Official Sony BDP-S480 Owner's Thread. All questions and comments go here - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #271 of 290 Old 03-02-2014, 01:53 PM
jkidman's Avatar
Any suggestions on an inexpensive receiver that can handle 5.1 plus?
jkidman is offline
post #272 of 290 Old 03-02-2014, 04:03 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Pretty much any current receiver can decode all of the newer audio codecs, including DD+.
BIslander is offline
post #273 of 290 Old 03-04-2014, 09:36 AM
marktherob2001's Avatar
I got a great deal on a Onkyo TX-NR616. You can throw anything at it including DSD on a USB key and it plays.
I updated my S480 to M07R0579 firmware this morning. It still plays SACD-R.
marktherob2001 is offline
post #274 of 290 Old 04-27-2014, 12:00 PM
Vio72's Avatar
Sony Blu-Ray BDP-S480 - can't get 1080p output - drops to 480i
Just installed a new Yamaha RX-v475 receiver with my sony blueray and my samsung 1080p tv.
All connected via hdmi.
When I turn the blueray player on (hdmi 2) and play the movie (blueray movie) the TV goes intol 480i mode and the blueray player says the output resolution is restricted. View/listen using hdmi-connected device.
Any ideas?
E.D.
Vio72 is offline
post #275 of 290 Old 04-27-2014, 02:04 PM
venejo's Avatar
Try to update both TV & Bluray's firmware.
Sony BRAVIA KDL-40EX720, Sony BDP-S480, Pioneer VSX-521-K, LaCie mini HD connect.
venejo is offline
post #276 of 290 Old 04-27-2014, 05:04 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Any ideas?
E.D.
The movie studios have excessive paranoia about copying our precious blu-rays to some other HD media via analog (why anyone would want to do that is beyond me) and thus forced manufacturers to limit resolution on analog video connections (component). Dropping to hdmi in these newer players sounds like this might be what is happening to you, if the player thinks you are also sending video over component.
I assume you have no component or composite video cables connected in your system anywhere (ONLY hdmi going between your blu-ray player, receiver and TV)..
You might try going into your blu-ray player setup and make sure HDMI is specified as the primary/only output for video.
Double check settings in your receiver also.
A long-time audio/video addict!
Rich86 is offline
post #277 of 290 Old 04-27-2014, 05:41 PM
Vio72's Avatar
Thanks for the tip - I'll have a look and post back! Thanks!
Vio72 is offline
post #278 of 290 Old 04-27-2014, 06:48 PM
JoeSchmoe007's Avatar
Quoted: 21 Post(s)
Any ideas?
E.D.
This is most likely infamous HDCP handshake issue that was supposed to be all sorted out years ago. This means that your display thinks your input device doesn't provided required copy protection and drops down resolution to 480P.
How was blu-ray player connected before?
If you connect bluray player directly to TV to the same HDMI port - is there still a problem? If there is no problem then it is incompatibility between BDP and Yamaha. Try different HDMI ports on Yamaha and on TV - sometimes this helps. On my TV Roku doesn't work on one of the HDMI ports (other devices work on this port).
JoeSchmoe007 is offline
post #279 of 290 Old 05-03-2014, 08:12 AM
Try updating using this firmware http://esupport.sony.com/US/perl/swu-download.pl?upd_id=7206&os_id=99&mdl=BDPS480
This will not screw up cinavia or screw up the ability to play SACR-R.
It gives a firmware update that allows the above before sony closed the door on these functions. They now sell players that have closed he door.
Mark
post #280 of 290 Old 05-06-2014, 09:11 AM
Vio72's Avatar
I've unhooked the BRP from my receiver and plugged directly into the TV, via HDMI.
When the BLP starts up - it looks fine - plays in HD - 1080i. When I play a BR movie, that's when it drops to 480i.
Weird.
I'm going to look at firmware this evening as well as other BRP settings.
The other thing that I am wondering is - before I play a BR movie, why does the screen display at1080i, rather than 1080p?
What a pain in the neck! ;-)
E.D.
Vio72 is offline
post #281 of 290 Old 05-06-2014, 02:14 PM
Quoted: 21 Post(s)
Weird.
E.D.
Did it ever play BR at 1080i or 1080P on your TV in any setup?
post #282 of 290 Old 05-09-2014, 09:23 PM
malcolmst's Avatar
I just wanted to point out that now it is possible to downgrade :). I have some utilities on my website for anyone who's interested: http://malcolmstagg.com/bdp-s390-downgrade.html . Some people have successfully downgraded the s480, among other players.
sam298 likes this.
malcolmst is offline
post #283 of 290 Old 05-18-2014, 11:30 PM
jfron's Avatar
Hi all,
So I've been having some problems regarding the aspect ratio of .mkv files that are formatted for 720P/1080P. Those files in particular, regardless of the aspect ratio, the picture is stretched to the full size of the screen. Therefore, 2.35:1 is stretching to 1.85:1 (which from a trained eye is completely unwatchable). This only seems to happen with the HD content, as I have tested it with 576P and lower and the black bars show on top/bottom for those aspect ratio. Store bought BD/DVDs display the correct aspect ratio, as does Netflix/Hulu and all that jazz.
Any help?? This is extremely frustrating as I am having to downgrade my files in order to get a watchable file frown.gif
jfron is offline
post #284 of 290 Old 05-19-2014, 05:49 PM
jfron's Avatar
Any ideas, guys? I realize that I posted this pretty late.
jfron is offline
post #285 of 290 Old 05-29-2014, 01:02 PM
jfron's Avatar
Cool, thanks everyone!
jfron is offline
post #286 of 290 Old 08-29-2014, 07:27 AM
sam298's Avatar
Originally Posted by malcolmst View Post
I just wanted to point out that now it is possible to downgrade . I have some utilities on my website for anyone who's interested: http://malcolmstagg.com/bdp-s390-downgrade.html . Some people have successfully downgraded the s480, among other players.
I upgraded to latest version that had cinavia. Tried some hex editing to downgrade but no luck. Thanks for this utility. Works great.
Onkyo TX-NR616 with Mirage OS3 7.1 / Sony 55HX800
Pioneer SC-95 | Polk In-wall | SVS PB-2000 | Marantz UD5005
Pioneer BDP-140 / Benq W1070
sam298 is offline
post #287 of 290 Old 09-06-2014, 12:38 PM
lind777's Avatar
Blu-Ray Player's MP4 Playback Capability using USB Drive
I currently have a Sony BDP-S480 Blu-Ray player and it does provide playback of MP4 files but it stretches them to fill a 16x9 screen and I can not figure out how to not have it stretch it. I have tinkered with all the settings and nothing outputs it at its native resolution. Does anyone have a Blu-Ray or DVD player recommendation which gives more control over the playback of MP4 files? Recommendation on that even does a good job at playing back MP4s. Being able to navigate my collection with a remote is a must.
lind777 is offline
post #288 of 290 Old 02-09-2015, 07:40 AM
Liked: 0
Disable upscaling
Hi there,
I own a bdp-s480 for quite a while now and am very happy about the upscaling of the bluray player. Nervertheless, i recently acquired a activehd elite cable with marseille shipset capable of 4K upscaling.
My problem is that in order to get upscaling from the cable i need to disable the one from the bdp-s480 which so far i wasnt able to.
In the option i have put BNR/FNR/MNR to a stop but the bluray player still output in 1080p/50 anything i read (DVD, 720p mkv files...).
What else can i do in order to shut down upscaling? thx for your help.
smulder1977 is offline
post #289 of 290 Old 02-09-2015, 12:59 PM
Liked: 0
Originally Posted by smulder1977 View Post
Hi there,
Found the answer by myself:
screen config -> output format -> native size
post #290 of 290 Old 01-05-2016, 10:53 PM
Crimsoncleaver's Avatar
Quoted: 72 Post(s)
Liked: 27
Can the player make a difference to 3D?
I have a Sony BDP-S480.
It's quite an early 3D blu-Ray player model, and was wondering, can a player make a difference for 3D performance?
I have a passive Sony 79X900B TV which does perform really well, since a firmware update fixed fast action 3D performance. But very occasionally I see crosstalk etc, could changing my player reduce this?
Crimsoncleaver is offline
Reply Blu-ray Players
mp4 blu-ray dvd playback hardware
