Official OPPO BDP-93 Owner's Thread - Page 693 - AVS Forum | Home Theater Discussions And Reviews
 197Likes
post #20761 of 28165 Old 05-08-2012, 10:00 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2034
Originally Posted by scrapser View Post
I'm a bit confused setting up my system. I have a Denon AVR-3312CI and a Klipsch 5.1 speaker set.
If you're using HDMI then configure your speakers in your AVR. There is no way to configure audio that's in a digital bit stream. Your receiver will convert to LPCM first thing.
htwaits is offline
post #20762 of 28165 Old 05-08-2012, 11:31 PM
rakosnicek's Avatar
Quoted: 26 Post(s)
Originally Posted by isisyodin View Post
I am thinking that 4K support will be reason to refresh the current line; I estimate that 2013 CES all major manufacturers will have at least one model including Oppo with a launch of Q3 2013. Just a guess.
That and working (bidirectional?) IP control.
None of the current players integrate into an environment where you are using your iPod/iPad/iPhone as the remote control device and controlling everything via TCP/IP. And unless I'm mistaken, that is precisely the market that Oppo sees itself selling into.
rakosnicek is offline
post #20763 of 28165 Old 05-08-2012, 11:43 PM
Philnick's Avatar
Quoted: 234 Post(s)
Liked: 102
kkpro, if your display has multiple HDMI inputs, each input can probably be calibrated independently. I assume you're running all your players' video through your AVR and then running a single HDMI cable from the AVR to the display.
Instead, connect the Oppo's first HDMI output directly to the display through one of the display's other HDMI inputs and the Oppo's second HDMI output to the AVR for sound only - unless you're running analog audio into the AVR (my preference) in which case you don't have to bother with an HDMI cable to the AVR from the Oppo.
Once you have the Oppo on its own input to the display, you can calibrate the display independently for the Oppo and for the other video sources. The only inconvenience will be having to switch inputs on the display with the display's remote when you switch between the video feeds from the Oppo and the AVR.
The Oppo has dual HDMI outputs to allow its video to bypass the AVR - not specifically for this reason but to cope with AVRs that can't pass 3D video - but you can take advantage of that capability to deal with the difference between the Oppo's and your other players' output calibrations.
In my own system, I calibrated the component input to my display that I use for my HD cable box by temporarily connecting a disk player's component output to that input and using a calibration disk to set up that input. I then put the disk player back on an HDMI input and reconnected the cable box to the component input - the colors on cable were much richer once I had calibrated the component input. This was my way to work around the failure of the cable companies to provide calibration signals! (The cable companies' "On Demand" systems would be ideal for this!)
Philnick is offline
post #20764 of 28165 Old 05-08-2012, 11:52 PM
Philnick's Avatar
Quoted: 234 Post(s)
Liked: 102
scrapser, the reason the Oppo (and other players with multichannel analog outputs) have speaker configuration sections in their setup routines is to cope with the fact that most AVRs do not apply their own speaker configuration settings to their multichannel analog inputs.
If you're using a multichannel analog hookup to the AVR and have an AVR like I just described (which is most AVRs) the players' speaker configuration is the only place you can set things up.
If you're running HDMI audio to the AVR, the players' speaker configuration settings have no effect.
Philnick is offline
post #20765 of 28165 Old 05-09-2012, 02:23 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2273 Post(s)
Liked: 2854
Originally Posted by kkpro View Post
Why would the video be any different? If I used the default settings, which is what I would use if that were my only player, then all of my other players would be off. I have 2 other Panasonics and a Toshiba HD-DVD player which all use the same brightness and contrast settings. The Oppo is the only one that is different.
I am not trying to be argumentative, I would just like to get the best out of the system. I had a Lumagen before and that is how I thought it worked. You calibrated for one source using the projectors controls and then used the Lumagen's controls for any variances in the other sources. I assumed this would be the same principle just using the Oppo's controls.
The difference in this case is that the OPPO is KNOWN to put out correct gray scale on HDMI 1 using explicit 1080p output and its default settings. The discovery that you have to alter the OPPO's Brightness and Contrast settings means that something peculiar is up. And it's worth trying to figure out what.
Evidently something odd is going on with the other players you've tried. It could be that the players themselves are putting out odd gray scale -- which would be something of a coincidence from more than one player -- or that you are using a different video data format from those players compared to what you are using from the OPPO, and the rest of your video chain (AVR and Display) are reacting differently to the two video formats.
For example, if you were using RGB from the other players and YCbCr from the OPPO, that could indicate that your AVR or Display have a quirk in the way they handle RGB input. Or if you are using Deep Color from the OPPO but not from the other players. Or if you are using 1080p/24 from the OPPO but not from the other players. These video format differences SHOULDN'T make a difference but they are likely candidates to check since there IS a difference.
It could also be that the input you are using for HDMI video from the OPPO has some setting difference compared to the inputs you are using for the other players. Presumably you copied over settings to configure the new input. Perhaps one didn't get copied correctly? Check in particularly for any sort of video "enhancement" settings in the AVR or Display such as dynamic contrast adjustment.
Now understand, the setup as you are using it now probably looks fine, and may indeed end up being the best you can do -- given what the other players are putting out, and their lack of Picture Adjustment controls.
But the discovery that you need to change the Brightness and Contrast controls in the OPPO to get a good match with a calibrated display should be a Red Flag that something is wrong in the calibration setup.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #20766 of 28165 Old 05-09-2012, 02:29 AM
Read the FAQ!
Liked: 2854
Originally Posted by ehlarson View Post
Translation: Bob is under an NDA and has seen or has a protoype.
You are thinking of the interactive holographic projector.
Oh wait, I shouldn't have said that. I really shouldn't have said that....
--Bob
post #20767 of 28165 Old 05-09-2012, 05:21 AM
scrapser's Avatar
Thank you and HTWAITS for your replies. It is most appreciated.
scrapser is offline
post #20768 of 28165 Old 05-09-2012, 08:19 AM
Klipschman70's Avatar
Hi there
Can anybody please verify whether Youtube app is still supported with 61-1219 firmware from December? I realized since the introduction of the latest firmware which supports Youtube leanback, whenever I try to start youtube, I only get Youtube splash screen ...
Harry
Klipschman70 is offline
post #20769 of 28165 Old 05-09-2012, 08:27 AM
Read the FAQ!
Liked: 2854
Originally Posted by Klipschman70 View Post
Hi there
Harry
It is not. Google changed the communication interface at the YouTube server end which invalidated the old app that was included in that 1219 firmware. The new YouTube LeanBack app is available in the current, "official" firmware, firmware 0413, which came out on April 23.
--Bob
post #20770 of 28165 Old 05-09-2012, 09:04 AM
Thanks Bob
I guess I need to update my Oppo to the latest firmware
post #20771 of 28165 Old 05-09-2012, 11:37 AM
hidefpaul's Avatar
Quoted: 124 Post(s)
Liked: 79
--Bob
LOL
Paul
5.1 Home Theatre
Pioneer 60" Kuro
Integra DHC 80.3 Pre Amp
Parasound Halo A51 5 Ch Amp
Speakers : Elac's FS-247's (L,C,R SR, SL)
Sub: Velodyne SPLR1000
hidefpaul is offline
post #20772 of 28165 Old 05-09-2012, 01:28 PM
DouglasCleary's Avatar
--Bob
Even working it isn't much better. What an awful app. Single threaded app from the 90's anyone?
Bob - do you know if Oppo coded that or if Google threw it over the wall?
DouglasCleary is offline
post #20773 of 28165 Old 05-09-2012, 03:20 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
YouTube changed the authentication for their LeanBack service, which is why OPPO had to release a new firmware to allow for the new authentication information.
Neuromancer is offline
post #20774 of 28165 Old 05-09-2012, 09:24 PM
demroyer's Avatar
Hmmm...I just got my new Oppo BDP-93 up and running last week, and I immediately updated it to the latest firmware (April 23rd). Even so, the YouTube app is barely functional - most times when I try to run it, it just sits at the splash screen. On occasion it will connect, but when it does the menus are god-awful slow.
And speaking of slow menus, the NetFlix interface is painfully slow to use, which kills me since the video quality of NetFlix on Oppo seems to be better than my myriad other NetFlix-enabled devices (TV, XBox, Roku, etc.). I presume the video looks so good due to the upscaling by the QDeo processor (I am running my video directly to the TV via HDMI1 and the audio to the receiver via HDMI2). At first I thought this slowness must be related to the wireless connection, which seems very inconsistent on the Oppo - it often says it can't connect, or the signal strength varies a good deal (even though all the other wireless devices in my home theater have a full-strength signal all the time). I switched it over to a hard-wired 100MB Ethernet cable, but still not much improvement in the NetFlix interface or with accessing YouTube.
Anyone else experiencing these types of problems? Otherwise, I'm impressed as hell by the Oppo so far...
Demian
demroyer is offline
post #20775 of 28165 Old 05-09-2012, 10:35 PM
chs4000's Avatar
I think the slow Netflix interface is just the way how it is on the Oppo BDP-93. I can't stand it, so I don't bother with it and instead use a Roku 2 XS.
chs4000 is offline
post #20776 of 28165 Old 05-10-2012, 01:19 AM
Talk2Me's Avatar
Quoted: 28 Post(s)
I don't have any problems with my 93's Netflix app. I even compared to my fat PS3. The PS3 seems a little cleaner, but I think that is because Netflix allows the PS3 to stream 1080.
Talk2Me is offline
post #20777 of 28165 Old 05-10-2012, 07:56 AM
woodsart's Avatar
Hey, I find that streaming HD Netflix extremely good-much better than my Panasonic player. Some HD movies are as good as some bluray, very impressed, just wish that I could figure out this DNLA thing, but no worries.
Rob
Also to finalize the collection of speakers, the Philharmonic 2s,..... I will be picking up my "matching center speaker" this sunday to fininally get it all together, so the oppo will be finally doing it's job properly!
woodsart is offline
post #20778 of 28165 Old 05-10-2012, 11:48 AM
I'm fine with the playback quality of the apps but moving around in them is bad. Netflix and VUDU included. I don't know if it is the remote or the apps but it is sluggish to the point that is barely usable. VERY disappointed in the 93 as far as that goes.
post #20779 of 28165 Old 05-10-2012, 11:57 AM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
are you using the remote that came with the player or using the harmony remote? I use the harmony remote. it works great.
Jacob
Jacob305 is online now
post #20780 of 28165 Old 05-10-2012, 12:08 PM
woodsart's Avatar
Yes, that is what I use as well and I agree..... a little slow, but tolerable with ethernet.
woodsart is offline
post #20781 of 28165 Old 05-10-2012, 04:21 PM
blairy's Avatar
Quoted: 51 Post(s)
Liked: 29
It's over 12 months since I've tried netflix, but back then to avoid searching or browsing via the Oppo, you could do all that on your PC, queue up what you wanted to watch and when you login via Oppo it's all there ready to go.
Is that function stil available?
blairy
blairy is offline
post #20782 of 28165 Old 05-10-2012, 05:35 PM
chs4000's Avatar
blairy
Yes, it sure is. It's the only way I'd use Netflix on my BDP-93.
chs4000 is offline
post #20783 of 28165 Old 05-10-2012, 05:36 PM
woodsart's Avatar
blairy
Beat me to the punch.....just to add..... the interface is very nicely functional too!
One ? myself, does the TV/AVR need to be DNLA ready to stream from PC?
woodsart is offline
post #20784 of 28165 Old 05-10-2012, 07:32 PM
Geezer's Avatar
Quoted: 20 Post(s)
blairy
I use a wifi tablet to search & add movies to the que while on my couch.
Geezer is offline
post #20785 of 28165 Old 05-10-2012, 07:55 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2698 Post(s)
Liked: 1925
No, not if you are using the player as a DLNA client.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #20786 of 28165 Old 05-10-2012, 09:13 PM
woodsart's Avatar
Thanks, Bill, appreciate the help. DNLA client, is there a setting on the 93 or is it default?
woodsart is offline
post #20787 of 28165 Old 05-10-2012, 09:43 PM
wmcclain's Avatar
Liked: 1925
Make sure Setup -> Network Setup -> My Network is ON (that's the default).
You access the servers via the "My Network" icon on the Home screen.
-Bill
post #20788 of 28165 Old 05-11-2012, 06:18 AM
woodsart's Avatar
-Bill
Got it, did that....the issue is that when I go to my "My Network" and click on it, while searching for a split second a window appears another split second and says loading, but nothing loads, so this is as far as I have gotten.
However, as I have researched, I have found every situation is totally different. I have contacted support several times and many suggestions were made to no avail yet. So, it appears I will have to figure this out.
Any, other info would be appreciated, but I do understand, this is too difficult to explain as each system is different.
I will continue to follow this and others hopefully I can report back soon with results.
My goal is to stream music from the PC, steaming online music programs and video in that order of importance. All of which OPPO says was possible.
But, hey, this is suppose to be fun, to research, to experiment, to buy and to enjoy our hobby!
And, of course, read, contribute and learn from these great forums!
woodsart is offline
post #20789 of 28165 Old 05-11-2012, 06:23 AM
wmcclain's Avatar
Liked: 1925
What DLNA server are you running? Does it appear in My Network?
Did you read the FAQ section starting here: What is DLNA?
-Bill
post #20790 of 28165 Old 05-11-2012, 06:41 AM
woodsart's Avatar
-Bill
Yeah, Bill, I have been reading that and frequently asked questions and a couple of other.
oShare was the first and then traversity, the techs said either would work. As of now none have shown up on my network, everything with the oppo is working as expected. The PC is a new ASUS and internet with comcast. I am sure it is a simple setting somewhere I am missing. I have changed things in WMP and a few other as well throughout the PC as recommended. It really shouldn't be that that complicated, though, I haven't looked into the AVR yet to see if that might be the culprit. But the ethernet is coming "in" the OPPO.
Thanks, Rob
woodsart is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
