OPPO BDP-93 Pre-release Thread - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 1692 Old 11-09-2010, 02:29 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
MODS WANT IT, SO MODS GET IT:
Official OPPO BDP-93 Owner's Thread
Neuromancer is offline
post #2 of 1692 Old 11-09-2010, 02:32 PM
Brian-HD's Avatar
Quoted: 44 Post(s)
Liked: 41
Finally! DAC?
Brian-HD is offline
post #3 of 1692 Old 11-09-2010, 02:38 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
Don't know if we can fully talk about the internals, but what the hell: Cirrus Logic CS4382 (same as the BDP-83).
post #4 of 1692 Old 11-09-2010, 02:41 PM
Brian-HD's Avatar
Quoted: 44 Post(s)
Liked: 41
Originally Posted by neuromancer View Post
don't know if we can fully talk about the internals, but what the hell: Cirrus logic cs4382 (same as the bdp-83).
O! Any info on how ordering will be?
Brian-HD is offline
post #5 of 1692 Old 11-09-2010, 02:45 PM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
I just sold my bdp-80 yesterday for this. I hoped my timing was good.
I cant access the manual its a dead link?
Murilo is offline
post #6 of 1692 Old 11-09-2010, 02:48 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
The inclusion of FLAC and WAV should shut some of you people up. I remember this being requested endlessly during the BDP-83's reign.
post #7 of 1692 Old 11-09-2010, 02:50 PM
michdys's Avatar
Not dead, but probably: not born yet
michdys is offline
post #8 of 1692 Old 11-09-2010, 02:51 PM
michdys's Avatar
Well, I'm so grateful Oppo listened
michdys is offline
post #9 of 1692 Old 11-09-2010, 02:52 PM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
What has my life come to when i look forward to reading through a manual?
Murilo is offline
post #10 of 1692 Old 11-09-2010, 02:52 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
The only thing missing that I can see is support for .iso files and I think that shouldn't surprise anyone. Just about everything else on the 83 wish list is there except the high-end audio which will be on the 95.
JazzGuyy is online now
post #11 of 1692 Old 11-09-2010, 03:26 PM
dazzerxxx's Avatar
Does this include support for HD res material ?
D
dazzerxxx is offline
post #12 of 1692 Old 11-09-2010, 03:32 PM
wrinklefree's Avatar
wrinklefree is offline
post #13 of 1692 Old 11-09-2010, 03:33 PM
Stew4msu's Avatar
eSATA Port - The BDP-93 features an eSATA port on its back panel. Consumers can take advantage of this fast eSATA connection to play contents from their hard disks full of audio, video and photo files. Most commercially available hard disks pre-formatted with NTFS, FAT32 and FAT file systems are supported, and file sizes larger than 4GB can be played back.
Dual USB Ports - Two USB 2.0 high speed ports are provided, one on the front panel and one on the back. Users can enjoy high definition video, high resolution photos and music directly from their USB drives.
So, will this be able to replace the WDTV that I'm currently using to play archived videos? Will it work with a USB hub? I currently have three 1TV drives connected to my WDTV.
Stew4msu is offline
post #14 of 1692 Old 11-09-2010, 03:34 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
I've tested 24-bit/192KHz FLAC and WAV files on the player with success. Multi-Channel FLAC as well.
post #15 of 1692 Old 11-09-2010, 03:41 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
WDTV may still support some codecs or features that the BDP-93 won't, but this player is much more robust in terms of what it can and can't play compared to the BDP-83 which had very minimal user created media support.
This works with thumbdrives, but have not tried this with externals as I only have one massive 2TB external.
post #16 of 1692 Old 11-09-2010, 03:44 PM
Stew4msu's Avatar
That'll work.
Stew4msu is offline
post #17 of 1692 Old 11-09-2010, 03:45 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Neither does it support .tar, .rar, or .zip files. It is extremely easy using existing free software (such as 7-zip) to extract an .iso file into a separate folder on your USB key or hard drive.
BobearQSI is offline
post #18 of 1692 Old 11-09-2010, 03:47 PM
wfgds's Avatar
for DVD, the up-converted picture quality bridges the visual gap from your current DVD library to Blu-ray discs; for network streaming and user-encoded content at a variety of formats and quality, the BDP-93 offers enhancement options including video noise reduction, compression artifact reduction, intelligent color, contrast, detail and edge enhancements.
So network streamed video won't be up-converted by the Marvell video processor? The specs only mention DVD Up-conversion.
wfgds
wfgds is offline
post #19 of 1692 Old 11-09-2010, 03:49 PM
dazzerxxx's Avatar
D
post #20 of 1692 Old 11-09-2010, 03:57 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
As long as you are using HDMI 1 (the output the Marvell is connected to) and are using a resolution other than SOURCE DIRECT, then the Marvell chipset will always be doing some kind of processing to the signal, which include scaling.
So say you have the player set to 1080p then Netflix will be 1080p out, despite the input being 480p to 720p.
You can also apply image enhancers such as Noise Reduction for all sources, including streaming services.
post #21 of 1692 Old 11-09-2010, 04:05 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
No one ever asked for the .tar, .rar, etc capabilities. The ability to directly play video or audio on an .iso file was requested quite a few times. That's why I mentioned it.
post #22 of 1692 Old 11-09-2010, 04:07 PM
voigtskins's Avatar
I have sold my BDP-83 and all signed up for the 93!!!! Thanks NERO for another GREAT thread as I loved your last work.Hope player comes by end of month as I am ready for another OPPO BEST PLAYER.
EAP {First Fifty} OPPO BDP-83 BLU-RAY, Oppo BDP-93 First Batch Issued, Oppo BDP-103 First Batch Issued
voigtskins is offline
post #23 of 1692 Old 11-09-2010, 04:09 PM - Thread Starter
Quoted: 81 Post(s)
Liked: 287
And was denied every single time due to issues related to "piracy". MTK does not want to support it, and OPPO really can't force them.
post #24 of 1692 Old 11-09-2010, 04:10 PM
mpedris's Avatar
Does anyone have any links to reviews of this player, if there are any?
"Some folks hate the whites who hate the blacks
who hate the Klan
Most of us hate anything that
we don't understand"
- Kris Kristofferson.
mpedris is offline
post #25 of 1692 Old 11-09-2010, 04:11 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
thanks neuromancer.
thanks for releasing the official info about the player. looking very good.
Jacob
Jacob305 is offline
post #26 of 1692 Old 11-09-2010, 04:14 PM
abaazov's Avatar
it says netflix available in US only. i really hope that changes by launch date.
amnon
abaazov is offline
post #27 of 1692 Old 11-09-2010, 04:16 PM
BobearQSI's Avatar
Quoted: 39 Post(s)
Liked: 35
Yes, I understand that, I'm simply mentioning it because many people don't seem to understand that .iso is very much like .zip in that it simply stores multipe files/folders into a single file, and can easily be un-packed.
post #28 of 1692 Old 11-09-2010, 04:17 PM
wfgds's Avatar
Great, thanks. I will definitely be purchasing one now.
wfgds
wfgds is offline
post #29 of 1692 Old 11-09-2010, 04:22 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2683 Post(s)
Liked: 1916
No, too soon.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #30 of 1692 Old 11-09-2010, 04:55 PM
bigyela's Avatar
pandora?
bigyela is offline
Closed Thread Blu-ray Players
