Official OPPO BDP-93 Owner's Thread - Page 903 - AVS Forum
 24Likes
post #27061 of 27084 Old 10-03-2014, 08:07 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 415 Post(s)
Liked: 897
^ The ability to push content from a DLNA server to the OPPO (perhaps controlled by your Android device browsing and commanding that DLNA server), or to use OPPO's own, Android, MediaControl app to pull content from servers is something supported in the 10x players, not the 93 or 95.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #27062 of 27084 Old 10-03-2014, 08:36 AM
indieke2's Avatar
--Bob
I not understand very well. I would use my hard disc. So there is no way at all to choose my music with an app, hard disc attached, let stand alone choose from cover? That is something I can do with my travel Dune TV 201....... I payed 100 €. In fact I can play on that many files the Oppo not feel well about. ...
I not understand why this should not get implanted with a new update of software. So much easier to choose a music file. I do this with my computer and Jriver so well. But the result in sound should be better with oppo, although I am surprised how well it plays already.
I like my HT, wine and pretty girls. But...am I the only one
indieke2 is offline
post #27063 of 27084 Old 10-03-2014, 09:00 AM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
^ I was just reminded that there *IS* an "experimental" version of OPPO's MediaControl app for Android that will work with the 93:
https://play.google.com/store/apps/d...m.oppo.oremote
The details on the firmware version need in the player are stated there.
You could use this app to browse and select content to play from an attached hard drive.
--Bob
post #27064 of 27084 Old 10-03-2014, 09:06 AM
indieke2's Avatar
--Bob
Thanks bob, i have seen that. But it is not clear to me, how to select files. Is there a way to dispit, with all teh covers of music, like with J river, or are it just maps?
Are the new upgrades in firmware, worth to leave the iso capibility?
indieke2 is offline
post #27065 of 27084 Old 10-03-2014, 09:13 AM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
^ Nothing but lists as far as I am aware (I don't use Android). The hardware in the 93 is not really designed to do the type of two-way communication MediaControl depends on. (Those changes came with the 10x players.) So frankly it's amazing to me they got even this stuff working.
If you are a heavy user of ISO files, I'd say the firmware upgrade is not worth it.
With the 10x players, J River can "push" content to the player. So you can use whatever app you like to browse and select content in J River and have it play on the 10x player. The 9x players do not support the DLNA Digital Media Renderer (DMR) protocol which enables that. And it is unlikely that will be added to them.
--Bob
post #27066 of 27084 Old 10-03-2014, 09:16 AM
indieke2's Avatar
--Bob
Thanks for your kind explanation. I have some BD's rips that not pay on it, maybe it would with the firmware upgrade. No I am not a heavy user of Iso's, just for 3 d content, I not watch that often.
indieke2 is offline
post #27067 of 27084 Old 10-04-2014, 12:54 AM
IanD's Avatar
Originally Posted by colinpurves View Post
Maybe time for me to sell the 93 and grab a 10 series. I found an excuse at last!
Not to detract from your excuse, but most 3D TVs should have an option to reverse the left and right eye views, because not all sources follow the standard convention.
See if you can find that option in the Sony before selling the Oppo.
IanD is offline
post #27068 of 27084 Old 10-04-2014, 08:01 AM
IanD's Avatar
Regardless of how the 93 is set for Analog Speaker Configuration Down-mix or speaker enabling (i.e., speaker LARGE vs. OFF), the 93 *ALWAYS* sends HDMI LPCM 7.1 for these two tracks, and all the channel content is indeed received by the 105D in the proper place.
You are absolutely right.
I'm not sure how I came to the conclusion that Speaker Configuration Down-mix was modifying the number of LPCM channels sent via HDMI. A simple test with a 7.1 soundtrack has confirmed 7.1 received at the AVR regardless of down-mix being set to 7.1 or 5.1
IanD is offline
post #27069 of 27084 Old 10-10-2014, 06:24 PM
sgibson's Avatar
Originally Posted by wmcclain View Post
Quote:Originally Posted by raavango
How would I get the benefit of watching the signal from HDMI1 and the sound from the spekers. Do I just turn the TV speaker volume down and just play the Bluray? Will the speakers give out audio from the bluray?
Regards
Raavango
Yes, although TVs usually allow their internal audio to be turned off completely.
-Bill
Hello Bill,
Since changing from Onkyo TX-NR709 to new Denon AVR-X4100W, I
cannot play Flac on Oppo 93 . Using same signal path
connections/cables as before. Oppo 93 primary connection to Denon AVR is HDMI cable
Signal path: Oppo 93 Optical Out to Teac UD-H01 DAC Optical In.
Then RCA Analog L&R out of Teac DAC to Denon AVR-X4100W CD
Analog In. Oppo is Setup with Optical Connection for Audio Out to
Teac Dac In to play Flac Music. Oppo Music play screen shows a Speaker Icon
with a red "X" through it.
Teac plays problem-free Flac via HTPC feed from USB cable. Denon plays this
route with no problems. looks like I'm missing a
playback/audio/optical setting in the Oppo settings?
Any ideas, help greatly appreciated,
sgibson
sgibson is offline
post #27070 of 27084 Old 10-10-2014, 06:29 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 525 Post(s)
Liked: 366
Originally Posted by sgibson View Post
Oppo screen shows a Speaker Icon
That indicates "Mute". Either the Mute button has been pressed or you have volume set to zero.
-Bill
wmcclain is offline
post #27071 of 27084 Old 10-11-2014, 07:36 AM
sgibson's Avatar
-Bill
Bill,
duh....must have inadvertently hit the Mute, while doing Setup, swapping cables, etc.
You saved me further troubleshooting and frustration. All is well now and the flac music flows gloriously once again.
BTW, Oppo 93 does a superb job on new Dolby Atmos playback through Denon AVR-X4100W + External amp = 9.2 channels (11 speakers total)
If interested come visit Dolby Atmos forum here at avs. Ole' Oppo93 still rocks!
Thanks much,
sgibson
sgibson is offline
post #27072 of 27084 Old 10-16-2014, 10:29 AM
ryewhiskey's Avatar
DVD-Audio question
I'm not sure if this is related to my receiver or the BDP-93, but I figured I'd throw it out there.
I have quite a few multi-channel audio discs, and I used to be able to listen to them in either Dolby Digital (using coax from BDP-93 to receiver) or DVD-A (using analog out to the receiver) mode. After resetting my receiver and possibly fiddling with some of the settings on the BDP-93, my receiver doesn't seem to recognize Dolby Digital streams from the Oppo anymore. The BDP-93 briefly shows DVD-A on its display, but my receiver only gives me the option for Dolby Pro Logic.
Under Playback Setup, I have DVD-Audio Mode set to DVD-Audio. I tried re-setting it to DVD-Video, but I still couldn't get the receiver to recognize Dolby Digital. Any ideas why?
Apologies in advance if this question is confusing, but I'm just hoping that somebody out there might have a suggestion or two. I should add that I just updated the firmware on my receiver (H/K AVR 635) so that might well be responsible.
ryewhiskey is offline
post #27073 of 27084 Old 10-16-2014, 11:11 AM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
^ There is a separate setting in the OPPO for what type of Digital audio is sent out on the Optical/Coax outputs. Check that you have Setup > Audio Format Setup > Coaxial/Optical Output set to BITSTREAM.
DVD-Audio is a licensing restricted, high bandwidth, format, so I believe you may only be able to play it over Coax by selecting the DVD-Video content and getting the lossy Bitstream alternative track.
For best quality audio when playing a DVD-Audio disc into a receiver that doesn't have HDMI Input, use multi-channel Analog output from the OPPO (and select DVD-Audio instead of DVD-Video).
--Bob
post #27074 of 27084 Old 10-16-2014, 12:52 PM
ryewhiskey's Avatar
--Bob
Thanks Bob. I do have Bitstream selected for Coaxial output, but for some reason when playing a music DVD that has a Dolby Digital layer, I'm still only getting the option of Pro Logic. I used to be able to literally toggle back and forth on my receiver between Dolby Digital and high-resolution DVD-A.
And, yes, I realize the DVD-A is higher quality, but I have a few multichannel discs that are solely Dolby Digital and also I think it's interesting to compare the EQ and bass management of my receiver versus the BDP-93. (With Dolby Digital, I'm getting the Harman/Kardon's EQ. With DVD-A via analog outs, I'm getting Oppo's EQ.)
post #27075 of 27084 Old 10-16-2014, 01:03 PM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
^ I suggest you give OPPO Tech Support a call. There's undoubtedly a simple settings error here, and this sort of stuff is resolved faster if you can just go over it together on the phone.
I suspect the settings error is in your Receiver -- something to do with how it is configure to apply Surround Sound processing when it sees stereo input.
--Bob
post #27076 of 27084 Old 10-16-2014, 02:09 PM
rdgrimes's Avatar
Quoted: 285 Post(s)
Liked: 233
You cannot "toggle back and forth" on a DVD-A unless it has been authored to allow that, in which case it would be a function of the menu on the disc. In other words, the player can only output the DD audio or the high res audio - one at a time - and the choice between them involves interrupting playback via the disc menu. Hope that makes sense. Some DVD-A may also offer a 2-ch high resolution audio option in addition to 5.1.
Other DVD-A will force you to exit the high resolution playback and load the DVD-A content which will have only the DD audio.
rdgrimes is offline
post #27077 of 27084 Old 10-18-2014, 02:38 AM
rakosnicek's Avatar
BDP-93 DLNA crashes with latest firmware
I don't know any other way to put it but since upgrading to the latest firmware, my BDP-93 has become most unreliable when it comes to DLNA.
I can no longer even just browse the directory hierarchy before the player freezes. It would appear that the Oppo unit decides to open files in DLNA all by itself! In short, the current firmware is proving to be a real B*H and is woeful in the DLNA area.
Has anyone else updated to the latest firmware and seen these or similar things with DLNA?
Did you back out the firmware upgrade? If so, how?
Well the only problem is downgrading the firmware means the iPhone remote control app will no longer work. argh! Wish Oppo hadn't of abandoned support for this model so soon.
rakosnicek is offline
post #27078 of 27084 Old 10-18-2014, 04:11 AM
Super Moderator
teachsac's Avatar
Quoted: 59 Post(s)
Liked: 140
I don't have any issues with the latest firmware.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself
teachsac is offline
post #27079 of 27084 Old 10-18-2014, 06:31 AM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
With DLNA problems, start by rebooting your DLNA server to make sure it hasn't cached old info about the OPPO. Also check to see whether there is an upgraded "profile" available from the server maker for this OPPO.
If no easy answer that way, then get in touch with OPPO Tech Support regarding the server you are using and the type of problems you are seeing.
--Bob
post #27080 of 27084 Old 10-18-2014, 08:15 AM
chiptouz's Avatar
Quoted: 25 Post(s)
Liked: 59
Anyone using the avs demo discs (using Blu-ray Discs and not streaming from a server) on this player with the most current firmware? I haven't installed new firmware for some time and just want to be sure I can still use these discs.
Argyl Home Theater - Indefinitely Delayed
My Movie Library - and still growing!
Family Room: Sharp LC-80uq17u + Denon 3808ci + Oppo 93, Speakers: C: Polk CSi-A6, F(L+R): Polk Rti-A7, S(R+RS) Polk TC60i, Sub: HSU – VTF3-MK4
chiptouz is offline
post #27081 of 27084 Old 10-18-2014, 01:22 PM - Thread Starter
Neuromancer's Avatar
Quoted: 13 Post(s)
Liked: 174
BDMV is still supported with the latest Official Firmware, so this disc is still compatible with the player.
Neuromancer is offline
post #27082 of 27084 Old 10-20-2014, 06:55 AM
pallepaf's Avatar
Is the undefeatable noise reduction using HDMI 1 present on the BDP-93, as it is on the BDP-103, as an effect of the QDEO chip?
I've really tried searching for an answer but didn't find it, so please don't be mean if you think I should have found one.
pallepaf is offline
post #27083 of 27084 Old 10-20-2014, 03:23 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 174
Yes to both. It is part of the Marvel QDEO solution.
post #27084 of 27084 Old 10-20-2014, 03:35 PM
Read the FAQ!
Quoted: 415 Post(s)
Liked: 897
^ Get the 103D or 105D if you want to avoid this. No QDEO in those.
--Bob
Reply Blu-ray Players
Blu Ray Players , Oppo Bdp 93 Blu Ray Player
User Tag List
