Official OPPO BDP-95 Owner's Thread - Page 310 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #9271 of 11910 Old 08-01-2012, 09:18 PM
greylight44's Avatar
Quoted: 24 Post(s)
Liked: 24
When using the DVD 24p conversion, will the display info always read NTSC or will it read 24fps?
greylight44 is offline
post #9272 of 11910 Old 08-02-2012, 02:42 AM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 702 Post(s)
Liked: 598
Originally Posted by leo2498 View Post
Hi guys,
My BDP-95 arrived this saturday and I noted that it is get hot too much? It is normal? I put it in a cabinet sealed like you can see in this photo, it’s the hot problem?
I have mine in a cabinet with a slightly larger opening but with a door (which I keep slightly open during play). My cabinet also happens to have a slit opening in the back about 2 inches wide and 7 inches tall for cable access. Though I have never found the 95 very hot even after 4 hours of straight use, I think it's probably a good idea to allow the unit's fan to have the ability to draw in cooler air from the back through such an opening. If it doesn't, wait until the wife is gone and perform quick surgery on your furniture. smile.gif
marcuslaw is offline
post #9273 of 11910 Old 08-02-2012, 04:03 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2655
The On Screen Display of the player shows what's on the disc, so that will be unchanged with DVD 24p on or off.
The info on your display shows what the player is sending and that should read 24hz.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #9274 of 11910 Old 08-02-2012, 04:32 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1286 Post(s)
Liked: 1347
The fan is actually an exhaust fan, but the air it sends out needs to be able to go somewhere.
scanspeak likes this.
gsr is offline
post #9275 of 11910 Old 08-02-2012, 04:49 AM
Quoted: 1704 Post(s)
Liked: 731
Has any compared the 95 using AV709 to a known reference signal generator and can comment of whether or not the Oppo is outputting true reference? Specifically in the area of luminance.
JimP is online now
post #9276 of 11910 Old 08-02-2012, 04:56 AM
wmcclain's Avatar
Liked: 2655
I recall Spears & Munsil (or probably just one them) stating that the OPPO does put out reference levels. This has been true of all of their players. I don't have a link.
OPPO assisted in the creation of the S&M calibration disc, a sign they take this sort of thing seriously. It gets tested pretty extensively.
-Bill
post #9277 of 11910 Old 08-02-2012, 05:09 AM
wmcclain's Avatar
Liked: 2655
The remarks from S.Spears I was thinking of were from the BDP-83 days, but the current players will be the same in this regard:
http://www.avsforum.com/t/1131344/high-definition-benchmark-bd-edition-by-stacey-spears-and-don-munsil/570#post_18182916
OPPO has text book perfect video leves with all controls at default. Measured the output using an HDMI analyzer.
http://www.avsforum.com/t/1206484/spears-munsil-calibration-advice/30#post_19093763
The levels out of the OPPO are equal to a test pattern generator. By that I mean they are perfect by default. If you adjust contrast in the OPPO, you are trying to work around a shortcoming in something else downstream.
Best quality is obtained by adjusting the picture controls on the display.
http://www.avsforum.com/t/1054927/official-pioneer-elite-bdp-05fd-bdp-51fd-owners-thread-vs-1-32-dts-hd-ma/16470#post_16140244
When we first met with OPPO, they told us not to build a disc to make their player look good. They said that if it exposes problems, they will fix them. With that said, the first build of the disc found issues with their player during beta. So far they have fixed every single one.
-Bill
post #9278 of 11910 Old 08-02-2012, 05:09 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3788 Post(s)
Liked: 4927
Better yet, I've seen the result of HDMI digital data captures. The OPPO puts out reference HDMI signals when it's Picture Adjustment settings are left on their Factory Default (0) values. Its Luma output correctly matches Content Luma for the full range of Content Luma.
The numerical values found in the gray scale bars on Spears & Munsil Blu-ray are a reliable Content Source for doing fine checks of Luma -- down to individual Luma step values. For example see the Dynamic Range High and Dynamic Range Low charts.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #9279 of 11910 Old 08-02-2012, 06:17 AM
Liked: 731
Thanks everyone.
Would it be fair to say that I should be using the S&M disc rather than the AVSHD709????? What about window size to prevent measurement problems on the 65VT50. Apparantly, window size is an issue with this display.
JimP is online now
post #9280 of 11910 Old 08-02-2012, 06:25 AM
wmcclain's Avatar
Liked: 2655
Thanks everyone.
I use both for adjustment by eye. If you are using a meter you need the AVS disc; S&M doesn't have the patterns.
-Bill
post #9281 of 11910 Old 08-02-2012, 08:41 AM
enthuzist's Avatar
That is what I did. Now I have a few of these CAB-COOL Cabinet Coolers on both sides of my center. The thermostat ensures that it only runs when needed and is very quiet.
Mitsubishi WD-92842, Onkyo HT-S9400THX, Oppo BDP-93, XBOX 360 w/Kinect, XBOX (modded), WD My Book Essential, FiOS Bundle
enthuzist is offline
post #9282 of 11910 Old 08-02-2012, 10:08 AM
leo2498's Avatar
Quoted: 63 Post(s)
Thanks for your answer, the hot problem was when I touched the metal in the bottom of the oppo, it no burn my finger but I feel that is more than warmer, when you said is not very hot after 4 hours it is a little more that warmer? by the way, from the back wall to the back of the bdp95 are maybe 4 o 5 inch with a small hole(3" diameter) for cable entry.
Leo,
Saludos
My HT: B&W 804D fronts, HTM4D center, 805D rears, Classe CA-2300 Main amp, Preamp Stereo CLASSE CP800, Preamp Multi Channel Marantz AV8801, A31 parasound center and Surround Amp, Source Oppo BDP-95 screen Samsung 55" UE55d8000 SVS SB12-NSD
Stereo: B&W 804S fronts, Pre: Denon AVR-2809CI amp Rotel RB1582.
leo2498 is offline
post #9283 of 11910 Old 08-02-2012, 10:14 AM
rdgrimes's Avatar
Quoted: 2481 Post(s)
Liked: 1785
The bottom plate of the player is designed to be a major component of it's cooling. IOW it's supposed to get warm. This is the reason that removing the player's feet is not recommended. Of course, any heat coming from below will add to that.
rdgrimes is offline
post #9284 of 11910 Old 08-02-2012, 01:24 PM
leo2498's Avatar
Quoted: 63 Post(s)
thanks for the clarification, I'm thinking the same thing but I don't want missing any problem or issue with temperature for this special racks.
Leo,
Saludos
leo2498 is offline
post #9285 of 11910 Old 08-02-2012, 02:03 PM
rdgrimes's Avatar
Liked: 1785
If you're really concerned there are a few things you can do. 1st, make a 3" hole in the back of a cabinet directly next to the player's fan opening. 2nd, after 2 hrs of BD playback, listen closely for the player's fan noise. If the fan is running fast, it's probably too hot. 3rd, get a thermal sensor to measure the temp of the player's exhaust air. It think the target internal temp for the player is around 125' F.
rdgrimes is offline
post #9286 of 11910 Old 08-02-2012, 05:51 PM
wmcclain's Avatar
Liked: 2655
OPPO has given me permission to add some additional background info to the FAQ entry Is DVD 24hz conversion supported?:
How is it done?
The OPPO developer who implemented this feature provided these comments:
As noted, there is no on-the-fly switching from 1080p60 output to the 1080p24 output when 3:2 cadence is detected. Once DVD 24P Conversion is set to ON, the player will output 1080p24 for any 480i content source. If the source does not have the proper 3:2 cadence, the output will have apparent motion judder caused by incorrect frame dropping.
The BDP-83's DVD 24p implementation was to monitor the de-interlacer to detect reliable 3:2 cadence. Once it is detected, the video processor is then switched to 1080p24 output. This causes a new HDMI handshake in the middle of playback. If later on the de-interlacer loses lock to the 3:2 cadence, frame tearing can happen.
For the BDP-93's Marvell Qdeo KG2 processor, we can program it to any output frame rate. During the initial development we tried 1080p24 output for DVD, and the result was not good. The video processor drops frames based on the required output frame rate. We randomly got smooth video at one time, and very jerky motion at another try. Any trick play operation such as pausing or fast forwarding could turn a good case into bad. Marvell told us that the KG2's frame rate converter could not be controlled by the de-interlacer to drop only the duplicated frames. This is why DVD 24P Conversion was not offered for the BDP-93/95.
Fast forward two years and I learned a way to isolate the input and output video clock. The de-interlacer can then be configured to do 3:2 -> 1:1 cadence conversion, and write the results to a frame buffer chain. The output side, no longer constrained by the input video clock, can read from the frame buffer chain and output at 23.976 frames/second. Although the KG2's documentation and reference code do not show such a use case, we were able to apply it successfully to the KG2 processor used in the BDP-93/95.
The 3:2 -> 1:1 cadence conversion works well in our test if the input is really 3:2. It can recover from a bad cadence nicely, unlike the BDP-83. If the input is not 3:2, but 2:2 or video, the result will be incorrect but there will no tearing. Users can expect to see motion judder if the input cadence is not suitable for 24p conversion. We make the conversion option available during playback so users can switch it off if it does not work well for the content being played.
The developer said this work was nothing to brag about, but I say: I'm not worthy.
-Bill
post #9287 of 11910 Old 08-02-2012, 06:32 PM
leo2498's Avatar
Quoted: 63 Post(s)
thanks I will try to use your advice and let you know how is it.
Leo,
Saludos
leo2498 is offline
post #9288 of 11910 Old 08-02-2012, 07:22 PM
fuzzybk's Avatar
Using a BDP-95 with a Panasonic 65VT50, is it better to output 422, 444 or RGB?
I just had my 65VT30 THX calibrated. I told the calibrator I might get the Oppo 95 to go with it. (I currently have a Sony BDP-S5000ES) The calibrator said if I did get the Oppo 95, I should use 4:2:2.
Opps, just saw it said 65VT50 and not 65VT30. Please ignore.
Cheers from the Great White North.
My gear: ANTHEM AVM50v, STATEMENT A5 - ARCAM DV139, CD17 - PANASONIC 65VT30 (THX Calibrated) - SONY BDP-S5000ES - PANAMAX 5500EX - M&K V1250THX sub - TANNOY EYRIS DC3, DCC, DC1 - AUDIOQUEST Cables - SHUNYATA RESEARCH Power cords - HARMONY One - PRIMACOUSTIC Recoil Stabilizers - BLUESOUND Node
fuzzybk is offline
post #9289 of 11910 Old 08-03-2012, 10:25 AM
darcman's Avatar
Quoted: 34 Post(s)
Liked: 27
Hi I have had my 95 for a few weeks now and ya its awesome. I debated between the 95 and 93 and just thought might as well get the best. I do a fair bit of 2 channel flac listening so the 95 won out. I have a Yamaha RX-V1900 receiver, an Emotiva IPS-1 amplifier. and Energy Veritas V1.8 speakers. To be honest the 95 with only hdmi connections sound great. If you really want to extract everything the dedicated analogs are even better.
I have a WD 1tb elements hardrive that I hooked up via usb to try out, ya works great powers the drive on and off too. I wanted to use the ESATA on the 95 so I picked up a WD 1tb My Book AV. The My Book AV is kinda pricey considering I could have got a WD 2tb My Book essential for the same price. The My Book AV is supposed to be built for home theater demands and it does have esata and usb 2.0 interface. The My Book AV works great via the esata but the 95 wont power it off. The only gripe I would have with the 95 is that the search is very slow as I have about 600gb of flacs. Maybe this could be fixed with another firmware update.
I had the 95 hooked up with fairly inexpensive rcas. I decided to try some xlr to rca cables. Ya I know all that I read said they are not the best. I tried it anyways and I swear the 95 sounds even better. Heres a link to the cables, they are pretty nice. They have other reasonably priced cables too.
http://www.ebay.com/itm/3ft-Pro-Series-2-XLR-Female-2-RCA-Male-Audio-Cable-CablesOnline-XR-A103N-/280874783341?pt=LH_DefaultDomain_0&hash=item416571126d
Oh ya about the only other negative is that I too experienced the netflix freeze issue but sounds like they have a fix in the works. Another thing that I am happy to report is that mine doesnt have a noisy fan problem. I have checked and the fan was on but I couldnt hear it.
darcman is offline
post #9290 of 11910 Old 08-03-2012, 10:44 AM - Thread Starter
Neuromancer's Avatar
Quoted: 96 Post(s)
Liked: 370
The Netflix issues have been resolved with the latest Beta Firmware
Neuromancer is offline
post #9291 of 11910 Old 08-03-2012, 10:51 AM
Liked: 731
So has anyone tried out the public beta software?
If so, what have you found?
JimP is online now
post #9292 of 11910 Old 08-03-2012, 11:23 AM - Thread Starter
Quoted: 96 Post(s)
Liked: 370
It works very well. If you find that it wasn't, then you can easily return the player to the current 66-0413 Firmware.
post #9293 of 11910 Old 08-03-2012, 05:14 PM
bakerwi's Avatar
Quoted: 81 Post(s)
Liked: 46
From the photo you provided it looks like your BDP-95 sitting above a PrePro or AVR. Is that correct?
Home theater - LG OLED65E6P, Sony UBP-X800, Oppo UDP-203, Arcam FMJ BD300, Denon DVD-5910
Master bedroom - Oppo BDP-103
Breakfast area - Pioneer BDP-320
Office - Sony BDP-S5000ES
Family room - Pioneer BDP-320, Sony BDP-S790
Revel Performa3 F208, C208, M106, M105
bakerwi is offline
post #9294 of 11910 Old 08-03-2012, 07:16 PM
classicrecording's Avatar
Quoted: 46 Post(s)
Liked: 94
I had severe problems with Netflix freezing up, but I installed the latest firmware and watched several movies in the last few days without a single problem.
Good show Oppo!
classicrecording is offline
post #9295 of 11910 Old 08-03-2012, 09:10 PM
leo2498's Avatar
Quoted: 63 Post(s)
Yes it do just on top of my denon 3310 but the denon only feed my center and surrounds.
Leo,
Saludos
leo2498 is offline
post #9296 of 11910 Old 08-03-2012, 11:05 PM
Liked: 731
leo2498
Does the denon run hot? If so.....well....you know what we're about to recommend. smile.gif
JimP is online now
post #9297 of 11910 Old 08-04-2012, 06:47 AM
bakerwi's Avatar
Quoted: 81 Post(s)
Liked: 46
leo2498
Jim,
That's where I was going.smile.gif Also, his rack looks very compact with limited space around his components unless it is just the photo he provided.
bakerwi is offline
post #9298 of 11910 Old 08-04-2012, 07:56 AM
leo2498's Avatar
Quoted: 63 Post(s)
Jim,
the denon have 3" between the wall of the rack, after 4 hour of use yes it is a little warmer and truly help with the heat problem. I have between back wall of the rack a fake cabinet to hide cables that is why the cabinet is sealed but I'm thinking seriously in a kind of surgey it if that could be a real problem.
A bigger pic of the rack:
Leo,
Saludos
leo2498 is offline
post #9299 of 11910 Old 08-04-2012, 08:59 AM
rdgrimes's Avatar
Liked: 1785
Based on what you've posted, there doesn't appear to be any big concern about heat. Use it and enjoy. But monitoring temps with a thermal sensor is easy and inexpensive.
rdgrimes is offline
post #9300 of 11910 Old 08-05-2012, 07:06 PM
mark_k's Avatar
:)one year and a half after its launch, Oppo 95 is still the best multi media player to me...smile.gif
Mark K
mark_k is offline
Reply Blu-ray Players
Blu Ray Players , Oppo , Oppo Bdp 95 Blu Ray Disc Player
