Official LG BD690/670/650/6xx Series Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
post #2341 of 2344 Old 05-10-2016, 03:28 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Noticed with latest update my 670 lost the YouTube App.
NOT happy.
SanchoPanza is offline
post #2342 of 2344 Old 05-10-2016, 11:34 PM
FarmerBob's Avatar
Quoted: 80 Post(s)
Liked: 58
Mine didn't really lose the app, it just hasn't updated it as all other manufacturers have to work with the newer Youtube. Samsung has a history abandoning older models.
FarmerBob is offline
post #2343 of 2344 Old 11-30-2016, 01:32 PM
Quoted: 276 Post(s)
Liked: 207
Does the old BD610 model play 1080i/50Hz (25 fps) discs out of the box? I found a thread on another forum that lists players that accept 50Hz discs, and it seems many LG players handle 50Hz, but it seems to vary from player to player. Some LG players are listed as outputting 50Hz when playing 50z discs, no conversion. Other LG players convert the 50Hz signal to 60Hz output. The 611 is listed in that thread as outputting 50Hz but it seems nobody has reported any information on the 610 so it isn't mentioned. I bought the 610 for them from Wal-Mart many years ago as a gift. The manual says nothing about this either way - there's no mention of 50Hz anywhere. I called LG to ask and of course I'm not certain she knew what she was giving me for information. She claimed their internal documents say it will output a 50Hz disc as 50Hz but of course I'd like to confirm it here if possible, since you have to take anything you hear from customer service with a grain of salt these days. She sounded uncertain. When I called back and asked a second tech support representative, he said it doesn't and he had no information on it. So as usual with "customer support", they don't know their own products.
I'd like to buy Planet Earth II on blu-ray from Amazon UK as a gift, and they own the LG BD610. The discs are 1080i/50Hz (25.000 fps), region-free, just like the original Planet Earth series. I want to make sure their player can play the discs before I buy them. Their TV is a Vizio and I know it will accept both 50Hz and 60Hz signals, so as long as their player will play the disc, it should be fine whether it outputs the signal as 50Hz or 60Hz since either way their TV will accept it.
jerimiah is offline
post #2344 of 2344 Old 09-19-2017, 03:16 AM
Quoted: 346 Post(s)
Liked: 110
I tried searching this thread, but oddly, the results came back blank.
I'm hoping some current or former owners of the BD670 or similar can shine some light on the picture mode differences between "standard" and "user setting." User setting is visibly sharper while standard is visibly softer. The question is, is "user setting" adding artificial sharpness or is "standard" artificially softening the picture?
"User setting" mode lets you adjust some picture settings. Sharpness and noise reduction can be turned down or up from a default value of zero. I think this means that some sharpness and noise reduction is in effect at zero, which would mean turning them down all the way would turn them off. I'm just not sure.
Which picture mode provides the "purest" picture quality, without any enhancements?
LG OLED65B6P
no1special is offline
Reply Blu-ray Players
Blu Ray Players , Lg , Lg Bd650 3d Network Blu Ray Disc Player With Smart Tv , Lg Bd670 3d Wireless Network Blu Ray Disc Player With Smart Tv , Lg Bd690 3d Wireless Network Blu Ray Disc Player With Smart Tv And 250gb Hard Drive , New Lg 3d Blu Ray Player Smart Tv 1080p Bd650
