Pioneer Blu-ray players 2011 - BDP-140/BDP-440/BDP-LX55/BDP-53FD - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 11-17-2011, 07:05 AM
Vonbek777's Avatar
Just ordered mine, delivery early next week. Can't wait!
Vonbek777 is offline
Old 11-17-2011, 07:57 AM
ccotenj's Avatar
Liked: 101
"Surprise-in "pure direct" the subwoofer works in SACD. It does not work in stereo CD"
ask the reviewer if the sacd has a .1 channel encoded, as this would be the only way he'd be getting anything from the sub in "pure direct" mode...
- chris
ccotenj is offline
Old 11-17-2011, 08:00 AM
emidalla's Avatar
They already asked him, waiting for a reply
P.S. Tonight he should also post some pictures
emidalla is offline
Old 11-17-2011, 08:01 AM
realzven's Avatar
Liked: 84
I'll ask the reviewer and keep you updated
stay tuned
realzven is offline
Old 11-17-2011, 09:00 AM
realzven's Avatar
Liked: 84
to ccotenj, the reviewer confirm the LFE canal on the SACD "Sacre de Igor Stravinsky"
realzven is offline
Old 11-17-2011, 09:08 AM
drSeehas's Avatar
Originally Posted by realzven View Post
... the reviewer confirm the LFE canal on the SACD "Sacre de Igor Stravinsky"
In the "stereo" layer or in the "multichannel" layer or in both?
drSeehas is offline
Old 11-17-2011, 09:09 AM
ccotenj's Avatar
Liked: 101
cool, thanks for following up...
it shouldn't be surprising to him then that he got something from the sub channel... nor should it be surprising that he didn't get anything from a cd...
that translates into: the "reviewer" should likely have noted that in his initial review, as what he observed isn't "surprising" at all (it would be "surprising" if it worked otherwise)... actually, he shouldn't have even noted it at all, as it could mislead people into thinking incorrectly...
- chris
ccotenj is offline
Old 11-17-2011, 09:11 AM
ccotenj's Avatar
Liked: 101
by definition, there is no .1 channel in the stereo layer of a sacd... which is why i raised the question, re "pure direct and .1 channel"...
the reviewer should strike the entire comment from his review, to be honest...
- chris
ccotenj is offline
Old 11-17-2011, 11:05 AM
Speakerphile's Avatar
Quoted: 51 Post(s)
Liked: 165
Originally Posted by HTMan34 View Post
I thought Chris Walker already cleared the whole USB thing. He said that the players will not only accept the Pioneer one but also any wireless bridge device.
Typically, "wireless bridge" refers to a wireless device that connects via Ethernet, rather than USB.
Chris, could you please clarify?
Though I am an employee of Magnolia Home Theater, the views and opinions I express on this forum are those of my own and not my employer.
Speakerphile is offline
Old 11-17-2011, 01:24 PM
purdyd's Avatar
yes, i think it was pretty clear from Chris and from testing, that you need a wireless bridge and the only way to talk to the sc-55/57 on a network is through its ethernet port
unlike previous blue ray players which could use a USB wifi adaptor like the AS-WL200
the reason the AS-WL300 connects to the ethernet and USB is that the USB supplies power.
page 23
http://www.pioneerelectronics.com/St...ions102811.pdf
there was some very slim hope that a USB dongle might work, even though Chris said it wouldn't, since the meditek 8555 chip set claims to have support for WLAN support thru usb- although that feature would have to be enabled and would require some degree of software support i imagine
http://www.mediatek.com/en/Contacts/...ID%3A11&q=8555
purdyd is offline
Old 11-17-2011, 02:02 PM
jleholeho's Avatar
page 23
there was some very slim hope that a USB dongle might work, even though Chris said it wouldn't, since the meditek 8555 chip set claims to have support for ethernet - although that feature would have to be enabled and would require some degree of software support
true...
so what`s the cheapest option that will work?
jleholeho is offline
Old 11-17-2011, 02:05 PM
purdyd's Avatar
Originally Posted by jleholeho View Post
true...
a roll of cat 5 ethernet cable and two RJ45 connectors
purdyd is offline
Old 11-17-2011, 03:01 PM
drSeehas's Avatar
Confirmed for LX55 in a german forum:
No track/chapter numbers in player display
2nd HDMI Out audio only
http://www.hifi-forum.de/index.php?a...stID=1209#1209
drSeehas is offline
Old 11-17-2011, 03:04 PM
Vonbek777's Avatar
I've been using one of those power outlet ethernet devices. So I have a powerline plugged into the wall and ethernet to my hub where I have about 5 a/v devices plugged in. Another powerline adapter in my server room with ethernet to my router. Works really well, my wifi has been very flaky, so I prefer ethernet and this option meant I didn't have to run rj45 jacks through the walls.
Old 11-17-2011, 07:08 PM
jleholeho's Avatar
I see...
I meant what`s the cheapest option besides employing ethernet cable connected to the same router in which is plugged another ethernet cable from my VSX-1120...this combination is a reason of the AVR dropouts...
I want to have the player online until the AVR dropouts are fixed (if ever)
but I don`t want to pay 100 EUR for some wirelless bridge...the player cost 214 EUR itself...
my USB wifi dongle didn`t work...
Old 11-17-2011, 07:38 PM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I just installed my BDP-53FD. The BDP-53FD adds two HDMI outputs for separate video and audio with Pure Audio mode, Marvell video processing which eliminates 480i mode, DTS downmix, an extra blue light, and a heavier base. SACD can be output as DSD bitstream or PCM at 88.2 KHz. You need to aim the remote precisely in order for it to work correctly. The disc mechanism might be a little quieter than the BDP-52FD. In case you're wondering, I am keeping the BDP-53FD because of the MediaTek MT8555, Pioneer's PQLS, and the Marvell video processing. Who knows what might get added as new firmware updates are released. Even if nothing gets added, I'm happy with the combination of the MT8555, PQLS, and Marvell.
Big C is offline
Old 11-17-2011, 08:21 PM
purdyd's Avatar
I see...
I meant what`s the cheapest option besides employing ethernet cable connected to the same router in which is plugged another ethernet cable from my VSX-1120...this combination is a reason of the AVR dropouts......
we don't know what message is coming out of the the BDP-440 that makes the VSX-1120
if it is an ethernet message than simply going to a wireless bridge will NOT help you out as that message will still get to the VSX-1120
the only thing I can think of is that you would need to put one or the other behind a router and disable UPnP forwarding - and that assumes it is a UPnP message that is causing the problem
however, doing that will create issues if you want both player and receiver to see the same DLNA server
however, what i would want to do first is put the VSX-1120 and BDP-440 on an ethernet hub with nothing else and capture all the traffic with an ethernet packet sniffer up until the VSX-1120 recycled
in summary, i don't think the wireless bridge is the answer to your problem
it is either going to be Pioneer issuing a fix or for you to take it upon yourself and find out what the offending message is and probably getting a router to keep it from getting to the VSX-1120
David
purdyd is offline
Old 11-17-2011, 08:37 PM
jleholeho's Avatar
damn remote sensor...unbelievable
David
Thanks a lot for explanation...my brother in law who is a programmer and could certainly help me with what you said lives in Prague and doesn`t come over much often...I guess I`ll wait a little bit for Chris Walker`s response (who hopefully will be able to say something essential on this issue) or I`ll be forced to get the right equipment and troubleshoot it myself
I was almost decided to pass over for Denon AVR 2312 (very good price) + DBP1611, as users in another thread confirmed playback of what I need but I refuse to pay twice the BDP-440s price...though I can`t see any special difference on these players...
Old 11-17-2011, 09:17 PM
unidisk's Avatar
Just got my 53FD tonight. Everything seems to be fine except the network connection. It can acquire the IP address via DHCP but the intetnet connection test failed. I can ping the unit with anoter computer that is on the same subnet. But the unit cannot goto the internet. I have checked the information page. It seems the IP address/getway/DNS server are all fine. More over the unit will hang after a while. It will not respond to any command on the remote. Pressing the keys on the front panel does not work either. I have to power cycle the unit by unplugging it.
If I do not plug it into the network, everything seems to be fine. Play out bluray/CD/SACD are all working fine.
I am very frustrated. Anybody have tested the 53FD network functionality?
I have checked there is no firmware update yet.
unidisk is offline
Old 11-18-2011, 12:44 AM
drSeehas's Avatar
Originally Posted by unidisk View Post
Just got my 53FD tonight. Everything seems to be fine ...
You get track/chapter numbers in the player display?
drSeehas is offline
Old 11-18-2011, 01:37 AM
jleholeho's Avatar
Oops...looks like our LAN issue is bigger than we thought
Pioneer got serious work to do unless they want customers to completely boycott their products...
Old 11-18-2011, 03:00 AM
Usman24's Avatar
have you disconnecting the player from the mains socket and plugging it back in an than tried again?
This type of problem used to happen with my Denon 4010ud everytime i tried updating the firmware. I only connected it to the internet when firmware was available.
Usman24 is offline
Old 11-18-2011, 05:48 AM
unidisk's Avatar
I still fighting with the network issue with unit. Spent the whole night trying to find out why my the unit freezes from time to time. It turns out that my local network traffic will crash the box. Now I need to find out what type of the traffic actually causes it. I have to disconnect my network device one by one to see.
unidisk is offline
Old 11-18-2011, 08:37 AM
realzven's Avatar
Liked: 84
some photos of the LX55 from a french poster (thanks to antislash )
unboxing....
installation
realzven is offline
Old 11-18-2011, 08:46 AM
realzven's Avatar
Liked: 84
the Menu
menu "custom" :
menu "Function" :
SACD :
realzven is offline
Old 11-18-2011, 09:51 AM
frantic77's Avatar
hi guys!
does the LX55 play 1080p MKv ?does it read from an external HDD?
thanks in advance
frantic77 is offline
Old 11-18-2011, 01:42 PM
jleholeho's Avatar
Menu overlay is identical with the BDP-440 except for the advanced Video adjust options.
it`s nice to see availability of adjusting video parameter while on playback..I do hope they bring it for BDP-440, too
and yes, both 1080p MKV and ext. HDD are playable on my BDP-440 (NTFS, no exFAT)...I`m guessing BDP-LX55/53FD must be the same...
Old 11-18-2011, 04:38 PM
frantic77's Avatar
thanks
Old 11-19-2011, 04:42 AM
videofreak64's Avatar
Another good thing, it plays ripped SACD (copies) with no problem.I burn about 20 SACD they all play fine. My friend have Marantz universal player, his player couldn't recognize this disks.
videofreak64 is offline
Old 11-19-2011, 07:43 AM
purdyd's Avatar
Sacd Iso image on a hard disk? Bdp -440?
Ok I see you said "burned" so I presume on a cd
purdyd is offline
Pioneer , Pioneer Bdp 140 Blu Ray Disc Player Black , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Lg , Blu Ray Players , Pioneer Blu Ray Player Bdp 140
