Pioneer Blu-ray players 2011 - BDP-140/BDP-440/BDP-LX55/BDP-53FD - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1231 of 1865 Old 02-20-2012, 03:46 PM
jleholeho's Avatar
Sounds absolutely crazy, that you`d need to pay for ANY update...
I suggest to contact Pio US and send them these 3 emails from Pio EU:
1. "Dear Sir/Madam,
Thank you for your email, your enquiry has been registered in our system
under reference number:
Pioneer ticket ref nr: 2386
Dear Mr. Lehotsky
It's been a while since we contacted you about the problem of AV receivers
powering off while LAN was connected. It took a long time collect data
when this problem occurred, to investigate the root cause of this problem
and then to reprogram the firmware to fix this problem. The last 3 weeks
we tested a beta firmware. It needed to be so long because we wanted to
make sure that it solves this issue and this problem could occur a few
times a day or only once a week, so testing took quite long.
Since 23 jan 2012 however, firmware 0.112 is made available for service
center to fix this issue:
VERSION : 0.112 (MAIN: 1.009, SUB: 1.207, DSP: 1.003) released on Jan 23,
2012
Fixes the following issues.
- The power turns off and on automatically when connecting to certain BDP
(BDP-440/52FD,
Philips BDP8000, etc.) with LAN (Related QI : B1067206)
VSX-1020-K/FLXCN
VSX-1020-K/SYXCN5
VSX-1020-K/UXCNCB
VSX-1025-K/CUXCN
VSX-1025-K/SYXCN5
VSX-30/UXCNCB
VSX-31/UXCNCB
VSX-920-K/AXCN5
VSX-920-K/FLXCN
VSX-920-K/SYXCN5
VSX-925-K/CUXCN
SC-35/UXJCB
SC-1525-K/CUXJ
SC-LX73/SYXJ5
SC-LX73/DLPWXJ
SC-LX73/AXJ5
SC-LX73/FXJ
VSX-33/UXJCB
VSX-32/UXJCB
VSX-1325-K/CUXJ
VSX-1125-K/CUXJ
VSX-1120-K/UXJCB
VSX-LX53/AXJ5
VSX-LX53/FXJ
VSX-LX53/SYXJ5
VSX-LX53/DLPWXJ
VSX-2020-K/SYXJ5
I'm sorry to hear that you felt the urge to sell your VSX-1120. I wanted
to be able to offer you a solution for this issue sooner. That said, the
VSX-1121 doesn't have this (or any other known) problems, so enjoy.
Please note that it is not possible to reply to this message. Should you
wish to reply, then please contact us at:
http://www.pioneer.eu/eur/content/su...ntactform.html
ensuring that you fill in the reference number, which will allow us to
respond more effeciently.
Best regards
Pioneer Europe Customer & Service Support"
2. "Dear Sir/Madam,
Pioneer ticket ref nr: 2359
I'm sorry, I made a mistake in previous e-mail. Because of differences in
internal structure, there are 2 firmware versions available to fix the
power off issue when LAN is connected:
VERSION: 0.112
VSX-1020-K/FLXCN
VSX-1020-K/SYXCN5
VSX-1020-K/UXCNCB
VSX-1025-K/CUXCN
VSX-1025-K/SYXCN5
VSX-30/UXCNCB
VSX-31/UXCNCB
VSX-920-K/AXCN5
VSX-920-K/FLXCN
VSX-920-K/SYXCN5
VSX-925-K/CUXCN
VERSION: 0.111
SC-35/UXJCB
SC-1525-K/CUXJ
SC-LX73/SYXJ5
SC-LX73/DLPWXJ
SC-LX73/AXJ5
SC-LX73/FXJ
VSX-33/UXJCB
VSX-32/UXJCB
VSX-1325-K/CUXJ
VSX-1125-K/CUXJ
VSX-1120-K/UXJCB
VSX-LX53/AXJ5
VSX-LX53/FXJ
VSX-LX53/SYXJ5
VSX-LX53/DLPWXJ
VSX-2020-K/SYXJ5
In case of your American VSX-1020 you'll need version 0.111 Please
understand that this is not a "lower/older" version of 0.112. It's the
same firmware but for different hardware.
With kind regards,
Best regards
3. "Dear Sir/Madam,
Pioneer ticket ref nr: 2417
Sorry for the delayed reply. The update for the VSX should be performed by
an authorized service center from Pioneer. It is not possible to carry-out
this update yourself as it requires some jigs which are not available to
end consumers. Therefore the update is also not published on our website
for this matter.
As for the remote responsiveness, we actually opened up the remote of the
BDP-LX55 to check. The problem is not with the unit itself but rather with
the remote control. As this is hardware related it will be unlikely that it
can be solved. When you point the remote straight to the unit there should
not be any problem with it, only when you hold it up or down. Otherwise you
can always use any other Pioneer control or universal remote as
countermeasure.
Best regards
No word about paying for anything...
If they intend to release firmware updates for money, they could easily close the production...no one would buy a Pio product, ever...
and I`m not so convinced that it`s actually an AVR`s problem...they should definitely come up with something for the BDPs, at the first place...
jleholeho is offline
post #1232 of 1865 Old 02-22-2012, 10:18 AM
JOgden's Avatar
I received this email on the problem, I will copy and paste what you did and see what they say. I'll also have to try what they suggested:
Thank you for contacting Pioneer Electronics (USA) Inc.
Make sure that the HDMI Control has been turned off on the receiver. The Control feature between the two devices can trigger the receiver or even in some cases the player to power on/off.
Thank You,
Gill
JOgden is offline
post #1233 of 1865 Old 02-22-2012, 07:47 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
What I really need to know is when the new firmware of BDP-53/LX-55 be released to fix the sound drop out problem that's plaguing literally every single unit I've encountered this month.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1234 of 1865 Old 03-01-2012, 08:33 AM
gobbo67's Avatar
Hi --
our goal is to drive BDP-140 player from an Extron IP Link 250 controller; can anyone point me to right direction to download a "Command Protocol Driver" for BDP-140 / BDP-440?
Many thanks,
Alex/
gobbo67 is offline
post #1235 of 1865 Old 03-01-2012, 08:08 PM
norml4721's Avatar
Originally Posted by Enitime View Post
Ok, so last year was a bit of a dud with the Sharp merger and then the rushed-to-market 3D players. So let's see what this year brings.
Bad product shots are all I've seen so far, but the new look is very nice, and consistent across the range. They also match the new VSX and SC receivers.
BDP-140
BDP-440
BDP-LX55
BDP-140:
3D Playback
SACD Support
Network Functions (DLNA, YouTube etc...)
PC File Playback (DivX plus HD etc)
iControl AV2 Control App
Quick Response
Wi-Fi Connection (Via Optional Adaptor)
Sound Retriever Link
Stream Smoother Link
BDP-440 adds
PQLS Bitstream Multi-Channel
Aluminium Front Panel
IP Control
BDP-LX55 adds
QDEO Video Processor
Twin HDMI Outputs
RS232 Connection
High Grade Audio Parts
Armoured Chassis
This is all preliminary information only.
Judging by the specs, I think this year seems a lot more interesting. They tick all the requirement boxes for 3D, DLNA, networking.
SACD support not only in the high-end, but all the way down to the entry level player is a nice touch. That alone goes a fair way in separating the brand from the Panasonic/Samsung/LG brands towards an enthusiast market without alienating the mass market.
The LX / Elite model actually stands out this year. Twin HDMI is a proper high-end feature. Upgraded video processing is a proper high-end feature.
The weak model appears to be the mid-range BDP-440. Not much that distinguishes it from the entry-level BDP-140. If I'd been in charge I would probably have canned the wifi for the 140 just to set it apart. Or included the wifi dongle with the 440.
Estimated recommended retail prices
BDP-140 - $199
BDP-440 - $299
BDP-LX55 - $399-$499 (There's probably two Elite versions but only one LX)
Hi :
I called pioneer today and asked about the BDP-LX55 release date. I was told that the LX55 will not be sold or released in the U.S. only in Europe.
Bummer !!
norml4721 is offline
post #1236 of 1865 Old 03-01-2012, 08:17 PM
Quoted: 612 Post(s)
Liked: 584
Lx55=53fd
my home theatre
post #1237 of 1865 Old 03-02-2012, 06:50 AM
jleholeho's Avatar
Originally Posted by gobbo67 View Post
Hi --
Many thanks,
Alex/
You can find the file in some post in this thread...
I was asking for this before and one guy from here provided it to me...
I´m just unsure about the post no., you need to check the first half of the thread...
it´s a file with complete IP commands for both BDP-140 and 440..
speaking of which, do you guys have some clue on how to enable WAKE ON LAN in the BDP-440/52FD?
post #1238 of 1865 Old 03-02-2012, 07:53 AM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
Hi --
Many thanks,
Alex/
Actually I posted it for someone in the "Pioneer Elite BDP-52FD and BDP-53FD Owners' Thread" thread.
Anyways, here it is again:
2011 Blu-ray IP & RS-232 Commands BDP140_BDP52FD.pdf 57.041015625k . file
b curry is offline
post #1239 of 1865 Old 03-03-2012, 11:56 AM
jleholeho's Avatar
I guess you posted it for me somewhere in this thread, too
that`s what I was referring to...
thx anyway
post #1240 of 1865 Old 03-12-2012, 09:21 AM
drSeehas's Avatar
New firmware for the BDP-LX55 in Europe:
http://www.pioneer.eu/uk/support/sof...l#download_271
drSeehas is offline
post #1241 of 1865 Old 03-12-2012, 10:50 AM
andyrome64's Avatar
... which doesn't fix anything and introduces Cinavia the nastiest piece of DRM stuff ever.
andyrome64 is offline
post #1242 of 1865 Old 03-12-2012, 11:57 AM
Quoted: 612 Post(s)
Liked: 584
it fixes the "sound cutting in and out" problem plagued on many players with January and February built, especially when PQLS is activated.
my home theatre
post #1243 of 1865 Old 03-12-2012, 04:21 PM
drago44's Avatar
..... still no CD track number on the display .... no chapter number Blu-ray and DVD
Pioneer engineers .... wake up!
drago44 is offline
post #1244 of 1865 Old 03-12-2012, 04:51 PM
frantic77's Avatar
that sucks
frantic77 is offline
post #1245 of 1865 Old 03-12-2012, 04:56 PM
jleholeho's Avatar
Where the hell is a proper FW update for both BDP-440/LX55???
What about DLNA instability/freezing, poor remote responsiveness, LAN-associated AVR dropouts, no tracks/folders on front display, SACD playback issues....???
It`s been 6 months since the BDP-440 hit the shelves in the EU, some 4,5 months since the BDP-LX55`s release...they really must be totally crazy...
post #1246 of 1865 Old 03-13-2012, 03:04 AM
Jacks5000's Avatar
It's because these players are not built by Pioneer , they are built by TCL CORP, ie cheap made & lack of support
Jacks5000 is offline
post #1247 of 1865 Old 03-13-2012, 07:35 AM
Quoted: 612 Post(s)
Liked: 584
Pioneer should've pushed TCL Corp to update the firmware accordingly based on Pioneer's insistence and needs. But I bet you that the legal insistence is not included in the initial contract.
my home theatre
post #1248 of 1865 Old 03-15-2012, 06:47 AM
jleholeho's Avatar
poor b......s
why the hell would they state "these really ARE our own Pio devices"??
post #1249 of 1865 Old 03-15-2012, 07:00 AM
mystic_sniper28's Avatar
given the price of the unit you would of thought that pioneer would of thought of something before outsourcing builds
mystic_sniper28 is offline
post #1250 of 1865 Old 03-15-2012, 08:32 AM
Quoted: 612 Post(s)
Liked: 584
poor b......s
I told you guys from the beginning but you guys chose to listen Wakamo.
Of course he is going to say that it's developed by Pioneer... He works for Pioneer.
Regardless, I still think the BDP-53/LX55 is the best player out there, especially for the money and I will still back/recommend a good product regardless of brand and/or who manufactures them.
my home theatre
post #1251 of 1865 Old 03-15-2012, 04:39 PM
jleholeho's Avatar
yep, I remember
and I do think the same way, paid some 213 EUR (270 USD) for my BDP-440 (I really didn`t need the Qdeo in BDP-53/LX55)...there`s no such universal player with similar performance, PQLS, compressed media playback, etc at the price...
we just need it to work properly, no damn freezing, no LAN-associated issues, some performance improvements...that`s it...
post #1252 of 1865 Old 03-15-2012, 04:41 PM
yhtomitb's Avatar
I updated a BDP-53FD in our store today. The update was very fast and I now have discrete IR "On" and "Off" for the unit. Much preferred to a toggle power and Power-Up on Play command. Of course, that is still there as well.
I will be bringing my SACD collection and checking to see if any of the problems I was experiencing are now fixed.
I look forward to seeing the results.
yhtomitb is offline
post #1253 of 1865 Old 03-15-2012, 08:12 PM
Quoted: 612 Post(s)
Liked: 584
can anybody who are using BDP-53FD confirm whether this player will playback PAL and/or 1080i/50 natively? I use the BDP-LX55 so it obviously play PAL and 1080i/50
my home theatre
post #1254 of 1865 Old 03-15-2012, 10:42 PM
Hubertoliver's Avatar
Quoted: 40 Post(s)
Liked: 37
I've been looking at the BDP-440's that are on EBAY that have been altered for our voltage and are zone free. Any thoughts or comments on these?
Army Rangers lead the way!
Yamaha RX-A1050, Yamaha BD-A1010, Sharp Q+ 60SQ15U, Monster Power HDP IR 2550, Klipsch Quintet SL, Klipsch Sub 12
Hubertoliver is offline
post #1255 of 1865 Old 03-16-2012, 03:33 AM
jleholeho's Avatar
The EU BDP-440s are made 100-240V/50Hz/60Hz so don´t worry about voltage or PAL/NTSC and if you find multi-region that´s even better (if you need MR, of course)
post #1256 of 1865 Old 03-16-2012, 05:49 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
After some online investigting, I notice that these players have a similar user interface to Philips BD players. See if this multi-region hack works for you guys:
1. Unload any discs.
2. Close the tray.
3. Press "HOME MENU."
4. Enter the numerical sequence on your remote, 1389310.
5. Press "HOME MENU" to exit.
6. To confirm the change, press "HOME MENU."
7. Enter the numerical sequence on your remote, 8520. You will see the current region.
I hope this works for you guys. However, now that I don't have the player, it would just be my luck that the procedure works and I'd wish I had kept the damn player and put up with its bs!
Big C is offline
post #1257 of 1865 Old 03-16-2012, 09:47 AM
Quoted: 40 Post(s)
Liked: 37
I ordered a BDP-440 today and should have it Tuesday.
post #1258 of 1865 Old 03-16-2012, 03:21 PM
jleholeho's Avatar
2. Close the tray.
Interesting...I´m out of town for the weekend but I´ll definitely try this when I´m back...
though I communicated with one UK retailer before who told me what´s the DVD MR procedure for Pio BDPs..you also need to press Home Menu and some numbers on a remote a few times, however, you need to involve codes from the "hack remote"
http://www.ebay.co.uk/itm/Pioneer-DV...item1c175f53a4
this very remote is allegedly confirmed to work with the newest Pio BDPs, too...
I´ll try this too, in case your scenario didn´t work, and post the procedure here if I was succesful..
post #1259 of 1865 Old 03-18-2012, 10:11 PM - Thread Starter
Enitime's Avatar
Originally Posted by srx View Post
While i was googling for n-50 network player, i came across a website and saw a photo of n-50 network player.
Under the n-50 were two pioneer units which looked like a stereo amplifier and a cd player and they cosmetically matched the n-50.
Does anybody know about new pioneer stereo components? or did anyone who have been at IFA ever seen these components?
Off-topic and a bit late, but I finally have something about this. That's an A-30 integrated stereo amplifier. Workhorse style unit, no tuner, no digital processing, no display - The kind you keep a few decades. The remote on top belongs to the A-30 and has separate dedicated controls for the network player and SACD player which is why it has so many buttons.
Also comes in black.
A-30 - 175W
70+70W (20-20k 4Ω .1%)
40+40W (20-20k 8Ω 0.05%)
Signal to Noise 105dB
There's two other ones :
A-20 (4Ω 50W / 8Ω 30W) 135W
A-10 (basically A-20 without remote control)
I guess they're finally replacing their awful looking 80's style A109/209/etc. since they upgraded the G-clef range not too long ago, IIRC. That would put the price in the hundreds, not thousands.
Below that is a matching SACD player. No matching tuner, the network player is the modern equivalent.
Enitime is offline
post #1260 of 1865 Old 03-19-2012, 03:23 PM
jleholeho's Avatar
2. Close the tray.
Unfortunately, this doesn`t work...
my EU BDP-440 is still reg 2 for DVDs
I should have the "hack remote" within a week, I`m curious what it brings...
Reply Blu-ray Players
Pioneer , Pioneer Bdp 140 Blu Ray Disc Player Black , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Lg , Blu Ray Players , Pioneer Blu Ray Player Bdp 140
