Official OPPO BDP-95 Owner's Thread - Page 372 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #11131 of 11869 Old 07-08-2014, 12:44 PM
_Jack_'s Avatar
3D menu & volume display
Hi guys,
This player is a 3D-player, but when I enter the 3D mode to play a movie
both the player menu, volume progress bar and sometimes the subtitles
are visible just for my right eye. In the left eye I can not see anything or
aside moved menu or the other displayed things.
That does not seem to be normal
By my friend, that has the Oppo 103D and a 4K TV the problem
is also present
What should I do to see that all properly while playing 3D blurays
or MKV movies ??
(my TV is a SONY KDL-46W905A - a new one)
Any hint would be very appreciated.
_Jack_ is offline
post #11132 of 11869 Old 07-08-2014, 01:09 PM
Smarty-pants's Avatar
Quoted: 748 Post(s)
Liked: 627
^ So what is the problem exactly? Are the subtitles not readable when they are on screen?
Why are you watching with only one eye? AFAIK, Captain Jack Sparrow doesn't wear an eye patch.
Smarty-pants is offline
post #11133 of 11869 Old 07-08-2014, 02:21 PM
JanEkstrom's Avatar
Originally Posted by riwi View Post
Hi Jan,
My 95 was software modded to be a US player. At the time I could not live with the fact that the EU model would not play mp3. It does now but my EU player is still US in firmware.
Regards Richard
Hi Richard
Thanks for fast reply - sorry to hear that as I had hoped for a verification...
How did you mod it to be a US version?
Regards
Jan
Oppo BDP 95 | Pioneer SC-LX87 | Panasonic P50VT20 | Pro-Ject RPM 5.1
Fronts: JBL L-112, Center: JBL LS Center, Backs: JBL Control One Pro, Sub: Velodyne SPL-1200 Ultra
JanEkstrom is offline
post #11134 of 11869 Old 07-08-2014, 03:01 PM
riwi's Avatar
Quoted: 13 Post(s)
The shop that sold it to me did that. I don't know how it was done exactly. The online stuff does not work because I am in the EU but I don't care about that.
riwi is offline
post #11135 of 11869 Old 07-09-2014, 12:32 PM
JanEkstrom's Avatar
^ Thanks for the answers Richard
(=) Jan
post #11136 of 11869 Old 07-12-2014, 09:51 AM
brucest's Avatar
I recently looked at an old (secrets of home theater) review of the Integra DHC 80.1 processor, August 2010. In a laudatory review Chris Eberle suggested that the digital coaxial input for CD's provided the best sound by a significant margin. He was using an Oppo BDP 83 as a source. He an a reference to jitter which I was able to link to. I assume that this means that this setup was utilizing the DAC's in the Integra rather than the Oppo. I have a 95 and and an Onkyo 886. I've now tried that hookup. Other than somewhat higher gain, I'm not sure I notice anything different. I would suspect that using the analog outs would take advantage of what should be superior 95 DAC's. Am I thinking about this correctly?
brucest is offline
post #11137 of 11869 Old 07-12-2014, 09:53 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2511 Post(s)
Liked: 3142
^ Digital audio output (HDMI or Optical/Coax) uses the DACs in the AVR only.
Analog audio output uses the DACs in the OPPO, and may *ALSO* use the DACs in the AVR if the AVR re-digitizes that Analog audio input for audio processing (e.g., Room Correction).
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #11138 of 11869 Old 07-12-2014, 12:59 PM
brucest's Avatar
Bypass
I think I'm able to bypass the Onkyo DACs and processing when I choose analog inputs for CD and chose direct feed.
brucest is offline
post #11139 of 11869 Old 07-19-2014, 07:50 PM
Liked: 0
The hd connected to the USB port works perfectly. Now I would like to use the OPPO as a DAC, ie. to convert the outputs from the PCs digital outputs (coax or toslink) but it doesn't seem to work. Coax and toslink are labelled as outputs in the OPPO manual. I read elsewhere I can do this using the USB - but I would need to have a male to male USB connector to do this. They are available but will it work? I can't seem to find anywhere to select additional inputs but it may be that as they are detected they will show up under the music selection like the hd does. Can the 95 be used as a dac for external sources?
Thanks in advance for any response.
Goober58 is offline
post #11140 of 11869 Old 07-19-2014, 07:56 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2769 Post(s)
Liked: 1994
Welcome to AVSForum.
The audio ports are output only. The USB ports are for mass storage devices only, so you need to mount a hard drive or USB stick.
You can access sources via a DLNA server.
The 103/105 series adds digital inputs.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #11141 of 11869 Old 07-19-2014, 09:11 PM
Liked: 0
Thank you wmcclain. I guess I'm in the market for an inexpensive, but decent quality DAC to convert my PCs toslink/coax digital output to line level analog for my preamp. Oh well this system will have two sources, a PC with a DAC and the OPPO-BD95. Come to think of it it's not like the videos I want to hear via the PC are high quality in the first place. But it would have been nice bypassing the OPPO hd gui and using foobar or iTunes instead.
Thanks again.
Goober58 is offline
post #11142 of 11869 Old 07-21-2014, 11:08 AM
Jon S's Avatar
Quoted: 803 Post(s)
Liked: 260
I have a Oppo BDP95 which has performed admirably since I bought it new over a year ago... Recently I have been having HDMI synching issues. Sometimes when skipping chapters, I would lose audio. The receiver will change from DTS HD Master to stereo on the display (which is the default when no signal is received). Now, when I power on the system, the receiver will sometimes not recognize the Oppo, the display showing no source.
I changed the HDMI cable and that did not resolve the issue. I also have a Pioneer BDP-09FD and it has not shown any problems when used, leading me to believe the issue is the Oppo. Any ideas?
I did a full reset on the Oppo last night. I hope maybe that will resolve the issue. Crossing my fingers. It is on the latest firmware. I think the issues appeared after the firmware was upgraded.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #11143 of 11869 Old 07-21-2014, 11:48 AM
Read the FAQ!
Liked: 3142
^ Get a flashlight and check the HDMI sockets and plugs for bent pins -- both ends of every cable in the HDMI signal path.
Note that new cables came sometimes be the cause of problems because kinks in the cable (from packaging) tug on the plugs. It only takes a small shift of plug in socket to screw things up.
Check whether the problems still exist with a lower bandwidth HDMI signal. Set the player's output to 480p (not 480i), and turn Deep Color OFF. Also set explicit choices for HDMI Color Space (YCbCr 4:4:4 is the usual default) and audio type. I.e., set HDMI LPCM or HDMI Bitstream, not AUTO.
If 480p and 1080i work but 1080p does not, check whether the problem is use of 1080p/24 output.
This is all just gathering evidence to see if the problem really is in the HDMI connections or something else.
Another thing to try is to switch the OPPO to an input on your AVR that is working well with some other device. This can help tell whether the problem is in the OPPO or in that AVR input.
--Bob
post #11144 of 11869 Old 07-23-2014, 01:13 AM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Hey OPPO owners, help me understand something ...How is it that the models, BDP-95 and 93 are being apparently sold for a considerably higher price than original (and current price of the of the standard BDP-103) on the used market??????(BDP-83s and BDP-85s are being marketed at over current 103 prices too!!!--on ebay, Amazon, audiomart, audiogon, etc)
vcrpro3 is offline
post #11145 of 11869 Old 07-23-2014, 05:12 AM
wmcclain's Avatar
Liked: 1994
Some have region-free hardware mods, which is value added.
The older players also have pre-sunset analog outputs, which some people still need, although that is a shrinking population with time.
The older players do not enforce Cinavia, which is a benefit to some.
For a few brief months, the BDP-93 and -95 had firmware which would play DVD and Blu-ray ISO files. Players with that firmware command a premium.
Otherwise: some outlets are just "sellers markets". I'm often surprised at what people are willing to pay on ebay. It makes no sense.
-Bill
post #11146 of 11869 Old 07-23-2014, 08:57 AM
Quoted: 748 Post(s)
Liked: 627
^There's a sucker born every day... on eBay
post #11147 of 11869 Old 07-26-2014, 08:34 AM
greylight44's Avatar
Quoted: 24 Post(s)
Liked: 24
I'm not 100% sure what the problem is yet, but I wanted to get some feedback since it's the weekend. After going to a 7.1 setup last week, I am now getting the pop/snapping sound through all speakers that was a problem with the firmware previous to the latest version. I am using the Multi-channel outs, which was the setup that had the problem with the previous firmware before OPPO fixed it. Anyone else experiencing this? I have the latest firmware, and did not have a problem for the first month or so with the 5.1 setup. I will be checking everything over the weekend, since I can't contact OPPO until Monday. Thanks.
greylight44 is offline
post #11148 of 11869 Old 07-26-2014, 09:10 AM
Read the FAQ!
Liked: 3142
^ OPPO Tech Support often monitor their email even on weekends.
The usual reason to get pops or snaps using the Analog outputs is that you have a ground level problem in your system -- a DC bias on the cable shields that causes a transient whenever the audio comes out of Mute.
Check this the same way you would check for "ground loops" (i.e., 60Hz hum). Disconnect as much as possible -- even down to just one speaker -- to see if the problem goes away, and then start reconnecting until the problem reappears.
The single most common source of garbage on the cable shields these days is stuff coming into your house on the shield of a cable or satellite TV feed. Test this by temporarily disconnecting that feed wire where it comes out of your wall.
Note that you have to physically disconnect cables to check this sort of stuff. The garbage travels between parts of your system along the shields of the cables connecting them, and the intervening devices don't even have to be turned on.
Since you have added cables to go to 7.1, you may also have a faulty cable (i.e., a faulty cable shield).
--Bob
post #11149 of 11869 Old 07-26-2014, 10:33 AM
Quoted: 24 Post(s)
Liked: 24
Thanks, Bob. Eliminating the center back speakers has eliminated the problem, and I will look into your suggestions as far as those 2 channels go. The sound I was getting was eerily similar to the problem I had with the previous firmware. The only other thing I would mention now, is the problem appeared with 5.1 discs, with everything set for 7.1 and the rear channels on.
Addition: I'm ordering new shielded cables, hoping this will eliminate the problem.
post #11150 of 11869 Old 07-27-2014, 08:13 PM
bathes2051's Avatar
My BDP95 has stopped recognizing firmware updates since the one before the September 2013 one (always says "Congratulations, you already have the latest firmware", despite having a valid network connection).
Did that happen to anybody else? Would I risk anything doing a USB upgrade?
bathes2051 is offline
post #11151 of 11869 Old 07-27-2014, 09:12 PM
Quoted: 748 Post(s)
Liked: 627
The USB and optical disk upgrades are simply an alternative to doing the upgrade by network.
It is odd though that your player says it has the latest firmware if the firmware is still an older version from September.
You may want to contact Oppo support about that before proceeding further,
but theoretically, using the USB method to update shouldn't be a risk.
post #11152 of 11869 Old 08-01-2014, 01:07 PM
smoorenc's Avatar
Quoted: 29 Post(s)
Jon S mine started same issue last week.
smoorenc is offline
post #11153 of 11869 Old 08-02-2014, 04:19 AM
smoorenc's Avatar
Quoted: 29 Post(s)
Disconnects stopped, thanks Bob Pariseau
--Bob
THANKS BOB, I make these changes
"Check whether the problems still exist with a lower bandwidth HDMI signal. Set the player's output to 480p (not 480i), and turn Deep Color OFF. Also set explicit choices for HDMI Color Space (YCbCr 4:4:4 is the usual default) and audio type. I.e., set HDMI LPCM or HDMI Bitstream, not AUTO.
If 480p and 1080i work but 1080p does not, check whether the problem is use of 1080p/24 output."
And mine started working correctly again. You are a savior!
smoorenc is offline
post #11154 of 11869 Old 08-02-2014, 06:06 AM
wmcclain's Avatar
Liked: 1994
What are your final settings?
-Bill
post #11155 of 11869 Old 08-02-2014, 10:29 AM
dintymoore2003's Avatar
Quoted: 16 Post(s)
My 95 no longer connects to my network. I've had it for almost 2 years now, and have always had it plugged into a Netgear switch along with other devices such as my AVR and WD Live box. The other devices are communicating, and even when I switch ports on the switch, the common issue is the 95 not communicating. Neither locally or to the internet. I unplugged and plugged the CAT cable as well. Cycled power, switched back and forth from wireless to ethernet, and nothing. Anyone else run into this recently?
dintymoore2003 is offline
post #11156 of 11869 Old 08-02-2014, 10:33 AM
wmcclain's Avatar
Liked: 1994
Is the LED on the ethernet port in the rear on?
Does this player show good IP values in Setup?
Have you tried a different cable? Rebooted the router?
-Bill
post #11157 of 11869 Old 08-02-2014, 10:37 AM
Read the FAQ!
Liked: 3142
If you have good IP values in Network Setup > Connection Info, see if you can PING that IP address from your computer. Check that no other device on your house network is trying to use the same IP address.
--Bob
post #11158 of 11869 Old 08-02-2014, 10:42 AM
Quoted: 16 Post(s)
-Bill
Green light is solid, amber light blinks, switches cables to one that I know works, and still nothing. Under connection info, it indicated not connected and gives me 000's for ip info.
post #11159 of 11869 Old 08-02-2014, 10:55 AM
Quoted: 16 Post(s)
-Bill
Rebooting the router worked. I should have known. I reboot that thing more than I should have to. I think I'm better off going with separate modem/router/WAP, than all in one Motorola box. Anyway, thanks for the quick replies!
post #11160 of 11869 Old 08-02-2014, 11:04 AM
wmcclain's Avatar
Liked: 1994
Excellent! Fans of the UK series The IT Crowd will know that the help desk solution to everything is:
  1. Is it plugged in?
  2. Turn it off and on again.
-Bill
Reply Blu-ray Players
Blu Ray Players , Oppo , Oppo Bdp 95 Blu Ray Disc Player
