Owner's thread for the Samsung BD-D6500. All questions and comments go here - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 205 Old 04-04-2012, 10:58 AM
Classico's Avatar
Originally Posted by mikek View Post
I am not able to play Netflix at all for the last 8 weeks. It connects to Netflix and when it attempts to play a title there is a message from Netflix that says:
We are having difficulty playing this title right now. Please try another title or try again later.
This happens on every title all the time. All other apps work correctly. I've tried everything. It is not my network and the same thing happens on other networks.
Does Netflix work fine with the latest firmware for other people?
thanks.
I only just installed 1025.1. Had to get it on USB drive.
After installing I immediately played what I KNOW to be HD - America-Story of US. At first it stalled, rebuffered etc. Then for the next 15 min. played flawlessly, rebuffered again then continued without issue. Other titles started with the same issue & then played properly. I rarely have a rebuffering issue with titles that are NOT HD.
If you have not done it, I strongly suggest you do the RESET (holding the STOP button for 8 sec,); it gets rid of OLD problem programs and might even install the newest version of Netflix, if the older one is "stuck" in your unit. If you are wireless u need to do the access code again.
One other thing I noted, that is simply bizzare. Going from playing disc to Netflix seems to upset my player. I have found that I must remove the disc & UNPLUG the unit. Replugging it, I go directly to Netflix and for the most part it works. THEN, to go back to watching a BD I must unplug again, or some of my titles will not play without stuttering.
It appears, on my unit at least, that something of the previous operating software is NOT cleared out & interferes with the operation. Simply turning it off does not seem to work. WHAT A PAIN. If that really is the case Samgsung should write code that will clear the old program & start with a clean slate--if that is the case. I only know that this tiresome procedure works for me.
Good luck, Classico
Classico is offline
post #152 of 205 Old 04-04-2012, 03:08 PM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
No luck. Netflix still won't play titles. I get the having trouble right now message.
I think you are on to something because it has something to do with the system resources. If I try to check on a software update after netflix doesn't work I get a system resources error.
If I never updated the firmware on this player I think I would have never had any problems because it worked great for the first few months I had it.
I guess I'll send it out for warranty repair. Maybe they will give me the newer model.
mikek is offline
post #153 of 205 Old 04-06-2012, 08:16 AM
serge-montreal's Avatar
Is there ANY way to play a 3d movie from the USB port or via a DVD disk on this BD-D6500 ?
My 1tb HD is connected to the blu ray, and the mp3 works fine, the regular movies are ok...
I tried a MKV 3d movie, an AVI 3D movie... the sound is ok, the image is SBS but not 3D.
I downloaded a 3D demo from another site and the f****** demo is working from a USB key!
so IT IS possible but HOW ??
Help me please!!!!
serge-montreal is offline
post #154 of 205 Old 04-08-2012, 02:04 AM
chickenwatt's Avatar
I only was happy with this player until firmware 1022, then came 1023 bothering with cinavia control and then 1025 that apart of have horrible stream interruptions I lost all the aplications that I like except for AOL HD, so everytime they put a new firmware the BDD-6500 goes useless, I wonder what those guys are smeling , I decide to buy a LG BD-670 that is way better in streaming apps.
Sorry Samsung but you mess it up.
I wonder: how a company the bigest in memory production makes a player without buffer, my god!!
chickenwatt is offline
post #155 of 205 Old 04-09-2012, 08:01 AM
gary50's Avatar
Yes, this player has been rendered useless for streaming since the firmware update. I finally gave up after spending too many hours on Friday speaking with both Samsung and Netflix reps and I returned the player for a Panasonic. The Panasonic is streaming like a pro with no problems. It's a pleasure to stream movies now. I wish I had done this nine months ago when I bought my sysem.
I'm hoping these issues are behind me now and I can actually enjoy the technology instead of being aggravated by it.
gary50 is offline
post #156 of 205 Old 04-09-2012, 08:27 AM
starbase1999's Avatar
On April-7, my WiFi internet connection was working fine. I was looking through the new apps that were available since the player auto-installed version 1025. I deleted apps that I didn't want through the edit screen. Then I lost my internet connection. When I looked for network status, I said that I was on a wired connection.
When I tried switching over to wireless, it said that I had to connect my LAN adapter. Since WiFi is built in, why would the player be asking for that? Is it possible that deleting apps caused the player to not remember that it had built-in WiFi?
I called Samsung who suggested unplugging it and then holding the stop button on the player for a system reset. It then recognized the built-in wireless for a minute, and then asked for the LAN adapter again.
I called Samsung again. They said support would call me within 24 hours. I called them back after 26 hours. They said that the unit would have to be sent back fro repair and that it would be free since I had bought the player less than a year ago. I explained that if I could download the prior version of firmware onto a USB drive, I should be able to revert the system They said that the player will not install older versions.
Now I'm waiting for an e-mail containing a label and directions on how to return the player.
starbase1999 is offline
post #157 of 205 Old 04-09-2012, 05:23 PM
DHDigital's Avatar
i'm pretty disgusted with samsung. I've did a 3 or 4 email exchange with support. I can only assume they didn't re-read the previous complaints/issues. Each time I have to send in the firmware number, then all my equipment, then I get a response of "hold down reset" "have you tried unplugging it." I just go in circles.
I suggest hopping on one foot and eating a cheese burger.
DHDigital is offline
post #158 of 205 Old 04-09-2012, 06:19 PM
jroptop's Avatar
Do yourself a favor and get rid of the bd-d6500 before you end up on blood pressure medication,its also been nothing but a hassle for me also,not to mention the player too,with the interuption of buffering,to slow load times etc.I went with a Sony S590 and have had NO issues and its quick and never buffers!
jroptop is offline
post #159 of 205 Old 04-09-2012, 06:36 PM
buton's Avatar
i have the same problem and it sucks....
i have had this over a year and now this !!!! and i cannot return it to the store...
i hope this get solved...
buton is offline
post #160 of 205 Old 04-13-2012, 02:27 AM
DHDigital's Avatar
i'm glad i'm not the only one with this problem (hey maybe its a samsung feature!)
sorry again, it is just so frustrating. I spent a lot of time looking for certain features and I did return a sony for this. I wish I would have kept it. With all the new 2012 model coming out right now and not having the option to return. I don't know what way to go. I want netflix, amazon, youtube, pandora (with a screensaver) and hulu. I also want dlna, usb to read, mkv, divx, avi, mp3/4. and a boot time under 10 minutes. A harddrive is nice, but i have a 8 gig, usb nub drive, i don't care about wireless, because I have an 8-port gig switch next to my entertainment center.
I just don't know how they have made every firmware worse. It was fine when I bought it in novemeber through beginning of january.
post #161 of 205 Old 04-16-2012, 04:29 PM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
I just got my player back from samsung repair center.
They replaced Samsung AK94-00503A BD PCB Main Assembly Board.
Now Netflix works. Yippee!
mikek is offline
post #162 of 205 Old 04-16-2012, 05:19 PM
jroptop's Avatar
Well,I figured Id give Samsung another try with their new BD-E6500 blu ray,and let me tell you this,aside from the frustrations Ive delt with the D series and returned it for a Sony,I decided to try the Samsung E6500 and what a BIG difference,I can honestly say its as good as my Sony,if not better,a complete internal overhaul and have NOT experienced the issues that the D series suffered.Its quick like the Sony,streaming is awesome,2 HDMI inputs with pass through technology and a few other new features that I love so far,Just an update to this thread for those who love the Compatibility of Samsung TV and Blu Ray
jroptop is offline
post #163 of 205 Old 04-16-2012, 09:12 PM
ArcticFormula's Avatar
Have the lovely BD-D6500. Have the Netflix can't play this title now, choose another title issue. This has been happening for 3 weeks. Have the 1025.0 firmware, and cannot seem to update to 1025.1. When I download the zip file B-BRCM65BSP from Samsung's website, it unzips to a folder called "image" or a folder named the same as the file name (if I let Vista extract it). I just can't get the player to recognize this whether I use a flash drive or burn it to disc. Tried all differnet ways, downloaded an ISO burning program (which I might not be using correctly), nonetheless, online software upgrade says no upgrade available, and all other attempts have failed as well. Whoever said about don't get ones blood-pressure up is right. I'm about ready to smash this thing with a hammer, I don't care what it cost, just want the satisfaction of smashing it to pieces, and never buy another Samsung product again. The streaming was always fickle, and thought maybe it was my wireless router. But I have plugged it into my linksys E1000 router, no difference, just bought a linksys EA4500 router, and no help. Have a pretty stready 10 to 15 megabit cable modem connection. It is this DVD player. Samsung is supposed to be sending me the firmware update on disc, within 5 to 10 working days. Would have been nice if they would have offered to do that on the first phone call a couple weeks ago and not the on 4th phone call, but that's another matter.
ArcticFormula is offline
post #164 of 205 Old 04-17-2012, 09:29 AM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
1025.1 ain't gonna work. It is the same one you have now even though it says 1025.0.
See above: send it in for repair.
mikek is offline
post #165 of 205 Old 04-17-2012, 05:16 PM
^ Did you have to pay to send it in to them? Did they ask for a sales receipt, I can't find mine. Thanks in advance.
post #166 of 205 Old 04-18-2012, 06:24 AM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
No I called Samsung and gave them the serial number and they told me that it is still under warranty.
Tell them that you want it repaired. They emailed me a UPS shipping label and I had to box it. I still had the original box and I shipped it in that.
I received it back about 10 days later in the same box I shipped it in.
mikek is offline
post #167 of 205 Old 04-24-2012, 01:32 PM
Classico's Avatar
How long did it take?
Last night 4/23-24 Sammy did a fix on their Smart internet. It now loads faster. I immediately went to Netflix and started an HD program. It took about 3 tries then played flawlessly. I hope it continues. I have not had much issue with non HD programs.
I was also told weeks ago to send in my player to solve the Netflix issue. It sounds like a good idea, just to get the latest mother board and software.
Just went to another HD program: America - Story of Us. Loaded FIRST time and played without rebuffering. Maybe we do have a viable solution. Let's hope so.
Classico
Classico is offline
post #168 of 205 Old 04-25-2012, 06:54 AM
I got the player back from Samsung. It's now recognizing that it was WiFi built-in. The receipt says -
1 - BN59-01130B - Network; WIDT-10A,BCM43236, Internal WiFi
2 - Labor & Parts - Parts replaced
Not very meaningful about what was actually done.
post #169 of 205 Old 04-25-2012, 12:54 PM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
About 10 days.
mikek is offline
post #170 of 205 Old 04-25-2012, 03:21 PM
Classico's Avatar
Day 2 - Netflix is essentially stable. In a 44min HD program I got 1 very short rebuffering. It appears that the solution was in Sammy redoing their internet interface--and maybe the Netflix interface also. For now it works acceptably well.
Classico
Update: I can confirm that Netflix playback, while not exactly perfect is certainly very useable. There are ocassional hiccups, but they are now the exception rather than the rule as before.
Whatever Samsung did seems to be working.
Classico
Classico is offline
post #171 of 205 Old 04-27-2012, 12:19 PM
darylc's Avatar
I've had really bad luck with Samsung products of all kinds and have sworn them off although I still have my 2500 blu-ray player. From phones, to tvs, etc. However, a friend of mine was given this 6500 model Blu-ray player as a gift and it's been nothing but headaches. I think one should only give Samsung products to people you "don't" like.
Anyway, it's an attractive unit, with decent feature list. My friend doesn't use streaming so can't comment on that. But it would not play any disc all the way through. Whether it's DVD or Blu-ray...at some the drive would start stalling and then freeze. After that, nothing would clear it up. If we powered it off and waited till next day...it would start to play again and then repeat the same behavior. This led me to think it was probably heat related, so we put some spacers under it (where it felt very hot). This did not change the behavior.
I looked for firmware update and found one. Successfully installed it, and was finally able to play a movie all the way through. So, I got the next one to put in...and it would not load it. Arrrrgh. Says it can't read the disc. I went home, put the disc in my old 2500 and it fired right up. After the updates, it will play discs all the way through without freezing, but it now just won't load certain discs. I put all those discs it would not load through my old player and had no problem. So, that was that for the Samsung.
They ended up with the sony 590. It's not as nice/fancy looking case, etc., as the Samsung, but it loads every disc they have and played them all the way through without complaint. Friends don't let friends buy samsung.
darylc is offline
post #172 of 205 Old 04-27-2012, 04:26 PM
Mine's still not working (not streaming netflix), a rep insisted this was due to the firmware being version 1023.0. I explained that I've tried every way to upgrade to 1023.1 but it wouldn't take. He said they would send a disk. A week later, it's here version 1023.0, and of course there is nothing to upgrade.
post #173 of 205 Old 04-30-2012, 06:52 PM
buton's Avatar
still experimenting problems with this piece of $%"#%$"#%$"#... sometimes it works sometimes dont... hate this..
buton is offline
post #174 of 205 Old 05-09-2012, 12:04 PM
Classico's Avatar
I find this so frustrating. After my unit was working for better than a week it has now fallen back to its old form. I called Samsung and was told that they are working on their SmartHub & that they would call me back within 24-48 hours with answers AND solutions. This is a real mess.
Samsung needs to get on the stick and get this done. It can work if they get on the right track. Tempus fugit Samsung.
Classico
UPDATE: I have sent my 6500 in for repair. BUT, here is something to consider. I called Netflix and they performed a test on the reception speed. I will report on that in my next post.
Classico is offline
post #175 of 205 Old 05-22-2012, 11:34 AM
Classico's Avatar
When Netflix did their test on my input speed (yes they can) it was between 0 & 1 on a scale of 10. In other words constant time outs, no connects, and FAILED rebuffering. It then became obvious that the problem was with the built-in Wi-fi. To test that assumption, I installed my Samsung 5500 with an outboard Wi-fi. What do you think? I connected to Netflix & over a period of 3 days I did not have a SINGLE issue with connecting to Netflix. Hour after hour whether SD or HD, I did not have ANY problems.
I hope that Samsung's repair station here in SoCal (they are independant) can FIX the Wi-fi. If not they say I will get an upgraded unit. Therefore, if you are still having a Netflix issue, the overwhelming chances are that you have a bad Wi-fi unit, and it is NOT (as many thought) an issue with software.
Hope this helps,
Classico
Classico is offline
post #176 of 205 Old 05-23-2012, 08:50 AM
Estame6's Avatar
Hi Guy's, Maybe I'm not the smartest..... I've tried googling this but what is the difference between BD D6500 and the BD C6500. There is even an E, I am ready to buy but need to know this as there is a price big price difference. Many thanks....
Estame6 is offline
post #177 of 205 Old 05-24-2012, 06:31 AM
mikek's Avatar
Quoted: 184 Post(s)
Liked: 78
That letter denotes the model year for Samsungs. It works for TVs too.
C is 2010 D 2011 E 2012
The E model doesn't have component out I believe.
mikek is offline
post #178 of 205 Old 05-24-2012, 08:24 AM
Estame6's Avatar
Many thanks for that, no wonder I couldn't figure that out reading the specs. I purchased a refurbished for less than $100 inc s/h from amazon. Cant quite figure out the warranty but the unit seems to work fine and you cant tell it's not new. Many thanks again, ...Dave
Estame6 is offline
post #179 of 205 Old 06-26-2012, 10:37 AM
Classico's Avatar
I FINALLY GAVE UP ON THIS 6500.
I sent it in for repair & got it back with all new innards (motherboard & wi-fi) and for 1 1/2 days it was working. Then it just went back to the old " re-buffering" every few minutes. I returned it to Costco, got my money back and bought the Sony BD S590 [BX59 for Costco means I got free HDMI]. What a difference. A vastly superior Netflix UI and NO rebuffering. I get HD picture with DD 5.1 sound. My only question--why did I stick with the 6500 JUNK for so long?
Samsung really cannot fix this turkey. The wi-fi overheats then quits. Make them take it in for service & when they cannot fix it they will replace it with a newer model. Do it BEFORE the manufact. warranty runs out. That is unless you got it from Costco--then just return it and get the Sony.
The Blu-Ray video & sound are excellent & on top of Netflix you can also get Amazon Prime, which I understand is giving Netflix a run for their money & is a better overall value since with PRIME you get FREE 2 day shipping from Amazon.
Classico
Classico is offline
post #180 of 205 Old 08-09-2012, 02:04 PM
gordonshumway's Avatar
Hi,
Has anyone figured out how to disable or change the automatic screen saver mode on D6500 bluray? I have a widget for streaming video watching, but it's pretty annoying to have to press info or some other button every 5 minutes (which is what this thing's screensaver mode is set to)
I've seen similar complaints in C6500 thread and apparently a newer firmware update resolved it, but I'm worried about loading a newer update on my unit since I've read some horror stories about those in the thread... not to mention cinavia garbage.
gordonshumway is offline
Reply Blu-ray Players
Samsung , Samsung Bd D6500 Za D6500 Serivce Blue Ray Disc Player 3d Stereo , Blu Ray Players , Philips , Samsung Refurbished Blu Ray Disc Player Bd C6800 B
