Official Sony BDP-S780 Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #511 of 684 Old 02-29-2012, 08:16 PM
mdavej's Avatar
Quoted: 2212 Post(s)
Liked: 969
Originally Posted by TiVolino View Post
Ok, is anyone else having trouble with Hulu+ ? The interface comes up, I pick a program, it plays the first "commercial" or two, then it just freezes with the blue splash showing. It never returns, and when I try and power down, it freezes and flashes "see you" on the player display. I then have to un plug the power and plug it back in to get it to power up.
Does the same thing wired or wireless, amazon plays fine.
I have the same problem on a totally different player (panasonic). So I blame the Hulu+ servers, in which case there is no solution.
mdavej is offline
post #512 of 684 Old 02-29-2012, 08:20 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
That is correct to the 24p question above.
apw2607 is offline
post #513 of 684 Old 02-29-2012, 08:21 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Played two shows tonight with Hulu + on my s580 and played fine.
apw2607 is offline
post #514 of 684 Old 02-29-2012, 10:18 PM
TiVolino's Avatar
I have the s780. Seems odd that the Hulu servers would cause me to have to boot my player by disconnecting the power...
TiVolino is offline
post #515 of 684 Old 03-01-2012, 05:08 AM
LBJ2's Avatar
24p is not supported on any of the Sony players for VOD/USB/DNLA content. Its unclear if its supported on the 2012 players ... seems doubtful since they haven't mentioned it yet. It is supported on the new 2012 panasonic players (220, 320, etc).
Hello: Where did you find info that there is a 24P content streaming limitation for the S780?
I ask because Vudu streams HDX movies in 1080p/24p and to me Vudu HDX PQ streamed through my S780 is indeed far superior (on my 1080p/24p capable TV) to all the other streaming content I have seen so far and would be surprised/disappointed to learn that I was not viewing 24P--albeit I haven't figured out a way to confirm 24P while streaming Vudu like I can with a blu-ray disk.
LB
LBJ2 is offline
post #516 of 684 Old 03-01-2012, 09:47 AM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
1) The 24p setting is only for Bluray and DVD. This is specified in the owners guide.
2) My receiver can look at the HDMI output signal to determine what type of signal it is ... 1080p/60 ... 1080i/50 .... 1080p/24 ... etc. Never had it indicated a 1080p/24 signal on any VOD content.
3) Most players that are able to send 1080p/24 for other content besides bluray, such as VOD (like the panasonic 220) have the user manually set this setting each time, as there is no "flag" in the VOD content to tell the player to send 24p out automatically.
apw2607 is offline
post #517 of 684 Old 03-01-2012, 10:07 AM
LBJ2's Avatar
Same here. My settings both TV and Receiver only show 1080P when streaming Vudu HDX but the HDX content is streaming at some fps and I am not sure why its not being measured/displayed.....according to Vudu its 24p
Also I am not sure the three references to the 24p setting in the S780 guide specifically excludes streaming content as it details specific 24P settings for BD/DVD viewing only, which is why I asked for your point of reference since I haven't been able to find anything definitive with regards to streaming content and 24p myself.
LB
LBJ2 is offline
post #518 of 684 Old 03-01-2012, 12:00 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Not sure about that ... from the S780 Specs.
BD:
HD (24Hz) (24p True Cinema): Yes
DVD:
DVD 24p output: Yes
In the setting's menu it clearly states the 24p setting is for BD and DVD content ONLY.
apw2607 is offline
post #519 of 684 Old 03-01-2012, 12:52 PM
LBJ2's Avatar
BD:
DVD:
DVD 24p output: Yes
Agreed--but I don't think BD/DVD 24p viewing settings has anything to do with the ability of the player to stream 1080p/24p content.
I called Vudu and of course they told me that they do stream HDX in 1080p/24p with their proprietary encoding called TruFilm. Which I already knew about as I found this on their website.
http://supports.vudu.com/questions/209/What+is+HDX%3F
So for me the question still remains if S780 can process streaming 24fps or not. Unfortunately I haven't been able to find any info yet that specifically addresses this issue.
I also own a Panasonic BDT210 and its displays 1080p/60 when streaming Vudu HDX 1080p/24 content while my S780 just displays 1080P and no fps indicator.
What is HDX?http://supports.vudu.com/questions/209/What+is+HDX%3F
HDX - The Benchmark for On-Demand Picture Quality
VUDU delivers movies in HDX™ - the groundbreaking video format that delivers the highest quality true High Definition 1080p content available from any Internet, broadcast or satellite on-demand service.
Experience HDX
o True Cinematic Experience -HDX movies are displayed in 1080p at 24 frames per second, the true cinematic gold standard.
o 2X the Resolution -Ultra-detailed and virtually artifact free on any size of TV screen, HDX movies are displayed at twice the resolution of other Internet HD video formats.
o Immersive High Resolution Sound -HDX technology delivers the best available surround sound quality for Internet delivered movies with immersive, high resolution sound at a 40% higher bit-rate than standard surround sound DVD's.
o Optimized for Larger HDTVs -VUDU's unique TruFilm™ technology optimizes the encoding, transmission and display of HDX movies on 40-inch HDTVs and larger Home Theater screens.
LB
LBJ2 is offline
post #520 of 684 Old 03-01-2012, 02:09 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
VUDU delivers movies in HDX(TM) - the groundbreaking video format that delivers the highest quality true High Definition 1080p content available from any Internet, broadcast or satellite on-demand service.
Experience HDX
o Optimized for Larger HDTVs -VUDU's unique TruFilm(TM) technology optimizes the encoding, transmission and display of HDX movies on 40-inch HDTVs and larger Home Theater screens.
Vudu for me shows 1080p/60 on my s580.
apw2607 is offline
post #521 of 684 Old 03-01-2012, 02:18 PM
LBJ2's Avatar
Vudu for me shows 1080p/24 on my s580.
Now that's interesting! How are you seeing this? On your TV with the TV remote display function? or via the S580 remote?
LB
LBJ2 is offline
post #522 of 684 Old 03-01-2012, 02:23 PM
Cortiz's Avatar
Quoted: 79 Post(s)
Liked: 64
Off topic question, sorry! Just curious about which player you like better and which one you think has better PQ, AQ and which one is faster? I already own the S780 just cuirous how it compares with Panny. I am thinking about picking one up for the bedroom.
Cortiz is offline
post #523 of 684 Old 03-01-2012, 02:45 PM
LBJ2's Avatar
I have the S780 for my main entertainment room pared with a Sony XBR 60" TV and the Panny BDT210 ( I got at Costco during the holidays for $120 with a free Avatar 3D BD) for the bedroom pared with a Samsung 46" LED Smart TV.
I have to say that I enjoy both BD players but for my eyes I really don't see any difference in blu-ray PQ--both are excellent. I do prefer the Panny Viera Cast over the Sony streaming video app capabilities because Panny allows me to chose which streaming video apps I want to download whereas the Sony S780 controls all streaming apps and Sony decides which streaming apps are downloaded or not. Likewise the Panny BDT210 Netflix app allows for 5.1 dolby digital whereas the Sony Netflix app does not. Both are equally fast loading BDs etc.--I don't see where one is faster than the other in this regard.
LB
LBJ2 is offline
post #524 of 684 Old 03-01-2012, 04:02 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
I'm sorry. That was a typo. I meant to say 1080p/60 !!
apw2607 is offline
post #525 of 684 Old 03-01-2012, 04:08 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Now you know you can select which apps you want in the favorites list. Highlight a app, select options and then select make favorite.
You can get to the favorites from either a button on the remote (some have this) ... or select options from either the music or video categorites and say display favorites.
Its not ideal ... but it may help.
apw2607 is offline
post #526 of 684 Old 03-01-2012, 04:19 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I thought Sony did upgrade to 5.1 too recently?
zoro is offline
post #527 of 684 Old 03-01-2012, 04:37 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
That maybe the case with the new 2012 players, but at least with the current 2011 players, and the current firmware, its all still Stereo (with traditional dolby surround in most cases).
apw2607 is offline
post #528 of 684 Old 03-01-2012, 06:33 PM
LBJ2's Avatar
I've never really used the Favorites feature on the S780 before so will definitely check that out. Thanks for the tip.
LB
LBJ2 is offline
post #529 of 684 Old 03-02-2012, 09:02 AM
LBJ2's Avatar
You can get to the favorites from either a button on the remote (some have this) ... or select options from either the music or video categories and say display favorites.
Well..I loaded my Favorites today on the S780 as you suggested--nice feature! This is much more convenient then scrolling through all those apps I don't use.
LB
LBJ2 is offline
post #530 of 684 Old 03-02-2012, 09:05 AM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Yea, some of the earlier remotes had a dedicated favorites button on the remote itself. Later Sony changed this, and removed it, and replaced the red Netflix button.
I think they had it right first time around. After all not everyone uses netflix as their main streamer !
apw2607 is offline
post #531 of 684 Old 03-02-2012, 10:51 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I am glad I did sell my new 780, in anticipation of 790( with 4K upscale)
So, only sony product that does it is Ps3 currently? Am I right? how about sony TVs and streamers?
zoro is offline
post #532 of 684 Old 03-02-2012, 03:46 PM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Thats correct. Currently its only the Ps3, and thats not Dolby Digital + either, just DD. Better than regular Stereo with Dolby Surround though.
Yes, even their streamers SMP-N100 and SMP-N200 are Stereo audio with Netflix.
We're all hoping 2012 is going to change this.
apw2607 is offline
post #533 of 684 Old 03-05-2012, 02:56 AM
DaGamePimp's Avatar
Quoted: 407 Post(s)
Liked: 442
I picked up the S780 yesterday from a BB-MagHT location for $130 and can honestly say the S780 does indeed have superior image quality to my S580.
I also own a Sony 1000ES, Samsung C6900, LG 590, Panasonic BD35, PS3 Phat, PS3 Slim (& Blu Ray - HTPC). The S780 rivals the 1000ES for the best image out of all the players I own.
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is online now
post #534 of 684 Old 03-05-2012, 04:54 AM
birdy's Avatar
Anybody can tell me if is possible to plug the web cam to the back usb port?
And is possible to plug a keyboard? where front or back usb port? I see that the internet browser is more fast that the ps3 browser....but for use it is necessary to plug a keyboard...
And finally is there any way to make zoom with the player for fill the screen with the 2.35:1 format movies?
Thanks and sorry for my bad english....
birdy is offline
post #535 of 684 Old 03-05-2012, 09:25 AM
apw2607's Avatar
Quoted: 290 Post(s)
Liked: 336
Jason
Thats good to know Jason. I'm going to take a look at the new S590 in the new week or so, and if that doesn't improve anything (streaming mainly for me), I may just pick up a S780 for cheap, until the S790 arrives later this year.
I'm a bit concerned that Sony may have dropped VUDU from their supported streaming services. I've seen no information on VUDU support on any of the new 2012 players.
apw2607 is offline
post #536 of 684 Old 03-06-2012, 07:59 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
Will Sony release S790 for 2012?
Keen to compare it to my S770.
Iain- is offline
post #537 of 684 Old 03-06-2012, 09:00 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I am waiting for it too! Supposedly April
zoro is offline
post #538 of 684 Old 03-06-2012, 10:58 AM
InCali's Avatar
I think I may have to relocate my Sony BDP blu ray player. Can anyone out there confirm that the form factor for the optical audio output is TOSLINK?
Home Theater: Acer H9500BD 3D Projector, 120" Elite Screen, Sony BDP-S780 3D Blu-Ray Player, Logitech Z-5500 5.1 Surround
Family Room: Mitsubishi 73" 3D DLP, Sony BDP-S5100 3D Blu-Ray Player, Onkyo TX-SR333 5.1-Channel Home Theater Receiver; Polk Audio TL250 HP Surround w/PSW10 Subwoofer
InCali is offline
post #539 of 684 Old 03-06-2012, 11:15 AM
Cortiz's Avatar
Quoted: 79 Post(s)
Liked: 64
I have both the S770 and S780. While I think the PQ/AQ is very similar between the two, I actually preffer the S770. I just love the S770. Everything about the S770 is just flawless, IMO one of the best all around BD players ever made.
When the S790 comes out, i will give it a try to see how it measure up against the S770.
Cortiz is offline
post #540 of 684 Old 03-06-2012, 11:31 AM
mdavej's Avatar
Liked: 969
The 780 has both toslink and coax digital outputs.
mdavej is offline
Reply Blu-ray Players
Blu Ray Players , Sony , Sony Bdp S580 Blu Ray Disc Player Black , Sony Bdp S770 3d Blu Ray Disc Player With Wi Fi , Sony Bdp S780 3d Blu Ray Disc Player
