Official Marantz UD7006 universal player owners thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 87 Old 05-10-2012, 09:08 PM
asherwood's Avatar
Well... The 83 that I returned was NTF by OPPO. They didn't fix it, and I was stuck with a bad player. I thought I would give them another chance with the 95. Not again.
asherwood is offline
post #62 of 87 Old 10-29-2012, 01:45 PM
rvdws's Avatar
Yes it plays SACD-r ! (tested with hdmi)
Yes it plays watermarked DVDA-R (tested with hdmi)
rvdws is offline
post #63 of 87 Old 12-16-2012, 04:33 PM
quinoa's Avatar
Why won't the drawer open?
Any help out there?
I just got this unit as a factory remanufactured for Xmass and the thing won't even open!
Should I just send it back and forget all about it and continue to use my $100 sony?
quinoa is offline
post #64 of 87 Old 12-24-2012, 04:59 PM
LeeC22's Avatar
Any help out there?
If you're like me, this player will be an unending story of failures, glitches, lock ups, and pulled power cables.
I bought my first one last year, and within three months it was getting replaced. Lock ups, suddenly turning itself off etc... So I got the replacement last November. On the whole, it's generally a very unreliable player. Disc playback is erratic at times, pausing, stuttering, picture break up etc... This September, the problems started to escalate... if I booted up with a disc in, the machine would freeze. If I changed disc and used the power button to turn it off with the door open, the door would close, the machine would power off, then occasionally the door would suddenly open again.
Sent it to Marantz 4 weeks ago, and in the ten days they had it, they (allegedly) fixed various things. Within 5 days, the machine had again locked up on boot up, and required the power cable to be pulled... which I recorded with a video camera, as evidence. So back it went again two weeks ago, and as yet, I still don't have it back. I had a phone call a week ago from the repair centre, from a guy telling me the importance of having your display on first, to stop the HDMI control from causing problems. Can't see why you'd need your TV on, to listen to music CDs, and if you run it through an AV receiver, the TV status is irrelevant. But HDMI control isn't a "do we have a display? Yes then work properly, else don't work properly" kind of system... so I don't know what he was going on about.
And apparently, it looking for firmware updates can cause problems. The guy was switching it on at the morning, and off at night, as his "testing" regime and couldn't find a fault. I daresay that if my usage was turn it on, don't use it, then turn it off, I might not see a fault either... but you don't spend £700 on a player, to just turn it on and off. You watch discs, you change discs, you operate functions... which is what a tester should do. So he couldn't find a fault, and I fully expect it to come back with either a fictional repair, or a "no fault found" report.
While it's been away, the two Sony players I have been using have worked flawlessly... one of them cost me about £90. I have to say, I wouldn't touch anything with either the Marantz or Denon name on it, with a barge pole after this.
LeeC22 is offline
post #65 of 87 Old 12-25-2012, 10:28 AM
quinoa's Avatar
Thanks for the update. With your report I'm sending it back for a full refund.
quinoa is offline
post #66 of 87 Old 12-30-2012, 01:06 PM
Maarten1's Avatar
I have the same problems. Good machine in sound and picture quality but the rest...
Lockups, hang ups in the movie menu, making a buzzing sound when inserting a blu-ray.
Had it repaired. New software and (dont know the word) repaired the buzzing noise. Something with stabilisation or someting.
It worked fine for some time but it started buzzing again when i play a blu-ray. Its just the front where you put the disc in. Its connected with springs, and when you toutch it the player workes fine.
I think its just too lose. Didnt repare it because i didnt have warranty anymore and it is too much trouble i thought.
Now its working fine. Yes, the player wont open sometimes because you have to press it twice, but other than that is all good.
Overall i dont regret buying this 1000 euro player but next time I dont think I go for Marantz again. Im just a bit disappointing with the bugs.
Maarten1 is offline
post #67 of 87 Old 03-02-2013, 03:05 PM
jsclarke99's Avatar
Hey I'm hoping one of you guys on this forum may offer some advice. Having Marantz 5007 and 6007 receivers- I just bought the UD7006 refurbished from accessories4less, which is an authorized Marantz reseller . It works on all formats I've tried- except- the starting splash screens on all DVDs I've tried are filled with white vertical lines and dots. I'll attach a photo. Do you think this is a bad unit? Thanks everyone. John blu-ray distortion.jpg 457k .jpg file
Name:	blu-ray distortion.jpg
jsclarke99 is offline
post #68 of 87 Old 03-02-2013, 03:29 PM
jsclarke99's Avatar
I might add I'm playing familiar Blu-Ray disks that did not do this on the prev panasonic 310 player. I did a firmware update today 3/2/13. I've cycled through resolution- from auto to source direct to 1080P- sympton still exists. So far - this hasn't happend on a DVD- blu-ray disks only.
I'm going through a new (not refurb) Marantz SR7006 receiver, from there to a Samsung 60" LCD (D6500). Thanks in advnace
post #69 of 87 Old 03-02-2013, 06:54 PM
HowardV's Avatar
Quoted: 65 Post(s)
Liked: 52
That did not happen on my ud7006. Try routing it directly to your TV instead of going through a receiver as a test. This is just to definitely rule out your receiver. If it continues, I would ask for a replacement.
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
2 Anthony Gallo Reference SA Amps
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
post #70 of 87 Old 03-03-2013, 10:11 AM
jsclarke99's Avatar
Thanks Howard good suggestion. New cable- run straight to another input on the TV produced the same result. I'll call and reqest an exchange on Monday.
post #71 of 87 Old 03-05-2013, 02:39 PM
Maarten1's Avatar
The player makes a buzzing sound when i play a movie. Any ideas why?
It stops when i touch the loading thing (where you put the disc on)
Maarten1 is offline
post #72 of 87 Old 03-16-2013, 07:40 AM
jsclarke99's Avatar
Hey I just wanted to pass on how well Marantz handled my issue described above (white lines when many disks started up). I called- said I'd bought the player refurbished but from accessories4less (an authorized Marantz dealer) and I received it with this problem. The tech support guy at Marantz apologized- saying their quality control should have caught that. He emailed a return FedEx label and said as soon as they saw FedEx had my unit, they'd cross ship a replacement.
A week later I called, and they apologized but said they were out of stock on refurbished 7006's... but one would be shipping soon.
Yesterday, a total of two weeks later- I received a brand new, UD7007 from Marantz. That's pretty remarkable in my opinion, the most I expected was a refund or store credit. That kind of thing is going to keep me buying Marantz for quite a while. John
post #73 of 87 Old 03-20-2013, 08:36 AM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
That is amazing! You must be so happy. The UD7007 is a very impressive player. Would you recommend anyone to buy a UD7006 even though you now own the newest model UD7007? I am doing a demo in my home of the UD7006 and weighing the benefits. What is your opinion please?
zuluwalker is offline
post #74 of 87 Old 03-23-2013, 07:49 AM
jsclarke99's Avatar
Well, I'm very happy with the 7007-- but probably would have been very happy with the 7006 if it hadn't had a problem. They are quite similar- except for balanced audio outputs for main L and R (which I can't use currently anyway). I can certainly attest to Marantz honoring the warranty of a refurb'ed 7006 and given it's less than half the price of a 7007 and I'd probably still go for it. John
post #75 of 87 Old 04-03-2013, 11:28 AM
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
post #76 of 87 Old 04-04-2013, 09:59 AM
amairphoto's Avatar
Quoted: 44 Post(s)
I cant seem to find a dedicated UD7007 thread so ill post here.
When playing a cd i set the UD7007 to AV pure direct so that it cuts the video out and just sends the music. However when i put a blu ray in to watch i have to switch it back. Is there no way of the UD7007 remembering what im doing or realizing what is the best option. Instead of me keep having to change it back?
amairphoto is offline
post #77 of 87 Old 06-14-2013, 03:27 PM
alex567's Avatar
Hi, someone can please post a subjective difference between:
Marantz UD7006 vs Marantz UD5005
Marantz UD7006 vs Marantz BD7004
in terms of DVD upscaling and audio quality ?
alex567 is offline
post #78 of 87 Old 01-31-2014, 10:12 AM
vikx2's Avatar
 Hello , Can you say me if the UD7006 play mkv files through the front usb?
Thanks .
vikx2 is offline
post #79 of 87 Old 07-16-2014, 11:34 AM
Liked: 0
No 3D effect
Hi everyone,
I recently bought this Marantz UD7006 in our home theater with sony projector.
I was trying to play 3D movies through the USB stick, but Im unable to see the 3D effect. Also I tried playing a 3D video from YouTube, but the result is same. NO 3D Effect
Could anyone solve this problem?
Thanks in Advance
Naga Vikas
Naga Vikas Ch is offline
post #80 of 87 Old 07-17-2014, 05:58 AM
Maarten1's Avatar
Originally Posted by Naga Vikas Ch View Post
Hi everyone,
Thanks in Advance
Naga Vikas
Stupid question but do you have 3d screen projector?
You have to enable it on the menu of the player. It should work then.
Maarten1 is offline
post #81 of 87 Old 07-30-2014, 07:43 AM
Liked: 0
UD-7006 problems
Dear Fellows,
I have an UD-7006 for almost three years now and it always had some problems I had never had with my previous Oppo DVD player. The drawer's been always lazy and the openning/closing now is a big issue. Sometimes I give-up! Few days ago I could open and inserted a BD but could not play it. Strangely I could watch the trailers but not the main feature. It just went black!
Lucky some of you who could get a brand new one in return. As I am writing from Brazil and I bought it abroad, I do not think Marantz would be much worried about my problem. Too bad!
I use it as a transport and connected through the NA 7004 DAC input, playing with their 8004 amp. In the very near future, I shall say good-bye to Marantz!!
att.,
Gustavo
gulao is offline
post #82 of 87 Old 07-30-2014, 09:53 AM
Daffietje's Avatar
Quoted: 54 Post(s)
Originally Posted by gulao View Post
Dear Fellows,
att.,
Gustavo
I had an UD7006 myself but I am glad I got rid of it.
It just nowhere near the quality of an Oppo. The disc unit and lasers they use for example are just cheap and low quality. The amount of problems people had and are still having with their drives is amazing. I had a buzzing sound coming from the drive quite often when playing bluray discs. It also makes way too much noise and as a mediaplayer its an even bigger failure.
They should just stop making Universal disc players or they should slash their prices in half, because they are not worth what they are asking for them.
So to conclude : a wise decision from you !
Thanks .
Since its quite a bad mediaplayer compared to for instance a DUNE player or an Oppo, chances are you will not be able to play the file.
Also when the file is 24p, the UD7006 in Europe converts this automatically to 60p leaving you with a judder party during the movie...
Panasonic TX-P50GT60 / Marantz SR5004 / 4 x KEF HTS 3001 SE (front + rear) + HTC 3001 SE (centre) + REL T-9 sub / Oppo BDP-103EU (MultiRegion+MultiZone)
Daffietje is offline
post #83 of 87 Old 08-02-2014, 04:38 PM
Maarten1's Avatar
I dont know why but i fixed the buzzing sound by pulling out the layer just a bit ferther when its ejected. It seems like the disk wont close correctly. I had it repaired in the firsts months but it kept comming back.
Other than that no problems now.
Maarten1 is offline
post #84 of 87 Old 09-16-2014, 01:23 PM
robolowski's Avatar
I got ud7006 with all the latest updates installed and yet there is no netflix icon in main menu.
Any help would be appreciated.
robolowski is offline
post #85 of 87 Old 08-17-2015, 08:10 PM
Liked: 0
Can this player UD 7006 play *.flac files from USB?
metamp is offline
post #86 of 87 Old 01-05-2016, 06:06 AM
Liked: 0
Is there any way to play mkv files? I have a lot of videos which are in mkv format.
post #87 of 87 Old 11-07-2016, 11:35 AM
Liked: 0
help subtitles from usb source
hi, can anyone help me to undestand if it is possible to select a subtitle from the same source as video, i mean from usb source? bluray ud7006
cristian_711 is offline
Reply Blu-ray Players
Blu Ray Players , Marantz , Marantz Ud7006 Blu Ray Disc Player
