Official OPPO BDP-93 Owner's Thread - Page 944 - AVS Forum | Home Theater Discussions And Reviews
 607Likes
post #28291 of 28313 Old 09-01-2017, 12:37 PM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
Originally Posted by drvais View Post
Is there a readfile included in that firmware? I'd like to see all that it addresses.
Its a BIN and sign files,they will send it to anyone that wants it,i can send it if allowed
Michaeldef is offline
post #28292 of 28313 Old 09-01-2017, 01:01 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3688 Post(s)
Liked: 4814
^ Talk to OPPO before installing any special, limited release versions like that. Such versions have not been released publicly because there are likely known problems in them for certain configurations. OPPO can help you decide whether a special version of firmware is worth a shot based on the problem you are having and your configuration.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #28293 of 28313 Old 09-01-2017, 02:58 PM
rdgrimes's Avatar
Quoted: 2449 Post(s)
Liked: 1764
Originally Posted by Michaeldef View Post
Oppo sent a Beta firmware that perfectly fixed the issue, Thanks so much, Now if i can find an ISO to ? convertor for existing ISO files
If you have a LOT of them, consider getting a regular media box that handles ISO files. Several of the current batch can handle 4K displays.
rdgrimes is online now
post #28294 of 28313 Old 09-01-2017, 03:00 PM
drvais's Avatar
Quoted: 131 Post(s)
Liked: 72
--Bob
Good call, thanks!
unOFFICIAL D-Box FAQ here!
unOFFICIAL D-Box HEMC FAQ here!
Hail to the King, baby!
drvais is offline
post #28295 of 28313 Old 09-02-2017, 08:07 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
--Bob
Correct,that is the road i went,they knew right off,after advising to change cables first, I did tell them if power off tv or disconnecting hdmi to tv,the player came back to life.Hated losing ISO,but upgrading nets the same results. I did not want a 4K,but my beautiful last of 3D Vizio M80 panel puked, Thank You for the expertise
post #28296 of 28313 Old 09-02-2017, 08:59 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
Loss of Drive names
Is there a way to restore the 3 drives names from a usb hub via usb cable to player ? the 93 used to show Phantom, Toshiba,and Western Digital drives,now shows usb1,2 and 3, after it is turned on,the PC's show the exact names as the 93 used to
post #28297 of 28313 Old 09-02-2017, 09:01 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3325 Post(s)
Liked: 2595
You should report this to OPPO. I am still seeing volume labels on directly attached drives, but am not using a hub.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #28298 of 28313 Old 09-02-2017, 10:01 AM
rdgrimes's Avatar
Liked: 1764
Try rebooting the hub.
post #28299 of 28313 Old 09-03-2017, 06:08 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
No avail there either.Strange
post #28300 of 28313 Old 09-03-2017, 06:21 AM
rdgrimes's Avatar
Liked: 1764
What is shown if you plug the drives directly into the Oppo without the hub?
post #28301 of 28313 Old 09-03-2017, 07:24 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
with only one drive at a time no hub directly to rear usb it shows usb 1
post #28302 of 28313 Old 09-03-2017, 08:02 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
same results via front usb also
post #28303 of 28313 Old 09-03-2017, 08:20 AM
rdgrimes's Avatar
Liked: 1764
My 93 has always had some degree of flakiness with USB drive labels, or failing to mount them in the first place. Always cleared by combinations of rebooting and/or hot plugging/unplugging the drives.
Last suggestion is to do a reset to defaults of the player, then unplug it and hold down the power button for 30 sec, then reboot.
post #28304 of 28313 Old 09-03-2017, 08:32 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
Thank you Sir will try that, Emailed Oppo but its a holiday weekend per Monday. Its been like that for weeks for the labels as its labels just went away same drives forever,Even before HDCP 2.2 issue, with the beta firmware installed,the settings stayed,so it makes sense as it has not been reset to defaults in years,Thanks so much,Regards, Michael
post #28305 of 28313 Old 09-06-2017, 03:38 AM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
Originally Posted by BSTNFAN View Post
For the players that have the old ISO capable firmware, I think there are a few discs that have trouble playing. They were fixed in later firmware, but then you lose the ISO capabilities.
However, the benefit of still having ISO capability is that you can process the title to remove DRM which causes the trouble playing. In effect, the problem is its own solution.
IanD is offline
post #28306 of 28313 Old 09-06-2017, 04:10 AM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
You don't need a converter for 2D Bluray: just mount the ISO using RedFox Virtual CloneDrive and copy the entire folder/file structure to a named folder; the Oppo 93 will play folder/file structure generally the same as an ISO. However, the ISO must be already unprotected: if it's simply an Imgburn copy, it will need to be passed through AnyDVD HD to remove the protection. The Oppo 93 won't play a protected ISO or folder/file structure.
3D Bluray are a different kettle of fish as they use sector mapping in an ISO to halve the actual referenced file sizes, so when you copy the folder/file structure you get approximately double the disc size. There is a way around this: you can delete the 2D movie m2ts files from the folder to reduce it to close to the original disc size and the 3D files will still play, but I'm not sure if it can be played as 2D. Alternatively, I think BDRebuilder can create a new folder/file with just the 3D movie only.
Of course you can use other software to convert the ISO into other forms such as mkv, but if you want to keep menus and extras, then an ISO or its folder/file structure equivalent is necessary.
IanD is offline
post #28307 of 28313 Old 09-06-2017, 05:56 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
All of thre ISO files in question are 5.1 music files,so i will make time for those, Now i have created another monster of trying to rename drives per Oppo, now 2 of the drives say they must be formatted,one drive is 3/4 full the other not much of anything,The third Toshiba drive now says Toshiba again,Good Grief, Thank You for those options
post #28308 of 28313 Old 09-06-2017, 02:31 PM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
All drives fixed through cmd on windows Now i need a link to convert music 5.1 ISO files step by step for dummies into something playable for BDP 93,Before Hurricane takes it all away !
post #28309 of 28313 Old 09-06-2017, 04:32 PM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
Music files are DVD structure I believe. IIRC, only DVD ISO will play on an Oppo 93, not DVD folder/file structure: it's different for Bluray.
So yes, you will likely need a converter for music files. FLAC is the main "free" lossless codec, but not sure if a 93 with latest firmware will play it natively (I'm not really into music).
IanD is offline
post #28310 of 28313 Old 09-06-2017, 04:39 PM
wmcclain's Avatar
Liked: 2595
The 93 does support FLAC; I don't recall the number of channels.
-Bill
post #28311 of 28313 Old 09-07-2017, 07:46 AM
Michaeldef's Avatar
Quoted: 66 Post(s)
Liked: 26
-Bill
The BDP93 does indeed play 5.1 DTS flac files,as per Eat A Peach right now
post #28312 of 28313 Old 09-08-2017, 06:30 PM
007james's Avatar
Quoted: 22 Post(s)
Well, one thing to make sure is that you have High-Speed hdmi cable through the whole path even if it's not 4K, I did have to bite the bullet and Update to Oppos latest firmware, I wish I had tried swapping cables first. I hate losing ISO but what can you do? There are programs that will covert to 5.1 DVD-A but you loose graphics. See what happens when you break the law, crime doesn't pay! Seriously, I own the dvd-a's i should be able to do whatever I want
007james is offline
post #28313 of 28313 Old 09-12-2017, 05:41 PM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
ISO is not really required for Bluray: there are folder/file and remux options for 3D.
DVDs unfortunately are different in that they won't play as folder/file, only ISO, but you can always burn a backup to DVD-R and play as a disc or convert DVD-A to lossless mkv with video or Bluray folder/file (more complicated but it can be done).
This is assuming playback from USB drive: I'm not sure how practical it is to stream media to the Oppo.
IanD is offline
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
