Official OPPO BDP-93 Owner's Thread - Page 945 - AVS Forum | Home Theater Discussions And Reviews
 611Likes
post #28321 of 28348 Old 10-06-2017, 04:35 AM
anoutsos's Avatar
Quoted: 51 Post(s)
Originally Posted by Bob Pariseau View Post
The S/PDIF LPCM output setting is a rate LIMITER, not an audio upscale choice. It is used to protect gear that can’t handle the higher rates. The output will never be higher than the rate present in the content.
For Blu-ray movies, the output is also limited by Copy Protection rules. So even if the track happens to be 96kHz, the output on S/PDIF will be 48kHz (from the “comparability” track always present for just such purposes).
Expect Stereo LPCM 48kHz, and either 16-bit or 24-bit according to the source track
—Bob
Thank you for clarifying it for me, Bob. So, the CP does allow 24-bit sound via toslink, then. If so, then the difference between 96kHz and 48kHz may not be perceptible. In any case, I know that Audyssey XT32 (always engaged in my current system*) downsamples the signal to 48kHz, anyway. So, should I decide to go down the stereo pre-amp route, I may not notice a big sound-quality difference in movies, using its high-end DAC. Of course, the biggest difference would still be the transition between 5.1 to 2.0. I am still struggling to make that decision. :-)
*Marantz AV8801/MM8077
anoutsos is offline
post #28322 of 28348 Old 10-06-2017, 09:54 AM
scrufftyguy's Avatar
Does anyone know if this Oppo can be used as a server (with a connected hard drive) for Plex & Infuse 5 on Apple TV?
scrufftyguy is online now
post #28323 of 28348 Old 10-06-2017, 10:10 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1285 Post(s)
Liked: 1347
Nope; connected USB devices are only available to the Oppo itself.
scrufftyguy likes this.
gsr is offline
post #28324 of 28348 Old 10-06-2017, 10:12 AM
Oh well, thanks for the speedy reply.
post #28325 of 28348 Old 10-06-2017, 10:42 AM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
I experimented with Plex years ago and couldn't even get the 93 to play things from a computer-based Plex server! It can play from DLNA/UPnP servers on a LAN, just not a Plex server. Like other Oppos, it has the ability to play multichannel LPCM and FLAC files that way, which AV receivers will knock back to stereo if you use the receiver as the streamer, while the Oppos will stream them in their full multichannel glory.
I've since given the 93 to my wife to use purely as a disk player, and upgraded to a used 103, which works as a renderer so it can be controlled by the server without turning on my projector. I use Twonky as my file manager, BubbleUPnP Server (a Windows program) to control my renderers and Android BubbleUPnP to control my renderers, which can also play music and video from my setup over the internet when away from home, by linking to BubbleUPnP Server. The same programmer who wrote those two also wrote the UPnP plugin for Foobar2000 (also a Windows program) which can act as a renderer locally, as a player over the net, and as a file server for BubbleUPnP. The only reason I use Twonky as the media file manager is that unlike foo_UPnP it shows you album graphics while browsing, not just while playing. Only Twonky ($20) and Android BubbleUPnP ($5 at the Google Play store) cost money. Foobar, foo_upnp, and BubbleUPnP Server are all free.
For those "gapless play" enthusiasts who hate concerts being interrupted between tracks, the Yamaha RX-A1030 AV receiver can stream (and even render) gaplessly, though it still streams only in stereo. So I switch renderers in the Android app and play stereo concerts that way. (Yamaha doesn't even call that model a renderer, so I can't vouch for other models!)
Oh, and foo_upnp and Android BubbleUPnP include search capability that can find files by looking for any text embedded in a file's tags.
For more info about this, including links to get the programs I mentioned, go to my post about this subject in the RX-A1030 thread here.
scrufftyguy and sickkent like this.
Philnick is online now
post #28326 of 28348 Old 10-06-2017, 05:22 PM
Methodical_1's Avatar
Quoted: 421 Post(s)
Liked: 254
Well, I think I am going to have to step up to one of the newer Oppo model player - kinda forced to now. I'm starting my path towards 4k TV (researching OLEDs now) and plan to have one in my HT by years end. However, in the mean time, I purchased the King Kong 4k movie thinking I could just play the 1080 version until I get a UHD player and found out the 93 won't read the disk. It didn't dawn on me when I purchased the movie as I just was focused on the 1080P version of the movie on the disk. Is there a way to play this disc on the 93 that I may be missing?
HT Configuration: 7.2.4 l Panasonic Plasma (65") l Denon X4300H l Polk LSiM 707s, 706c, FXi-30 l Infinity ERS-610 l SVS PB-2000 (2x) l Monolith 7 l Behringer A500 (2x) l Oppo BD-93 l MH mmf-9.3 l Cassette Deck.
"Never be afraid to try something new, remember amateurs build the Ark, professionals built the Titanic"
Methodical_1 is offline
post #28327 of 28348 Old 10-06-2017, 05:26 PM
progprog's Avatar
Quoted: 94 Post(s)
Liked: 72
It's just a standard HD blu-ray....it should play on your 93. I'd think there's either something wrong with the disk...which you could test by trying on some other player...or with your player.
progprog is online now
post #28328 of 28348 Old 10-06-2017, 05:30 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2654
The standard Blu-ray doesn't play? What happens, what is the error?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #28329 of 28348 Old 10-06-2017, 05:30 PM
Quoted: 421 Post(s)
Liked: 254
I thought so.
Update: I checked another player and the same thing. I'll be returning the movie this weekend.
Update: I had a duh moment. I placed the 4k movie in the player. All is good.
post #28330 of 28348 Old 10-06-2017, 10:04 PM
anoutsos's Avatar
Quoted: 51 Post(s)
Can anyone tell me if those HDMI de-embedders that they sell, for a few tens of bucks, actually outputs the full-resolution LPCM audio via toslink/coaxial? Does it bypass the CP on blu-rays, which limits the toslink output to CD resolution on the player? How big is the audio delay they typically introduce? Can audio/video be re-synced, after splitting?
anoutsos is offline
post #28331 of 28348 Old 10-07-2017, 05:10 AM
wmcclain's Avatar
Liked: 2654
On UHD players its always the other way around: people mistakenly play the BR when they wanted the UHD.
-Bill
wmcclain is offline
post #28332 of 28348 Old 10-07-2017, 06:57 AM
Quoted: 421 Post(s)
Liked: 254
-Bill
Glad to know I'm not the only one to have the doh moment - haha! I hope I don't do that when I get the UHD player.
post #28333 of 28348 Old 10-07-2017, 08:36 AM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
And I remember seeing at least one comment in the Blu-ray reviews section by a guy who didn't think the Blu-ray looked any better than a DVD - until he realized he'd played the DVD copy by mistake.
I think this may often be caused by one of the disks being hidden by a paper insert inside the case - whether for registering the streaming version or just an ad for other disks!
post #28334 of 28348 Old 10-07-2017, 09:53 AM
Quoted: 421 Post(s)
Liked: 254
Originally Posted by Philnick View Post
...I think this may often be caused by one of the disks being hidden by a paper insert inside the case...
You are correct because that's what happened to me.
post #28335 of 28348 Old 10-07-2017, 09:41 PM
IanD's Avatar
Quoted: 108 Post(s)
Liked: 59
Plus the studios often labeling UHD and Bluray discs almost identically. They used to do something similar with some Bluray discs and their Bluray extras discs or with separate Theatrical and Extended versions. I think Paramount was the worst offender, using a plain grey background to the artwork and tiny lettering which did not distinguish between discs very well.
Personally, I think discs need to be colour coded according to a standard to readily differentiate them: I always have to don reading glasses to tell the discs apart.
winoman likes this.
IanD is offline
post #28336 of 28348 Old 10-09-2017, 07:19 PM
ddell's Avatar
Oppo Remote App & IOS 11
I "upgraded" my iPhone to IOS 11, and my much beloved Oppo Remote App has stopped working. Any news on whether OPPO intends to make Oppo Remote IOS 11 compatible?
David
ddell is offline
post #28337 of 28348 Old 10-09-2017, 07:31 PM
Phil Tomaskovic's Avatar
Quoted: 175 Post(s)
Liked: 33
I reported it to them and initially got the old “reboot your router, check your network...”. Told them I did all that and they said they would look into it. Might be worth you sending an email to support also.
Sometimes it works if I restartt the app multiple times.
Phil Tomaskovic
Phil Tomaskovic is offline
post #28338 of 28348 Old 10-09-2017, 07:35 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3787 Post(s)
Liked: 4927
^ The Remote app is currently showing in the iOS App Store as not compatible with iOS 11.
You’d need to ask OPPO Tech Support directly as to status.
—Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #28339 of 28348 Old 10-10-2017, 01:42 PM
ddell's Avatar
I did contact Oppo, and they just said their engineers are working on it. No time estimate. Sadly, I didn't feel much sense of urgency. I understand the futility of giving dates, as I used to manage software development projects. I would have like some sense of remorse that that it wasn't ready in time for the rollout of ios 11.
David
ddell is offline
post #28340 of 28348 Old 10-11-2017, 03:07 PM
wl1
wl1's Avatar
Quoted: 247 Post(s)
Liked: 200
I understand the App is 32 bit, and Apps have been 64bit compatible for a while. Oppo (or whoever writes their Apps) must have seen this coming. I think Ios11 is 64bit only.
Mildly annoying, but considering they haven’t got the 203 app sorted (e.g remembering night mode), I think it could take a while for a 93 App rewrite.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #28341 of 28348 Old 10-12-2017, 01:26 PM
WestCoastD's Avatar
Quoted: 291 Post(s)
Liked: 110
Hello:
Not sure why my BDP-93 (and even BDP-103 & BDP-105) fail to recognize or playback the audio tracks on certain .MOV files? These are files generated from my Nikon S8100 digital camera and downloaded to my network drive(s). Some files, recorded and downloaded from the same event, will playback fine. While most others fail. After file loads I get message: "The audio format is not supported", then the video plays back with no audio.
Windows Media Player will playback all files fine.
I'm curious if there are methods to update or fix this?
WestCoastD is online now
post #28342 of 28348 Old 10-12-2017, 01:31 PM
wmcclain's Avatar
Liked: 2654
Originally Posted by WestCoastD View Post
Hello:
Not sure why my BDP-93 (and even BDP-103 & BDP-105) fail to recognize or playback the audio tracks on certain .MOV files? These are files generated from my Nikon S8100 digital camera and downloaded to my network drive(s). Some files, recorded and downloaded from the same event, will playback fine. While most others fail. After file loads I get message: "The audio format is not supported".
We would have to know the audio codecs involved, of which there are many. The FAQ has a list of types known not to be supported.
There is a free utility called MediaInfo. Check the output from that for the files than do and don't work and see if there is a pattern.'
-Bill
wmcclain is offline
post #28343 of 28348 Old 10-12-2017, 01:52 PM
WestCoastD's Avatar
Quoted: 291 Post(s)
Liked: 110
-Bill
thanks Bill. I'm on the MediaInfo site right now. Just want to make sure I'm downloading the correct utility app:
https://mediaarea.net/en/MediaInfo/Download/Windows
I using Windows 10, I would think this is the proper version to load:
v0.7.99 Universal (32/64 bit) (64 bit only without installer)
Appreciate your help
post #28344 of 28348 Old 10-12-2017, 02:48 PM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
Hello:
I ran up against this with the MOV files from my Canon DSLRs as well. What I found was that Canon DSLRs (and perhaps Nikon as well) write a mutant form of MOV file with the bit order of the audio reversed, yielding what is called a SOWT file. (That's "TWOS" spelled backwards!)
I got a more pronounced error with my 93 - it wouldn't play the file at all. After that message it just bailed.
I ended up using my Win 7 PC to play the files through my AVR instead of the 93.
Otherwise, you'll have to do a file conversion to mp4 or other format, which can be very time-consuming.
post #28345 of 28348 Old 10-12-2017, 02:57 PM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
I'd use the version with an installer unless you're advanced enough to do the installation yourself.
post #28346 of 28348 Old 10-12-2017, 05:25 PM
wmcclain's Avatar
Liked: 2654
I get it via my linux distribution. On Windows I would use the one marked "If you don't know which one to download, download this one".
-Bill
wmcclain is offline
post #28347 of 28348 Old 10-12-2017, 07:15 PM
Philnick's Avatar
Quoted: 256 Post(s)
Liked: 115
-Bill
Exactly! That one has an installer that will not only choose the correct version for your machine, it will also put it in the correct program files folder tree (on 64 bit systems there are two) and make whatever registry entries are needed to make it work!
post #28348 of 28348 Old 10-12-2017, 10:31 PM
WestCoastD's Avatar
Quoted: 291 Post(s)
Liked: 110
really appreciate your input here. Yeah, I'm definitely going with the "installer" version of MediaInfo app.
And, yes, it seems the Nikon firmware builds the MOV file with a susceptible audio file format.
I will install MediaInfo and get back
Reply Blu-ray Players
BDP-95 , Blu Ray Players , multiregion , Oppo Bdp 93 Blu Ray Player
