blu-ray player in 24p sync loss in menus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-08-2010, 09:33 AM - Thread Starter
Cham313's Avatar
When I put my Blu-ray player in 1080p24 mode (when source material is present), when I begin playing a blu-ray, the material alternates several times between 24p sources and 60p sources. For instance, the FBI warning might be in 24p, then a studio logo in 60p, and then a studio disclaimer back to 20p. Each time my Blu-ray (Panasonic BD30) player encounters the different type of encoding, it has to change mode, causing my projector to lose sync and momentarily put up "No HDMI signal". With newer discs it is a very irritating flash-fest of digital encode artifacts lasting a couple of minutes.
Does anyone know if newer Blu-ray players handle this better than the BD30? Also I'm assuming that the loss of sync isn't putting a strain on my projector. Should I be concerned?
Cham313 is offline
post #2 of 8 Old 11-08-2010, 09:48 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2709 Post(s)
Liked: 1936
These are HDMI handshakes and I suspect are inevitable when the source changes frame rate or resolution. They are indeed irritating and sometimes hard to diagnose because everyone's display chain can handle it differently.
Concern: I don't know.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3 of 8 Old 11-08-2010, 10:13 AM
chs4000's Avatar
They are indeed inevitable as far as I'm aware. The only solution would be to turn off 24p. Not something I'd do, personally. I'd rather have 24p enabled . . . unfortunately, my Samsung BD-C6900 forces me to re-enable it almost every time I turn on the player. I suspect during its bootup, it doesn't properly detect that my equipment is 24p capable.
Ahhhh, HDMI handshake, how I love thee. I'd like to find the guy who invented this . . . and shake his hand.
chs4000 is offline
post #4 of 8 Old 11-08-2010, 02:01 PM - Thread Starter
Cham313's Avatar
Are there Blu-ray players that will convert 1080p60 to 1080p24? I wouldn't care if trailers and warnings had some unnatural judder as a result.
Cham313 is offline
post #5 of 8 Old 11-08-2010, 02:20 PM
wmcclain's Avatar
Liked: 1936
No can do. (There may be some special circumstances, but it is not the common case).
-Bill
post #6 of 8 Old 11-08-2010, 02:52 PM
rdgrimes's Avatar
Quoted: 2011 Post(s)
Liked: 1342
It wouldn't matter, since any change in the *source* resolution is what triggers the HDMI handshake.
rdgrimes is offline
post #7 of 8 Old 11-08-2010, 06:32 PM
Kilian.ca's Avatar
Liked: 37
There's no 1080p60 on Blu-ray Disc itself, but the player can output 1080p60.
There's no HDMI handshake inside a BDP so any internal frame-rate and resolution conversion isn't seen by the interface as such - it all happens in the video chip before reaching HDMI. Setting BDP to output 1080p60 in all cases (which all players can do, as suggested in post #3) might result in a smoother transition because the display no longer deals with the resolution change. Still it takes a brief moment to do that internally in the BDP and the display might be susceptible to this brief interruption. Even if you use component video without HDMI, there is still a brief transition.
I have the Panny DMP30 and although the player changes resolution my Pioneer Kuro never displays a "No HDMI signal" during the brief transition, only a brief blank screen lasting less than a second. The Kuro or the Edge VP has never had long re-sync issues with any of my four BDPs. So it's logical to conclude that the player is not all to blame but rather how the display responds and re-syncs.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #8 of 8 Old 11-08-2010, 06:53 PM - Thread Starter
Cham313's Avatar
Thanks for the info. My projector (JVC HD250) syncs quickly to the new timing (under one second per transition, and only on some of them briefly, for a small fraction of a second, displaying the No HDMI signal), but what I find annoying is the sheer quantity of transitions (at least on some Blu-rays) when starting up. Some seem to do this about 30 times. Others, on the other hand (Criterion disks for example) are quite clean in startup in comparison.
Cham313 is offline
Reply Blu-ray Players
