Official OPPO BDP-93 Owner's Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
post #901 of 28165 Old 11-28-2010, 07:21 PM
ckenisell's Avatar
Quoted: 110 Post(s)
Liked: 62
Originally Posted by Bob Pariseau View Post
OK, is ANYBODY here still having front panel button problems that are not just due to having to wait for the player to complete booting up?
--Bob
I was one of the originals that had this issue. I can confirm that waiting until the display says "Open" before pressing the off button with the tray open, will result in the tray closing and the 93 turning off.
Chet
ckenisell is offline
post #902 of 28165 Old 11-28-2010, 07:24 PM
kinglm's Avatar
Quoted: 151 Post(s)
Liked: 135
Originally Posted by Perpendicular View Post
OPPO is aware but it might not be that high on their to-do list.
Let's hope it moves up on the to do list. I say that of course not knowing what else is on the to do list. . Considering one of the core features is streaming Netflix. Adding a step like reestablishing the Internet connection first is not so good.
kinglm is offline
post #903 of 28165 Old 11-28-2010, 07:42 PM
fritowrdo's Avatar
Agreed.
I am putting ordering Netflix on hold until this is solved but I already showed my wife the DLNA TVersity server so she knows how to do this.
I will have to type up a 'How to' how to turn on WiFi until this one is solved for my wife.
fritowrdo is offline
post #904 of 28165 Old 11-28-2010, 07:43 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2272 Post(s)
Liked: 2854
Originally Posted by CRRobert View Post
Just have the component on the TV, but was thinking I could use the HD Fury to convert the hdmi before going into the TV.
If it works then that could be a good way to go. But HDCP copy protection is intended to prevent conversion from HDMI to Component at HD resolutions. So a converter box like this is in tricky area as regards licensing.
Keep in mind that starting in January, the industry is going to make it progressively harder to get HD output for Blu-Ray on Component, just as they already do for SD-DVD.
It is already the case that any studio could author a Blu-Ray disc with the flag set that will prohibit any Blu-Ray player from putting out HD video on Component while playing that disc. There are very few discs that do this right now. You will see more such discs next year.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #905 of 28165 Old 11-28-2010, 08:04 PM
Quoted: 184 Post(s)
Liked: 83
You could always leave your player on 24/7 if it's a serious problem for you.
Perpendicular is offline
post #906 of 28165 Old 11-28-2010, 08:10 PM
Read the FAQ!
Liked: 2854
Well I'm not at all sure what's working differently for you guys, but my 93 re-connects just fine to my Apple Airport wifi across power cycles. All by itself.
--Bob
post #907 of 28165 Old 11-28-2010, 08:16 PM
stevenjw's Avatar
Quoted: 309 Post(s)
Liked: 325
Did they tell you that or is that your guess? Seems like having a consistent wireless ethernet connection would be important during pre-release so that we receive any firmware updates. I would rank this as more important that media player support fixes.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one."
My HT gear
stevenjw is online now
post #908 of 28165 Old 11-28-2010, 08:20 PM
Quoted: 184 Post(s)
Liked: 83
I'm in the know.
The discussion pertains to the Wi-Fi dongle via the USB port.
At least, that was my understanding.
post #909 of 28165 Old 11-28-2010, 08:24 PM
ElwayLite's Avatar
Originally Posted by JohnAV View Post
And why wouldn't you have a constant WiFi connection?
Its not that it needs to be constant, but the player needs to be smart enough to reconnect upon power on, automatically. I have to reconnect every time, and its quite annoying.
ElwayLite is offline
post #910 of 28165 Old 11-28-2010, 08:24 PM
chs4000's Avatar
Fyi folks,
Source Direct does not work for Netflix. I get 1080p sent to my display, of course I'm setting SD mode prior to starting the Netflix app, and my Reon-VX was set to pass through.
chs4000 is offline
post #911 of 28165 Old 11-28-2010, 08:26 PM
Read the FAQ!
Liked: 2854
Originally Posted by chs4000 View Post
Fyi folks,
Which HDMI output are you using? Source Direct worked for me on HDMI 1 last time I checked (which was a while back).
--Bob
post #912 of 28165 Old 11-28-2010, 08:27 PM
ElwayLite's Avatar
Can I set NR to 2, so itll work on Nflix, and be confident it will have no video effect on source direct blu-rays?
post #913 of 28165 Old 11-28-2010, 08:28 PM
Read the FAQ!
Liked: 2854
Source Direct bypasses the processing in the QDEO so, yes.
--Bob
post #914 of 28165 Old 11-28-2010, 08:32 PM
ElwayLite's Avatar
Thanks Bob, thats what I thought, but wanted to be sure.
Watched the Last Airbender tonight, and all went well. Got the 93 setup how I want, except for NR 2, and was very happy with the PQ. The Disc did not even come out very warm, after 1hr 40 mins. Also checked out Nflix earlier.
post #915 of 28165 Old 11-28-2010, 08:33 PM
fritowrdo's Avatar
--Bob
I assume you are running a different firmware than the rest of us?
This problem just sounds like the daemon/service is not turning on upon power on with the firmware we have.
Everything else is working fine now for me EXCEPT this. Almost there......
post #916 of 28165 Old 11-28-2010, 08:36 PM
Read the FAQ!
Liked: 2854
Well if that's the case, then you have something to look forward to!
Yes, I'm running different firmware, but I had no problem with this back when I was running the 1108 firmware either. I know, because it's one of the things I check.
On the other hand, I'm also running different hardware (sorry, can't discuss details), and that may be relevant.
--Bob
post #917 of 28165 Old 11-28-2010, 08:36 PM
fritowrdo's Avatar
I'm in the know.
The tech guys at Oppo have been busy tonight as I have had a slew of emails from them on stuff to try.
But what you state here makes sense to what they are having me try and do.
post #918 of 28165 Old 11-28-2010, 08:40 PM
ElwayLite's Avatar
I went ahead and emailed them about my reconnection issues.
post #919 of 28165 Old 11-28-2010, 08:42 PM
fritowrdo's Avatar
--Bob
Not a problem on the NDA.
I just tried the front USB port and no go either.
Oh well, I will probably bag it for the night but give Oppo kudos for replying on a Sunday night.
post #920 of 28165 Old 11-28-2010, 08:47 PM
Gates's Avatar
Quoted: 181 Post(s)
Liked: 72
Originally Posted by Toe View Post
Sorry to hear that, but thanks for the confirmation.
Sigh. What a hobby, eh? Anyway, glad to hear the puzzle is solved.
--Bob
Thanks guys. I'll get it fixed ASAP. I was getting a second Paradigm Sub 12 this week too, and now I'll have to wait to try it out until the amp is fixed
JVC DLA-400RS, Elunevision 112" Reference screen, Marantz AV8802a Pre/Pro, Samsung UBD-K8500 UHD player, NAD M25 amp, Anthem PVA-4, 4x Paradigm CI Elite E80-R ceiling speakers, Paradigm Studio 60 v5, Paradigm Studio 20 v5, Paradigm Prestige 15B, Paradigm Studio CC-690 v5, Paradigm Studio Sub12 X 2, Oppo bdp-93, Richard Gray 1200c Custom power conditioner.
Gates is offline
post #921 of 28165 Old 11-28-2010, 08:56 PM
Read the FAQ!
Liked: 2854
I've got something for you to try if the Oppo folks haven't already had you try it:
Wait for the player to completely power up. Then unplug and replug the wifi dongle -- leaving it unplugged for at least a couple seconds. The idea is to have it show up afresh as an available USB device.
Does that procedure result in a wifi connection? If so, does it seem to work every time?
--Bob
post #922 of 28165 Old 11-28-2010, 08:58 PM
ExToker's Avatar
Well I'm no techie, but it seems that if all is required is to manually choose to use the last setting, it wouldnt be that tough of a fix to tell the machine do it automatically upon boot through an update.
It wouldnt affect those having no problem and would fix the issue for those that are.
One could certainly call this an obvious oversight. I know Oppo for being strong advocates of hard wiring, considering the main purpose of connectivity has been the updates and BD Live in the past.
However, with the addition of streaming, billed as a prominent feature, it seems it should have been foreseen out of the gate.
ExToker is offline
post #923 of 28165 Old 11-28-2010, 09:01 PM
FilmoFreddy's Avatar
Got mine yesterday. After setup I played an SACD (No "Ticks"-YIPPIE!) But, about 5 minutes in to the 1st disc I tried the front panel controls & they were totally locked. Remote bricked as well. Finally got it to turn off (via remote) after pressing power for about 30 seconds. Powered down & after restart I've had no issues. Its Played every BD & SACD flawlessly. Streaming NetFlix (Wireless) from DSL & all is well EXCEPT..I too have to re-initialize the 93 at power up. THAT's a PAIN!....OPPO does have something very special here though & I'm sooooo glad to have mine.
FilmoFreddy is offline
post #924 of 28165 Old 11-28-2010, 09:02 PM
Read the FAQ!
Liked: 2854
Relax guys. Oppo isn't about to ignore a concern like this.
--Bob
post #925 of 28165 Old 11-28-2010, 09:08 PM
Read the FAQ!
Liked: 2854
I'm sorry you had a player crash, but just so you know you don't have to hold the power button for it to shut down when it is in that state. Just press power once and wait, and after a delay it will shut down the crashed player.
It wouldn't hurt to email Oppo with the details on that first disc. If you can, please include the bar code number or "ISBN" number from the disc packaging as sometimes discs come out in different versions bearing the same name. And if you recall any other details of just what you were doing when the player crashed then include those as well.
Even if you can't get the crash to repeat yourself, it may be possible for Oppo to draw a connection between your instance and any other reports they might get.
--Bob
post #926 of 28165 Old 11-28-2010, 09:16 PM
fritowrdo's Avatar
--Bob
No go on that.
I tried one time for 15 seconds out and plug it in, no go till manually turn it on.
I tried one for several minutes out and plug it in, no go till manually turn it on.
Can I buy it chocolate or flowers to make it work?
post #927 of 28165 Old 11-28-2010, 09:19 PM
Read the FAQ!
Liked: 2854
In my experience, problems like this respond better to a chalk pentagram. Sacrifices are also widely recommended. But messy.
--Bob
post #928 of 28165 Old 11-28-2010, 09:24 PM
Read the FAQ!
Liked: 2854
OK, if you are still with me, I've got one more thing to try. Grab an empty USB stick and put it in the front port with the wifi dongle in the rear port. (FAT or NTFS formatted on the USB drive.)
Now power up. Since you have the USB stick in the front port it should be found during power up, resulting in the Home menu being displayed shortly after it reports "No Disc" on the normal, Oppo splash screen.
If you get to the Home menu then we know your USB stuff is powering up properly.
Now does THAT get you an automatic wifi connection?
--Bob
post #929 of 28165 Old 11-28-2010, 09:28 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
anyone else with the 120 refresh HDTVs and also using netflix? I get a bit of a studder when watching netflix. I have to turn off the digital motion (philips HDTV). some HDTVs have a different word for it. I have to use the digital motion when playing blurays and dvds. I have discussed this with oppo. I wanted to know if anyone else is having the problem. thanks.
Jacob
Jacob305 is offline
post #930 of 28165 Old 11-28-2010, 09:29 PM
neuronbob's Avatar
--Bob
Mine, too. Once I got the connection up, every time I've power-cycled, the wireless network seems just fine and I can use Netflix.
neuronbob is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
