Pioneer Blu-ray players 2011 - BDP-140/BDP-440/BDP-LX55/BDP-53FD - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1801 of 1865 Old 02-25-2014, 11:19 AM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
I saw 2 for £139 in the shop in Scotland! Now both have gone... It was so tempting but I have pio bdp-140, Dune Smart H1, PCH A-400 - so could not justify this purchase....
borland is offline
post #1802 of 1865 Old 02-25-2014, 11:55 AM
grill's Avatar
Store is no sore :-)
grill is offline
post #1803 of 1865 Old 02-25-2014, 12:37 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
StevenC56 is offline
post #1804 of 1865 Old 03-13-2014, 06:55 AM
wmy5's Avatar
I just uploaded the service manual, repair guide, schematics of Pioneer BDP-LX55 (Elite BDP-53FD). Here is the link:
http://elektrotanya.com/pioneer_bdp-lx55:53fd_sm.pdf/download.html
wmy5 is offline
post #1805 of 1865 Old 03-23-2014, 05:31 AM
Jase69's Avatar
Can a custom FW be applied to the BDP-LX55 if it is supplied with Pioneer firmware version 3.24?
Cheers
Jason
Jase69 is offline
post #1806 of 1865 Old 03-27-2014, 01:03 PM
Cheers
Jason
YES
djvaso and grill like this.
Ace Of Snakes is offline
post #1807 of 1865 Old 03-27-2014, 05:29 PM
Jase69's Avatar
Originally Posted by Ace Of Snakes View Post
YES
Thanks very much but I took the plunge and purchased one, I am currently in Taiwan and thought "why not?". It was easy to get it shipped from mainland China.
I am glad I did, I didn't have to faff about with firmware modifications as it's all been done for me and the unit does exactly as expected.
Well pleased.
Jase69 is offline
post #1808 of 1865 Old 04-14-2014, 12:53 AM
xti000's Avatar
xti000 is offline
post #1809 of 1865 Old 04-14-2014, 01:00 AM
Jase69's Avatar
Looks like a Linux kernel and the tools required to build it.
Jase69 is offline
post #1810 of 1865 Old 04-15-2014, 12:14 AM
It's GPL/LGPL source codes used in Pioneer firmware. BTW this codes was modified by FW developers. For example squashfs 3.4 from this link not compatible with player. Some codes have wrong version. For example BDP-160 FW used squashfs 4 instead of 3.4 from your link.
post #1811 of 1865 Old 05-03-2014, 08:28 AM
Hellenback's Avatar
Thanks very much for this manual.
A bit late to the party but at least now I have a manual for a competent technician to use to maybe sort some of the glitches with this player should I decide to bother having it fixed.
I have it plugged into a power bar to power it on/off as opposed to using the remote/front button as I never know when they'll freeze. I primarily use it with a 2TB HDD of FLAC music files attached and it works great. I was happy to find a way to add folders to the playlist playback function. It's a bit of a glitchy player but as I paid peanuts for it "used like new" I don't mind.
I think some of the problems with these multifunction Blue Ray players is that they're more like computers than disc spinners. My cable box PVR is auto re-booted every night at 2:AM so why not the Pio just so it doesn't get confused rolleyes.gif
Sad to say that after all these years as a Pioneer "loyalist" I've finally had it with their lousy customer service. My next player will be an Oppo and I'll be searching for a different AVR regardless of their ICE and "PQLouSy" technology tongue.gif
Hellenback is offline
post #1812 of 1865 Old 05-03-2014, 08:42 AM
Hellenback's Avatar
@ Ace of Snakes
Thanks for your work with SACD-r playback firmware on some other machines. Though I used HKAN's FAQ site firmware, I believe he incorporated your SACD-r code in his for some of the DVD players' custom firmware.
I haven't read through this entire thread so don't know if there is a reliable custom firmware for the 53fd that's easily installed via CD or USB flash to make it region free (and maybe a bit more glitch free). I'm on firmware 3.24. It would sure be worth at least a beer or a coffee (unless there is a specific cost for it).
post #1813 of 1865 Old 05-06-2014, 07:18 AM
@Hellenback
You can use LX-55 firmware for 53FD
this is North America analog for BDP LX55
SM for both models http://yadi.sk/d/yb4fx3794UXtq
post #1814 of 1865 Old 05-07-2014, 09:03 PM
Hellenback's Avatar
@Hellenback
Thanks again in advance for any replies.
I thought you sent the firmware update then realized it was the service manual (SM) which I already have. I'd never used the deja-vu reader before so at least now I know what the extension means!
As the update just covers DVDs I might implement but would need to buy a universal remote first and am not sure I run into enough DVDs from other regions to warrant the cost. We'll see....would be nice if the BD region was more easily hackable (ie: software).
post #1815 of 1865 Old 05-15-2014, 10:29 AM
ilfuoco's Avatar
Hello im new,
my problem is that i have upgrade my LX55 to CFW 55RU401-01-1 and now can't read DVDs or BDs with the region code of my country.
I stay in Germany.
How can i fix it?
ilfuoco is offline
post #1816 of 1865 Old 05-15-2014, 11:05 AM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
I am not sure what CFW you have, mate. can you clearly state it? is it 4.0X family or 5.0X? in any case you can change BD zone by accessing special hidden menu. However for different CFW the combination of the buttons on the RC is a bit different. you may try different combos (menu-settings-3344 or 5566 or 9999 (this code can also change HDMI resolution). good luck. then set for DVD 0, 1-6. 0 - multiregion, for BD 1,2,4. 1=A, 2= B, 4=C . You need B in Germany
borland is offline
post #1817 of 1865 Old 05-15-2014, 12:08 PM
@borland
You should know. This is 5.10 2014.01.01 HDSir release
post #1818 of 1865 Old 05-15-2014, 12:19 PM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
ooo - yes, Sir! sorry - I am a bit slow today - recovering from some vodka and whisky abuse..... someone's banging in my head - why did I get so late to bed? (Nazareth)
borland is offline
post #1819 of 1865 Old 05-16-2014, 07:24 AM
@ilfuoco
Home menu - Initial settings
move cursor to options and don't enter to it
press 8 5 2 0
for DVD enter 0
for BD
1 = A
2 = B
4 = C
post #1820 of 1865 Old 05-17-2014, 05:39 AM
ilfuoco's Avatar
Thanks for the quick answers. But i can't come in the hidden menu?!
I stay on Options and press 8520 3344 5566 999 nothing happens.
Softwareinformations stand BDP-LX55-V03.24
what can id do?
ilfuoco is offline
post #1821 of 1865 Old 05-17-2014, 04:57 PM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
if you can't get into hidden menu it means your CFW IS NOT activated!
borland is offline
post #1822 of 1865 Old 05-18-2014, 01:00 AM
ilfuoco's Avatar
OK, how can i activate it? i can't read russia is there an easy way to do it?
ilfuoco is offline
post #1823 of 1865 Old 05-18-2014, 08:21 AM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
can you see your player's SN and MAC from the menu?
borland is offline
post #1824 of 1865 Old 05-18-2014, 11:23 AM
ilfuoco's Avatar
It,s already done, thanks so much ACE of snakes.
ilfuoco is offline
post #1825 of 1865 Old 05-19-2014, 12:36 AM
Hellenback's Avatar
Originally Posted by wmy5 View Post
Pioneer BDP-53FD (LX55) have a AK4480 DAC, which is DSD capable.
(http://www.akm.com/akm/en/file/datasheet/AK4480EF.pdf)
But now I doubt that the way Pioneer implement the DAC not use the AK4480's DSD capability. I use two RCA cables to connect my BDP and my AVR (Onkyo NR818) through analog connectors. But when I am playing a stereo SACD, I set the "HDMI Audio Output" to "Bitstream", then there is no sound coming out through analog output. The analog output is active only when I set the "HDMI Audio Output" to "PCM" or "Off". So I suspect that there is no DSD signal directly feeding the DAC. Although AK4480 can take DSD bitstream, Pioneer maybe simply converts all DSD to PCM before it going to DAC.
Any idea? Thank you.
I can't be certain about native DSD (ie not packed in SACD) as I don't have a DSD DAC so I just get a hiss sound, indicating the signal is there but not decoded.
With SACD-r discs, which this player handles very well, my Elite receiver displays the DSD->PCM conversion indicator which would suggest the 53fd passes DSD just fine. Not sure if you mean DSD over optical or direct to analog outs but even then the player passes 88.2 (I assume PCM) no problem and the AKM DAC sounds great to me. I think this player gets too bad a rap due to it's kind of staggering out of the gate. With the firmware updates and at the price it can usually be had for, there isn't much competition. I'm certainly happy with my player.
post #1826 of 1865 Old 05-19-2014, 12:56 AM
wmy5's Avatar
You had some misconceptions here. When you transport digital signal from your Blu-ray player to your receiver, no matter it is DSD or PCM, the AKM DAC in the Blu-ray player is not engaged, instead, what you were listening to is the DAC in your receiver. You need to keep in mind that DSD->PCM is a decoding process which is entirely in digital domain.
As for the question of native DSD support, my own finding is positive. LX55/53FD does support direct DSD->Analog conversion without any PCM stage. I found the LX55 service manual. As shown below, LX55 does feed the AK4480 with DSD signal. To listen to the native DSD, you can connect your 53FD to your receiver/amplifier with a pair of analog RCA cable.
Hope this will help.
wmy5 is offline
post #1827 of 1865 Old 05-24-2014, 08:30 AM
gxxrgehk's Avatar
Can anybody tell me how to downgrade BDP-LX55 from official firmware version 3.00 so that I can install CFW?
Thanks in advance.
gxxrgehk is offline
post #1828 of 1865 Old 05-26-2014, 06:35 PM
Hellenback's Avatar
I'm was/am aware of the fact that when the DSD->PCM light is on the receiver is decoding the DSD signal (over HDMI). I wasn't sure if the player passed the DSD signal untouched -> analog or converted it to PCM first. That part of your info is good to know so thanks, but as I can't read a circuit diagram I'll have to take your word for it.
post #1829 of 1865 Old 05-27-2014, 04:46 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Don't forget to set HDMI audio and Digital Out to Off to insure no DSD-to-PCM takes place before it reaches the analog out.
Big C is offline
post #1830 of 1865 Old 05-27-2014, 08:51 AM
Hellenback's Avatar
@ Big C
Thanks for the tip. Can you tell me if the 58AV also does DSD direct to analog outs (stereo & surround) or if it first converts to PCM? I've always wondered about this and if it is the default setting or adjustments need to be made for it (and if so what are they). I thought I read somewhere that it converted to PCM first but could easily be mistaken.
Regardless of how things are implemented it is still a great (my favorite?) sounding player.
I need to compare the 53fd with the DSD -> analog set properly to compare DAC chips/implementation (in stereo only of course ;(
Reply Blu-ray Players
Pioneer , Pioneer Bdp 140 Blu Ray Disc Player Black , Lg 55lx9500 55 1080p 480hz 3d Led Lcd Hdtv , Lg , Blu Ray Players , Pioneer Blu Ray Player Bdp 140
