Official Panasonic DMP-BDT110/210/310 Owners Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #181 of 8592 Old 03-08-2011, 08:12 PM
cishida's Avatar
Both the 65 and 110 output an irritating screeching noise when playing DVDs. Anyone else notice this? Way louder then when playing blu-rays.
Maybe part of the problem is that there is no fan noise to cover up the noise from the drive mechanism. I should install my own fan .
cishida is offline
post #182 of 8592 Old 03-08-2011, 08:26 PM
Jacob305's Avatar
Quoted: 85 Post(s)
Liked: 48
for people having problem playing the netflix with the screen going out. you should call netflix and report it to them. I called and reported about it.
Jacob
Jacob305 is offline
post #183 of 8592 Old 03-08-2011, 08:32 PM
jbolt's Avatar
Originally Posted by Charles R View Post
Online Panasonic states only the 210 can play MKV (some formats) via USB (and I presume network). However the manual lists MKV support for both the 110 and 210 via USB...
USB devices (up to 2 TB)
DivX® [BDT210_for_Canada] MKV MP3 JPEG/
MPO (3D still picture)
Has anyone tested playing MKV files with the 110 via USB or network?
Received my Panasonic 110 yesterday. Cleared off an old 160GB 2.5" external hard drive and formatted it to FAT32 with Disk Utility on my Mac. I put on a 3.5GB MKV file of TRON and it played fine through the Panasonic. Looked good too. No stutter. I am excited about that because I was contemplating getting the 210 so I could use an external hard drive. Now I know the 110 can do it.
I'm guessing the files will have to be 4GBs or under which kinda sucks since most of my MKVs are over 4GBs. I have 67 MKV movies and only 7 are under 4GBs. Does anybody know a way to resize the files to 4GB without losing picture quality?
jbolt is offline
post #184 of 8592 Old 03-08-2011, 08:39 PM
meet2x4's Avatar
Until I can build/buy a decent HTPC for streaming I'm dealing with MKV streaming on this thing. But what's REALLY pissing me off is half my MKV's aren't showing up at all and the other half that are showing up are showing up intermittantly, yesterday I had 7 MKV files, today I have 3 and after going to the home menu and going right back in I've got 4???? WTF?! I've demuxed and remuxed the ones that won't show up. They all appear to be the same kind of video files/format inside the MKV container. I give up. Still worth every penny for blu-ray and netflix capability though!
Oh and has anybody tried custom firmware from firmwareinfo.com? Looks like a godsend custom firmware if it doesn't brick your device. If it's too good to be true, it is right?
meet2x4 is offline
post #185 of 8592 Old 03-08-2011, 08:57 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I've only played one MKV that was about 7GB and it stuttered. I have about 4TB all MKV 1080p movies so none of them are even close to 4GB, I'll continue using my WDTV Live to play those I guess.
I don't know of any method to resize MKV files
colour is offline
post #186 of 8592 Old 03-09-2011, 04:17 AM
Chuck_IV's Avatar
Quoted: 100 Post(s)
Liked: 54
Have you tried Handbrake? I think Handbrake may be able to downsize mkvs. The only issue with Handbrake is it is SSSLLLOOOWWW.
Chuck_IV is offline
post #187 of 8592 Old 03-09-2011, 05:59 AM
deuce1973's Avatar
Originally Posted by cishida View Post
It's asking for your WPA/WEP passcode, not the airport id. Have you attempted to connect any other devices to the airport? If so then you have probably been asked for a security code. That code/string is what you need to enter into the panasonic.
Thanks for the reply!. I finally got it to work. Thanks again!
BTW, I tried to log-into my Netflix...but couldn't figure out how to TYPE my login-email address and password. I assume via the remote and the number(letter) keys, but I can't figure out the process for which to type letters and is there a backspace for any mistakes? There must be some "shift" button I am missing, but can't figure it out.
Display: Panasonic Plasma TH58PZ800U
AVR: Pioneer Elite SC-67
BD: Panasonic DMP-BDT210
Media: Apple TV4, AppleTV2 (for optical out)
5.1.2: Aperion 6T/5C/5B/4B, Bravus 12D sub
DVR: Comcast X-1 - Game: PS3, Nintendo classic - Remote: Harmony 700
deuce1973 is offline
post #188 of 8592 Old 03-09-2011, 06:03 AM
deuce1973's Avatar
Originally Posted by spike1073 View Post
From Customer Review on Amazon site:
"#2 The firmware the unit currently ships with will not let you get into the Internet streaming apps or anything for that matter until you update the firmware. Updating the firmware from the 1.09 firmware it ships with will not work as of this date via wireless or wired internet connections. The secondary option is to burn the frmware to a disc. This you think would be straight foward, but it isn't. Using Windows 7 or Vista, you MUST create an ISO 9660 ONLY... I went through 3 coasters before this player could properly read the Firmware update disc I created to bring it up to 1.47. Using any other ISO format will fail."
If true, this is a ridiculous update procedure. Can others confirm what the update procedure is?
Just wanted to chime in, I was able to do the Firmware update over Wireless this morning from 1.09 to 1.47. Perhaps when that review was written that wasn't an option. But it worked for me today.
post #189 of 8592 Old 03-09-2011, 06:07 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
Hit the OK button and it will pop up a keyboard to navigate through.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #190 of 8592 Old 03-09-2011, 06:08 AM
deuce1973's Avatar
S~
Thanks very much!
post #191 of 8592 Old 03-09-2011, 06:11 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
Thanks very much!
You're welcome.
S~
teachsac is offline
post #192 of 8592 Old 03-09-2011, 07:55 AM
rushhound's Avatar
I have two of the 210's and both are whisper quiet whether playing a Blu-ray or a DVD.
If you have an "irritating screeching noise" that isn't right.
rushhound is offline
post #193 of 8592 Old 03-09-2011, 08:00 AM
rushhound's Avatar
http://www.firmwareinfo.com/viewtopic.php?f=49&t=79
We do not yet provide enhanced firmware for the Panasonic DMP-BDT110, DMP-BDT111 or DMP-BDT210
What exactly is the "godsend" about the firmware you are talking about?
post #194 of 8592 Old 03-09-2011, 08:12 AM
BigB's Avatar
Hi,
Just ordered a 210 from Panasonic.com Work place rewards. Does this model handle Youtube Playlist ?
That has been a sticking point for us (along with Netflix Playback) and I ended up returning the Roku, Apple TV and Boxee for that reason, and want to avoid another return if that's not possible.
Appreciate
BigB is offline
post #195 of 8592 Old 03-09-2011, 08:17 AM
JOHNnDENVER's Avatar
Enables multi-region play as well as some other goodies.
JOHNnDENVER is offline
post #196 of 8592 Old 03-09-2011, 08:30 AM
rushhound's Avatar
Where is it and what are some of the "goodies" as I have no need for multi-region playback?
post #197 of 8592 Old 03-09-2011, 08:34 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I'm not interested in downsizing my MKV's. the person I replied to is. Ya if he finds a program it will be slow.
colour is offline
post #198 of 8592 Old 03-09-2011, 09:57 AM
cishida's Avatar
My 110 definitely produces quite a bit of sound playing the two DVDs l've tried. Maybe I have a bad unit or maybe the 210 has a better blu ray drive (seems unlikely) Might try to exchange through amazon.
cishida is offline
post #199 of 8592 Old 03-09-2011, 09:58 AM
meet2x4's Avatar
Looks like it will be released on April 4th. And the main goodie I'm looking forward to is DIVX support on my BDT-110. It almost looks like an "unlock" of sorts to use the device to it's full potential.
If it's legit it looks like that's all this guy does is Panny blu-ray firmwares.
meet2x4 is offline
post #200 of 8592 Old 03-09-2011, 10:03 AM
rushhound's Avatar
Gotcha! Thanks for the info!
post #201 of 8592 Old 03-09-2011, 10:08 AM
rushhound's Avatar
I can't imagine the drive is any different in any of this series.
I would definitely swap it out as that isn't normal.
Amazon is great with returns and since this is a defect they will issue you a pre-paid shipping label.
Now is definitely the time to have it replaced while you can swap with Amazon and not have to deal with Panasonic service.
post #202 of 8592 Old 03-09-2011, 10:17 AM
meet2x4's Avatar
So I was playing around last night and took Windows out of the "sharing" equation. I'm lucky enough to have an ASUS WAP that allows for a USB NAS setup. Threw all my MKV's on the NAS drive, setup the share, lo-and-behold all the MKV's are visible and playable now. Probably a stupid permission issue not getting handed down to the files for some reason. Is anybody else even having this problem or am I just an isolated incedent?
Oh and I thought I was crazy for noticing the "black blips" when watching Netflix, at least I'm not alone there. No rhyme or reason to it, it's such a short pause that it's barely noticable but when I'm not actually watching the screen I catch it out of the corner of my eye, trips me out.
meet2x4 is offline
post #203 of 8592 Old 03-09-2011, 10:20 AM
meet2x4's Avatar
Oh and a heads up on this. They offer a trial firmware that's gimped on features but apparently if you make a "donation" (between 20-50 Euros from what I've read) you'll get the full edition of the firmware. I'm not going to hop on this bandwagon until I see on their forums that it works. I'm not going to spend $50-70 if it doesn't work as they state in their FAQ.
meet2x4 is offline
post #204 of 8592 Old 03-09-2011, 12:46 PM
rushhound's Avatar
Anyone with the 210 running wireless, can you tell me if it the "N" band runs on 2.4ghz or 5ghz?
post #205 of 8592 Old 03-09-2011, 12:54 PM
More information here...
http://www.firmwareinfo.com/viewtopic.php?f=7&t=4
I don't actually us it yet.. But multi-region play is important to me for sure.
post #206 of 8592 Old 03-09-2011, 01:11 PM
rushhound's Avatar
Looks interesting if one needs those features.
What happens down the road when Panny issues the usual firmware updates to fix problems and this 3rd party firmware is on there? Would it get wiped out?
post #207 of 8592 Old 03-09-2011, 01:21 PM
Charles R's Avatar
Liked: 649
Per the manual...
When using Wireless LAN connection, video from the DLNA Certified media server is not played back or video frames are dropped during playback.
Higher transfer rate router such as 802.11n (2.4 GHz or 5 GHz) Wireless router may solve the problem. If you use 802.11n (2.4 GHz or 5 GHz) Wireless router, it is necessary to set the encryption type to AES. Simultaneous use with a microwave, cordless telephone etc. at 2.4 GHz may result in connection interruptions or other problems.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #208 of 8592 Old 03-09-2011, 01:50 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
You probably couldn't update with a third party firmware installed, you'd have to remove it and reinstall the original firmware (if possible). Then the third party firmware may not work if you wanted to reinstall it depending on what the update did.
colour is offline
post #209 of 8592 Old 03-09-2011, 01:58 PM
BdoUK's Avatar
The player sees both the 2.4 ghz and 5 ghz bands. I have mine connected via 5 ghz and have had absolutely no problems streaming content. I'm very happy with the wireless connection quality in this player.
BdoUK is offline
post #210 of 8592 Old 03-09-2011, 03:04 PM
rushhound's Avatar
Per the manual...
Higher transfer rate router such as 802.11n (2.4 GHz or 5 GHz) Wireless router may solve the problem. If you use 802.11n (2.4 GHz or 5 GHz) Wireless router, it is necessary to set the encryption type to “AES”. Simultaneous use with a microwave, cordless telephone etc. at 2.4 GHz may result in connection interruptions or other problems.
Thanks guys! I'm running a "G" router at the moment but I have a dual band "G" and "N" on hand that I will now set up.
No problems streaming Netflix with "G" but figure the "N" will help with media from my PC.
Reply Blu-ray Players
Blu Ray Movies , Panasonic 1080p Blu Ray Player Dmp Bd35ak Brand , Panasonic 3d Blu Ray Player Dmp Bdt210 , Panasonic Dmp Bd55k Blu Ray Disc Player , Panasonic Dmp Bdt100 Full Hd 3d Blu Ray Disc Player , Panasonic Dmp Bdt110 3d 2d Blu Ray Disc Player , Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv , Receivers Amplifiers , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi
