Official Panasonic DMP-BDT110/210/310 Owners Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 03-16-2011, 08:09 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Originally Posted by cage22 View Post
Thanks to all who responded regarding the High Clarity Sound.
FoxBat - I'll definitely be going HDMI. Could you enlighten me or point me to a good weblink regarding bitstream? If I don't use bitstream, what else would I be using?
Is bitstream where the AV reciever does the decoding of Dolby/DTS?
Correct. If you have an old AVR that can't handle new audio codecs, the player will decode for you automatically.
Unless you want Divx (in canada) or prefer have the wifi dongle included, or want watch your video bit rate on your screen all the time, BDT110 is as good as 220 as far as audio and video goes.
Foxbat121 is online now
Old 03-16-2011, 08:47 AM
stash64's Avatar
Quoted: 192 Post(s)
Liked: 74
Originally Posted by Foxbat121 View Post
I don't see how it can affect digital audio output at all. It's not like it can make 0s into 0.5 or 1s into 1.1.
And it doesn't look like Panasonic implemented anti-jitter feature on HDMI. In the past, this same feature is reserved for BD players with 7.1 analog audio out, like BD80 and BD85. Since BDT210 only has 2.0 audio out, I'm not sure why this feature even have any effects.
Per the Panasonic website, both the BDT210 & 310 have the anti-judder feature though it is now called "Pure Audio on HDMI". I thought this would be a feature to turn off or on, but looks to be always on. I believe the Pure Audio feature helps to improve clocking of the audio stream over HDMI.
As for High Clarity sound, not sure exactly how it improves the sound but I do notice a difference over HDMI. I'm guessing it is just reducing potential for electronic interference and perhaps reducing the load on the power supply, which can't be a bad thing. Why output analog video if you never intend to use it ?
Sean
stash64 is offline
Old 03-16-2011, 09:10 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Pure audio is available on all models.
Old 03-16-2011, 10:39 AM
Charles R's Avatar
Liked: 539
With the 110 Dolby is limited to 5.1 via PCM along with a few other differences already covered.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 03-16-2011, 10:53 AM
cage22's Avatar
Foxbat121 - thanks for all the info. As for the bitstream, I've got a Yamaha RX-V3800 that I'm pretty sure can decode everything. Which is better - let the Yamaha RX-V3800 decode the bistream or have BDT do the decoding?
With regards to: "...BDT110 is as good as 220 as far as audio..." wouldn't the High Clarity Sound" make the 210 sound better?
Again, thanks to you and all.
cage22 is offline
Old 03-16-2011, 10:57 AM
tylerb2002's Avatar
Hello all,
Am I correct in my interpretation of the file format/disc type chart on the 310 Amazon page that this player will NOT play AVCHD files burned onto BD-R discs?? I have a canon camcorder that records in AVCHD, and I was going to get a BD burner for just this purpose. If the player can't play them, I will either look for another player or save the $100 on the BD-R drive. Has anyone tried to play AVCHD files on a recordable BD disc?
*EDIT* Also, can I stream AVCHD files from my PC? I would rather use discs than have to turn on the PC, but I would need about 20 DVD-R's to hold my home video collection. Perhaps I can use an old USB HDD.....hmm...Anyone know which of these options will work? Preference goes from BD-R to USB HDD to DVD-R to streaming from win7 pc.
Any help is appreciated!
--tb
tylerb2002 is offline
Old 03-16-2011, 12:10 PM
stash64's Avatar
Quoted: 192 Post(s)
Liked: 74
No, not the BD75. I was wrong to not include the BDT110.
Here's what was stated on the Big Picture Big Sound website:
"Panasonic has enhanced their "jitter purifier" technology, which they're now calling "Pure Sound." This feature effectively reduces the digital jitter from both PCM and bitstreamed digital outputs by improving the stability and accuracy of the digital clock. This is available on all of the 3D-capable players. They've also added a few new tube sound effects to their repertoire, emulating the sonic characteristics of various different vacuum tubes for audiophiles who appreciate that warm tube sound but aren't willing to invest in actual tube amplifiers."
Sean
stash64 is offline
Old 03-16-2011, 12:26 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
They should be identical. AVR forum has many threads about this.
See my previous posts about this.
Old 03-16-2011, 12:28 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
I should clarify that I only include players discussed in this thread:110/210/310
Old 03-16-2011, 12:36 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Actually, no. From what I understand from the manual, 110 only limits to 5.1 when it decodes 6.1 or less audio. If you have 7.1 track, it still will output 7.1 pcm. The 7.1 reformat feature is a useless feature. Previous panny players all do that on dts audio and often can't be turned off in order to use the much more superior Dolby IIx processing found in most AVRs. AVRs will always do a better job matrix 5.1 into 7.1 than the player.
Old 03-16-2011, 12:57 PM
Charles R's Avatar
Liked: 539
Per the manual...
[BDT110] : If “Dolby D/Dolby D +/Dolby TrueHD” is set to
“PCM”, the maximum possible number of Dolby sound is 5.1ch PCM.
Also...
PCM
BD-Video : 7.1ch PCM*1*2*3
*2 [BDT110] : The maximum possible number of Dolby sound is 5.1ch PCM.
Old 03-16-2011, 01:12 PM
tylerb2002's Avatar
Does anyone know if you can simultaneously output audio AND video from both HDMI ports on the 310? I would like to be able to compare upscaling quality between the Panny and my Denon 4310 AVR...
--tb
Any word on when they will be shipping the 310? I haven't pre-ordered yet, I was hoping the price would go back down to the $219 that some early posts mentioned...
Old 03-16-2011, 04:47 PM
hobbes4444's Avatar
Originally Posted by MUPPPP View Post
I recently got my Avatar for the BDT100 rebate in like 3 or 4 weeks.
Originally Posted by old corps View Post
I also mailed mine on 3/5. I'll post when I get mine.
Ed
Originally Posted by colour View Post
According to the rebate "ordinarily delivered within 8 to 14 weeks".
My avatar 3d rebate was received on 3/9, got it today, 3/16, via ups ground from tennessee. . . now, just hoping the VT30's become available shortly.
hobbes4444 is offline
Old 03-16-2011, 04:51 PM
hobbes4444's Avatar
and fwiw, bb stores seem to have the 110 and 210 in stock and they just sent a 12% off coupon to reward zone members. snagged a 110 today. we'll see if the 310 has worthwhile upgrades. . .
Old 03-16-2011, 05:24 PM
cyberized's Avatar
Quoted: 32 Post(s)
OH Happy Day! Received my NEW 210 via Amazon today and WALA got it up and running and I will really enjoy this because I had been trying to watch 3D BDs' using my Arcsoft TMT5 Software on Sammy/Checkerboard.....had been getting really BAD Audio Problems that made it NOT so entertaining. Just tested this new baby out and GREAT - I no longer have to go thru my HTPC to get 3D active and am getting FULL HD Sound too. Loving IT! TKS Panasonic!
cyberized is offline
Old 03-16-2011, 05:41 PM
jphillips63's Avatar
Quoted: 25 Post(s)
Is the 310 worth waiting for and does anyone know when it will be released? I'm still on the fence between the 310 and the oppo 93
jphillips63 is offline
Old 03-16-2011, 05:49 PM
cyberized's Avatar
Quoted: 32 Post(s)
From everything that I can surmise the only difference between the 210 and 310 is that the 310 has the 2 HDMI OUTs. I got the 210 and am a "Happy Camper!"
Old 03-16-2011, 05:55 PM
Quoted: 25 Post(s)
Thanks I am needing two hdmi outs as my avr doesn't pass 3d so i have to use one output to TV for video and the other to my avr for audio. To me that is my cheaper route to take a new avr is 1500.00 and Bo can still keep the ps3 to play games if i wish to.
I was looking on amazon and there specs says the 310 has one hdmi out can someone verify it has two outs?
Old 03-16-2011, 07:59 PM
jbolt's Avatar
Sounds like your HDMI cables, either the one to your AVR or the one to your projector is not up to task. White dots is a typical sign. It's not a firmware problem.
You can download firmware from Panasonic. Burn to a CD, not DVD, using a 3rd party CD burnner software. You can not use Vista/Win7's built in CD burning feature, nor freeware ImgBurn. Neither will produce disc that Panny player can accept.
The HDMI cables may be the case as sometimes the image flickers like a candle, but goes away when I unplug the cord and plug it back in. But it works fine when I go straight into the projector. It may be a bad BD/DVD HDMI plug in the receiver. I will try tonight to see if it still happens in one of the other HDMI ports like the one for gaming. The cables are brand new, but cheap cables I bought from Monoprice.
As for firmware, I do not see it on the Panasonic site yet where I can download and burn it. Do you have a link?
jbolt is offline
Old 03-16-2011, 08:07 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Don't over look the short HDMI cable from player to AVR.
I found out that my trusty MonoPrice 6ft 28 AWG cable, that always worked fine in 1080p60 in the past, has the similar problem when I enable 1080p24 mode (with deep color) on the player. I have to dig out my 6ft 24AWG cable to get rid of the snow flick issue. Granted these cables were purchased a few years back (HDMI 1.3).
Always look for latest firmware from Panasonic.net (Panny Global). That's the place first get posted, even before the internet download from the player. Pansonic.com typically lags behind.
Super Moderator
teachsac's Avatar
Quoted: 654 Post(s)
Liked: 962
http://panasonic.jp/support/global/c.../na/index.html
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 03-16-2011, 08:08 PM
Quoted: 25 Post(s)
More than likely it is your hdmi cable. Quality cables make or break a picture or piece of hardware I learned hard way and many hours of trouble shooting get quality cables and most of the troubles will go away.
Old 03-16-2011, 08:17 PM
Super Moderator
teachsac's Avatar
Quoted: 654 Post(s)
Liked: 962
Monoprice cables work perfectly. You don't need to spend an arm and a leg on Monster Cable or the likes.
S~
teachsac is offline
Old 03-16-2011, 08:29 PM
jbolt's Avatar
I swapped out my Monoprice cable with my expensive Auvio HDMI 3D ready cable and the snow and sound issues seem to go away, but the 2D to 3D conversion still does not work through AVR. I probably will just get an optical cable to run audio to the AVR and hook Panasonic straight to projector. I will do a firmware update first to see if that fixes the issue.
jbolt is offline
Old 03-16-2011, 08:48 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
Your AVR must support HDMI 1.4 in order to pass 3D video. That's why ppl pay extra $$ to buy BDT3xx with two HDMI outputs so that you can connect one to TV and one to older AVR.
Old 03-16-2011, 08:55 PM
Quoted: 25 Post(s)
This is correct you must have an avr that is hdmi 1.4 or you will have all sorts issues. I'm in same boat I'm seeking a player that has dual hdmi outs right now until I can update my avr.
Old 03-16-2011, 09:04 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
The only issue will be your BD player won't detect any 3D TV handshake and refuses to send out full HD 3D signal because non-HDMI 1.4 AVRs don't know how to relay those 3D format.
Old 03-16-2011, 09:06 PM
Tornillo's Avatar
I just took my 210 out of the box and the HDMI cable I had plugged into my 65...doesn't seem to fit in the 210. Is this possible?
Tornillo is offline
Old 03-16-2011, 09:16 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Anything's possible I guess, take a look at the HDMI output on the player and see if the rear cover is aligned properly.
colour is offline
Old 03-16-2011, 09:18 PM
hobbes4444's Avatar
Has anyone tried an exFAT formatted drive on the 110/210 USB port? Although it's not listed as supported, I'm holding out hope that it will be compatible with these players, or possibly the 310.
Blu Ray Movies , Panasonic 1080p Blu Ray Player Dmp Bd35ak Brand , Panasonic 3d Blu Ray Player Dmp Bdt210 , Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bdt100 Full Hd 3d Blu Ray Disc Player , Panasonic Dmp Bdt110 3d 2d Blu Ray Disc Player , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Receivers Amplifiers , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi
