAR24's Avatar
Quoted: 38 Post(s)
Liked: 30
What do you want to know about the video settings? Here's a link to the owners manual. It should help. http://70.168.148.201/documents/down...ual%20Rev1.pdf
Old 08-18-2012, 08:56 PM
Margaret2012's Avatar
Rented a blu-ray movie (hunger games) and it would play say checking for updated so i try to update it and get server error 11000404. Of course this happens 30 min after Vizio is closed. Anyone know how to fix this?
Margaret2012 is offline
Old 07-02-2013, 09:10 PM
PSzalapski's Avatar
Anyone know where to get the firmware update or a list of them? I'm trying to figure out if my VBR120A has the latest firmware. It reports it as VBR120A_3_3_035_VBR_36_01 , with a date of Dec 02, 2011. Is there a newer version?
PSzalapski is offline
Old 11-28-2014, 09:00 AM
MPNASCAR24's Avatar
Quoted: 38 Post(s)
Liked: 30
Does anybody know if picture cd's are supposed to work in my blu-ray player because the other day my sister wanted to show me her sonogram pictures which were burned onto a picture cd so i put it in my blu ray player & after it read the disk the disk tray automatically opened instead of showing the pictures. I tried loading the disk 2 more times but it did the same thing so i had to look at the cd on my computer. I know i can look at pictures on a USB Device but why wouldn't the picture cd work? When my sister got home she put the disk into her DVD Player which is not vizio & it worked so could the format of the disk or pictures be incompatible with this Vizio Blu-Ray Player. Any help will be greatly appreciated.
Vizio , Vizio Inc , Vizio Vbr120 Blu Ray Player With Internet Apps
