Official OPPO BDP-93 Owner's Thread - Page 897 - AVS Forum | Home Theater Discussions And Reviews
 198Likes
post #26881 of 28185 Old 06-30-2014, 07:23 PM
Mkard's Avatar
Quoted: 33 Post(s)
Liked: 31
Subtitle question
Hi all,
I did just spend some time searching this thread, albeit without great luck. I seem to always have poor subtitling when playing Blu-ray disks. Doesn't matter whether selected via disk menu or from remote controller "on-the-fly". Basic store bought production disks provide me with only about 1/3 of conversations to text. Frustrating. Watching Cloud Atlas was beyond UN-intelligible ! Seems to be consistent problem regardless of disk played.
Thanks Bob P. for the reminder to adjust subtitle height to zero after recent firmware change. But I still seem to have way too little conversation on screen. Any help would be appreciated.
Mkard
Mkard is offline
post #26882 of 28185 Old 06-30-2014, 07:30 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2799 Post(s)
Liked: 2028
Originally Posted by Mkard View Post
Hi all,
Mkard
Are you sure the subtitles you are missing are actually on the disc? Have you checked this on another player?
You're not zoomed in? And you have verified that the subtitle shift is set to zero?
I would try a Reset Factory Default, then re-enter local settings.
If still no good: I'd reload current firmware and Reset again.
If still no good: I'd contact OPPO support.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #26883 of 28185 Old 06-30-2014, 08:04 PM
Mkard's Avatar
Quoted: 33 Post(s)
Liked: 31
Bill,
Thanks. I think that I'll just do a reset all at this point. I know that Cloud Atlas and Gravity both displayed with black above and below main picture. Seemed odd. Reset, then re-enter the basics. oh well.
Mike
Mkard is offline
post #26884 of 28185 Old 07-01-2014, 08:20 PM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
I'd agree with going the factory reset route. Going up the firmware upgrade ladder without the recommended factory resets, I ended up watching a movie in which only two subtitles showed for the whole movie. It turned out the subtitle shift was wrong to exactly the right degree to completely hide all single-line subtitles and only show the top line for two-line subtitles. You really should be able to fix it with a simple setting change, but factory resets after firmware upgrades are a good idea in general.
Also, seems like Netflix finally fixed their months-long "no network" issue, slightly before the latest firmware was released. Either that or the incidence has gone way down--I used to see it almost every time.
CatBus is offline
post #26885 of 28185 Old 07-02-2014, 08:32 PM
labman1's Avatar
Quoted: 76 Post(s)
Liked: 24
Question
[QUOTE=CatBus;25424322]I'd agree with going the factory reset route. Going up the firmware upgrade ladder without the recommended factory resets, I ended up watching a movie in which only two subtitles showed for the whole movie. It turned out the subtitle shift was wrong to exactly the right degree to completely hide all single-line subtitles and only show the top line for two-line subtitles. You really should be able to fix it with a simple setting change, but factory resets after firmware upgrades are a good idea in general.
Also, seems like Netflix finally fixed their months-long "no network" issue, slightly before the latest firmware was released. Either that or the incidence has gone way down--I used to see it almost every time.[/QUOTE
Why is it important to do a factory reset after a firmware upgrade?
labman1 is offline
post #26886 of 28185 Old 07-02-2014, 10:14 PM
mhobart's Avatar
Quoted: 59 Post(s)
Liked: 47
[quote=labman1;25451249]
The reset ensures that the memory is cleared so anything left over from before the update is not used. That is not normally a problem but this is part of a "belt-AND-suspenders" approach.
mhobart is offline
post #26887 of 28185 Old 07-03-2014, 06:51 AM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
I had some Blu-Ray discs that wouldn't play anymore post-update. The players was "playing" the movie, but no picture and no sound. The factory reset solved the problem.
exm is offline
post #26888 of 28185 Old 07-03-2014, 08:06 AM
Jacob305's Avatar
Quoted: 81 Post(s)
Liked: 48
What titles did you have issues with?
Jacob
Jacob305 is online now
post #26889 of 28185 Old 07-03-2014, 10:39 AM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
Jacob
Enchanted and Toy Story 2
exm is offline
post #26890 of 28185 Old 07-06-2014, 11:04 AM
AndiXS's Avatar
Hello
Since the last firmware update my Oppo 93EU player sometimes freezes in the Blu-ray disc movie menu.
My only possibility to restart the player is by pressing the on/off button on the front of the player.
Has someone the same problem?
AndiXS is offline
post #26891 of 28185 Old 07-06-2014, 01:06 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2568 Post(s)
Liked: 3242
Originally Posted by AndiXS View Post
Hello
Try a Reset of the player:
1) Remove any disc, and jot down your Setup settings.
2) In Setup > Device Setup, Erase Persistent Storage
3) In Setup > Device Setup, Reset Factory Defaults. When the Easy Setup Wizard finishes, power down the player.
4) Pull the wall power plug for about 10 seconds.
5) Power up and re-enter your personal settings.
6) Power down one more time. Settings are saved during the power-down cycle.
Try the disc again and see if it still has a problem.
Note that dirt or scratches on the disc can affect disc menu functions just as much as playback of the movie. Check the disc, and clean it if needed.
If still no luck, report the problem to OPPO Tech Support and they can check it out. Include the bar code number from the disc packaging so they can be sure they are looking at the same version of the disc as you are using.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #26892 of 28185 Old 07-09-2014, 08:24 PM
mangamonster's Avatar
I was thinking about upgrading my 93 to a 105d (just thinking about it...), and was curious what my 93 is reselling for. I just checked ebay and amazon, it's reselling on average from 600-1200 consistently from every seller. Am I missing something here? Is there special 'magic' in the 93 that the latter models don't have??
mangamonster is offline
post #26893 of 28185 Old 07-09-2014, 09:06 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
For a standard used model in like new condition, 350-400.
The ones selling for more than that could have a few other incentives that raise the amount buyers are willing to pay.
If the player has older firmware that allows for ISO playback, and/or region free capabilities are the most common
features that will fetch a higher price.
Smarty-pants is offline
post #26894 of 28185 Old 07-10-2014, 07:06 AM
afss's Avatar
Quoted: 25 Post(s)
Also the 93 is Cinavia free, which is a very big plus,
afss is offline
post #26895 of 28185 Old 07-10-2014, 07:15 AM
Ahh, makes sense. Thx guys.
post #26896 of 28185 Old 07-10-2014, 07:46 AM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I paid $600 for each of my two ISO-capable BDP-93s. Got them through ebay, but it's a reseller who specializes in ISO-capable and region-free units. They are the cornerstone of my setup, since I do everything with ripped BD ISOs. You'll have to pry my BDP-93s from my cold, dead fingers.
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #26897 of 28185 Old 07-13-2014, 05:28 PM
tauheel05's Avatar
I'm about to update my player to the latest firmware...
Quick question...will the update affect its capability to play cinavia blu-ray back-ups?
tauheel05 is offline
post #26898 of 28185 Old 07-13-2014, 05:35 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1089 Post(s)
Liked: 1070
No. (If you want a verbose answer, please search the thread for Cinavia as this has been asked and answered a bunch of times and shouldn't be hard to find.)
gsr is online now
post #26899 of 28185 Old 07-13-2014, 05:44 PM
tauheel05's Avatar
Thank you!
post #26900 of 28185 Old 07-15-2014, 08:13 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6823 Post(s)
Liked: 3796
For those of you who might have a Sony 4K display like the XBR65-X900a, the recent FW update addressed an incompatibility issue between this display and the BDP-93. However, I continue to have an issue which causes continuous HDMI handshakes, with white-snow screens. The only way to stop the handshakes is by powering off the display, or the AVR, or sometimes both. A short video (1MB) demonstrates what I am experiencing: https://dl.dropboxusercontent.com/u/...po%20Video.MOV.
Full disclosure: I also have a Darbee Vision Darblet in the signal path between the AVR and the display. The signal path from the Oppo is 1080P all the way to the Sony display, with the Oppo set to RGB Video, and deep color off.
Anyone else seeing this? I have reported to Oppo as well.
AustinJerry is online now
post #26901 of 28185 Old 07-15-2014, 08:37 AM
Quoted: 749 Post(s)
Liked: 627
Have you tried to connect the player directly to the display to make sure the problem is between the player and tv?
Does the flashing ever stop? Also try powering on the display first, then the avr, then the player.
Also try that sequence in reverse and see if such a power on sequence helps the situation.
I don't recall others reporting this problem, so more than likely it is an issue with the display, or avr.
post #26902 of 28185 Old 07-15-2014, 08:40 AM
rdgrimes's Avatar
Quoted: 2086 Post(s)
Liked: 1416
The white snow is usually a resolution handshake failure. You might want to try setting the player to 720 or even 480 just to see if that prevents the problem, If it does, then a HDMI cable might be the cause. Even if it doesn't, I'd still swap out cables (all of them) to see what happens.
rdgrimes is offline
post #26903 of 28185 Old 07-15-2014, 12:15 PM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
So you guys say there's no point in upgrading the BDP-93 to the BDP-103?
exm is offline
post #26904 of 28185 Old 07-15-2014, 12:54 PM
wmcclain's Avatar
Liked: 2028
Did we say that? It would depend on your needs, and if the other player has something you want that the original does not, right?
-Bill
post #26905 of 28185 Old 07-15-2014, 01:38 PM
rdgrimes's Avatar
Liked: 1416
I wouldn't say that, but then I have both. The 103 has networking features that the 93 does not, which for some folks is a big deal.
rdgrimes is offline
post #26906 of 28185 Old 07-15-2014, 01:39 PM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
-Bill
I read a few reviews and comparisons and I can't really see a reason to upgrade. Normally I *LOVE* to upgrade but there's nothing I can see. Am I missing something?
fgsouza likes this.
exm is offline
post #26907 of 28185 Old 07-15-2014, 01:44 PM
mhobart's Avatar
Quoted: 59 Post(s)
Liked: 47
You might also want to try removing the intermediate devices one at a time if re-doing the HDMI cables does not isolate the problem. I know that I am simply re-stating the obvious, but interconnections are so often the culprit in electronics equipment.
mhobart is offline
post #26908 of 28185 Old 07-15-2014, 01:48 PM
wmcclain's Avatar
Liked: 2028
It depends on what interests you. The FAQ has a summary: How is the BDP-103 different from the BDP-93?
-Bill
exm and mhobart like this.
post #26909 of 28185 Old 07-15-2014, 01:54 PM
exm
exm's Avatar
Quoted: 129 Post(s)
Liked: 82
-Bill
Exactly what I was looking for, thank you. I'll stick with my BDP-93 until the next gen comes out. It seems the biggest improvement is 4k support, but these two items are deal breakers for me:
- BDMV folders are no longer supported on DVD media. (This was a directive from the Blu-Ray Disc Association; I don't know why they care).
- Cinavia (mandatory starting in 2012)
exm is offline
post #26910 of 28185 Old 07-15-2014, 03:03 PM
DSperber's Avatar
Quoted: 229 Post(s)
Liked: 186
Can't understand why (for me) THE MOST IMPORTANT FEATURE of the 103 continues to go unmentioned, until I mention it...
Two external HDMI inputs, for feeding your cable/satellite HDTV service through the 103. This provides all of the Oppo's video cleaning and processing and upconverting capabilities, applied to the "native" (i.e. untouched by the DVR/STB, but delivered exactly as-is in original 720p/1080i format) 720p/1080i output of your DVR/STB, and then upconverted to gorgeous clean beautiful 1080p for delivery to your HDTV.
Cable and satellite never looked so good, as when routed from DVR/STB through the 103 and then on to the AVR (or direct to the HDTV from HDMI-1 output, with audio to the AVR from HDMI-2 output).
This also allows for decoding the digital audio from HDTV to LPCM for feeding out via HDMI to an external sound system (e.g. headphone processor, like Smyth Realiser) that accepts discrete multi-channel digital audio via LPCM/HDMI input. There's no other way to get decoded discrete multi-channel digital audio via LPCM/HDMI (if you should need it) than this, as DVR/STB only deliver still-encoded digital audio via HDMI, requiring audio decoding ability in the receiving device (which the Smyth Realiser does not have). This allows all digital audio decoding (for all lossy and lossless formats, from HDTV as well as BluRay discs as well as streaming sources like Netflix) to take place in the Oppo, feeding the decoded discrete multi-channel LPCM output over HDMI to a target audio device that does not support its own decoding for these audio formats but does accept decoded LPCM over HDMI input.
The Oppo 103/105 players are the only ones that have external HDMI inputs.
Reason enough (for me) to upgrade my 93 for my primary viewing/listening location (where I have a Smyth Realiser and Panny 65VT50), which I did last year. HDTV picture never looked so good nor sounded so good through my headphones.
My 93 is re-purposed to secondary location in the house.
Smarty-pants and mhobart like this.
DSperber is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
