Official OPPO BDP-93 Owner's Thread - Page 424 - AVS Forum | Home Theater Discussions And Reviews
 611Likes
post #12691 of 28348 Old 07-11-2011, 10:35 AM
rich3fan's Avatar
Quoted: 20 Post(s)
I'm pretty sure I know the answer to this question, but I'll ask anyway... I'd like the player to, when I power it on go right to the "Home" screen after it finishes booting up. Is there a way to program it to do that?
If not, that's something I'd like to see in the future. Afterall, this machine is more than a BD player, so automating the process of getting into say, the Netflix app quicker would be beneficial, IMO.
Keep calm and drive a Camaro
rich3fan is offline
post #12692 of 28348 Old 07-11-2011, 10:43 AM - Thread Starter
Neuromancer's Avatar
Quoted: 96 Post(s)
Liked: 370
Pretty much the only real solution is to leave a USB thumbdrive connected to the player that has a file on it (movie, music, or picture). This will force the player to the HOME menu as long as there is no disc in the player.
Neuromancer is offline
post #12693 of 28348 Old 07-11-2011, 11:10 AM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
Very cool trick, and I'd say it's worth adding to the FAQ. Certainly beats the heck out of programming a 20-odd second startup delay into your remote for Netflix...
CatBus is offline
post #12694 of 28348 Old 07-11-2011, 11:15 AM
rich3fan's Avatar
Quoted: 20 Post(s)
Which is exactly what I was getting at with my question. Thanks for that CatBus.
(Note to self: Try a 25 second delay instead of 10 seconds for the 880 remote)
rich3fan is offline
post #12695 of 28348 Old 07-11-2011, 11:20 AM
scolumbo's Avatar
Liked: 36
Please make your request directly with Oppo as others of us have done. The bottom line, after a long string of e-mails, is they are at least considering it. The more they hear from customers, the better the chance of it happening.
This is especially aggravating when discs (DVD and BD) are left in the player. At least there is a workaround for disc autoplay, mentioned by Bob I think, that if you press the Home button as it's powering up, it stops the disc from loading and goes to the Home screen.
Still, a better solution is to give us a user option to default directly to the Home Screen on power up to those of us that use the Oppo for much more than playing discs.
scolumbo is offline
post #12696 of 28348 Old 07-11-2011, 11:21 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3780 Post(s)
Liked: 4922
Even an EMPTY USB stick in the front or rear port will cause the player to boot up into Home menu (assuming no disc left in the tray).
If you DO have a disc in the tray (and a USB stick plugged in), just power up the player using the Tray Open button on the front panel or remote and you'll get the same result.
By the way, with the Public Beta firmware, the Home button on the remote will toggle between Home menu and the Oppo splash screen. This is useful if you have a disc in the tray and want to start it by pressing the Play button -- perhaps having entered a track number for a music disc. The Play button won't work on Home menu (since the player doesn't know which media you want to play) but assumes the disc when on the splash screen.
If you are in a sub-menu or app entered from Home menu, press Home once to get back to Home menu, and then press Home again to get to that splash screen.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #12697 of 28348 Old 07-11-2011, 11:26 AM
rdgrimes's Avatar
Quoted: 2480 Post(s)
Liked: 1785
Some folks may recall that the BDP-93 was originally programmed to boot to the Home menu, but this was changed due to complaints from a majority of users. It's nice for those who want it but a nuisance for those who just want to play a disc. A user-selectable option for this function is the best solution.
But it's not like a single press of the "Home" button on the remote is much of an imposition.
rdgrimes is online now
post #12698 of 28348 Old 07-11-2011, 11:28 AM
Jacob305's Avatar
Quoted: 85 Post(s)
Liked: 48
--Bob
I notice that over the weekend after the update.
Jacob
Jacob305 is offline
post #12699 of 28348 Old 07-11-2011, 11:35 AM - Thread Starter
Quoted: 96 Post(s)
Liked: 370
Even without going back to the OPPO logo closing the tray with a standard disc (CD, DVD, Blu-ray) will load the program properly as long as you were in the base directory of the HOME menu.
post #12700 of 28348 Old 07-11-2011, 11:39 AM
scolumbo's Avatar
Liked: 36
Maybe my CRS is acting up, but I've had the 93 since launch last November and I can't recall that it ever defaulted to the Home screen. Are you sure that wasn't in a beta version that we (non-beta testers) weren't privy to?
Anyway, I totally agree a user option is the best solution.
scolumbo is offline
post #12701 of 28348 Old 07-11-2011, 11:56 AM - Thread Starter
Quoted: 96 Post(s)
Liked: 370
The BDP-83 had a firmware in December 2009 which defaulted to the HOME screen. The BDP-9x would only go to the Home screen when you have no disc in the player and there is attached storage (eSATA or USB).
post #12702 of 28348 Old 07-11-2011, 12:07 PM
scolumbo's Avatar
Liked: 36
Ahh, the 83. But then, I think you would agree the 93 does so much more, esp. with streaming services.
scolumbo is offline
post #12703 of 28348 Old 07-11-2011, 12:46 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3399 Post(s)
Liked: 2652
I've adapted a section from the BDP-83 FAQ, added the Home menu tricks, and added it to the BDP-93 FAQ: Are there any hidden features?
I've also created a new topic: What audio/video codecs are NOT supported? These are codecs in my test suite that are not currently supported. Some are obsolete and probably not very important. As the note says, if you have others that are not working, let me know via the comment link.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #12704 of 28348 Old 07-11-2011, 12:48 PM
rich3fan's Avatar
Quoted: 20 Post(s)
...But it's not like a single press of the "Home" button on the remote is much of an imposition.
No, it's not much of an imposition, but as I eluded to, I have a Harmony 880 remote that, without programming in a long inter-key delay, my "Start NetFlix" activity doesn't work. CatBus suggested using a +20 second delay, which means that each step to start the "Watch NetFlix" activity will take 20 or more seconds each, which isn't really acceptable to me. And frankly, my Oppo remote doesn't seem to have near the signal strength that my Harmony remote has, and I also seem to notice that some buttons stick when pressed, so I'm tranisitioning all of the 93's remote's duties over to the 880.
Neuromancer, Bob, thanks for your input and suggestions, and I'll send my request politely to Oppo support.
Meanwhile, I think I'll stop at the local Electronics store and buy my first ever thumbdrive.
rich3fan is offline
post #12705 of 28348 Old 07-11-2011, 01:02 PM - Thread Starter
Quoted: 96 Post(s)
Liked: 370
You should use SOURCE rather than HOME. Netflix is always at the top most selection of SOURCE, so you just need to give it the SOURCE command then ENTER.
post #12706 of 28348 Old 07-11-2011, 01:22 PM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
Please keep the hits coming, Neuromancer! This is great info for programmable remotes.
CatBus is offline
post #12707 of 28348 Old 07-11-2011, 02:25 PM
zacster's Avatar
I've been considering the Harmony 700 or One, and I was wondering if you could program it to go straight to Netflix on the Oppo, or also to my network with Twonky My concern is that I always have to wait for the Oppo to connect to my router before it can find these things. It feels like it take an eternity, but it is probably on the order of 10-20 seconds. I don't know much about the Harmony remotes and their capabilities, but they seem to be the only decent option out there at the moment.
zacster is offline
post #12708 of 28348 Old 07-11-2011, 02:26 PM
Kincaid's Avatar
Originally Posted by Mp0wer View Post
Has Oppo supported HD audio in a MKV file in any of these releases?
Currently, no, and the last I knew Oppo's response has remained the same as always which is that they are looking into it but it may never be supported.
Frankly, now that ISO support has been added for DVD and Blu-Ray I can see absolutely no reason for HD audio to not be supported in an a Matroska container. Initially I could have seen part of the reasoning being that there might be a connection to people not necessarily owning the content they are trying to watch although that is a bunch of hooey, IMHO. Matroska is simply a great media container and a lot of people use it for backing up their media material to a HDD. Nonetheless, now that we do have ISO support I am really hoping we finally get support for HD audio in Matroska.
Kincaid is offline
post #12709 of 28348 Old 07-11-2011, 03:12 PM
rich3fan's Avatar
Quoted: 20 Post(s)
-Bill
..and the BDP-93 FAQ is now a desktop icon on my home computer. Big thumbs up Bill!
rich3fan is offline
post #12710 of 28348 Old 07-11-2011, 03:32 PM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
It's actually over 20 seconds before the BDP-93 will accept the IR codes for starting Netflix. FWIW for my Netflix activity, I also insert a STOP command just before the HOME command (soon to be changed to the SOURCE command!) just in case someone left a disc in the player, to prevent autoplay.
CatBus is offline
post #12711 of 28348 Old 07-11-2011, 03:48 PM
scolumbo's Avatar
Liked: 36
When there are very long delays, I find that a large percentage of the time, I end up missing the command at the time it is needed to execute it, along with any other remaining commands. Then, I need the Help button which goes through the sequence again, adding more delay.
For me it's easier to just go through the power on sequence, and then execute another activity after I know the Oppo and other equipment has powered up and is ready for another command. In other words, two button presses instead of one. If there are activities without long delays, such as playing a disc, this additional step isn't necessary.
I have the Harmony One and it seems to send a stronger signal than the Oppo remote so that is also an advantage.
edit: it seems one of the reasons the delay is so long to get to the Home screen or accept other commands is because the Oppo has to first check to see if there is a disc in the player for disc autoplay. Now if one could have the option to disable disc autoplay...
scolumbo is offline
post #12712 of 28348 Old 07-11-2011, 06:44 PM
cocoon's Avatar
Interesting point.
Umm can you point to an easy tutorial for those of us who aren't experts on how to convert mkv with flac audio to a lossless audio format that the bdp-93 can use?
cocoon is offline
post #12713 of 28348 Old 07-11-2011, 06:57 PM
SeriousHorse's Avatar
Originally Posted by cocoon View Post
Interesting point.
I'm not sure you can easily convert FLAC audio to another lossless format (such as DTS). You can, however, easily convert it to AC3 using something like the Aften AC3 utility or eac3to. MeGUI is another excellent tool.
The first step is to extract the FLAC file (easiest way to do this is with MKVExtract). Second step is to convert it. Third step is to remux the AC3 audio with the video into an .mkv file, using MKVMerge GUI. Try videohelp.com/tools for everything you need (including "how to" guides).
It would obviously be much easier if the 93 supported FLAC in an .mkv container, but until it does you really shouldn't use FLAC audio in your rips.
SeriousHorse is offline
post #12714 of 28348 Old 07-11-2011, 07:50 PM
cocoon's Avatar
Originally Posted by SeriousHorse View Post
I'm not sure you can easily convert FLAC audio to another lossless format (such as DTS). You can, however, easily convert it to AC3 using something like the Aften AC3 utility or eac3to. MeGUI is another excellent tool..
DTS is not a lossless format except DTS-MA. I have used the popcorn hour listed tool to convert mkv with flac to 640k dolby. We need a similar tool to convert those mkv to mts with lpcm, dts-ma, or dolby true-hd. I don't care which as long as the audio quality is lossless.
cocoon is offline
post #12715 of 28348 Old 07-11-2011, 08:01 PM
wmcclain's Avatar
Liked: 2652
Can't you extract the FLAC audio to a .flac file and play that? (mkvextract)
You can also decode FLAC to lossless PCM as a WAV file. It will be about twice the size, but plays both locally and over DLNA.
Mkvmerge will accept WAV input and make mkv or mka containers with PCM contents. I suspect you can do multiple inputs for gapless playback.
It's been a while since I tested this. I'll check it again tomorrow, using FLAC files of different attributes.
I suspect FLAC within mkv is coming, but don't know when.
-Bill
post #12716 of 28348 Old 07-11-2011, 08:18 PM
Sorry, I did mean DTS-MA. But to do what you want to do, you'll need commercial software such as ArcSoft Total Media Theatre or Sonic Cinemaster Audio Decoder. In any case, it ain't easy:-)
post #12717 of 28348 Old 07-12-2011, 04:18 AM
jikdoc's Avatar
you can install trial versions and the codecs will remain and can be used to convert dtsma tracks to wav which can then be placed into mkv. mkv also affords you the ability to add srt subtitles which can be streamed over dlna
jikdoc is offline
post #12718 of 28348 Old 07-12-2011, 10:34 AM
Kincaid's Avatar
Interesting point.
Honestly, I don't ever convert from FLAC to anything so I really can't offer much. With respect to Matroska containers there is no support for DTS-MA and TrueHD. You also want to avoid plain DTS because the last I knew it still can make the BDP-93 choke. No idea why they can't solve that problem but it does seriously annoy me. HD audio is one thing but actually being unable to get DTS audio to work without choking the player is... well... plain sad.
When I need to convert HD audio from an original Blu-Ray disc I add Clown_BD into my workflow.
Kincaid is offline
post #12719 of 28348 Old 07-12-2011, 10:46 AM
ccotenj's Avatar
Liked: 101
moderators/bob/neuro/et.al....
would it be possible to start another "bdp-93" thread that would be dedicated to people who want to discuss containers, software, etc.?
i'm not saying that stuff isn't important to people... but it's really throwing a drag onto this thread...
just a suggestion...
- chris
ccotenj is offline
post #12720 of 28348 Old 07-12-2011, 10:49 AM
AtDaBeach's Avatar
Id second that.
AtDaBeach is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
