Pioneer Blu-ray players 2011 - BDP-140/BDP-440/BDP-LX55/BDP-53FD - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 04-05-2012, 03:13 AM
andyrome64's Avatar
Originally Posted by Big C View Post
Isn't May a little late? I wonder if this new firmware will include a new SACD decoder that will output DSD as multi-channel PCM at 176.4 KHz.
To be honest that is the last of my concerns. My only hope is that the new firmware will allow me to watch something for more than half an hour without video/audio dropouts. Seriously I have never experienced an hour of trouble-free playback with my BDP-440.
If they make it play ALL my CDs that's even better.
andyrome64 is offline
Old 04-05-2012, 08:16 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Will at least one of these players play BDs or DVDs ripped as .IMG or .ISO disc image files? If the files have to be ripped directly, will menu navigation be possible from ripped DVDs and BDs? Or will the player only cycle through the M2TS (BD) and VOB (DVD) files?
Big C is offline
Old 04-05-2012, 11:10 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Originally Posted by jleholeho View Post
for the record:
the hack remote I was talking about before (eBay UK, price 11 pounds) makes all three 2011 BDPs DVD multi region...tested and confirmed...
you just need to press Home Menu while no disc inside, then highlight Init. Setup and then press a button on the hack remote...then switch the player off and back on...once you then press 8520, region is 0...
If you have a universal remote (JP1, Philips Pronto, Pocket PC with OmniRemote, Logitek Harmony, etc.), you should be able to download this particular IR signal to it without buying another remote. Pioneer has included this IR hack in their players since 2002 with the DV-x5x series of SD DVD players. Whether or not you can get it to work on North American models is a 50% chance. For those of you who have hacked their Pioneer SD players, try it out on one of the 2011 BD players.
Big C is offline
Old 04-05-2012, 01:44 PM
mmg1999's Avatar
BDP-440:
No ISO, no IMG
VOB and M2TS - yes.
BDMV folder - yes (only one in AVCHD folder)
VIDEO_TS - no
mmg1999 is offline
Old 04-06-2012, 03:17 PM
BDP-140 DVD(R5) BR(C) now DVD region free with Logitech Harmony 600. Old IR hack without any modifications.
Ace Of Snakes is offline
Old 04-07-2012, 04:18 AM
jleholeho's Avatar
Yep, it´s good to hear...
I think the situation will be just the same with US models as there are no significant differencies inside the players whatsoever.
If anybody needs to get this done and doesn´t have an access to those learning remotes, contact Graham at this sale:
http://www.ebay.co.uk/itm/Pioneer-DV...#ht_2887wt_932
He could probably be able to ship to the USA, too...
jleholeho is offline
Old 04-07-2012, 07:31 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
To add to this theory, the BDP-53FD and BDP-LX55 use the exact same firmware file. I wonder if the BDP-52FD and BDP-440 use the same firmware file as well.
Big C is offline
Old 04-07-2012, 02:36 PM
Breniac's Avatar
Hi,
has anyone seen the video differences between oppo 93 and the pioneer lx55?
Breniac is offline
Old 04-07-2012, 05:08 PM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I believe the DSD-to-PCM sampling frequency is more a hardware issue than a firmware issue. So I've decided to stick with my Yamaha BD-A1010 unless Pioneer releases a player that will convert DSD to PCM at 176.4 KHz with PQLS. It's better to have the higher frequencies with jitter than not to have them at all. I hope they get it right this fall!
Big C is offline
Old 04-07-2012, 11:49 PM
Hkan's Avatar
Most likley the North American version can't be made multiregional this way!
But I'm happy if anyone proves me wrong ;o)
The R2 and R5 versions of (most) Pioneer players are the same, that is why the "hack" works on a R5 player and not on an R1 or R3 player.
R4 (read Australian) players where always multiregional due to import and export laws and if the player was not multiregional all the aussies had to do was to contact the company and point this out and then they should get this fixed for them!
Also this info has a few years on it's neck!
PioneerFAQ
@Twitter
Has "everything" for your Pioneer!
!!We need your support!!
Hkan is offline
Old 04-09-2012, 01:33 PM
Guys from china made FW mod for BDP-140. Now player can play BD iso images with menu, flac files without renaming, DVD-A and something else. http://115.com/file/bhkhke9f - gray button for free download. This is trial version with some limitations. Use it at your own risk.
Also you can get registration key for FW. Original chinese page: http://uc.jd-blog.com/thread-3483216-1-1.html
Old 04-10-2012, 07:06 PM
jleholeho's Avatar
Have you guys seen the new YouTube interface on the players? just found it today when playing with the player a little but, once I hit YouTube, it looked completely different...and much better, I need to add, more polished and snappy...since there hasn't been any FW for BDP-440 yet, it must be the update from YT directly..
edit:
I forgot to mention before that I´ve been using my BDP-440 with recently received 120v/60Hz VSX-1121 (mfd Sept. 2011) and there has NOT been any drop-outs so far...both devices are constantly LAN/ethernet-plugged...happily, it appears Pio were right when they said the AVR drop-outs shouldn´t be a problem with any of 2011 Pio AVRs...
Old 04-11-2012, 03:28 AM
Vf3
Vf3's Avatar
I managed to get 3D ISO's working by placing the content in the AVCHD folder in root of the USB drive. can anyone advise how to place multiple extracted ISO movies onto the drive as its seems the LX55 looks at just the one AVCHD folder.
Vf3 is offline
Old 04-12-2012, 04:06 PM
Vf3
Vf3's Avatar
OK so easiest way around having multiple AVCHD folders is to create a partition drive for every exctracted ISO. Is there a simpler method?
Vf3 is offline
Old 04-14-2012, 10:12 PM
Stefan1971HH's Avatar
I just got the BDP-140. It's an annoyance how extremely small the menu appears
on my 42'' TV. Hardly readable and causing headache. Anyone else experienced this or did I get a defective unit?-
Also .mov files are not played (unlike stated on the Pioneer homepage) regardless resolution and medium.
Stefan1971HH is offline
Old 04-19-2012, 01:54 PM
PioniraOllandica's Avatar
I'm using a BDP-140 on a 42" plasma, menu seems fine to me. I'll post a photo tomorrow for comparison.
Never tried to play any .mov files, I convert everything to .mkv (with makeMKV) and put it on a 1TB NTFS HD connected to the USB port located on the back.
I'll try to find a .mov file to test, will let you know
(Are you located in Ijmuiden?)
PioniraOllandica is offline
Old 04-21-2012, 10:17 PM
wutthilr's Avatar
Had anyone observe opalescent around object on DVD animation movie like Ice age 2, shrek 2, beauty and the beast?
LX55 with lastest firmware
May be in progressive mode only
wutthilr is offline
Old 04-22-2012, 04:57 AM
emidalla's Avatar
wutthilr, 1080i should solve your problem
emidalla is offline
Old 04-23-2012, 12:21 PM
CBdicX's Avatar
Quoted: 1127 Post(s)
Liked: 229
Hi, i want to buy the 440 and use it with the VSX 921.
Now the question: are the fronts of the two the same ?
It looks like if the 440 has more a brushed look then the 921, or is that just the way the pictures are taken ?
Thx.....
CBdicX is offline
Old 04-23-2012, 01:17 PM
The answer is no, the fronts are not the same.. so I bought the BDP-140 instead. The BDP-440 has a brushed aluminium front, the VSX-921 is shiny black. At some sites they show a brushed looking version of the VSX-921, according to some shops I asked, this is just a marketing trick, all VSX-921 are shiny black (plastic I may add)
This picture clearly shows the difference. Just to be shure go check them both out at a physical store like Correct (Rotterdam)
Old 04-23-2012, 01:34 PM
CBdicX's Avatar
Liked: 229
Thanks for the pictures, well, thats a stupid marketing move of Pioneer, now i will not buy a Pioneer and keep my Sony, at least that has a shiny front......
Do not think having to pay just for getting PQLS (and maby other stuff) is worth it, or is PQLS worth the money over keeping the Sony BDP S550 and swallow the different look ?
But the 140 seems to have the same front as the 440 (see jpg).......
Even on the Pioneer Europe site they have the same brushed front, so whats the deal with the 140, brushed or the same as the receiver ?
Bedankt ! (thanks)
CBdicX is offline
Old 04-24-2012, 09:22 AM
The BDP-140 and VSX-921 look the same, both have the shiny black front. It's hard to get a good picture but here's how mine look:
Old 04-24-2012, 09:37 AM
CBdicX's Avatar
Liked: 229
Ok, clear, they look indeed the same but i went for the BDP-LX55 du to the Marvel Qdeo upscaling what i will use a lot.
When i receive it (tomorrow hopefull) i will also make a picture of the two.
Did get a good price, 389.00 euro and a AudioQuest HDMI Pearl cable
CBdicX is offline
Old 04-24-2012, 09:50 AM
CBdicX's Avatar
Liked: 229
I am a bit in the dark, i will receive tomorrow a BDP-LX55 and this can put out bitstream over PQLS but is this of any use for the 921 ?
The spec list of the 921 states:
PQLS: YES multi channel
More parts have the "YES multi channel", but no mention of bitstream......
CBdicX is offline
Old 04-24-2012, 12:24 PM
emidalla's Avatar
Yoor BDP-LX55 will bitstream, and your 921 will do the decoding
emidalla is offline
Old 04-24-2012, 02:01 PM
CBdicX's Avatar
Liked: 229
Ok, but why is PQLS bitstream not mentioned for the 921 and for other higher receivers it is ?
I thought PQLS worked from a PQLS device to the amp, and in this case the LX55 sends bitstream through PQLS so the receiver needs also be bitstream PQLS, or am i on the wrong road ?
CBdicX is offline
Old 04-25-2012, 03:19 AM
Sky007FR's Avatar
Hi, i have a VSX921 and a BDP440, PQLS is working only in LPCM mode but not when bitstreaming unfortunately...
Sky007FR is offline
Old 04-25-2012, 04:20 AM
CBdicX's Avatar
Liked: 229
Thx for your reply
I have been doing some reading concerning bitstream versus LPCM.
Think we can not "hear" the differents between LPCM and bitstream from a BD player.
For what i read is that bitstream is a signal with a buildin clock and LPCM has not, but there is were PQLS comes into play and corrects for the "missing" clock data.
So i think bitstream will not be any better then LPCM in the case of LPCM working with PQLS.
I also read when a brand uses bad/cheap audio chips/decoders it will do more harm then good to a bitstream signal and using LPCM will be a better option.
So we have a choice, use bitstream and let the receiver do the decoding or use LPCM and let PQLS do its trick.........
(at least if we have that option on the BD player, i do not know yet, still waiting for the LX55 to arrive)
Just now found this info:
Dolby TrueHD and DTS-HD MA compress the LPCM audio signals without any loss of original data in order to save space on a disc. When the saved signals are decoded and decompressed, we will get LPCM signals again.
If the disc player decompresses and decodes the compressed audio, it will send the LPCM signals to the receiver. The receiver will then covert the LPCM signals from digital to analog for playback through the speakers. Alternatively, the compressed Dolby TrueHD or DTS HD MA signals can be sent by the player in raw digital format to the receiver (the older PS3 cannot do this) for decoding to LPCM and digital-to-analog conversion. This process is called Raw Bitstream Transport, High Bit Rate Audio Streaming, or Direct Digital Audio Mode, depending on the manufacturer. Bitstreaming is the preferred choice of many critical listeners.
If the player decodes the high resolution audio to PCM, any version of HDMI can transmit the signal to the receiver. If the player sends the signal in native digital Bitstreams to the receiver, HDMI terminals on both the disc player and the receiver must be version 1.3, and the receiver must have the ability to decode high resolution audio codecs.
So think letting the BD player send LPCM with PQLS will be a more then good option.
In some BD sound tests the "experts" preverd LPCM over bitstream where the info above suggests bitstream
Think its the best to let your and my ears make the choise, but i will put my money on LPCM with PQLS.....
CBdicX is offline
Old 04-25-2012, 05:22 AM
Sky007FR's Avatar
Exactly
I did the test and i didn't hear any difference between LPCM w/ PQLS and Bitstream w/out PQLS. So I chose the later to have a nice DTS-HD MA displayed on the VSX921
Sky007FR is offline
Old 04-25-2012, 06:01 AM
CBdicX's Avatar
Liked: 229
Exactly
What do you see on the display when you use LPCM with PQLS ?
CBdicX is offline
Pioneer , Pioneer Bdp 140 Blu Ray Disc Player Black , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Lg , Blu Ray Players , Pioneer Blu Ray Player Bdp 140
