Official OPPO BDP-93 Owner's Thread - Page 682 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
post #20431 of 28165 Old 04-21-2012, 11:24 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2532 Post(s)
Liked: 3191
Re the YouTube "Leanback" service:
Fun with 3rd party services.
It seems Google changed the interface between the server and the YouTube app. Apparently, unexpectedly.
As such, it's not a "bug" from Google's point of view. That is, Google are not going to back off the change to what their server is now sending out. And the current YouTube app on the OPPO can't handle that. The app for the OPPO will need to be adjusted to match. That's in process.
As with all the other 3rd party Internet service apps, the code for the YouTube app comes from the service provider -- in this case Google. I've no idea why they changed how their server works before getting an updated app in place.
I can't give any ETA on the updated app (which will have to come as an OPPO firmware update). But it's a fair assumption I think that it will be in the next Public Beta firmware release.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #20432 of 28165 Old 04-21-2012, 11:26 PM
Read the FAQ!
Liked: 3191
Originally Posted by dmusoke View Post
Thanks Bob:
That did the trick! My DNS 1 and 2 server addresses were out of whack with my the ones on my laptop. I had to use manual servers on my router when i decided to use OpenDNS's faster servers and Oppo didn't "know" about it.
Cool! Glad it worked.
--Bob
post #20433 of 28165 Old 04-22-2012, 12:48 AM
dmusoke's Avatar
Quoted: 275 Post(s)
Liked: 145
Originally Posted by rakosnicek View Post
Hmm, Oppo's (old?) offices in Silicon Valley were about 5 minutes from Google HQ ...
Though 5 minutes away from each other, i wouldn't be suprised if it took weeks to get approvals from management from both sides to work on problems together
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #20434 of 28165 Old 04-22-2012, 09:40 AM
lasitter's Avatar
I have a DLNA server (WD) and the OPPO can play content from its folders, except that it "burps" in between chapter or title changes. I forget which.
That's one reason I've not upgraded to the latest firmware, as I assume the OPPO will play cleanly and support working menus from the same content when in the .ISO format. The only thing I have to figure out is how to use it.
The WD live has no problem seeing / playing a .ISO on its local store, but the same file is invisible to the OPPO.
I'm guessing this is because it will only play that content from a local USB or SATA drive.
So I'd like to find out exactly how this works so I can create the right folder names for .ISO content (and ripped BD content while I'm at it).
I know this has been discussed in this thread frequently, but if anyone could point me to several posts and do a particularly good job of explaining everything .ISO for this player, it'd be a great help.
lasitter is offline
post #20435 of 28165 Old 04-22-2012, 11:14 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2780 Post(s)
Liked: 2001
ISO never worked over DLNA; as far as we know it's not possible.
For ISO on local storage, there is nothing to know. Just copy the file onto storage and attach it to the player. And don't update firmware.
If ISO support is important to you, I suggest finding a different device for that.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20436 of 28165 Old 04-22-2012, 11:18 AM
rdgrimes's Avatar
Quoted: 2071 Post(s)
Liked: 1394
ISO is not supported via DNLA. Your DNLA server may be allowing you to access them, but it's just opening the ISO and serving the individual video files. That's the cause of the pauses between files.
ISO was only supported via storage attached to the player, and the player will treat them exactly as it would the physical disc. DVD-V, DVD-A and BD are supported and will be accessible via the "Movies" icon on your home screen.
BDMV folders are still supported at this time, so there's another option for BD besides ripping to ISO. A BDMV folder will also be treated the same as the physical disc.
rdgrimes is online now
post #20437 of 28165 Old 04-22-2012, 01:16 PM
lasitter's Avatar
So you just name the folder "BDMV" on the local attached storage, or does the name matter?
lasitter is offline
post #20438 of 28165 Old 04-22-2012, 01:41 PM
wmcclain's Avatar
Liked: 2001
BDMV is the name used by BR video; I'm pretty sure you can't name it anything else. You can nest it inside other folders, named by titles, for example.
If you renamed it you would be able to navigate into the folder and play the individual m2ts files, but that's not the same as playing a copy of the disc.
-Bill
post #20439 of 28165 Old 04-22-2012, 02:01 PM
rdgrimes's Avatar
Liked: 1394
"BDMV" is the folder in the root of every BD disc that contains the movie. Same as "VIDEO_TS" on a DVD.
-Bill
This is incorrect, Bill. As long as the internal file structure is unchanged you can re-name a BDMV folder to anything you like. It still acts like a disc. At least for now.
post #20440 of 28165 Old 04-22-2012, 05:13 PM
EDH63's Avatar
Question: Would I benefit by enabling the QTC? If I applied a deep color mode to HDMI 1, will that give me something I'd be happy with?
EDH63 is offline
post #20441 of 28165 Old 04-22-2012, 08:57 PM
grxz's Avatar
No matter what I try, I cannot establish a wifi connection with a non-broadcasted SSID. As soon as I set the SSID to broadcast, the connection works flawlessly but when going back to non-broadcast I again have no connection. All my other devices (phone, printer, tablet, receiver) work without issue except the Oppo. When trying to set up a manual connection on non-broadcast I receive the message:
No matched SSID. Please re-enter SSID.
I have followed the suggestions at http://www.avsforum.com/avs-vb/showt...3#post21317653 but with no luck. What else can I attempt?
grxz is offline
post #20442 of 28165 Old 04-22-2012, 11:58 PM
hansel2000's Avatar
Are there any rumors for PGS-subtitle support in MKV-files?
hansel2000 is offline
post #20443 of 28165 Old 04-23-2012, 05:11 AM
wmcclain's Avatar
Liked: 2001
Welcome to AVSForum.
There wouldn't be any rumors; those who know wouldn't say. OPPO hardly ever talks about futures.
I've requested PGS/SUP support in MKV, along with hidef VOBSUB.
VOBSUB works now in MKV with standard definition video, but not when sized to hidef. SRT subtitles work now.
PGS/SUP work in m2ts files.
-Bill
post #20444 of 28165 Old 04-23-2012, 07:14 AM
hjones's Avatar
For anyone purchasing an Oppo 93 from Amazon in the last 30 days or so: what version of the firmware was on your unit? I have one coming tomorrow and wonder what are the chances of it coming with the March 2012 firmware. Looks like Oppo direct is shipping with the latest one. Thanks.
hjones is offline
post #20445 of 28165 Old 04-23-2012, 10:31 AM
CJayB's Avatar
Quoted: 45 Post(s)
Liked: 43
I received my Oppo 93 from Amazon on March 20th and it came with the Sept 2011 firmware. Because I don't care about the .iso capability I've already upgraded to the March firmware.
CJayB is offline
post #20446 of 28165 Old 04-23-2012, 10:49 AM
Jeremy Anderson's Avatar
Quoted: 353 Post(s)
Liked: 661
April 10th for me and September firmware. Already updated to March firmware without issues.
"Never believe any quote you read on the internet." - Abraham Lincoln
Jeremy Anderson is online now
post #20447 of 28165 Old 04-23-2012, 10:54 AM
ozar's Avatar
Liked: 152
Mine came from Amazon (shipped from Arizona) on April 18th and had the BDP9x-61-1219 firmware.
oz
ozar is offline
post #20448 of 28165 Old 04-23-2012, 01:30 PM
hjones's Avatar
Thanks for the info. Looks like mine is coming from Indiana. Will know tomorrow. Would like to have ISO support, but I also have a Dune in case I get the later firmware.
hjones is offline
post #20449 of 28165 Old 04-23-2012, 04:07 PM
jlin's Avatar
That's exactly the same for me too for last week's order!
I'm all set!
jlin is offline
post #20450 of 28165 Old 04-23-2012, 04:13 PM
jlin's Avatar
Does the current firmware only disable the ISO support for BluRay.. or does it disable ISO reading for regular DVD's?
jlin is offline
post #20451 of 28165 Old 04-23-2012, 04:44 PM
scolumbo's Avatar
Liked: 36
It disables all ISO playback (Blu-Ray, DVD-V, and DVD-A).
scolumbo is offline
post #20452 of 28165 Old 04-23-2012, 04:45 PM
Read the FAQ!
Liked: 3191
^^ Both are disabled. The ISO file format is no longer recognized regardless of what's in it. The BDMV folder structure still works for Blu-ray but not for SD-DVD or music discs.
--Bob
post #20453 of 28165 Old 04-23-2012, 06:25 PM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 319
Release date: April 23, 2012
Category: Latest Official Release
Main Version: BDP9x-66-0413
Loader Version: CN0900
Sub Version: MCU93-09-0218 (BDP-93), MCU95-08-0218 (BDP-95)
Release Notes
1. Updated the Youtube Leanback application to the latest revision which allows for users to log into their YouTube account(s) and upgrades the general user interface (UI).
2. Improved the support for "Disc Unbound" feature and other similar features observed on some newly released Blu-ray television and movie series, mainly FOX releases. This feature allows the audience to select the episode located on another disc, and once the correct disc is loaded, the player will directly jump to the pre-selected episode and start to play. Sample titles include "Sons of Anarchy, Season 3 and 4 (BD, 2011)", "The Killing, Season 1 (BD, 2011)", "Chuck, Season 4 (BD, 2011)", "Archer, Season 2 (BD, 2011)" and "Game of Thrones, Season 1 (BD, 2012)".
3. The "Blockbuster on Demand" icon has been removed from the home menu. Blockbuster stopped this service to most consumer electronic devices after March 31, 2012.
4. Improved general disc compatibility based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
Neuromancer is offline
post #20454 of 28165 Old 04-23-2012, 06:46 PM
JohnAV's Avatar
Quoted: 309 Post(s)
Liked: 467
Be sure to check out the updated YouTube Leanback interface, as the earlier interface was quite limited.
Be aware typing a sting of a characters in search pauses while YouTube tries to match content.
Oppo Beta Group
JohnAV is offline
post #20455 of 28165 Old 04-23-2012, 07:08 PM
Read the FAQ!
Liked: 3191
Before anyone asks, Blockbuster cut off service to all the manufacturers -- effective March 31. They made the unilateral decision to go exclusive with Samsung.
Frankly, it's no great loss.
But it does point out that even the major manufacturers get stuff like this only at the whim of the 3rd party service providers.
--Bob
post #20456 of 28165 Old 04-23-2012, 07:55 PM
EDH63's Avatar
--Bob
Bob, you seem to be one of the many go-to guys around here, so I'd like to direct an earlier question to you. Please read below...
EDH63 is offline
post #20457 of 28165 Old 04-23-2012, 08:00 PM
Read the FAQ!
Liked: 3191
^ Uh, can I buy a vowel? What's a "QTC" and where/how would you be enabling it?
--Bob
post #20458 of 28165 Old 04-23-2012, 08:04 PM
EDH63's Avatar
I'm sorry, I thought you were familiar with the 93 settings. The QTC is the Qdeo True Color setting. It's applied to HDMI1 when a deep color mode is enabled. I can go into the settings and enable that deep color mode on HDMI1, but I wanted to see if it's even necessary. I thought maybe you had some first hand insight into this.
EDH63 is offline
post #20459 of 28165 Old 04-23-2012, 08:11 PM
Coyote Waits
htwaits's Avatar
Quoted: 927 Post(s)
Liked: 2046
htwaits is offline
post #20460 of 28165 Old 04-23-2012, 08:15 PM
scolumbo's Avatar
Liked: 36
Originally Posted by edh63 View Post
i'm sorry, i thought you were familiar with the 93 settings.
Originally Posted by htwaits View Post
roflmao
scolumbo is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
