Official OPPO BDP-93 Owner's Thread - Page 686 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
Old 04-28-2012, 06:38 AM
streamerlover's Avatar
Originally Posted by rworne View Post
i have my oppo ios application going into beta. I'm looking for volunteers to help test it out.
To do so, you need to have the following:
1. Oppo 83 or higher bd player with rs-232 port
2. A mac or pc nearby with a free serial port, or an ethernet to rs-232 adapter.
3. One of those usb/serial based region free dongles that plugs into the back
the app works as a remote for the player and displays various data on the screen as to disc type, subtitles, what type of audio playback, elapsed time, etc. If you have a dongle, the app will "clone" your unlock key and unlock the player for you. The app itself does not function as a region-free mod.
I have a few slots open for testers, just pm me if you are interested.
cool!
streamerlover is offline
Old 04-28-2012, 12:28 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Originally Posted by DouglasCleary View Post
I like the new YouTube app but the interface is SLOW.
concurred, and the auto-searching is annoying as eff. Have to wait 30 seconds (or so it seems) between each successive char entry.
vinnie97 is offline
Old 04-28-2012, 01:43 PM
rworne's Avatar
Liked: 32
Originally Posted by streamerlover View Post
cool!
Yes! But no volunteers.
I thought there was interest in an iOS app for Oppo players, guess I was wrong.
rworne is offline
Old 04-28-2012, 01:58 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1081 Post(s)
Liked: 1038
Your requirement #3 might be a sticking point for a lot of people... Why is the external region free mod required?
gsr is offline
Old 04-28-2012, 02:09 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
agreed.
Jacob
Jacob305 is offline
Old 04-28-2012, 06:09 PM
rworne's Avatar
Liked: 32
Not really required. It is something I want to test. As long as someone has one it's fine, I just need a sample size of more than one.
The real sticking point is the nearby PC or Mac. I have free redirector software to allow this to work, we all know the Oppo cannot be controlled directly over the network.
rworne is offline
Old 04-28-2012, 08:25 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2443 Post(s)
Liked: 3073
Yes, as noted above that aspect of the User Interface for the new YouTube app definitely still needs, umm, fine tuning.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 04-28-2012, 08:58 PM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
--Bob
its true that it does need some fine tuning. its certainly an improvement over the last version.
Jacob
Jacob305 is offline
Old 04-28-2012, 09:44 PM
Bruceko's Avatar
Quoted: 29 Post(s)
Tonight I tried starting up the 93 and the red light turns blue for a couple second then back to red. After that if I push the on button it just stays red.
tried unplugging it and it goes through the same sequence.
Any ideas?
Bruceko is offline
Old 04-28-2012, 10:35 PM
Read the FAQ!
Liked: 3073
Any ideas?
Disconnect EVERYTHING from the player, including the power cord. After about a minute, re-attach JUST the power cord.
Now try powering up the player using the Tray Open button on the front panel (which will also eject the tray so that any disc in there can not start loading).
If the player does not power up normally (as evidenced by the front panel), then it likely needs service.
One other thing to try is to take the player to a different room with a different wall power circuit (i.e., not on the same circuit breaker as your normal location), just in case there's some issue with wall power at your normal location.
--Bob
Old 04-28-2012, 10:39 PM
Bruceko's Avatar
Quoted: 29 Post(s)
Thanks Bob
Unplugging everything solved the problem
Bruceko is offline
Old 04-28-2012, 10:43 PM
Read the FAQ!
Liked: 3073
Thanks Bob
Check your connections carefully, as this would suggest something is shorted or plugged into the wrong socket at one end or the other. If you are using any attached hard drives, check that their external power is functioning as otherwise they may have been trying to draw too much power from the USB socket on the OPPO.
--Bob
Old 04-29-2012, 10:35 AM
tizzy's Avatar
I have my Oppo iOS application going into beta. I'm looking for volunteers to help test it out.
1. Oppo 83 or higher BD player WITH RS-232 port
2. A Mac or PC nearby with a free serial port, or an Ethernet to RS-232 adapter.
3. One of those USB/Serial based region free dongles that plugs into the back
The app works as a remote for the player and displays various data on the screen as to disc type, subtitles, what type of audio playback, elapsed time, etc. If you have a dongle, the app will "clone" your unlock key and unlock the player for you. The app itself does not function as a region-free mod.
I have a few slots open for testers, just PM me if you are interested.
I have been informed from Oppo Support some weeks ago that they are working on an iOS app. This was connected with my inquiry about enabling Oppo players, particularly the 93, to act as DLNA renderer. They namely said: "The current hardware is not capable of reliable DLNA rendering, but we are working on control and browser apps." and, additionally, "once the app is fully finished that will one of it's functions".
This all is very exciting! I like the interface, but is this the same app Oppo is working on?
If you still need testers, I can participate (iPhone 3G and 4S, Oppo BDP-93EU (no dongles), Anthem AVM 50v, Synology 211j as music storage and DLNA server).
tizzy is offline
Old 04-29-2012, 11:17 AM
stockmonkey2000's Avatar
Liked: 29
I did a search but could not find this issue addressed but it is possible I missed it in the 20,000+ posts on this thread. I am having an issue where I originally set up my Player with the easy setup on a TV and selected the compatible mode for the HDMI audio because I wasn't sure my receiver supported 1.3. Now I have it hooked up in the theater room and I need to change to Advanced so I can pass Dolby TrueHD and DTS Master Audio. The only problem is I do not see this menu option anywhere. I looked at the manual and it said you can go through the easy setup again by resetting the factory defaults. However The manual says that the reset factory default is under the device setup menu, but I cannot find the factory reset anywhere in this menu or any other menu for that matter. Anyone else have this issue?
stockmonkey2000 is offline
Old 04-29-2012, 11:29 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2755 Post(s)
Liked: 1985
Make sure disc playback is completely stopped before running Setup. Then look under Device Setup. Note that it is a scrolling list and you may have to arrow down past the bottom.
There is an Easy Setup menu option which is less drastic than Reset Factory Default; it doesn't erase your account ids, for example.
The Setup Checklist has an outline of the Setup Menu and also notes on the difference between Advanced and Compatible settings: http://watershade.net/wmcclain/BDP-9...Checklist.html
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 04-29-2012, 12:19 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 159
Cool, I do not have a Oppo BDP-93 yet but I am interested if this is an iPad app. I have your oRemote app and use it with a Onkyo PR-SC5508P.
As in a Global Caché GC-100. I have a GC-100-12
Wendell R. Breland is online now
Old 04-29-2012, 12:37 PM
Liked: 29
-Bill
Thanks that was the issue - when I stopped the playback, the easy setup appeared in the menu.
Old 04-29-2012, 03:26 PM
Splicer010's Avatar
Liked: 39
Anyone else have an issue with Netflix movies locking the Oppo up at around the hour mark? Done it twice so far to us since the new FW was installed. Never an issue before.
Splicer010 is offline
Old 04-29-2012, 07:01 PM
Read the FAQ!
Liked: 3073
^ Blu-ray or SD-DVD? If SD-DVD it could be a problem with reading the outer edge of the disc surface due to scratches or fingerprints which are more common there than closer to the center hole. The player may not be stuck but just searching for something it can read.
--Bob
Old 04-29-2012, 08:33 PM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 318
Splicer010 is likely talking about streaming, not discs in this case. There is a similar post on the OPPO Facebook wall.
Neuromancer is offline
Old 04-30-2012, 12:45 AM
Read the FAQ!
Liked: 3073
Just to repeat, the Compatible and Advanced choices in the Easy Setup Wizard are simply two sets of factory default settings for the stuff found in the Setup menu. If you are already familiar with the settings in the Setup menu there's NO NEED to re-run the Easy Setup Wizard or Reset Factory Defaults. They don't do anything special or hidden. They just reset the collection of settings found in the Setup menu.
In your case the setting you are looking for is Setup > Audio Format Setup > HDMI Audio. Use "Bitstream" to tell the player it is OK to send things like TrueHD or DTS-HD MA to your AVR for decoding. Use LPCM to tell the OPPO to do the decoding itself and send the resulting, and completely equivalent, high bandwidth, multi-channel, LPCM instead. (The first thing your AVR does when receiving a Bitstream is to decode it into that same LPCM itself.)
If you are going to use Bitstream, then you should also set Secondary Audio OFF (unless you decide to play a disc feature -- such as PIP Commentary tracks -- that uses Secondary Audio).
--Bob
Old 04-30-2012, 01:57 AM
Joe Schwartz's Avatar
Are you talking about the 0413 firmware that just came out yesterday?
Yes Bob, I was referring to the 0413 firmware. Using that firmware, I was unable to activate my BD-93 for Netflix, even though I had successfully activated it in the past with older firmware. I called Netflix support, and they were unable to determine the problem. No matter how many times I tried to activate it, with a new activation code each time, it said that the activation code had expired.
Joe Schwartz is offline
Old 04-30-2012, 02:47 AM
Read the FAQ!
Liked: 3073
Try the following reset of the player:
1) Remove any disc. Jot down your settings in Setup.
2) Erase Persistent Storage.
3) Reset Factory Defaults. When the Easy Setup Wizard finishes, power down the player. (The Reset will also clear any current Netflix activation information.)
4) Pull the power plug for about 10 seconds. Do not skip this step.
5) Power up and re-enter your personal settings (including networking of course).
6) Power down one more time. Settings are saved during the power down cycle.
Now power up again, go into Setup > Device Setup > Firmware Information, and confirm that all 3 parts of your firmware are up to date. The expected versions are listed in the firmware history portion of the first post of this thread, or on the OPPO Support page for the player. Check the Main, Loader, and Sub/MCU versions.
Now try again to activate Netflix. If it fails again, I think you'll have to work the problem with OPPO tech support. It is possible I suppose that something in your networking (external to the player) is blocking the player from communicating with Netflix.
It is also possible that Netflix is confused and thinks you have already activated the maximum number of devices allowed against your account. But their support should have caught that when you called them. I'm presuming you were not actually streaming Netflix on other devices at the same time you tried to activate the OPPO.
--Bob
Old 04-30-2012, 05:38 AM
DouglasCleary's Avatar
--Bob
Have you heard that it is being worked on?
If they ever publish an API I know at least one person that would write apps for it - to give to Oppo not even for pay.
DouglasCleary is offline
Old 04-30-2012, 06:01 AM
Read the FAQ!
Liked: 3073
^ Sorry, Beta Testers can't talk about whatever we might learn regarding work in progress.
--Bob
Old 04-30-2012, 08:14 AM
rworne's Avatar
Liked: 32
They just need to publish their network protocol. As of now, the only way in is via the serial port and while I have a solution, it's not for everyone. Unless they do something really funny with it, the app I have will work the same serial or network once they enable Ethernet control. I do pretty much the same with my Onkyo app that can do either.
I also found out another tidbit: Apparently Oppo players share the same key for region-free playback. At least two players are sharing the same key, and I bet more do too.
rworne is offline
Old 04-30-2012, 10:08 AM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
Just ran into this last night. Goes to rebuffering but nothing ever rebuffers and you can't get out to the Home screen. You have to do a hard power-off and back on. Luckily playback resumes just fine. Also never had this issue before, and I've used streaming through a lot of firmware iterations.
CatBus is offline
Old 04-30-2012, 12:54 PM
I Integrate's Avatar
Yeah, I know your first thought might be "why compare a $1000 player to $500 player?" The answer to that is, I work for a Marantz dealer and can purchase product for 1/2 retail with their employee accommodation program. So either player would cost me $500+ shipping.
I currently have a Marantz DV6001 that I use strictly for SACD, stereo and multi-channel. I also have a PS3 that I use for Blu Ray's and Netflix streaming. I want to combine the two to clear up some space as well as get a nicer player all together.
The Marantz was my first choice, but the more I read about the Oppo the more I like them. It would have to be the BDP93, as the 95 is out of my budget.
Any input would be much appreciated, I'm pretty sure the Marantz is the answer but I don't want buyers remorse later down the road.
I Integrate is offline
Old 04-30-2012, 01:47 PM
Quoted: 288 Post(s)
Liked: 159
You may want to read the review of the Marantz UD9004 Universal Blu-ray Player and the Oppo BDP-93 at the Secrets of Home Theater site.
Old 04-30-2012, 03:41 PM
dmusoke's Avatar
Quoted: 269 Post(s)
Liked: 145
I believe the Marantz has a much better analog audio section than the 93, so if that's important to you, then get the Marantz.They have a long history of excellent analog performance. The video performance is also excellent via HDMI or Component. The Oppo93/95 performed excellent(at least on tests) on video via HDMI but poorly on component video. Again, another point of difference between the two players. Any yes, i like the all copper chassis of the Marantz for maximum EMI rejection. Probably explains the very clean audio spectral plots it displayed.
OTOH, for extra services, like all things streaming and playing various audio streaming codecs, the 93 is best for that.
So it depends on your preferences on what;s important to you...but Oppo's customer service and willingness to fix your problems or adding features via firmware updates is King!
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
