Official OPPO BDP-93 Owner's Thread - Page 896 - AVS Forum | Home Theater Discussions And Reviews
 182Likes
post #26851 of 28091 Old 06-13-2014, 08:54 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1989 Post(s)
Liked: 2448
^ You may have overlooked the Repeat, Random and Shuffle playback operations, which will act within a folder for media file music playback. See the Manual.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #26852 of 28091 Old 06-13-2014, 09:08 PM
Torqdog's Avatar
Quoted: 106 Post(s)
Liked: 200
I just finished performing the FW update and listened to some 5.1 channel music and a few difficult dialog movies afterwards. A slight improvement was noticed over the settings I had entered using Bob's workaround formula. It's a heck of a lot better than before the workaround. Seems like at long last, we have some accurate speaker distance settings. Woohoo!
Torqdog is offline
post #26853 of 28091 Old 06-13-2014, 10:39 PM
Philnick's Avatar
Quoted: 224 Post(s)
Liked: 101
Lightbulb
Originally Posted by wojtekmk2 View Post
Thanks, Bill. Yeah, All Music sorts all my 10,000 songs by the number, and then alphabetically. Kind of cool, because it picks the first song from every album, sorts them alphabetically, then the second song, and so on. I like to have the music play all day long in the background, so I get a nice mix...It would have been nice to be able to do that WITHIN a folder, though, not the whole HD. For example, I have a folder named Miles Davis, and in it his discography in nested folders. It would be nice to be able to select All Music within the Miles Davis folder, just to have MD run all day long... Maybe Oppo will include such a feature in future players/firmwares.
A simple way to do this would be to create a definition file for your server that only shares the Miles Davis branch of the tree, and nothing else - All Music would then do that.
With oShare this would be trivially-easy, since its list of folders is a simple numbered list in ASCII text in its "oShare.INI" file.
Make a copy of your normal oShare.ini called Normal-oShare.ini.
Then edit your oShare.ini file to include only the path to the top Miles Davis folder and no other folders. Make a copy of that INI file and name it MilesDavis-oShare.ini.
Then going back and forth is just a matter of exiting oShare, deleting oShare.ini, copying either your MilesDavis-oShare.ini file or Normal-oShare.ini to the active name, oShare.ini, and re-starting oShare.
Don't just rename them because then you'd end up having to recreate them.
Google "Open Command Window Here" for instructions on how to get to a DOS command prompt from Windows Explorer for these file operations - you could even automate it with a pair of simple batch files.
Philnick is offline
post #26854 of 28091 Old 06-14-2014, 10:37 PM
Philnick's Avatar
Quoted: 224 Post(s)
Liked: 101
Thumbs up PS No reset needed
Turned out that removing any disk from the drawer was all that was needed to restore access to the DVD-A and HDCP options lines in setup. I didn't have to do the ritual reset to factory defaults or erasing persistent memory.
Philnick is offline
post #26855 of 28091 Old 06-15-2014, 01:03 PM
Jorge Garcia's Avatar
Originally Posted by lotohnz View Post
Just wanted to say that since I installed the latest firmware a couple days ago, multi-channel audio via the analog outputs seems to have improved quite a bit, especially the imaging and bass clarity (which is to be expected obviously). I didn't think the delay fix would make such a big difference... at least to my ears it has.
btw, does anyone else here own a DVD-A of Donald Fagen's Morph The Cat album? At some point since the previous firmware update (October 2013) my BDP-93 lost the ability to play through the disk, getting hung up on the last half of the album. I was hoping the latest firmware might possibly fix it but it hasn't. Is anyone else experiencing this issue or do I need to try to find another DVD-A of the album?
thanks...
In fact, as far as I can perceive, the sound not only changed the analog output , also in HDMI digital,
It seems that they varied the balance at low frequencies, this makes the mid and high frequencies are more prominent, so that the dialogue and the environment are perceived more and gives the impression that the overall sound is better.
In my opinion this change hurts the overall balance of the frequency spectrum and as a result the overall sound has less body and is now worse than before although it seems otherwise.
They did the same with the 83 two years ago.
Jorge Garcia
THX, Audyssey, ISF , Mason certified
Jorge Garcia is offline
post #26856 of 28091 Old 06-15-2014, 01:42 PM
Read the FAQ!
Liked: 2448
^ Any change you are hearing on HDMI is coming from your AVR. To prove it, set HDMI Audio Bitstream, Secondary Audio OFF. Nothing is being done in the OPPO to that Bitstream output.
If you are testing with Bitstream tracks on either Analog or on HDMI LPCM, also check you have Dynamic Range Control OFF as there are known cases of bad DRC data on commercial discs.
--Bob
post #26857 of 28091 Old 06-19-2014, 04:51 PM
Read the FAQ!
Liked: 2448
The iOS version of the new, OPPO Remote app, v2.0.0 is now available on Apple's iOS App Store. Be sure you've updated your player to the latest firmware.
--Bob
post #26858 of 28091 Old 06-20-2014, 02:38 AM
lotohnz's Avatar
Quoted: 42 Post(s)
Liked: 51
Just a note - the latest firmware doesn't seem to appear in the first post anymore.
lotohnz is offline
post #26859 of 28091 Old 06-20-2014, 06:59 AM
Read the FAQ!
Liked: 2448
^ The Horror! The Horror!
In the interim, the details on the latest firmware for the 93/95 can be found on OPPO's Support page here:
http://www.oppodigital.com/blu-ray-b...e-80-0513.aspx
--Bob
lotohnz likes this.
post #26860 of 28091 Old 06-21-2014, 03:09 AM
fmalczewski's Avatar
Quoted: 93 Post(s)
Liked: 38
Just another note - the latest non-beta firmware a few days ago was not made available to me on my '93 (I was allegedly also up to date when I tried to update the firmware via the menus, but I hadn't updated it for several months (no betas)). Had to download and install it from the website.
fmalczewski is offline
post #26861 of 28091 Old 06-21-2014, 11:15 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 185
I, too, was quite surprised that the 93 didn't discover a firmware upgrade available from the Internet . Like you, I also had to place the UPG folder onto a USB drive and install it to my 93 that way.
Which brings me to several new questions.
(1) The 103 home screen shows a "BD" icon corresponding to the BluRay player. So in addition to being able to navigate to all the other apps (including Netflix), you can simply play discs as well.
In contrast, there is no "BD" icon on the 93 home screen. So if you do push the HOME button (say you plan to stream from Netflix) and you now want to get back to the BluRay player for discs, how does one get back to the player screen?? What is the recommended button-push sequence or navigation method you go through to get back to the player Oppo logo screen?
I suppose if I have it set up for auto-play, simply opening the tray and inserting a disc and closing the tray would trigger playback to begin. But I'm curious as to how one would otherwise get back to the Oppo logo screen (i.e. as the "BD" icon doe son the 103's home page)?
(2) The Netflix app on the latest official 93 firmware is NOT the latest Netflix app version currently present on the 103's latest official firmware. So whereas the "i" (INFO) button on the 103's remote now shows "1080 Super HD" when viewing a Netflix stream, using the "i" button on the 93 shows absolutely nothing when viewing a Netflix stream.
I wanted to know what was being sent to my 93 (which is set to 1080p, and thus would deliver 1080p no matter what was arriving at the 93) for delivery on to my connected Sony KDL-32XBR9 set. So I decided to change the 93 to "source direct", thinking I would then be able to use the DISPLAY button on the TV's remote to see what it was receiving. With the 93 in 1080p mode it showed "1080p 16x9 full pixel".
Strangely, with the 93 set to "source direct" the Netflix stream (presumably now just passing through the Oppo directly to the 32XBR9), the DISPLAY button on the TV now unexpectedly showed "720p 4:3 normal"!! Huh?? (note that "normal" is the designation for 4:3 OAR, with black bars on left and right when viewing 4:3 content)
And of course, it really did appear as "postage stamp" on the screen, within the 4:3 area and seemingly horizontally compressed as well. Both programs I streamed are actually wider than 16x9, and have black bars at top and bottom even when viewed as 1080p, but they did not look right at "720p 4:3 normal".
So, why does the Oppo in "source direct" not tell the Netflix app that the connected TV can in fact receive 1080p 16x9? When Netflix is not running, and I get into the Oppo's setup (while still in "source direct"), the DISPLAY button on the TV shows that the Oppo is talking to the TV in the expected "1080p 16x9 full pixel". But when viewing a Netflix stream in "source direct", it's now "720p 4:3 normal".
DSperber is offline
post #26862 of 28091 Old 06-22-2014, 12:23 AM
Philnick's Avatar
Quoted: 224 Post(s)
Liked: 101
Just press the HOME button again - it toggles back-and-forth between the logo screen and the screen with all of the online options.
Philnick is offline
post #26863 of 28091 Old 06-22-2014, 01:33 AM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 185
Well, I'll be! Couldn't have been simpler. Probably should have been able to guess that, or stumble into it. Maybe even look in the manual.
Anyway, thanks for the info.
DSperber is offline
post #26864 of 28091 Old 06-22-2014, 02:40 PM
Read the FAQ!
Liked: 2448
This is a settings problem in your TV.
I just checked with the HDMI 1 output of the 93 connected to HDMI BACK Input of the 105D. Cabled this way, I can use the on-screen Info display of the 105D to see what the 93 is sending out.
With the 93 set to Source Direct, and playing a Netflix HD stream, it is sending 720p/60 video flagged as 16:9 aspect ratio, which is correct. This is true whether the TV Aspect Ratio setting in the 93 is set to "16:9 Wide" or to "16:9 Wide/Auto".
So what's likely going on here is that your TV requires a MANUAL choice of aspect ratio processing, and that it is remembering that choice separately for each possible video input resolution. So when it sees 720p input coming from the 93, it uses whatever its last setting was for 720p input -- which in this case is evidently "4:3 normal". Just use the Picture Size control on the TV to change that (while viewing 720p input) and you should be fine. If I've got this right, any adjustment you make for 720p input won't affect 1080i or 1080p input.
As to the Netflix app itself, after the 93 was certified by Netflix for the original app release Netflix updated their hardware requirements for future Blu-ray player support. Only players with newer hardware meeting those requirements are supported for the newer Netflix apps. (Even then, the player maker has to convince Netflix to OFFER the app on that player.)
The upshot is that the 93 is unlikely to ever get the same version of the Netflix app as is now on the 10x players.
The firmware should have been available for network install so long as you were not currently running a Public Beta firmware. It may be you attempted the network install before the update server went live with the new firmware, or there may have been a temporary problem with the update server.
--Bob
post #26865 of 28091 Old 06-22-2014, 06:29 PM
Smarty-pants's Avatar
Quoted: 675 Post(s)
Liked: 547
^Coincidentally I ran into the same problem last week when the wife was watching Netflix on the BDP-93.
I also have a Sony 1080p LCD display, and when I set the -93 to Source Direct it does the same thing that DSperber is describing.
I don't know for sure what the detailed info is coming in, but it produces borders on all sides of the pic.
If I change the output of the -93 to 1080p and not Source Direct, then the screen is full again with no border bars.
I am 99.999% sure my TV settings are all set to output unaltered video. IE: 1080p in = 1080p out.
I will try to retest this again today if I can.
Smarty-pants is offline
post #26866 of 28091 Old 06-22-2014, 07:14 PM
Read the FAQ!
Liked: 2448
^ Look for a picture size adjustment in the TV. The same place where you set whether you see all of a 1080p picture or lose some around the edges to overscan. 720p input likely has a different memory for that setting, which you can only adjust while 720p input is happening.
--Bob
post #26867 of 28091 Old 06-22-2014, 07:25 PM
Quoted: 675 Post(s)
Liked: 547
^Ahhh that must be it... I will try looking at the TV settings while sending it different resolutions, and those same resolutions on different inputs.
Just got the tv used a few months ago and haven't taken the time to go though the fine details beyond basic calibration.
Since I have (thus far) run the -93 to that display via 1080p, having it unintentionally set to Source Direct must have exposed the unaltered set of settings @ 720p.
post #26868 of 28091 Old 06-22-2014, 08:41 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 185
Well, although I obviously can use the WIDE button on the XBR9's remote to zoom what is coming from the Netflix app, that still has no effect on what is coming from the Netflix app. The real problem is that the Netflix app is sending 720p and not 1080p, and also that it is sending 4:3 and not 16:9.
Sure, I can zoom the 720p to "full" (stretching it to fill the screen, though it's still originally delivered as 720p within 4:3 content), or "full pixel" (which reverts it to "postage stamp", i.e. 16:9 within the 4:3 area and with black bars on top). But this is all still NOT what is expected.
What is expected is to get 1080p from Netflix, not 720p. This is not a network issue. If I change the 93 from "source direct" to AUTO or 1080p, the output from the Netflix app is clearly now visually 1080p quality (from what I'm sure is 1080 Super HD I'm sure, although I can't be sure since there is no "i" function on the 93 as there is on the 103), and most certainly must also be 1080p 16:9. Actually, I DO have a 103 as well, and could grab it from the other room and connect it to the output of the 93 as you did, just to find out for sure (but this is fairly inconvenient for me, so I may just pass).
Granted, this might just be some quirk relating to the 32XBR9, but there's nothing in its setup to influence the 93 to cause the symptom I'm seeing. Yes, there is a 4:3 aspect ratio control and I have "4:3 normal" because I want 4:3 OAR (i.e. with black bars on left and right), rather than any stretch-o-vision presentation. But that only should come into play if the set receives 4:3 480i, and it only determines how the set displays 4:3... not having anything to do with its HD or 16:9 capabilities.
This problem is seemingly entirely the result of how "source direct" on the 93 passes information about the TV's discovered resolution and aspect ratio capabilities back to the Netflix app, and which is somehow concluding that nothing higher than 720p is possible, and also that the TV isn't capable of 16:9 presentation. Could also be a Netflix app problem on the 93, but again if I go from "source direct" to 1080p or AUTO on the 93 this problem disappears.
Again, I was really only trying to confirm that I was getting "1080 Super HD" out of the 93 on that set, and because of the lack of "i" capability using DISPLAY on the TV was the only alternative, and that required "source direct" from the 93 to avoid always showing 1080p and hiding what I wanted to discover, and that's what uncovered this mysterious conundrum of undesirable results. I'll obviously just have to go back to 1080p or AUTO on the 93, and accept what I believe to be "1080 Super HD" for what I'm seeing.
Any other thoughts? Still seems like a problem with "source direct" and the Netflix app on the 93 to me.
DSperber is offline
post #26869 of 28091 Old 06-22-2014, 09:06 PM
Read the FAQ!
Liked: 2448
^ The older app provided by Netflix for the 93 only handles up to 720p streams. Source Direct output at 720p/60 is correct. This is not a network speed limitation or anything like that. The app itself is limited to 720p. When you set 1080p output, the 93 is upscaling the 720p Netflix stream to 1080p for output.
The app provided by Netflix for the 93 is not capable of accepting 1080p Netflix streams (at any bit rate -- i.e., including "Super HD").
And as I said, I've just tested Source Direct for Netflix on the 93, and the 93 *IS* sending that as 16:9, not 4:3.
ETA: In the 93 make sure Setup > Video Setup > TV Aspect Ratio is set to either 16:9 Wide or 16:9 Wide/Auto.
--Bob
post #26870 of 28091 Old 06-22-2014, 10:11 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 185
Aha! I didn't realize the 93 was limited to 720p in its Netflix app. That's the missing info I didn't have until now.
And yes, the 93 has aspect ratio set to 16:9 WIDE/AUTO.
I guess I just thought I was seeing true 1080p from Netflix when the 93 was set to AUTO or 1080p, but obviously I was incorrect. If the Netflix app can only deliver 720p on the 93, then that's all I could possibly have been seeing.
There is a LARGE visual difference when viewing (1) 720p from Netflix "source direct" on the XBR9 (i.e. sent as "native" 720p to the XBR9), even when zoomed to "full" so that it looks like 16:9 (even though, again, the TV says it's getting 4:3 sent to it, not 16:9), vs. (2) 720p from Netflix upconverted and "processed" to 1080p 16:9 by the 93 for delivery to the XBR9, when AUTO/1080p is set on the 93 instead of "source direct".
Thanks for the insights.
Incidentally, the new info about the limit of 720p in the Netflix app for the 93 may also explain another mystery I've been dwelling on for a while now.
My sister in Chicago (Comcast) has a Sony BDP-S5100 which during my last visit I wired-connected to the LAN in her house, and configured the Netflix app on the S5100 using my streaming account. However the performance and image quality was consistently terrible. Low SD 240/480 resolutions, or maybe 480p. but never or just briefly getting to 720p before dropping again, and certainly never reaching 1080p as I might have expected.
I confirmed the latest firmware on the S5100. And this was shortly after the Comcast/Netflix monopoly deal so I had assumed it wouldn't be caused an intentional "slowdown" any longer, if at all here. Nevertheless, the performance out of the S5100 was (and still is) horrid.
I guess it's now apparent it could all be due to the old Netflix app on the S5100, and/or the S5100 player itself. Clearly what's now needed is an upgrade to a 103! This would also provide the benefit of her Comcast HDTV source being fed into the external HDMI input of this [potential] 103, improving not only Netflix streaming but also everyday HDTV... as well as BluRay discs (which she plays from her own Netflix disc subscription).
The S5100 player does "play nice" with the 55" Sony LCD set she has (don't recall the model, but it's a very good one about 2 years old), via CEC, and she likes that. She just pops a disc in the S5100 and the TV comes on and changes to the BluRay HDMI input source. But I suspect the 103's CEC mechanism would probably work the same way with her Sony TV.
Looks like I know what the next occasion's "gift" will be.
thanks again.
DSperber is offline
post #26871 of 28091 Old 06-22-2014, 10:35 PM
Read the FAQ!
Liked: 2448
^ The newer Netflix app in the 10x players will also give you 5.1 Surround Sound for programs that offer it.
--Bob
post #26872 of 28091 Old 06-23-2014, 01:15 AM
Quoted: 675 Post(s)
Liked: 547
^Regarding the above issue seen by DSperber and myself on our Sony displays, and the 720p resolution resulting in decreased picture size.
After recalibrating my display tonight and playing with settings, I have determined that it is definitely as issue with the tv, not with the Oppo.
I have the Oppo on Input2, and I have my U-verse STB on Input1.
The Uverse box only has two HD options, and that is to output 720p full time, or 1080i full time. I always have mine on 1080i since most channels broadcast in that resolution.
Anyway, I tried switching it to 720p tonight and I get the exact same problem as when sending 720p from the -93.
Switch it back to 1080i, and the pic fills the screen again like it should.
I don't know what is going on there. I have gone through all the settings in the display and there is no different setting for individual resolutions.
The same settings apply full time on any given input, though you can calibrate them separately for different inputs.
Anyway, there are only a couple settings for the picture and I always keep it on "full pixel" which is like a source direct type setting.
Whatever is coming into the display is what is shown... no zoom or overscan.
There are a couple other display settings that didn't seem to make any difference at all, so those didn't help.
The only way to get 720p to fill the screen is to use one the zoom modes, like the one called "FULL".
...AND, if I send 480p, the pic is even smaller on screen than with 720p, with gigantic black bars around all 4 sides.
At least I only paid $150 for it used, and I can always send 1080i for cable and 1080p from a player.
The moral of the story?... Sony is retarded. Now back to your irregularly scheduled Oppo babble.
post #26873 of 28091 Old 06-23-2014, 02:11 AM
Waboman's Avatar
Quoted: 4467 Post(s)
Liked: 10157
Why do certain people do this "^" instead of using the quote button? Makes no sense.
Waboman is online now
post #26874 of 28091 Old 06-23-2014, 03:19 AM
Read the FAQ!
Liked: 2448
^ No need to quote something that's the prior post. It's sitting right there to refer to.
--Bob
post #26875 of 28091 Old 06-23-2014, 03:40 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 988 Post(s)
Liked: 860
--Bob
Unless another poster hits their submit post button first.
gsr is offline
post #26876 of 28091 Old 06-23-2014, 04:31 AM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 185
I would be glad to use the old "quote" method, but unfortunately the new VB forum software has a very annoying bug which has not yet been resolved. MY response (shown under the quoted text above) will be yellow (in the dark theme), because it has been presented as a LINK!!
So all of my text is yellow and underlined (if you hover your cursor over it), making it very annoying.
Once the forum techies get this problem fixed, I think, you'll see lots more "quote" usage again as used to be the case with previous forum software. I know I don't want to use it right now, because I really want my text to be white and not yellow/URL.
DSperber is offline
post #26877 of 28091 Old 06-23-2014, 09:20 AM
Spacedave's Avatar
Quoted: 17 Post(s)
Add me to those who could not update the new firmware on the web. I followed the instructions on the support page, but the 93 said I was up to date, when I have not updated for many months. The USB method worked, immediately was flagged as new firmware and updated.
Yes, my web connection works, watched a couple short YouTube clips after updating. Interface is painful.
Spacedave is offline
post #26878 of 28091 Old 06-23-2014, 12:15 PM
BSTNFAN's Avatar
Quoted: 18 Post(s)
Liked: 34
Also, remember that some of us show most recent first. Putting a "^" in your post just means you can predict what the next post is going to say
BSTNFAN is offline
post #26879 of 28091 Old 06-23-2014, 12:33 PM
Read the FAQ!
Liked: 2448
Fortunately, you folks are intelligent enough to interpret that correctly.
--Bob
post #26880 of 28091 Old 06-24-2014, 08:27 PM
chiptouz's Avatar
Quoted: 27 Post(s)
Liked: 59
Quick question for you guys here that use MKV's and DLNA. Does the oppo 93 support MKV files with LPCM 5.1? I am getting an error when I play a file with it.
Chip
Argyl Home Theater - Indefinitely Delayed
My Movie Library - and still growing!
Family Room: Sharp LC-80uq17u + Denon 4520ci + Oppo 93, Speakers: C: Polk CSi-A6, F(L+R): Polk Rti-A7, S(R+RS) Polk TC60i, Sub: HSU – VTF3-MK4
chiptouz is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
