Official Panasonic DMP-BDT110/210/310 Owners Thread - Page 283 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #8461 of 8591 Old 04-20-2014, 09:57 AM
albani's Avatar
Originally Posted by Dudelus View Post
Hi guys, I brand new  - just joined 5 minutes ago.
Anyway, thanks to your thread I found regarding Cinavia, I found a Panansonic DMP BDT-215 on eBay that did not have Cinavia and I am very happy with it.
I recently tried to use my blu-ray for Netllix and found it did not work an it wanted to download firmware 1.92 as an update to fit it, but it also claimed it fixed other issues under the general label of "~~Playability of Blu-ray Disc".  To me that could include Cinavia so my question to anyone who has tried the new 1.92 update ---- can you confirm that the update does NOT include Cinavia?
Obviously, Panasonic tech support was of no help and unfortunately, once you upload the firmware there seems to be no way to go back in case Cinavia makes it way into the firmware.
I will not update until someone has prove the update is void of Cinavia.
Hi
I'v Pany serie BD 320 and I warn yo that do not try to FW update otherwise you get "Cinavia" as well!! as I made a mistake in the past and uploaded latest FW and now I got my Cinavia!
Therefore with latest FWs you wont be able any picture "improvements"!! so do not update your device and use it without Cinavia protection!
Bye++
Tosh 46SV685&Tosh 42WL863
Panasonic BluRay BDT320EG&Toshiba BluRay BDX5400
albani is offline
post #8462 of 8591 Old 04-20-2014, 10:13 AM
Super Moderator
teachsac's Avatar
Quoted: 692 Post(s)
Liked: 1124
This is the X10 thread. You have the X20. The X10 series does not include Cinavia.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #8463 of 8591 Old 05-04-2014, 09:41 PM
Carnivore's Avatar
I've been having network connectivity problems with my BDT110 forever. Every time I turn it on it is disconnected from the network and I have to spend the better part of an hour going through all sorts of troubleshooting steps before it will reconnect. I've tried changing the cable, setting up a static IP, turning off power save mode, going through the entire network setup routine over and over and over again. Eventually it connects and everything works fine until I'm done watching it, but then of course it powers itself off after a certain length of time and I'm back to square one. Honestly, I'm ready to smash this thing, it's so frustrating. Any suggestions?
Carnivore is offline
post #8464 of 8591 Old 05-13-2014, 03:47 PM
Mustang11's Avatar
After last update 1.92 for my BDT-215 the player comes on by itself. It is connected to my HDTV, which also turns on. Anyone else have this problem and possibly a solution?
Thank you
sheshechic likes this.
Mustang11 is offline
post #8465 of 8591 Old 05-18-2014, 12:21 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Thank you
It's happening with my two 310s. Also, when it's on, playing a dvd or blu-ray, it will occasionally turn off. I find it hard to believe that this isn't happening to other owners. Maybe people have new players and aren't using these models as much anymore.
sheshechic is offline
post #8466 of 8591 Old 05-18-2014, 03:52 PM
LowBudget5.1's Avatar
Thank you
Go into the settings menu and verify that Anynet+ is turned off. It may be turned on by default on the new firmware.
LowBudget5.1 is offline
post #8467 of 8591 Old 05-24-2014, 04:50 AM
Humm26's Avatar
S~
Hello,
Can you tell us if it's a technical limitation or we have to be aware of a new firmware could insert this protection in the X10 series?
Humm26 is offline
post #8468 of 8591 Old 05-24-2014, 05:06 AM
Super Moderator
teachsac's Avatar
Quoted: 692 Post(s)
Liked: 1124
The X10 will not get Cinavia. Manufacturers are not required to put Cinavia on players produced before the Sunset. As for a technical limitation, can't answer that.
S~
teachsac is offline
post #8469 of 8591 Old 05-28-2014, 05:18 PM
Jimbo57's Avatar
Promptly on April 7, my BDT-210 stopped streaming Netflix. I have not been able to update the firmware from 1.88 to 1.92 since then.
When I try, I get a prompt that says I don't have a network connection. I've tried wired & wireless, changing the settings appropriately each time.
I've tried downloading the firmware and burning it to disc, but I get a message that the disc is not readable.
Panasonic wants to charge me for a disc, wait for it to arrive, than charge me for tech support. Maybe this is not a new new player, but I've had it two years and this seemss pretty crappy to me.
Any suggestions? I tried setting the DNS to 8.8.8.8, but can't get the machine to save the settings. I'm prompted to use the "cancel" button, but neither my controller for my box has anything remotely resembling "cancel."
Jimbo57 is offline
post #8470 of 8591 Old 05-31-2014, 04:43 AM
gkjdallas's Avatar
All,
Thanks much! My wife and I were beating our heads against wall trying to log into our new NetFlix account last night. This morning, thank the AVS Forum, I googled up this. Pressing 'OK' in the fields for username and passwork does indeed bring up the alphanumeric selection matrix on the Panasonic SC-BT series.
gkjdallas is offline
post #8471 of 8591 Old 06-15-2014, 12:21 AM
EX500's Avatar
Anyone else experiencing issues with 1.92?
Debating whether to do the update.
If it does indeed cause phantom power issues, then at least my 210 may be powered up more than once every six months, even it is has to do so on its own
EX500 is offline
post #8472 of 8591 Old 06-28-2014, 04:24 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Originally Posted by awaters2879 View Post
bdt210 at my mother's is about to get drop kicked.
pretty much given up on netflix via this model and 1.92. tried different dns, power cycles, relocating the device, same issues. takes 10-15 seconds for each stream to initially load with the progress bar. even after loading it then takes ~6 seconds before the first flash to go to hq (which would be OK) except that, well, it intermittently flashes between qualities. 1 show was flashing so much it eventually dropped and returned a netflix error. the subtitles are way off too. YMMV w/ subtitles anyway. Re: power - i did show up one day and it was mysteriously turned on.
amazon prime hd videos stream without a hitch on the 210.
connection tests fine on pc and other wireless devices. sometimes test network speed while streaming and it's fine. no other users on the network when watching so no real need for QoS. plus this is on EPB's fiberoptics network - it's pretty speedy. the cdn is usually washington on the pc tests. gets to hq fast. wired connection. that link above was really handy for details on your streams. i get the same results at home on the same provider, across town.
watched 3 episodes of something with a chromecast on highest setting w/o problems. don't feel like lugging their player to my house to test it or taking my wireless router over to try that.
probably not going to invest much more time into netflix on the 210. they're looking to get a newer player to stream more content anyway, but the primary reason for letting the 210 go is that netflix is pretty much unenjoyable on the 210 now. can always throw it in the spare bedroom.
One last thing you might want to try is taking it off the Netflix account and re-registering it. It's a pain since Netflix no longer allows you to take of just one unit. Or call Netflix and see if they can do that for you.
post #8473 of 8591 Old 07-11-2014, 12:18 PM
F.Ultra's Avatar
I noticed another problem with v1.92, converting DTS-HD to PCM with Secondary Audio ON gives my AMP a DPL stereo signal. On the old firmware I got a full 7.1 PCM stream.
F.Ultra is offline
post #8474 of 8591 Old 07-21-2014, 05:43 AM
Liked: 0
My 210 is shutting down!!!
I have been experiencing a shut down of my 210 in the midst of watching a movie! with no warning or indication, the unit simply shuts itself off!!! To finish the movie, course, I have to trun it back on, find the chapter i was watching, set up all the audio functions, then resume watching, after doing hat yesterday, it shut itself right back down again! needless to say, I did not finish watching the movie. The unit says I have the current firmware or update, anyone else experiencing this issue? anything can i check or set that maybe causing this??? thoughts?
coopinnc is offline
post #8475 of 8591 Old 07-21-2014, 07:15 AM
UMDMatt's Avatar
Analog Outs--grr
I spent Friday night going from annoyed to full techno rage at my BDT-210 for not outputting analog audio for an impromptu outdoor movie. Being in the hobby for 15 years, you'd think I would have learned by now to Keep Calm and Google it on AVS. Anyway, next time I'll know...disable 24p in order to output 2-channel audio. Thanks AVS.
UMDMatt is offline
post #8476 of 8591 Old 07-21-2014, 07:26 AM
Super Moderator
teachsac's Avatar
Quoted: 692 Post(s)
Liked: 1124
Haven't experienced this. Do you have Vieralink on? If so, try turning it off.
S~
teachsac is offline
post #8477 of 8591 Old 07-21-2014, 07:57 AM
Liked: 0
from teachsac - Haven't experienced this. Do you have Vieralink on? If so, try turning it off.
I do not know - I will check the setting, any other thoughts would be appreciated!!
thanks!
coopinnc is offline
post #8478 of 8591 Old 07-22-2014, 03:26 PM
ti-triodes's Avatar
Quoted: 281 Post(s)
Liked: 374
thanks!
Does it have enough ventilation? Overheating sometimes causes a unit to shut off.
ti-triodes is offline
post #8479 of 8591 Old 07-28-2014, 06:54 PM
Liked: 0
Hello all...
I'm hoping someone can shed some light on what may be going on with my 310. I am using the secondary HDMI to output audio to my non-3D capable 7.1 receiver. It has worked great since I purchased it but suddenly the HDMI audio signal won't seem to "lock-up" or sync with the receiver. I get fragments of sound every couple of seconds (or longer). Audio from Primary HDMI works fine when connected directly to my TV. Ive tried several different HDMI cables including a brand new "high quality" one. I've also tried other inputs on my receiver but always get the same result. This makes me think it is definitely a problem with the 310.
Assistance or thoughts will be appreciated!
walamab is offline
post #8480 of 8591 Old 08-06-2014, 09:56 AM
angryht's Avatar
I think my 210 might be toast! It plays dvd fine (and CD's) but when I put in a blu-ray disc it starts to load then goes back to the Panasonic menu and won't play the disc. Looks like the majority of the latest problems are related to streaming, which I very rarely do since my internet is soooo slooooow. I'll do some more searches but I have a feeling this may be the end for an otherwise great player. Any thoughts?
-Greg
angryht is offline
post #8481 of 8591 Old 08-07-2014, 03:16 PM
ti-triodes's Avatar
Quoted: 281 Post(s)
Liked: 374
Try resetting the unit or clean the laser. If that doesn't work, it's probably history.
post #8482 of 8591 Old 08-09-2014, 05:36 AM
Giulio_P's Avatar
hello,
I have a Pana BDT 310, firmware 1.88, and I am wondering if it can be made region free, especially for blu-rays (I made a similar operation on a Toshiba blu-ray player BDX1200 in a very harmless way, just by pressing some buttons on the remote if I am not mistaken).. I searched on this forum (and many others) and I could just find old discussion on the argument. for example one method is to re-program an Harmony one (I have an Harmony 1000 and I am not sure if I can use it for the same purpose) or to buy a One for All remote
what is the latest solution for this issue? how can I dezone my Pana 310?
thanks!
Giulio_P is offline
post #8483 of 8591 Old 08-10-2014, 03:09 PM
ti-triodes's Avatar
Quoted: 281 Post(s)
Liked: 374
Originally Posted by Giulio_P View Post
hello,
thanks!
This has been discussed many times in this thread. Try this but it supposedly doesn't work with all discs. It does work on all mine however.
All you need to do is load up the disc. When the message pops up that says the disc will only play in a Region B or C player pops up, press "stop" on the remote control. Then press "1" on the remote, followed by "enter." This will bypass the message and load up the disc to play normally.
post #8484 of 8591 Old 08-10-2014, 09:16 PM
HoNuts's Avatar
hello,
thanks!
I posted this over at Blu-Ray.com last year. One of these methods has worked on every Region B disc that I have. -
I have a Panasonic DMP-BDT110 and it can play Region-B discs by doing a few different tricks. It won't play any PAL or 1080/50i content without modified firmware however. Here's the 3 methods that I've discovered so far:
Method 1 -
- Insert a disc and wait for the "Wrong Region" screen to appear
- Press the "Pop-Up Menu" button
- Disc should boot to the discs main menu or start playing the movie
Method 2 -
- Press Stop
- Press the "Pop-Up Menu" button (You may have to press this a few times)
Method 3 -
- Press Stop
- Press 1 and the number "1" should start blinking in the upper right corner. Press the "OK" button while 1 is blinking. You may have to try this a few times, as it usually doesn't work the first time. Try pressing OK on the first or second blink and it should work.
Stereodude likes this.
HoNuts is offline
post #8485 of 8591 Old 08-10-2014, 11:42 PM
Giulio_P's Avatar
Originally Posted by HoNuts View Post
Method 3 -
- Press Stop
thanks to both of you! it worked for me, too, at least for one Criterion BR.
I do have a BR player from Europe, which is set to play the BRs from region B. I expected some problem because the BR is NTSC (isn't it?) but it worked just fine.
Giulio_P is offline
post #8486 of 8591 Old 08-11-2014, 06:08 AM
angryht's Avatar
It sat overnight and worked the next day
-Greg
angryht is offline
post #8487 of 8591 Old 08-11-2014, 08:51 AM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 89
Method 1 -
Method 2 -
- Press Stop
Method 3 -
- Press Stop
I have both a BDT-210 & a BDT-220. Method #3 works on both of them but the 210 often takes several attempts before it works while the 220 works right away. While they play the blurays in 2D fine I've not been able to get 3D blurays to play in 3D-just in 2D.
Ed
old corps is offline
post #8488 of 8591 Old 08-12-2014, 03:19 PM
antivirus's Avatar
hello,
thanks!
Try this:
http://www.tps.uk.com/?tab_name=Pana...&choice_type=1
or this:
http://www.ebay.co.uk/itm/Panasonic-...-/300990034790
There's also a dedicated website for Panasonic enhanced firmware but the moderator here doesn't want links to that site being posted. Google is your friend.
antivirus is offline
post #8489 of 8591 Old 08-15-2014, 03:27 AM
homerging's Avatar
Quoted: 31 Post(s)
Method 1 -
Method 2 -
- Press Stop
Method 3 -
- Press Stop
Does this only work for out of zone Blu-rays? I tried it with an out of zone DVD and it didn't work
homerging is offline
post #8490 of 8591 Old 08-16-2014, 03:33 PM
hockeyzebra's Avatar
We've discussed this player at length regarding Cinavia. It does not, nor will it ever, have Cinavia. Panasonic is not required to implement it on this player.
S~
Just because it is not required does not mean they won't voluntarily add it to an update. I have read several similar responses in this thread, all of which state that Cinavia is not a requirement, but so far I have not seen actual confirmation that the latest firmware is in fact Cinavia free.
Can anyone actually confirm that v1.92 is Cinavia free (e.g. have tested it on a back up disc that is known to have Cinavia)?
Thank you.
BDT310, FW v1.88. BTW, Netflix is currently disabled because the player is attempting to push the update and it won't let me use that app until I upgrade. Very sleazy of them to do this.
hockeyzebra is offline
Reply Blu-ray Players
Blu Ray Movies , Panasonic 1080p Blu Ray Player Dmp Bd35ak Brand , Panasonic 3d Blu Ray Player Dmp Bdt210 , Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bdt100 Full Hd 3d Blu Ray Disc Player , Panasonic Dmp Bdt110 3d 2d Blu Ray Disc Player , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Receivers Amplifiers , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi
