Current players with Dual HDMI? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 53 Old 06-01-2013, 11:47 PM
stpetematt's Avatar
Does anyone own one that does not have analog outs?
Panasonic TC-P65ZT60 HDTV
Onkyo TX-SR805 THX Ultra 2
Axiom M60 Towers
Axiom VC-160 Center
Axiom QS8 Surrounds
HSU Engineering VT-15 Sub
PS3/360
stpetematt is offline
post #32 of 53 Old 06-02-2013, 06:38 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Originally Posted by stpetematt View Post
Hi all! Is there a current list now with this years models? I would prefer not to pay for analog outs, but I guess it's gonna be the Oppo 103 if not...
IMO, this is a rather silly request. You're not paying for the analog outs. You're paying for the dual HDMI outs. Only the higher end players have dual HDMI outs (consider the analog outs thrown in with the dual HDMIs). If cost is an issue, check out the Pannys and Sonys with dual HDMI outs (they are less expensive than the Oppo).
BillP is offline
post #33 of 53 Old 06-02-2013, 07:28 AM
bguzman's Avatar
Quoted: 52 Post(s)
Liked: 525
Yes, picked up a Pioneer Elite BDP-62FD that has dual HDMI and no analog outs. It also plays SACD and DVD-A discs. It can be found at Best Buy for $199 in store. It is a pretty good player but does not have many streaming options.
HT, Mitsubishi HC6500, 106" screen, Panasonic TC-P50G10, Oppo BDP-103, Toshiba A35, Panasonic LX-1000U, Pioneer Elite CLD-95, Faroudja NRS, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Dual 1219->Shure M91ED, Kyocera DA-610cx, Pioneer SA-1000, Polk Monitor 10A
bguzman is online now
post #34 of 53 Old 06-02-2013, 04:28 PM
stpetematt's Avatar
I don't know that it's that silly of a request. I'd imagine a lot of processing goes into making those analog outs that I wouldn't need. It's good to know Pioneer makes one. Thanks! I will look into it. Do you know if the Pioneer can send audio out bitstream? How is its video quality compared to the Oppo? That's excellent it's less than half the price if its comparable in most other ways other than the analog outs... Appreciate it!
Axiom M60 Towers
Axiom VC-160 Center
Axiom QS8 Surrounds
PS3/360
post #35 of 53 Old 06-02-2013, 05:43 PM
bguzman's Avatar
Quoted: 52 Post(s)
Liked: 525
Yes it can send bitstream. The video is great with Qdeo processing and I can play my high res FLAC files directly from a drive. I took a chance on this player and so far it is a winner for me.
post #36 of 53 Old 01-25-2014, 07:07 AM
trevtrbo's Avatar
Quoted: 86 Post(s)
Is it going to give me more headroom and possibly cleaner audio/video if I split the signal and let my Pioneer Elite sc-68 handle audio exclusively and my Panasonic vt60 handle video exclusively? Both are capable of 3d, but i heard from a few sources that giving designated hdmi outputs to designated channels gives you a cleaner overall picture and sound quality. ANY HELP IS APPRECIATED
trevtrbo is offline
post #37 of 53 Old 01-25-2014, 07:15 AM
Super Moderator
teachsac's Avatar
Quoted: 834 Post(s)
Liked: 1360
I have never seen a difference between running one vs. two hdmi cables. Running one is much less of a headache.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #38 of 53 Old 01-25-2014, 08:49 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
The ONLY need for dual HDMI outs is to run one to your 3D display and a second to an AVR that is not 3D capable. You don't get better PQ or AQ by running separate HDMIs.
BillP is offline
post #39 of 53 Old 01-25-2014, 09:09 AM
b curry's Avatar
Quoted: 460 Post(s)
Liked: 268
In a word, no.
Google TMDS on HDMI.  You need to understand how the signal is sent over HDMI.
Simplistically TMDS, Transition Minimized Differential Signaling, sends three different interleaved data packets (video, audio and auxiliary data for control) separated by blanking intervals over HDMI.  These exact same data packets are present on both of the HDMI runs coming from your BD player; both cables originate from the same transmitter in the BD player.  When you "split the signal" your receiver or display is still receiving the same data packets but the control data has given instructions to ignore that part of the signal that is not necessary.
I believe that two HDMI's was first done by Pioneer with the BDP-09 with a marketing spin that it would be better because of signal splitting.  I've never seen any scientific proof for this.  The primary advantage of two HDMI's was to not make an older AV receiver that was not able to support 3D obsolete.  You could feed the audio via HDMI to the older receiver and still take advantage of a 3D display with a second HDMI output.
There will be people that will continue to believe that two is better than one and that maybe true when you're wanting to support a legacy device, but not for improved audio or video.  Again I would urge you to read up on how HDMI signals are sent and it will become very clear there is no advantage for "a cleaner overall picture and sound quality" experience.
b curry is offline
post #40 of 53 Old 04-29-2014, 09:43 PM
jinj's Avatar
Quoted: 114 Post(s)
Liked: 43
Can a splitter do this?
http://www.monoprice.com/Product?c_id=101&cp_id=10113&cs_id=1011301&p_id=10249&seq=1&format=2
jinj is offline
post #41 of 53 Old 05-05-2014, 11:51 PM
ChrisW6ATV's Avatar
No, a splitter such as that will not "fix" the non-3D receiver issue. Typically what happens with an HDMI splitter is, both connected output devices (such as a 3D display and a non-3D-ready receiver) send their return signals back into the HDMI source (such as a Blu-ray player), and the player's HDMI circuit sends out a "lowest-common-denominator" signal that both devices will accept (non-3D in this case).
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #42 of 53 Old 10-25-2014, 05:49 PM
sigmaace01's Avatar
Current dual output HDMI players
Can you guys help me find out what other players have dual HDMI outputs besides Oppos and the Samsung BD-F7500? TIA
sigmaace01 is offline
post #43 of 53 Old 10-26-2014, 07:20 AM
Breathing Borla's Avatar
Quoted: 120 Post(s)
Liked: 31
I'm also trying to figure this out, seems like a lot of info is dated, I'm trying to get 3d and lossless with a Yamaha rxv 1900 which has older hdmi,
Is there a splitter for this yet? If not looking for a not super expensive dual hdmi player.
Breathing Borla is offline
post #44 of 53 Old 10-26-2014, 08:52 AM
Super Moderator
teachsac's Avatar
Quoted: 834 Post(s)
Liked: 1360
Panasonic BDT460.
S~
teachsac is offline
post #45 of 53 Old 10-26-2014, 03:02 PM
Quoted: 120 Post(s)
Liked: 31
Not sure I need 4k up scaling etc, any other suggestions?
post #46 of 53 Old 10-27-2014, 03:09 PM
Quoted: 120 Post(s)
Liked: 31
seems this lower model may work, it says twin HDMI?
http://www.amazon.com/dp/B00AYB3OOY
post #47 of 53 Old 10-29-2014, 10:28 PM
valvaholic's Avatar
Quoted: 93 Post(s)
Liked: 44
Cambridge Audio 752
valvaholic is online now
post #48 of 53 Old 10-30-2014, 09:40 PM
Liked: 0
SONY BDP-S790 blu-ray player has dual HDMI out.
CHIRUNGARS is offline
post #49 of 53 Old 11-21-2014, 12:24 PM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
Originally Posted by valvaholic View Post
Cambridge Audio 752
Good call. Not to mention 2 HDMI inputs as well - how many BD players can match that ?
Panasonic ZT65 (isf calibrated) / Cambridge Audio 752BD / Sky+ HD / Pioneer LX55 / Tannoy Arena 5.1 / Dual CS506 / Rega Mini Fono / Isotek Mira / Antimode 8033 / QED + Audioquest Cables / Virgin Media 50MB Network /
Cloverleaf is offline
post #50 of 53 Old 11-21-2014, 12:29 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3318 Post(s)
Liked: 2587
OPPO.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #51 of 53 Old 11-30-2014, 09:25 AM
Liked: 0
Also Pioneer BPD-450 has dual HDMI ports.
koroljov is offline
post #52 of 53 Old 12-28-2015, 04:50 PM
jh901's Avatar
Quoted: 515 Post(s)
Liked: 186
Bumping this old thread.
I'm not interested in the prices of universal players such as Oppo 103 (or Cambridge equivalent), but I do want the dual-HDMI functionality where one of the outputs can send audio only. The Panny BDT-460 has this feature. Is there a new model which also has it? Are there other options currently on the market from Sony, etc.?
Appreciated!
HT: Panasonic DMP-UB900 | JVC RS600 | 106" x 45" Stewart ST 100 | Marantz AV7005 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut B6; Focal CMS Sub
Stereo: Cary Audio 306 SACD Pro | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 | Focal Diablo Utopia III
Den: 60" Panasonic VT60
jh901 is offline
post #53 of 53 Old 12-29-2015, 05:40 PM
Lozin's Avatar
Quoted: 240 Post(s)
Liked: 109
I have the Panasonic BD-T460 and its great. Although I don't use the dual HDMI.
jh901 likes this.
Lozin is online now
Reply Blu-ray Players
Onkyo Bd Sp809 Blu Ray Disc Player Black , Onkyo Tx Sr707 7 2 Channel A V Surround Home Theater Receiver , Oppo Bdp 93 Blu Ray Player , Oppo Bdp 95 Blu Ray Player , Panasonic Dmp Bdt310 Integrated Wi Fi 3d Blu Ray Dvd Player , Samsung Bd D6700 3d Blu Ray Disc Player , Samsung Un55d7900 55 Inch 1080p 240hz 3d Led Hdtv Silver
