Official OPPO BDP-93 Owner's Thread - Page 915 - AVS Forum
 73Likes
post #27421 of 27423 Old 01-19-2015, 03:20 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 713 Post(s)
Liked: 1065
^ Check that 24p conversion is not happening either in your AVR or TV. Forced conversion of original /60 (i.e., video rate) content to /24 (film rate) is guaranteed to produce frame drop stutter.
Try lowering bandwidth on the HDMI. I.e., turn off Deep Color, and then try 480p output resolution. 480p (not 480i) is the "simplest" HDMI signal. Then try 720p, 1080i, and finally 1080p/60 again.
If the lower resolutions work but 1080p/60 still stutters, and if you are certain neither the AVR nor the TV is itself trying to force the video to 24p, then that suggests the problem is marginal HDMI cabling -- able to handle 1080p/24 but not 1080p/60.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #27422 of 27423 Old 01-20-2015, 07:57 AM
sbr100's Avatar
DVD stuttering
I will try all of the above guys....Thanks! I will let you know what ended up working once i watch more episodes.
sbr100 is offline
post #27423 of 27423 Old Today, 07:08 AM
IanD's Avatar
Quoted: 14 Post(s)
I have two Oppo 93: an ISO firmware model and one with the almost latest firmware. I have 1080p and 1080p24 set for both but I use the 93 with the most recent firmware for most of my viewing.
Recently I have been noticing that 720p24 mkv are being upconverted to 1080p60 whilst 720p23 mkv are being upconverted to 1080p24.
In the past I have noticed 1080p24.99 being interpreted as 1080p23 resulting in dropped frames on playback instead of 1080p50.
Is there a known issue with handling of frame rates other than 23.98fps and 25fps, especially with 720p source?
IanD is online now
Reply Blu-ray Players
Blu Ray Players , Oppo Bdp 93 Blu Ray Player
